[Mapbender-users] Force login on Application
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Tue Apr 27 23:39:15 PDT 2021
Hello Adrian,
great that you figured it out. And thanks a lot for sharing the
solution.
If you have a public application that would fit in our Mapbender gallery
you are very welcome.
Best regards
Astrid
Am 2021-04-27 22:37, schrieb Adrián Ariza:
> I figure it out.
> I change security.xml from this:
> access_control:
> - { path: ^/user/login, roles: IS_AUTHENTICATED_ANONYMOUSLY
> - { path: ^/manager, roles: ROLE_USER }
> to:
> access_control:
> - { path: ^/?$, roles: ROLE_USER}
> Thanks!
> El mar, 27 abr 2021 a las 17:01, Adrián Ariza (<hardian at gmail.com>)
> escribió:
>> Thanks for your reply!
>> Yes, I can secur applications. I want to force the login form on the
>> home page, is it that possible?
>> Thanks!
>> El mar, 27 abr 2021 a las 3:01, Astrid Emde (WhereGroup)
>> (<astrid.emde at wheregroup.com>) escribió:
>>> Am 2021-04-26 20:01, schrieb Adrián Ariza:
>>>> Hi! It's there any simple way to force form login on the home
>>> page
>>>> (application)?
>>>> Thanks in advance!
>>>> _______________________________________________
>>>> Mapbender_users mailing list
>>>> Mapbender_users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
>>> Hello Adrián,
>>> this is very easy. Please have a look in the documentation and
>>> learn how
>>> to create user and groups and how to assign applications to
>>> users/groups.
> https://doc.mapbender.org/en/quickstart.html#user-and-group-management
>>> If application access is limited to users/groups you can share the
>>> link
>>> to the application but the users/groups have to login, before they
>>> can
>>> use the application.
>>> Mit freundlichen Grüßen
>>> Astrid Emde
>>> GIS-Consultant
>>> Aufwind durch Wissen!
>>> Web-Seminare und Online-Schulungen
>>> bei der www.foss-academy.com [1]
>>> Astrid Emde
>>> WhereGroup GmbH
>>> Eifelstraße 7
>>> 53119 Bonn
>>> Germany
>>> Fon: +49(0)228 90 90 38 - 22
>>> Fax: +49(0)228 90 90 38 - 11
>>> www.wheregroup.com [2]
>>> Meinen PGP Public-Key können Sie unter pgp.mit.edu [3]
>>> herunterladen:
> https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
>>> Signierte und/oder verschlüsselte Nachrichten sind sehr
>>> willkommen
>>> Folgen Sie der WhereGroup auf twitter:
>>> http://twitter.com/WhereGroup_com
>>> Geschäftsführer:
>>> Olaf Knopp, Peter Stamm
>>> Amtsgericht Bonn, HRB 9885
> -------------------------------_______________________________________________
> Links:
> [1] http://www.foss-academy.com
> [2] http://www.wheregroup.com
> [3] http://pgp.mit.edu
Astrid Emde
GIS-Consultant
Astrid Emde
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
www.wheregroup.com
Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Geschäftsführer:
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20210428/2588ad03/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20210428/2588ad03/attachment.sig>
More information about the Mapbender_users
