[Mapbender-users] issues uploading a WMS Service-URL (XML document cannot be parsed)
de Lima Guimaraes, Danilo
Danilo.deLima at pulheim.de
Wed Sep 21 07:08:09 PDT 2022
Hello Jörg,
these are the logs when I try to load a WMS-Service via WMS-Loader (frontend from Demo-Version)
[2022-09-21 16:04:34] php.INFO: Deprecated: Return type of Mapbender\DataSourceBundle\Entity\DataItem::offsetExists($offset) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice {"exception":"[object] (ErrorException(code: 0): Deprecated: Return type of Mapbender\\DataSourceBundle\\Entity\\DataItem::offsetExists($offset) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at C:\\mapbender\\vendor\\mapbender\\data-source\\Entity\\DataItem.php:107)"} []
[2022-09-21 16:04:34] php.INFO: Deprecated: Return type of Mapbender\DataSourceBundle\Entity\DataItem::offsetGet($offset) should either be compatible with ArrayAccess::offsetGet(mixed $offset): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice {"exception":"[object] (ErrorException(code: 0): Deprecated: Return type of Mapbender\\DataSourceBundle\\Entity\\DataItem::offsetGet($offset) should either be compatible with ArrayAccess::offsetGet(mixed $offset): mixed, or the #[\\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at C:\\mapbender\\vendor\\mapbender\\data-source\\Entity\\DataItem.php:112)"} []
[2022-09-21 16:04:34] php.INFO: Deprecated: Return type of Mapbender\DataSourceBundle\Entity\DataItem::offsetSet($offset, $value) should either be compatible with ArrayAccess::offsetSet(mixed $offset, mixed $value): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice {"exception":"[object] (ErrorException(code: 0): Deprecated: Return type of Mapbender\\DataSourceBundle\\Entity\\DataItem::offsetSet($offset, $value) should either be compatible with ArrayAccess::offsetSet(mixed $offset, mixed $value): void, or the #[\\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at C:\\mapbender\\vendor\\mapbender\\data-source\\Entity\\DataItem.php:117)"} []
[2022-09-21 16:04:34] php.INFO: Deprecated: Return type of Mapbender\DataSourceBundle\Entity\DataItem::offsetUnset($offset) should either be compatible with ArrayAccess::offsetUnset(mixed $offset): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice {"exception":"[object] (ErrorException(code: 0): Deprecated: Return type of Mapbender\\DataSourceBundle\\Entity\\DataItem::offsetUnset($offset) should either be compatible with ArrayAccess::offsetUnset(mixed $offset): void, or the #[\\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at C:\\mapbender\\vendor\\mapbender\\data-source\\Entity\\DataItem.php:122)"} []
[2022-09-21 16:04:34] php.INFO: User Deprecated: Using the "Twig_Extension_StringLoader" class is deprecated since Twig version 2.7, use "Twig\Extension\StringLoaderExtension" instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: Using the \"Twig_Extension_StringLoader\" class is deprecated since Twig version 2.7, use \"Twig\\Extension\\StringLoaderExtension\" instead. at C:\\mapbender\\vendor\\twig\\twig\\lib\\Twig\\Extension\\StringLoader.php:7)"} []
[2022-09-21 16:04:34] php.INFO: User Deprecated: Auto-injection of the container for "Mapbender\CoreBundle\Controller\AssetsController" is deprecated since Symfony 4.2. Configure it as a service instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: Auto-injection of the container for \"Mapbender\\CoreBundle\\Controller\\AssetsController\" is deprecated since Symfony 4.2. Configure it as a service instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\FrameworkBundle\\Controller\\ControllerResolver.php:77)"} []
[2022-09-21 16:04:35] php.INFO: User Deprecated: The "twig.exception_listener" service is deprecated since Symfony 4.4. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"twig.exception_listener\" service is deprecated since Symfony 4.4. at C:\\mapbender\\app\\cache\\dev\\ContainerSuMvwfB\\appAppKernelDevDebugContainer.php:5120)"} []
