[Mapbender-users] MS4W Mapbender 3.2.4 package available
Jeff McKenna
jmckenna at gatewaygeomatics.com
Sat Mar 27 13:17:38 PDT 2021
Hi Astrid, all,
I have fixed another difficult issue related to the latest
installing-in-dir-with-spaces changes. The new MS4W setup.exe installer
is available now at https://ms4w.com
Please always report any issues right away through the issue tracker:
https://ms4w.com/trac/
Thanks all!
Thank-you for using MS4W.
"MS4W: open doors as well as windows"
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2021-03-12 7:17 a.m., Astrid Emde (WhereGroup) wrote:
> Hello Jeff,
> thanks a lot for updating mapbender for MS4W and great that the
> long-time issue is fixed!
> Astrid
> Am 2021-03-09 19:04, schrieb Jeff McKenna:
>> Hi all,
>> The recent Mapbender 3.2.4 release is now also available as an MS4W
>> package, as well as included in the .exe installer at
>> https://ms4w.com/download.html
>> (the 3.2.4 release notes are at
>> https://github.com/mapbender/mapbender/releases/tag/v3.2.4 )
>> Important note: a long-time issue has been fixed, for the case when
>> using the MS4W installer and choosing a path with spaces, and if you
>> had selected Mapbender to install, the entire Apache would fail and
>> not start, due to one specific Apache directive not able to accept
>> paths with spaces. Now the MS4W installer will always use Windows
>> short names for all paths (such as C:\PROGRA~1) to avoid any issues.
>> The change has been made for all MS4W packages.
>> -jeff
>> Jeff McKenna
More information about the Mapbender_users
