[Mapbender-users] Server Error WMS
ihara.olivera at imm.gub.uy ihara.olivera at imm.gub.uy
Thu Mar 31 09:38:30 PDT 2022
Hi, how can i restart Apache?
----- Mensaje original -----
De: "Astrid Emde (WhereGroup)" <astrid.emde at wheregroup.com>
Para: "Mapbender users" <mapbender_users at lists.osgeo.org>
Enviados: Jueves, 31 de Marzo 2022 12:50:37
Asunto: Re: [Mapbender-users] Server Error WMS
Hello,
the service is from Montevideo Uruguay and has many layers
http://geoserver.montevideo.gub.uy/geoserver/ows?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
Many layers are possible but you can not visualisize all layers at once
as the WMS getMap-request has a limited length.
You can load the WMS to the Mapbender service repository.
But to configure the service you have to update the php.ini of your
Mapbender server, as the service has so many layer that the predifined
configuration for php is at its limit.
See
https://doc.mapbender.org/en/faq.html
Increase the following variables and restart Apache
max_input_vars = 4000
memory_limit = 1024M
But then you also have to limit the active layers for this WMS, as with
all layers active you will hit the limit for the url-lenth.
Hope that infromation helps
Astrid
Am 2022-03-31 17:01, schrieb Jörg Thomsen:
> Hello Belen,
> looks more like a miss-configuration of the WMS.
> getMap:
> https://geoserver.montevideo.gub.uy/geoserver/ows?SERVICE=WMS&_signature=34%3AU4eAyyKZ-J0-25u51BfmOl2L0Hw&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&FORMAT=image%2Fpng&TRANSPARENT=true&LAYERS=depaseo%3Atours&STYLES=&_OLSALT=0.6642019119728901&CRS=EPSG%3A25832&WIDTH=1688&HEIGHT=1191&BBOX=359697.1662468514%2C5617500%2C372452.8337531486%2C5626500
> results to:
> <ServiceExceptionReport xmlns="http://www.opengis.net/ogc"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.3.0"
> xsi:schemaLocation="http://www.opengis.net/ogc
> http://geoserver.montevideo.gub.uy/geoserver/schemas/wms/1.3.0/exceptions_1_3_0.xsd">
> <ServiceException> The requested Style can not be used with this
> layer. The style specifies an attribute of horarios and the layer is:
> depaseo:tours </ServiceException>
> </ServiceExceptionReport>
> Jörg
> Am 31.03.22 um 16:39 schrieb ihara.olivera at imm.gub.uy:
>> To whom it may concern, i'm writing to you in order to solve a problem
>> i am recently having with mapbender.
>> When i try to load a WMS serivce the application throws an internal
>> server error and no layer is shown.
>> Here's the WMS
>> url:http://geoserver.montevideo.gub.uy/geoserver/ows?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
>> <http://geoserver.montevideo.gub.uy/geoserver/ows?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities>
>> And here's the error i'am having:
>> /I look forward to/ hearing /your reply/ asap,
>> best wishes,
>> Belen.
>> El presente correo electrónico y cualquier posible archivo adjunto
>> esta dirigido únicamente al destinatario del mismo y contiene
>> información que puede ser confidencial. Si Ud. no es el destinatario
>> correcto por favor notifique al remitente respondiendo este mensaje y
>> elimine inmediatamente de su sistema, el correo electrónico y los
>> posibles archivos adjuntos al mismo. Esta prohibida cualquier
>> utilización, difusión o copia de este correo electrónico por cualquier
>> persona o entidad que no sean las especificas destinatarias del
>> mensaje. La Intendencia de Montevideo no acepta ninguna
>> responsabilidad con respecto a cualquier comunicación que haya sido
>> emitida incumpliendo nuestra normativa municipal, así como lo previsto
>> en la Ley 18.331 de Protección de Datos Personales y la Ley 18.381 de
>> Acceso a la Información Publica.
>> This e-mail and any attachment is confidential and is intended solely
>> for the addressee(s). If you are not intended recipient please inform
>> the sender immediately, answering this e-mail and delete it as well as
>> the attached files. Any use, circulation or copy of this e-mail by any
>> person or entity that is not the specific addressee(s) is prohibited.
>> The City Council of Montevideo is not responsible for any
>> communication emitted without respecting our Organization Policy or
>> the Data Protection Act and Habeas Data Action No. 18.331 and the
>> Information Access Act N 18.381.
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
> Viele Grüße,
> Jörg Thomsen
> Aufwind durch Wissen!
> Jetzt neu: Web-Seminare und Online-Schulungen
> bei der www.foss-academy.com
> Jörg Thomsen
> WhereGroup GmbH
> Bundesallee 23
> 10717 Berlin
> Germany
> Tel: +49 (0)30 / 5130 278 74
> Fax: +49 (0)30 / 5130 278 11
> joerg.thomsen at wheregroup.com
> www.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Folgen Sie der WhereGroup auf twitter:
> http://twitter.com/WhereGroup_com
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   Tel: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   www.wheregroup.com
   Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
   Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
   Geschäftsführer:
El presente correo electronico y cualquier posible archivo adjunto esta dirigido unicamente al destinatario del mismo y contiene informacion que puede ser confidencial. Si Ud. no es el destinatario correcto por favor notifique al remitente respondiendo este mensaje y elimine inmediatamente de su sistema, el correo electronico y los posibles archivos adjuntos al mismo. Esta prohibida cualquier utilizacion, difusion o copia de este correo electronico por cualquier persona o entidad que no sean las especificas destinatarias del mensaje. La Intendencia de Montevideo no acepta ninguna responsabilidad con respecto a cualquier comunicacion que haya sido emitida incumpliendo nuestra normativa municipal, asi como lo previsto en la Ley 18.331 de Proteccion de Datos Personales y la Ley 18.381 de Acceso a la Informacion Publica.
This e-mail and any attachment is confidential and is intended solely for the addressee(s). If you are not intended recipient please inform the sender immediately, answering this e-mail and delete it as well as the attached files. Any use, circulation or copy of this e-mail by any person or entity that is not the specific addressee(s) is prohibited. The City Council of Montevideo is not responsible for any communication emitted without respecting our Organization Policy or the Data Protection Act and Habeas Data Action No. 18.331 and the Information Access Act N 18.381.
More information about the Mapbender_users mailing list
