[Mapbender-users] #WMS #Mapbender #Tiles
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Tue Jun 21 04:11:39 PDT 2022
Hello Marcin,
great that you found the solution and thanks for sharing.
Maybe it will help others too.
See you and great week for you too
Astrid
Am 2022-06-21 13:09, schrieb Marcin Niemyjski:
> Hello again,
> I made it work, small change in mapcache.xml was required:
> <service type="wms" enabled="true">
> <format>PNG_BEST</format> </service>
> Thanks again for your time and have a great week,
> Marcin
> From: Mapbender_users <mapbender_users-bounces at lists.osgeo.org> on
> behalf of Marcin Niemyjski <mniemyjski at cloudferro.com>
> Sent: Tuesday, June 21, 2022 11:14 AM
> To: astrid.emde at wheregroup.com <astrid.emde at wheregroup.com>; Mapbender
> User List <mapbender_users at lists.osgeo.org>
> Subject: Re: [Mapbender-users] #WMS #Mapbender #Tiles
> Hello Astrid,
> I use Mapbender 3.3.0. As you recomended I created GetMap request
> with Transparency parameter set on True. This is the result:
> https://pasteboard.co/TVfZV2ctv10s.png
> and the request:
> *****?VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&LAYERS=DZROL_jpg&STYLES&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SRS=EPSG:2180&BBOX=504410.1847,505845.9847,698217.2257,699439.1832&WIDTH=500&HEIGHT=500
> [1]
> I tried changing the BGCOLOR, but the background remains black. So
> it's not a Mapbender bug (good job 🙂 ), but do you have any idea
> what I can change to make it work, I would appreciate any suggestions.
> See you,
> Marcin
> behalf of Astrid Emde (WhereGroup) <astrid.emde at wheregroup.com>
> Sent: Monday, June 20, 2022 5:08 PM
> To: Mapbender User List <mapbender_users at lists.osgeo.org>
> Hello Marcin,
> what version of Mapbender do you use?
> There was a bug, that Mapbender does not send the parameter
> TRANSPARENT=TRUE in upper case in the getMap-Request. Some services
> ignore the parameter, when it is in lower case.
> Image png is fine for a layer with transparency
> Please check your getMap-Request and modify it. If TRANSPARENT=TRUE
> solves the problem you can go to the Mapbender code and fix it.
> You find a desciption here:
> https://github.com/mapbender/mapbender/issues/1418
> https://github.com/mapbender/mapbender/pull/1419/files
> The fix will also be available in the next version.
> See you Astrid
> Am 2022-06-20 16:51, schrieb Marcin Niemyjski:
>> Hello,
>> I'm back with some questions about MapBender. I created a WMS layer
>> which after uploading to QGIS or Mapbender looks like this:
>> https://pasteboard.co/vM3SKvRZ5krL.png
>> I need the displayed wms not to cover other layers. The WMS comes
>> from mapcache, and the tiles are transparent when checked in another
>> program.
>> When I win this way to QGIS https://pasteboard.co/IU3LV6yB57Kv.png
> [1]
>> I get the effect I wanted https://pasteboard.co/ojWVBug6yDLC.png [2]
>> Could you please advise me how I could achieve such state of things
> in
>> MapBender?
>> The source paths that are shown by qgis when adding a new wms layer
>> (the one with the black background and the good one with the
>> transparent one) differ only in tileMatrixSet=.
>> Best regards,
>> Marcin
>> Links:
>> [1] https://pasteboard.co/IU3LV6yB57Kv.png
>> [2] https://pasteboard.co/ojWVBug6yDLC.png
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
> Aufwind durch Wissen!
> Jetzt neu: Web-Seminare und Online-Schulungen
> bei der www.foss-academy.com [2]
> Astrid Emde
> WhereGroup GmbH
> Eifelstraße 7
> 53119 Bonn
> Germany
> Tel: +49(0)228 90 90 38 - 22
> Fax: +49(0)228 90 90 38 - 11
> www.wheregroup.com [3]
> Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
> https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
> Folgen Sie der WhereGroup auf twitter:
> http://twitter.com/WhereGroup_com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Links:
> [1]
> https://www.lpis.pl/mapcache?VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&LAYERS=DZROL_jpg&STYLES&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SRS=EPSG:2180&BBOX=504410.1847,505845.9847,698217.2257,699439.1832&WIDTH=500&HEIGHT=500
> [2] http://www.foss-academy.com
> [3] http://www.wheregroup.com
Astrid Emde
GIS-Consultant
Astrid Emde
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
www.wheregroup.com
Geschäftsführer:
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20220621/30d75da9/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20220621/30d75da9/attachment.sig>
More information about the Mapbender_users