[2022-09-21 16:04:35] php.INFO: User Deprecated: The "Symfony\Component\HttpKernel\EventListener\ExceptionListener" class is deprecated since Symfony 4.4, use "ErrorListener" instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"Symfony\\Component\\HttpKernel\\EventListener\\ExceptionListener\" class is deprecated since Symfony 4.4, use \"ErrorListener\" instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Component\\HttpKernel\\EventListener\\ExceptionListener.php:25)"} []
[2022-09-21 16:04:35] security.INFO: Populated the TokenStorage with an anonymous Token. [] []
[2022-09-21 16:04:35] php.INFO: User Deprecated: The "templating" service is deprecated since Symfony 4.4 and will be removed in 5.0. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"templating\" service is deprecated since Symfony 4.4 and will be removed in 5.0. at C:\\mapbender\\app\\cache\\dev\\ContainerSuMvwfB\\appAppKernelDevDebugContainer.php:1495)"} []
[2022-09-21 16:04:35] php.INFO: User Deprecated: The Symfony\Bundle\TwigBundle\Loader\FilesystemLoader class is deprecated since version 4.3 and will be removed in 5.0; use Twig notation for templates instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The Symfony\\Bundle\\TwigBundle\\Loader\\FilesystemLoader class is deprecated since version 4.3 and will be removed in 5.0; use Twig notation for templates instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\TwigBundle\\Loader\\FilesystemLoader.php:14)"} []
[2022-09-21 16:04:35] php.INFO: User Deprecated: The "templating.locator" service is deprecated since Symfony 4.3 and will be removed in 5.0. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"templating.locator\" service is deprecated since Symfony 4.3 and will be removed in 5.0. at C:\\mapbender\\app\\cache\\dev\\ContainerSuMvwfB\\appAppKernelDevDebugContainer.php:4843)"} []
[2022-09-21 16:04:35] php.INFO: User Deprecated: The Symfony\Bundle\FrameworkBundle\Templating\Loader\TemplateLocator class is deprecated since version 4.3 and will be removed in 5.0; use Twig instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The Symfony\\Bundle\\FrameworkBundle\\Templating\\Loader\\TemplateLocator class is deprecated since version 4.3 and will be removed in 5.0; use Twig instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\FrameworkBundle\\Templating\\Loader\\TemplateLocator.php:14)"} []
[2022-09-21 16:04:35] php.INFO: User Deprecated: The "templating.name_parser" service is deprecated since Symfony 4.3 and will be removed in 5.0. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"templating.name_parser\" service is deprecated since Symfony 4.3 and will be removed in 5.0. at C:\\mapbender\\app\\cache\\dev\\ContainerSuMvwfB\\appAppKernelDevDebugContainer.php:4857)"} []
[2022-09-21 16:04:35] php.INFO: User Deprecated: The Symfony\Bundle\FrameworkBundle\Templating\TemplateNameParser class is deprecated since version 4.3 and will be removed in 5.0; use Twig instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The Symfony\\Bundle\\FrameworkBundle\\Templating\\TemplateNameParser class is deprecated since version 4.3 and will be removed in 5.0; use Twig instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\FrameworkBundle\\Templating\\TemplateNameParser.php:14)"} []
[2022-09-21 16:04:35] php.INFO: User Deprecated: The Symfony\Bundle\TwigBundle\TwigEngine class is deprecated since version 4.3 and will be removed in 5.0; use \Twig\Environment instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The Symfony\\Bundle\\TwigBundle\\TwigEngine class is deprecated since version 4.3 and will be removed in 5.0; use \\Twig\\Environment instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\TwigBundle\\TwigEngine.php:14)"} []
[2022-09-21 16:04:35] php.INFO: User Deprecated: The Symfony\Bridge\Twig\TwigEngine class is deprecated since version 4.3 and will be removed in 5.0; use \Twig\Environment instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The Symfony\\Bridge\\Twig\\TwigEngine class is deprecated since version 4.3 and will be removed in 5.0; use \\Twig\\Environment instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bridge\\Twig\\TwigEngine.php:14)"} []
