[Mapbender-users] LDAP integration
Adrián Ariza
hardian at gmail.com
Thu Apr 22 16:22:47 PDT 2021
Thanks for your reply!
I Install ldapBundle, configure security and parameters but now I see the
error
The reserved indicator "@" cannot start a plain scalar; you need to quote
the scalar at line 13 (near "- @ldapClient").
Could you gime som clue about fixing that?
Thanks in advance!
PD: Sorry for my english
El jue, 22 abr 2021 a las 6:03, Philipp van Biesbrock (<
philipp.vanbiesbrock at wheregroup.com>) escribió:
> Hi Adrián,
> Unfortunately we currently don't have any documentation. We're working on
> it though.
> Here's a quick tutorial for you:
> To use Mapbender with LDAP you can add this Symfony-bundle to your
> Mapbender:
> https://github.com/mapbender/ldapBundle
> This can be done manually or via composer: composer require
> mapbender/ldapbundle
> Don't forget to register in AppKernel.php
> Configuration isn't too easy. Basically you need to configure security.yml
> and parameters.yml.
> Security.yml needs the ldapProvider and some firewall configuration:
> providers:
> ldapProvider:
> main:
> entity:
> class: FOM\UserBundle\Entity\User
> property: username
> chain_provider:
> chain:
> providers: ["ldapProvider","main"]
> firewalls:
> secured_area:
> pattern: ^/
> anonymous: ~
> provider: chain_provider
> mapbender_ldap:
> login_path: /user/login
> check_path: /user/login/check
> service: ldapClient
> form_login:
> provider: main
> logout:
> path: /user/logout
> target: /
> Add this to parameters.yml fitting your ldap server configuration:
> ldap.host: example.com
> ldap.port: 389
> ldap.version: 3
> ldap.useTLS: false
> ldap.useSSL: false
> ldap.bind.dn: cn=admin,dc=example,dc=com
> ldap.bind.pwd: *********
> ldap.user.nameAttribute: cn
> ldap.user.baseDn: ou=user,dc=example,dc=com
> ldap.user.adminFilter: (objectClass=*)
> ldap.user.query: (&(cn={username})(objectclass=top))
> ldap.user.dn: cn={username},ou=user,dc=example,dc=com
> ldap.user.password: unicodePwd={password}
> ldap.group.nameAttribute:~
> ldap.group.baseDn: ou=groups,dc=example,dc=com
> ldap.group.adminFilter: (objectClass=*)
> ldap.group.id: cn
> ldap.group.query: member=cn={username},ou=user,dc=example,dc=com
> Now this probably won't work right away. Depending on your Ldap server
> settings it can be quite a hassle to get this running.
> Hope this helps.
> Am 22.04.21 um 06:12 schrieb Adrián Ariza:
> Hi! Are there any tutorial to configure LDA FOM? How to activate,
> configure and debug.
> Thanks in advance!
> Mapbender_users mailing listMapbender_users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/mapbender_users
> Mit freundlichen Grüßen
> Aufwind durch Wissen!
> Web-Seminare und Online-Schulungen
> bei der www.foss-academy.com
> WhereGroup GmbH
> Eifelstraße 7
> 53119 Bonn
> Germany
> Fon: +49 (0)228 / 90 90 38 - **
> Fax: +49 (0)228 / 90 90 38 - 11
> info at wheregroup.comwww.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20210422/9eeb6942/attachment.html>
More information about the Mapbender_users
