[Mapbender-users] (no maps on 4k screen)
Jörg Thomsen (WhereGroup) joerg.thomsen at wheregroup.com
Thu Oct 6 06:36:00 PDT 2022
Hello Marcin,
usually this happens, because the wms' don't deliver images of the
requested size. At first you could try to size-down your browser-window.
If this works, you could set the tiled checkbox in mapbender wms
configuration. Or you can change the wms settings (if you have access) -
in MapSever it is the maxsize-parameter.
Jörg
(please use a subject)
Am 06.10.22 um 13:33 schrieb Marcin Niemyjski:
> Hello,
> Using a high-resolution monitor (4k), the layers in mapbender were not
> loading, have someone encountered this error and knows what to do?
> Best regards,
> Marcin
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Viele Grüße,
Jörg Thomsen
Aufwind durch Wissen!
Jetzt neu: Web-Seminare und Online-Schulungen
bei der www.foss-academy.com
Jörg Thomsen
WhereGroup GmbH
Bundesallee 23
10717 Berlin
Germany
Tel: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 5130 278 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
More information about the Mapbender_users mailing list
