[Mapbender-users] User-Name as an attribute in the digitizer
Uwe Seher
uwe.seher at gmail.com
Mon Oct 26 07:37:11 PDT 2020
Thank you!
Am Mo., 26. Okt. 2020 um 13:38 Uhr schrieb Astrid Emde (WhereGroup) <
astrid.emde at wheregroup.com>:
> Hello Uwe,
> with Mapbender 3.0.8.1 you can not use this feature.
> It is likely that Mapbender 3.2.2 is release in some weeks. YOu can try
> it with that version. But I can not assure it.
> Astrid
> Am 2020-10-26 12:11, schrieb Uwe Seher:
> > Hello again!
> > If i read you right, with Mapbender 3.0.8.1 i can not use this feature
> > as long as i update in a couple of weeks.
> > Thank you for your help
> > best regards
> > Uwe Seher
> > Am Do., 22. Okt. 2020 um 12:35 Uhr schrieb Astrid Emde (WhereGroup)
> > <astrid.emde at wheregroup.com>:
> >> Hello,
> >> the definition is in the feature section and the user name is
> >> referred
> >> via $user and groups as $userRoles (which is an array):
> >> featureType:
> >> connection: geodata_db
> >> table: poi
> >> uniqueId: gid
> >> geomType: point
> >> geomField: geom_25832
> >> srid: 25832
> >> filter: 'st_isempty(geom_25832)
> >> false'
> >> events:
> >> onBeforeSave:
> >> $feature->setAttribute('abstract', 'MAPS');
> >> $feature->setAttribute('user_name', $user
> >> );$feature->setAttribute('group', implode(',', $userRoles));
> >> But it looks like this feature is not working with the actual
> >> Mapbender
> >> 3.0.8.6 which uses digitizer 1.1.x. It works with digitzer 1.3
> >> version.
> >> To change to the 1.3 version you have install Mapbender via Github
> >> and
> >> change in composer.json to "mapbender/digitizer": "dev-release/1.3",
> >> Then you can build your own mapbender with digitizer 1.3.
> >> Astrid
> >> Best regards Astrid
> >> Am 2020-10-22 08:58, schrieb Toma, Charlotte:
> >>> Hello Uwe,
> >>> you can use the „events“ to add predefined attributes from the
> >>> mapbender database, e.g. the groupname or the username. You can
> >> use
> >>> the example in the documentation
> > (https://doc.mapbender3.org/en/functions/editing/digitizer.html#events
> >>> [1]) and add the „onBeforeSafe“ event. Furthermore you need a
> >>> coulumn in your table to save the information.
> >>> Greetings from Wiesbaden
> >>> Charly
> >>> Mit freundlichen Grüßen
> >>> im Auftrag
> >>> Charlotte Toma
> >>> Landeshauptstadt Wiesbaden
> >>> -Der Magistrat-
> >>> Stadtplanungsamt
> >>> -610230-
> >>> Gustav-Stresemann-Ring 15
> >>> 65189 Wiesbaden
> >>> Tel.: 0611 31-3436
> >>> Fax: 0611 31-3917
> >>> E-Mail: 61GIS at wiesbaden.de
> >>> Internet: www.wiesbaden.de [1] [2]
> >>> Jede nicht gedruckte Seite spart Holz, Wasser und Strom.
> >>> Von: Mapbender_users
> >> [mailto:mapbender_users-bounces at lists.osgeo.org]
> >>> Im Auftrag von Uwe Seher
> >>> Gesendet: Donnerstag, 22. Oktober 2020 08:14
> >>> An: Mapbender User List <mapbender_users at lists.osgeo.org>
> >>> Betreff: [Mapbender-users] User-Name as an attribute in the
> >> digitizer
> >>> Hello!
> >>> I want to log, when a feature has been changed by the digitizer.
> >> Is
> >>> there a possibillity to use the logged in username as an attribute
> >> in
> >>> the digitizer form or store it otherways in the edited feature?
> >>> Thank you in advance
> >>> Uwe Seher
> >>> Links:
> >>> [1]
> >>> [2] http://www.wiesbaden.de/
> >>> _______________________________________________
> >>> Mapbender_users mailing list
> >>> Mapbender_users at lists.osgeo.org
> >>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
> >> Astrid Emde
> >> GIS-Consultant
> >> Aufwind durch Wissen!
> >> Jetzt neu: Web-Seminare und Online-Schulungen
> >> bei der www.foss-academy.com [2]
> >> Astrid Emde
> >> WhereGroup GmbH
> >> Eifelstraße 7
> >> 53119 Bonn
> >> Germany
> >> Fon: +49(0)228 90 90 38 - 22
> >> Fax: +49(0)228 90 90 38 - 11
> >> www.wheregroup.com [3]
> >> Folgen Sie der WhereGroup auf twitter:
> >> http://twitter.com/WhereGroup_com
> >> Geschäftsführer:
> >> Olaf Knopp, Peter Stamm
> >> Amtsgericht Bonn, HRB 9885
> > Links:
> > [1] http://www.wiesbaden.de
> > [2] http://www.foss-academy.com
> > [3] http://www.wheregroup.com
> Astrid Emde
> GIS-Consultant
> Astrid Emde
> WhereGroup GmbH
> Eifelstraße 7
> 53119 Bonn
> Germany
> www.wheregroup.com
> Geschäftsführer:
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20201026/4afcdcb0/attachment.html>
More information about the Mapbender_users
