[Mapbender-users] Get the options for the selectbox via SQL not working Mapbender 3.3.0
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Tue Mar 8 01:40:48 PST 2022
Hello Gal,
the behaviour of digitizer changed.
It is not fully documented yet but will be soon.
Here is a developer docu for the digitizer/data-manager
https://github.com/mapbender/data-manager#form-input-fields
https://doc.mapbender.org/en/functions/editing/digitizer/digitizer_configuration.html#selectbox-selectbox-or-multiselect-type-select
https://github.com/mapbender/mapbender-workshop/blob/release/3.2/MIGRATION_GUIDE.md
See digitize demo for an example
https://github.com/mapbender/mapbender-workshop/blob/release/3.2/app/config/applications/mapbender_digitize_demo.yml
The changes are:
- the order is the other way round - first value, then key (this chenged
in Symfony)
- an empty value can be generated see example
This is how it could look like
type: select
title: Jahr
attr:
required: required # if it is a mandatory field
options:
- label: 'Plese select a value'
value: ''
connection: myconnection
sql: 'SELECT DISTINCT descriere, cod FROM
nomenclator_viabilitate Order By cod;'
Hope the information helps
See you Astrid
Am 2022-03-08 10:07, schrieb Gal Zsolt:
> Hello List!
> I try to migrate on application from Mapbender 3.0.8.5 to Mapbender
> 3.3.0.
> I have a Selectbox in Digitizer where I get the options for the
> selectbox via SQL, the select box don't display any value. When I
> click the arrow apear a list with indeces. I attach image.
> type: select
> title: Viabilitate
> sql: 'SELECT DISTINCT cod, descriere FROM
> nomenclator_viabilitate Order By cod'
> A workout is to not to use SQL, but I have 130 options (tree species).
> Please suggest other solution, if are any.
> Thanks
> Zsolt
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
FOSSGIS Konferenz
09.-12. März 2022 online
https://www.fossgis-konferenz.de/
Astrid Emde
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
Tel: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20220308/8ed945af/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20220308/8ed945af/attachment.sig>
More information about the Mapbender_users
