[Mapbender-users] Postgresql version for Mapbender
Gal Zsolt
zsolt.gal at satelitnt.com
Wed Oct 5 00:14:36 PDT 2022
Hello Astrid,
Thank you for answer.
GÁL Zsolt
On 5 October 2022 at 10:02:02 +03:00, Astrid Emde (WhereGroup) <astrid.emde at wheregroup.com> wrote:
> Hello Gal,
> maybe this page helps <https://symfony.com/doc/4.4/reference/configuration/doctrine.html>
> But you definitely should update your PostgreSQl version. You can install another PostgreSQl version in parallel.
> See you Astrid
> Am 2022-10-05 03:41, schrieb Gal Zsolt:
> > Hello List,
> > I use pgAdmin as management tool for Postgresql. Yesterday I upgrede
> > to version 6.14. I must downgrade to 6.11 because this is the last
> > version wich work with my postgresql servers versions:
> > 9.6...(19,20,24).
> > I try to find out wich version of Postgresql work with Mapbender 3.3.1
> > and 3.2... but I dont find a good, clear answer.
> > I have installed and use Mapbender on Linux servers.
> > My question is which version of PostgreSQL does MapBender 3.3.1 (and
> > 3.2.....) require/work?
> > GAL Zsolt
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > <https://lists.osgeo.org/mailman/listinfo/mapbender_users>
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
> Aufwind durch Wissen!
> Jetzt neu: Web-Seminare und Online-Schulungen
> bei der www.foss-academy.com
> Astrid Emde
> WhereGroup GmbH
> Eifelstraße 7
> 53119 Bonn
> Germany
> Tel: +49(0)228 90 90 38 - 22
> Fax: +49(0)228 90 90 38 - 11
> <http://www.wheregroup.com>
> Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
> <https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB>
> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
> Folgen Sie der WhereGroup auf twitter:
> <http://twitter.com/WhereGroup_com>
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20221005/a2781d44/attachment.htm>
More information about the Mapbender_users