[2022-09-21 16:04:35] php.INFO: User Deprecated: The Symfony\Bundle\FrameworkBundle\Templating\EngineInterface interface is deprecated since version 4.3 and will be removed in 5.0; use Twig instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The Symfony\\Bundle\\FrameworkBundle\\Templating\\EngineInterface interface is deprecated since version 4.3 and will be removed in 5.0; use Twig instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\FrameworkBundle\\Templating\\EngineInterface.php:14)"} []
[2022-09-21 16:04:35] php.INFO: Deprecated: Return type of Mapbender\DataSourceBundle\Entity\DataItem::offsetExists($offset) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice {"exception":"[object] (ErrorException(code: 0): Deprecated: Return type of Mapbender\\DataSourceBundle\\Entity\\DataItem::offsetExists($offset) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at C:\\mapbender\\vendor\\mapbender\\data-source\\Entity\\DataItem.php:107)"} []
[2022-09-21 16:04:35] php.INFO: Deprecated: Return type of Mapbender\DataSourceBundle\Entity\DataItem::offsetGet($offset) should either be compatible with ArrayAccess::offsetGet(mixed $offset): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice {"exception":"[object] (ErrorException(code: 0): Deprecated: Return type of Mapbender\\DataSourceBundle\\Entity\\DataItem::offsetGet($offset) should either be compatible with ArrayAccess::offsetGet(mixed $offset): mixed, or the #[\\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at C:\\mapbender\\vendor\\mapbender\\data-source\\Entity\\DataItem.php:112)"} []
[2022-09-21 16:04:35] php.INFO: Deprecated: Return type of Mapbender\DataSourceBundle\Entity\DataItem::offsetSet($offset, $value) should either be compatible with ArrayAccess::offsetSet(mixed $offset, mixed $value): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice {"exception":"[object] (ErrorException(code: 0): Deprecated: Return type of Mapbender\\DataSourceBundle\\Entity\\DataItem::offsetSet($offset, $value) should either be compatible with ArrayAccess::offsetSet(mixed $offset, mixed $value): void, or the #[\\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at C:\\mapbender\\vendor\\mapbender\\data-source\\Entity\\DataItem.php:117)"} []
[2022-09-21 16:04:35] php.INFO: Deprecated: Return type of Mapbender\DataSourceBundle\Entity\DataItem::offsetUnset($offset) should either be compatible with ArrayAccess::offsetUnset(mixed $offset): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice {"exception":"[object] (ErrorException(code: 0): Deprecated: Return type of Mapbender\\DataSourceBundle\\Entity\\DataItem::offsetUnset($offset) should either be compatible with ArrayAccess::offsetUnset(mixed $offset): void, or the #[\\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at C:\\mapbender\\vendor\\mapbender\\data-source\\Entity\\DataItem.php:122)"} []
[2022-09-21 16:04:35] php.INFO: User Deprecated: Using the "Twig_Extension_StringLoader" class is deprecated since Twig version 2.7, use "Twig\Extension\StringLoaderExtension" instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: Using the \"Twig_Extension_StringLoader\" class is deprecated since Twig version 2.7, use \"Twig\\Extension\\StringLoaderExtension\" instead. at C:\\mapbender\\vendor\\twig\\twig\\lib\\Twig\\Extension\\StringLoader.php:7)"} []
[2022-09-21 16:04:35] php.INFO: User Deprecated: Auto-injection of the container for "Mapbender\CoreBundle\Controller\AssetsController" is deprecated since Symfony 4.2. Configure it as a service instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: Auto-injection of the container for \"Mapbender\\CoreBundle\\Controller\\AssetsController\" is deprecated since Symfony 4.2. Configure it as a service instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\FrameworkBundle\\Controller\\ControllerResolver.php:77)"} []
