[Mapbender-users] User-Name as an attribute in the digitizer
Toma, Charlotte Charlotte.Toma at wiesbaden.de
Wed Oct 21 23:58:12 PDT 2020
Hello Uwe,
you can use the „events“ to add predefined attributes from the mapbender database, e.g. the groupname or the username. You can use the example in the documentation (https://doc.mapbender3.org/en/functions/editing/digitizer.html#events) and add the „onBeforeSafe“ event. Furthermore you need a coulumn in your table to save the information.
Greetings from Wiesbaden
Charly
Mit freundlichen Grüßen
im Auftrag
Charlotte Toma
Landeshauptstadt Wiesbaden
-Der Magistrat-
Stadtplanungsamt
-610230-
Gustav-Stresemann-Ring 15
65189 Wiesbaden
Tel.: 0611 31-3436
Fax: 0611 31-3917
E-Mail: 61GIS at wiesbaden.de<mailto:61GIS at wiesbaden.de>
Internet: www.wiesbaden.de<http://www.wiesbaden.de/>
Jede nicht gedruckte Seite spart Holz, Wasser und Strom.
Von: Mapbender_users [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Uwe Seher
Gesendet: Donnerstag, 22. Oktober 2020 08:14
An: Mapbender User List <mapbender_users at lists.osgeo.org>
Betreff: [Mapbender-users] User-Name as an attribute in the digitizer
Hello!
I want to log, when a feature has been changed by the digitizer. Is there a possibillity to use the logged in username as an attribute in the digitizer form or store it otherways in the edited feature?
Thank you in advance
Uwe Seher
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20201022/800aed9a/attachment.html>
More information about the Mapbender_users mailing list
