[Mapbender-users] Overview element in print template has no content
Gal Zsolt
zsolt.gal at satelitnt.com
Thu Jun 17 08:34:06 PDT 2021
Hello Astrid,
I try to make printclient.js to work, with partial success.
The overview rectangle display the map, but the map ugly, it is distorted.
I will upgrade to 3.2.5.
Thanks for your answer.
Zsolt
On June 17, 2021 at 9:11:25 am +03:00, Astrid Emde (WhereGroup) <astrid.emde at wheregroup.com> wrote:
> Hello,
> there was a bug with the overview map in older versions.
> But now wuth 3.2.5 it works fine.
> <https://demo.mapbender.org/application/mapbender_user_yml>
> Astrid
> Am 2021-06-16 17:40, schrieb Gal Zsolt:
> > Hello List!
> > I find in the archive this topic without solution.
> > I have the same problem.
> > I check in Geoserver log but there are no problem as I see, the two
> > map (Main map and Overview) was served.
> > I will appreciate any suggestion or solution.
> > I use Mapbender 3.0.8.5 installed on Debian and Geoserver 2.18.1
> > Thank you.
> > GÁL Zsolt
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > <https://lists.osgeo.org/mailman/listinfo/mapbender_users>
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
> Aufbau von Geodateninfrastrukturen mit Open-Source-Software
> FOSS Academy 5 Tage-Kompaktkurs „Sommerschule 2021"
> Jetzt anmelden: <https://foss-academy.com/kompaktkurse/>
> Astrid Emde
> WhereGroup GmbH
> Eifelstraße 7
> 53119 Bonn
> Germany
> Fon: +49(0)228 90 90 38 - 22
> Fax: +49(0)228 90 90 38 - 11
> <http://www.wheregroup.com>
> Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
> <https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB>
> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
> Folgen Sie der WhereGroup auf twitter:
> <http://twitter.com/WhereGroup_com>
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20210617/effed11e/attachment.html>
More information about the Mapbender_users