[2022-09-21 16:04:35] php.INFO: User Deprecated: Loading the file "../vendor/mapbender/openlayers6-es5/dist/ol-debug.js" from the global resource directory "C:\mapbender\app" is deprecated since Symfony 4.4 and will be removed in 5.0. {"exception":"[object] (ErrorException(code: 0): User Deprecated: Loading the file \"../vendor/mapbender/openlayers6-es5/dist/ol-debug.js\" from the global resource directory \"C:\\mapbender\\app\" is deprecated since Symfony 4.4 and will be removed in 5.0. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Component\\HttpKernel\\Config\\FileLocator.php:84)"} []
[2022-09-21 16:04:36] php.INFO: User Deprecated: Using the WebserverBundle is deprecated since Symfony 4.4. The new Symfony local server has more features, you can use it instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: Using the WebserverBundle is deprecated since Symfony 4.4. The new Symfony local server has more features, you can use it instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\WebServerBundle\\WebServerBundle.php:23)"} []
[2022-09-21 16:04:36] request.INFO: Matched route "mapbender_core_application_configuration". {"route":"mapbender_core_application_configuration","route_parameters":{"_route":"mapbender_core_application_configuration","_controller":"Mapbender\\CoreBundle\\Controller\\ConfigController::configurationAction","slug":"mapbender_user"},"request_uri":"http://localhost/mapbender/app_dev.php/application/mapbender_user/config","method":"GET"} []
[2022-09-21 16:04:36] security.INFO: Populated the TokenStorage with an anonymous Token. [] []
[2022-09-21 16:04:36] php.INFO: User Deprecated: The "templating" service is deprecated since Symfony 4.4 and will be removed in 5.0. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"templating\" service is deprecated since Symfony 4.4 and will be removed in 5.0. at C:\\mapbender\\app\\cache\\dev\\ContainerSuMvwfB\\appAppKernelDevDebugContainer.php:1495)"} []
[2022-09-21 16:04:36] php.INFO: User Deprecated: The Symfony\Bundle\TwigBundle\Loader\FilesystemLoader class is deprecated since version 4.3 and will be removed in 5.0; use Twig notation for templates instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The Symfony\\Bundle\\TwigBundle\\Loader\\FilesystemLoader class is deprecated since version 4.3 and will be removed in 5.0; use Twig notation for templates instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\TwigBundle\\Loader\\FilesystemLoader.php:14)"} []
[2022-09-21 16:04:36] php.INFO: User Deprecated: The "templating.locator" service is deprecated since Symfony 4.3 and will be removed in 5.0. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"templating.locator\" service is deprecated since Symfony 4.3 and will be removed in 5.0. at C:\\mapbender\\app\\cache\\dev\\ContainerSuMvwfB\\appAppKernelDevDebugContainer.php:4843)"} []
[2022-09-21 16:04:36] php.INFO: User Deprecated: The Symfony\Bundle\FrameworkBundle\Templating\Loader\TemplateLocator class is deprecated since version 4.3 and will be removed in 5.0; use Twig instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The Symfony\\Bundle\\FrameworkBundle\\Templating\\Loader\\TemplateLocator class is deprecated since version 4.3 and will be removed in 5.0; use Twig instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\FrameworkBundle\\Templating\\Loader\\TemplateLocator.php:14)"} []
[2022-09-21 16:04:36] php.INFO: User Deprecated: The "templating.name_parser" service is deprecated since Symfony 4.3 and will be removed in 5.0. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"templating.name_parser\" service is deprecated since Symfony 4.3 and will be removed in 5.0. at C:\\mapbender\\app\\cache\\dev\\ContainerSuMvwfB\\appAppKernelDevDebugContainer.php:4857)"} []
