[Mapbender-users] User-Name as an attribute in the digitizer
Uwe Seher
uwe.seher at gmail.com
Mon Oct 26 04:11:02 PDT 2020
Hello again!
If i read you right, with Mapbender 3.0.8.1 i can not use this feature as
long as i update in a couple of weeks.
Thank you for your help
best regards
Uwe Seher
Am Do., 22. Okt. 2020 um 12:35 Uhr schrieb Astrid Emde (WhereGroup) <
astrid.emde at wheregroup.com>:
> Hello,
> the definition is in the feature section and the user name is referred
> via $user and groups as $userRoles (which is an array):
> featureType:
> connection: geodata_db
> table: poi
> uniqueId: gid
> geomType: point
> geomField: geom_25832
> srid: 25832
> filter: 'st_isempty(geom_25832) =
> false'
> events:
> onBeforeSave:
> $feature->setAttribute('abstract', 'MAPS');
> $feature->setAttribute('user_name', $user
> );$feature->setAttribute('group', implode(',', $userRoles));
> But it looks like this feature is not working with the actual Mapbender
> 3.0.8.6 which uses digitizer 1.1.x. It works with digitzer 1.3 version.
> To change to the 1.3 version you have install Mapbender via Github and
> change in composer.json to "mapbender/digitizer": "dev-release/1.3",
> Then you can build your own mapbender with digitizer 1.3.
> Astrid
> Best regards Astrid
> Am 2020-10-22 08:58, schrieb Toma, Charlotte:
> > Hello Uwe,
> > you can use the „events“ to add predefined attributes from the
> > mapbender database, e.g. the groupname or the username. You can use
> > the example in the documentation
> > (https://doc.mapbender3.org/en/functions/editing/digitizer.html#events
> > [1]) and add the „onBeforeSafe“ event. Furthermore you need a
> > coulumn in your table to save the information.
> > Greetings from Wiesbaden
> > Charly
> > Mit freundlichen Grüßen
> > im Auftrag
> > Charlotte Toma
> > Landeshauptstadt Wiesbaden
> > -Der Magistrat-
> > Stadtplanungsamt
> > -610230-
> > Gustav-Stresemann-Ring 15
> > 65189 Wiesbaden
> > Tel.: 0611 31-3436
> > Fax: 0611 31-3917
> > E-Mail: 61GIS at wiesbaden.de
> > Internet: www.wiesbaden.de [2]
> > Jede nicht gedruckte Seite spart Holz, Wasser und Strom.
> > Von: Mapbender_users [mailto:mapbender_users-bounces at lists.osgeo.org]
> > Im Auftrag von Uwe Seher
> > Gesendet: Donnerstag, 22. Oktober 2020 08:14
> > An: Mapbender User List <mapbender_users at lists.osgeo.org>
> > Betreff: [Mapbender-users] User-Name as an attribute in the digitizer
> > Hello!
> > I want to log, when a feature has been changed by the digitizer. Is
> > there a possibillity to use the logged in username as an attribute in
> > the digitizer form or store it otherways in the edited feature?
> > Thank you in advance
> > Uwe Seher
> > Links:
> > [1]
> > [2] http://www.wiesbaden.de/
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/mapbender_users
> Astrid Emde
> GIS-Consultant
> Aufwind durch Wissen!
> Jetzt neu: Web-Seminare und Online-Schulungen
> bei der www.foss-academy.com
> Astrid Emde
> WhereGroup GmbH
> Eifelstraße 7
> 53119 Bonn
> Germany
> Fon: +49(0)228 90 90 38 - 22
> Fax: +49(0)228 90 90 38 - 11
> www.wheregroup.com
> Folgen Sie der WhereGroup auf twitter:
> http://twitter.com/WhereGroup_com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20201026/e33ad419/attachment.html>
More information about the Mapbender_users
