[Mapbender-users] Setting Search Router fails
treckmann at gisme.de
Tue Jan 5 08:17:59 PST 2021
Hi all,
trying to setup a search like
class: Mapbender\CoreBundle\Component\SQLSearchEngine
class_options:
connection: mydb
relation: mytable
attributes:
- gid
- text01
geometry_attribute: the_geom
form:
text01:
type: text
options:
required: false
label: Nummer
attr:
data-autocomplete: 'on'
compare: ilike
results:
view: table
count: true
headers:
text01: Nummer
gid: bezeichnung
callback:
event: click
options:
buffer: 10
minScale: null
maxScale: 10000
styleMap:
The Table which holds the Geometries and the values are epsg:25832 same as
map definition
When using I'm getting error in log like:
....Funktion st_asgeojson(geometry) ist nicht eindeutig....
...HINT: Konnte keine beste Kandidatfunktion auswählen. Sie müssen
möglicherweise ausdrückliche Typumwandlungen hinzufügen....
I'm using PG 10.5 and PostGIS 2.5 on Windows 10 running x64
MapBender iversion is 3.2.3 installed with MS4W (current release)
Any tip?
Regards
Hardy
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20210105/f826ca52/attachment.html>
More information about the Mapbender_users
