[Mapbender-users] Feature info Print
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Mon Oct 25 00:42:54 PDT 2021
Hello GÁL,
does this problem ooccur with every WMS? It normally should work with
text/html - I just tried it with Mapbender 3.2.7.
Did you try the mapbender-user WMS?
Do you get any other message?
See you Astrid
Am 2021-10-08 11:25, schrieb Gal Zsolt:
> Hello List!
> In Layersets I set Infoformat to text/html and Print result option
> check.
> When I try to print I receive the next message:
> Oops! An Error Occurred
> The server returned a "403 Forbidden".
> Something is broken. Please let us know what you were doing when this
> error occurred. We will fix it as soon as possible. Sorry for any
> inconvenience caused.
> If Infoformat is set to text/plain the print is OK.
> Have anybody find/know about this problem?
> I use the text/html settings because I write my custom templates to
> show data (Geoserver, ftl, GetFeatureInfo).
> I will be grateful for any suggestion/solution.
> Thank you.
> GÁL Zsolt
> Satelit NT
> 0744384065
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Schon gewusst?
In unserem Blog geben wir Tipps & Tricks zu
Open-Source-GIS-Software
und berichten aus unserem Experten-Alltag:
https://wheregroup.com/blog/
Astrid Emde
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20211025/ece236c4/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20211025/ece236c4/attachment.sig>
More information about the Mapbender_users
