[Mapbender-users] Paper Sizes and Root URL
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Sun Apr 3 22:46:12 PDT 2022
Hello Chance,
Am 2022-03-31 18:58, schrieb Chance:
> Greetings all,
> After attempting to code OpenLayers by hand, I am extremely grateful
> to have found Mapbender. Absolutely very fine quality and a lot of
> hard work.
Thanks a lot for the feedback.
> I am in the United States and unfortunately our current standards do
> not line up to the rest of the world. Our standard paper size is 8.5
> by 11 inches. Could someone point me in the right direction of how I
> would go about setting this up? Also I have seen a question about the
> scale unit and believe this was not something that will not be
> addressed. Any advice is appreciated of where I might be able to
> override the code to show Feet instead of Meters?
It is no problem to choose a different print layout.
The print templates are generated with Libre Office draw.
You could take one of the excisting Mapbender print templates from
mapbender/app/Resources/MapbenderPrintBundle/templates/ and modify it to
your needs.
1. Open
mapbender/app/Resources/MapbenderPrintBundle/templates/a4_portrait_offical.odg
2. Click on the page to open the context menu and choose properties. The
page setup will show up and you will be able to modify the page format.
3. After that you have to design the layout
4. You have to save the file as odg and create a pdf for the new format
(Select all elements with Ctrl-A - Export to pdf - Selection.
5. In your Mapbender application you have to refer to your new print
template in the element PrintClient
See also
https://doc.mapbender.org/en/functions/export/printclient.html#create-your-individual-templates
> Finally I see some sites where the home page is a map application. I
> have tried to set this with a ReWrite in my Reverse Proxy but it
> breaks links and keeps me from being able to get back to the admin
> panel. What would be the best way to configure a Map app to be the
> home page?
> Thank you,
> Chance
> Dallas, Texas, United States
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Jetzt neu: Web-Seminare und Online-Schulungen
bei der www.foss-academy.com
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   Tel: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   www.wheregroup.com
   Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
   Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
   Folgen Sie der WhereGroup auf twitter:
   http://twitter.com/WhereGroup_com
   Geschäftsführer:
   Olaf Knopp, Peter Stamm
   Amtsgericht Bonn, HRB 9885
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20220404/573b8142/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20220404/573b8142/attachment.sig>
More information about the Mapbender_users mailing list
