[Mapbender-users] Digitizer/multiple input
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Mon Jan 11 02:14:14 PST 2021
Hello,
I checked the behaviour and created a bug ticket.
https://github.com/mapbender/mapbender/issues/1299
Astrid
Am 2021-01-11 07:43, schrieb Stephan Reber:
> Hello,
> i use mapbender 3.2.2. I 've got two questions about the multiple
> input.
> If I set multiple input to true, the selectbox is so small, that i
> could
> not read my values. If I set multiple to false,I can use the css option
> to set the length of the selectbox. Is it possible to set the length of
> the selectbox for multiple input?
> In my database (PostgreSQL) the column, where to store the multiple
> input, is defined as character varying. The stored value with multiple
> input is 'Array'. The form does not show the stored values. The single
> input works fine. What can i do to make the multiple input work?
> Thanks and best regards
> Stephan
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei der www.foss-academy.com
Astrid Emde
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the Mapbender_users