[2022-09-21 16:04:36] php.INFO: User Deprecated: The Symfony\Bundle\FrameworkBundle\Templating\TemplateNameParser class is deprecated since version 4.3 and will be removed in 5.0; use Twig instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The Symfony\\Bundle\\FrameworkBundle\\Templating\\TemplateNameParser class is deprecated since version 4.3 and will be removed in 5.0; use Twig instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\FrameworkBundle\\Templating\\TemplateNameParser.php:14)"} []
[2022-09-21 16:04:36] php.INFO: User Deprecated: The Symfony\Bundle\TwigBundle\TwigEngine class is deprecated since version 4.3 and will be removed in 5.0; use \Twig\Environment instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The Symfony\\Bundle\\TwigBundle\\TwigEngine class is deprecated since version 4.3 and will be removed in 5.0; use \\Twig\\Environment instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\TwigBundle\\TwigEngine.php:14)"} []
[2022-09-21 16:04:36] php.INFO: User Deprecated: The Symfony\Bridge\Twig\TwigEngine class is deprecated since version 4.3 and will be removed in 5.0; use \Twig\Environment instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The Symfony\\Bridge\\Twig\\TwigEngine class is deprecated since version 4.3 and will be removed in 5.0; use \\Twig\\Environment instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bridge\\Twig\\TwigEngine.php:14)"} []
[2022-09-21 16:04:36] php.INFO: User Deprecated: The Symfony\Bundle\FrameworkBundle\Templating\EngineInterface interface is deprecated since version 4.3 and will be removed in 5.0; use Twig instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The Symfony\\Bundle\\FrameworkBundle\\Templating\\EngineInterface interface is deprecated since version 4.3 and will be removed in 5.0; use Twig instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\FrameworkBundle\\Templating\\EngineInterface.php:14)"} []
[2022-09-21 16:04:36] request.INFO: Matched route "_wdt". {"route":"_wdt","route_parameters":{"_route":"_wdt","_controller":"web_profiler.controller.profiler::toolbarAction","token":"399abb"},"request_uri":"http://localhost/mapbender/app_dev.php/_wdt/399abb","method":"GET"} []
[2022-09-21 16:04:36] php.INFO: User Deprecated: Using the "Twig_Extension_StringLoader" class is deprecated since Twig version 2.7, use "Twig\Extension\StringLoaderExtension" instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: Using the \"Twig_Extension_StringLoader\" class is deprecated since Twig version 2.7, use \"Twig\\Extension\\StringLoaderExtension\" instead. at C:\\mapbender\\vendor\\twig\\twig\\lib\\Twig\\Extension\\StringLoader.php:7)"} []
[2022-09-21 16:04:36] php.INFO: Deprecated: Return type of Mapbender\DataSourceBundle\Entity\DataItem::offsetExists($offset) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice {"exception":"[object] (ErrorException(code: 0): Deprecated: Return type of Mapbender\\DataSourceBundle\\Entity\\DataItem::offsetExists($offset) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at C:\\mapbender\\vendor\\mapbender\\data-source\\Entity\\DataItem.php:107)"} []
[2022-09-21 16:04:36] php.INFO: Deprecated: Return type of Mapbender\DataSourceBundle\Entity\DataItem::offsetGet($offset) should either be compatible with ArrayAccess::offsetGet(mixed $offset): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice {"exception":"[object] (ErrorException(code: 0): Deprecated: Return type of Mapbender\\DataSourceBundle\\Entity\\DataItem::offsetGet($offset) should either be compatible with ArrayAccess::offsetGet(mixed $offset): mixed, or the #[\\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at C:\\mapbender\\vendor\\mapbender\\data-source\\Entity\\DataItem.php:112)"} []
[2022-09-21 16:04:36] php.INFO: Deprecated: Return type of Mapbender\DataSourceBundle\Entity\DataItem::offsetSet($offset, $value) should either be compatible with ArrayAccess::offsetSet(mixed $offset, mixed $value): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice {"exception":"[object] (ErrorException(code: 0): Deprecated: Return type of Mapbender\\DataSourceBundle\\Entity\\DataItem::offsetSet($offset, $value) should either be compatible with ArrayAccess::offsetSet(mixed $offset, mixed $value): void, or the #[\\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at C:\\mapbender\\vendor\\mapbender\\data-source\\Entity\\DataItem.php:117)"} []
