[Mapbender-users] User-Name as an attribute in the digitizer
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Tue Oct 27 00:28:59 PDT 2020
Hello,
at the moemnt we are working internally at the integration of digitizer
in Mapbender 3.2.x.
Astrid
Am 2020-10-26 17:10, schrieb Gal Zsolt:
> Hello to all,
> I install mapbender 3.2.0 and it work very fast, but in this version
> Digitizer is missing.
> It's sure 3.2.2 will have Digitizer?
> Zsolt
> On 26 October 2020 at 16:37:11 +02:00, Uwe Seher <uwe.seher at gmail.com>
> wrote:
>> Thank you!
>> Am Mo., 26. Okt. 2020 um 13:38 Uhr schrieb Astrid Emde (WhereGroup)
>> <astrid.emde at wheregroup.com>:
>>> Hello Uwe,
>>> with Mapbender 3.0.8.1 you can not use this feature.
>>> It is likely that Mapbender 3.2.2 is release in some weeks. YOu
>>> can try
>>> it with that version. But I can not assure it.
>>> Astrid
>>> Am 2020-10-26 12:11, schrieb Uwe Seher:
>>>> Hello again!
>>>> If i read you right, with Mapbender 3.0.8.1 i can not use this
>>> feature
>>>> as long as i update in a couple of weeks.
>>>> Thank you for your help
>>>> best regards
>>>> Uwe Seher
>>>> Am Do., 22. Okt. 2020 um 12:35 Uhr schrieb Astrid Emde
>>> (WhereGroup)
>>>>> Hello,
>>>>> the definition is in the feature section and the user name is
>>>>> referred
>>>>> via $user and groups as $userRoles (which is an array):
>>>>> featureType:
>>>>> connection: geodata_db
>>>>> table: poi
>>>>> uniqueId: gid
>>>>> geomType: point
>>>>> geomField: geom_25832
>>>>> srid: 25832
>>>>> filter: 'st_isempty(geom_25832)
>>>>> false'
>>>>> events:
>>>>> onBeforeSave:
>>>>> $feature->setAttribute('abstract', 'MAPS');
>>>>> $feature->setAttribute('user_name', $user
>>>>> );$feature->setAttribute('group', implode(',', $userRoles));
>>>>> But it looks like this feature is not working with the actual
>>>>> Mapbender
>>>>> 3.0.8.6 which uses digitizer 1.1.x. It works with digitzer 1.3
>>>>> version.
>>>>> To change to the 1.3 version you have install Mapbender via
>>> Github
>>>>> and
>>>>> change in composer.json to "mapbender/digitizer":
>>> "dev-release/1.3",
>>>>> Then you can build your own mapbender with digitizer 1.3.
>>>>> Astrid
>>>>> Best regards Astrid
>>>>> Am 2020-10-22 08:58, schrieb Toma, Charlotte:
>>>>>> Hello Uwe,
>>>>>> you can use the „events“ to add predefined attributes
>>> from the
>>>>>> mapbender database, e.g. the groupname or the username. You
>>> can
>>>>> use
>>>>>> the example in the documentation
> (https://doc.mapbender3.org/en/functions/editing/digitizer.html#events
>>>>>> [1]) and add the „onBeforeSafe“ event. Furthermore you
>>> need a
>>>>>> coulumn in your table to save the information.
>>>>>> Greetings from Wiesbaden
>>>>>> Charly
>>>>>> Mit freundlichen Grüßen
>>>>>> im Auftrag
>>>>>> Charlotte Toma
>>>>>> Landeshauptstadt Wiesbaden
>>>>>> -Der Magistrat-
>>>>>> Stadtplanungsamt
>>>>>> -610230-
>>>>>> Gustav-Stresemann-Ring 15
>>>>>> 65189 Wiesbaden
>>>>>> Tel.: 0611 31-3436
>>>>>> Fax: 0611 31-3917
>>>>>> E-Mail: 61GIS at wiesbaden.de
>>>>>> Internet: www.wiesbaden.de [1] [1] [2]
>>>>>> Jede nicht gedruckte Seite spart Holz, Wasser und Strom.
>>>>>> Von: Mapbender_users
>>>>> [mailto:mapbender_users-bounces at lists.osgeo.org]
>>>>>> Im Auftrag von Uwe Seher
>>>>>> Gesendet: Donnerstag, 22. Oktober 2020 08:14
>>>>>> An: Mapbender User List <mapbender_users at lists.osgeo.org>
>>>>>> Betreff: [Mapbender-users] User-Name as an attribute in the
>>>>> digitizer
>>>>>> Hello!
>>>>>> I want to log, when a feature has been changed by the
>>> digitizer.
>>>>> Is
>>>>>> there a possibillity to use the logged in username as an
>>> attribute
>>>>> in
>>>>>> the digitizer form or store it otherways in the edited
>>> feature?
>>>>>> Thank you in advance
>>>>>> Uwe Seher
>>>>>> Links:
>>>>>> [1]
>>>>>> [2] http://www.wiesbaden.de/
>>>>>> _______________________________________________
>>>>>> Mapbender_users mailing list
>>>>>> Mapbender_users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
>>>>> Astrid Emde
>>>>> GIS-Consultant
>>>>> Aufwind durch Wissen!
>>>>> Jetzt neu: Web-Seminare und Online-Schulungen
>>>>> bei der www.foss-academy.com [2] [2]
>>>>> Astrid Emde
>>>>> WhereGroup GmbH
>>>>> Eifelstraße 7
>>>>> 53119 Bonn
>>>>> Germany
>>>>> Fon: +49(0)228 90 90 38 - 22
>>>>> Fax: +49(0)228 90 90 38 - 11
>>>>> www.wheregroup.com [3] [3]
>>>>> Folgen Sie der WhereGroup auf twitter:
>>>>> http://twitter.com/WhereGroup_com
>>>>> Geschäftsführer:
>>>>> Olaf Knopp, Peter Stamm
>>>>> Amtsgericht Bonn, HRB 9885
>>>> Links:
>>>> [1] http://www.wiesbaden.de
>>>> [2] http://www.foss-academy.com
>>>> [3] http://www.wheregroup.com
>>> Astrid Emde
>>> GIS-Consultant
>>> Astrid Emde
>>> WhereGroup GmbH
>>> Eifelstraße 7
>>> 53119 Bonn
>>> Germany
>>> Geschäftsführer:
> Links:
Astrid Emde
GIS-Consultant
Astrid Emde
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
www.wheregroup.com
Geschäftsführer:
More information about the Mapbender_users