[2022-09-21 16:04:36] php.INFO: Deprecated: Return type of Mapbender\DataSourceBundle\Entity\DataItem::offsetUnset($offset) should either be compatible with ArrayAccess::offsetUnset(mixed $offset): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice {"exception":"[object] (ErrorException(code: 0): Deprecated: Return type of Mapbender\\DataSourceBundle\\Entity\\DataItem::offsetUnset($offset) should either be compatible with ArrayAccess::offsetUnset(mixed $offset): void, or the #[\\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at C:\\mapbender\\vendor\\mapbender\\data-source\\Entity\\DataItem.php:122)"} []
[2022-09-21 16:04:36] php.INFO: Deprecated: str_contains(): Passing null to parameter #1 ($haystack) of type string is deprecated {"exception":"[object] (ErrorException(code: 0): Deprecated: str_contains(): Passing null to parameter #1 ($haystack) of type string is deprecated at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Component\\Asset\\Package.php:76)"} []
[2022-09-21 16:04:36] php.INFO: Deprecated: substr(): Passing null to parameter #1 ($string) of type string is deprecated {"exception":"[object] (ErrorException(code: 0): Deprecated: substr(): Passing null to parameter #1 ($string) of type string is deprecated at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Component\\Asset\\Package.php:76)"} []
[2022-09-21 16:04:36] php.INFO: Deprecated: ltrim(): Passing null to parameter #1 ($string) of type string is deprecated {"exception":"[object] (ErrorException(code: 0): Deprecated: ltrim(): Passing null to parameter #1 ($string) of type string is deprecated at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Component\\Asset\\PathPackage.php:61)"} []
[2022-09-21 16:04:36] php.INFO: User Deprecated: Auto-injection of the container for "Mapbender\CoreBundle\Controller\ConfigController" is deprecated since Symfony 4.2. Configure it as a service instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: Auto-injection of the container for \"Mapbender\\CoreBundle\\Controller\\ConfigController\" is deprecated since Symfony 4.2. Configure it as a service instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\FrameworkBundle\\Controller\\ControllerResolver.php:77)"} []
[2022-09-21 16:04:36] php.INFO: User Deprecated: The "twig.exception_listener" service is deprecated since Symfony 4.4. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"twig.exception_listener\" service is deprecated since Symfony 4.4. at C:\\mapbender\\app\\cache\\dev\\ContainerSuMvwfB\\appAppKernelDevDebugContainer.php:5120)"} []
[2022-09-21 16:04:36] php.INFO: User Deprecated: The "Symfony\Component\HttpKernel\EventListener\ExceptionListener" class is deprecated since Symfony 4.4, use "ErrorListener" instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"Symfony\\Component\\HttpKernel\\EventListener\\ExceptionListener\" class is deprecated since Symfony 4.4, use \"ErrorListener\" instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Component\\HttpKernel\\EventListener\\ExceptionListener.php:25)"} []
[2022-09-21 16:04:37] php.INFO: User Deprecated: Using the WebserverBundle is deprecated since Symfony 4.4. The new Symfony local server has more features, you can use it instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: Using the WebserverBundle is deprecated since Symfony 4.4. The new Symfony local server has more features, you can use it instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\WebServerBundle\\WebServerBundle.php:23)"} []
[2022-09-21 16:04:37] request.INFO: Matched route "mapbender_core_application_element". {"route":"mapbender_core_application_element","route_parameters":{"_route":"mapbender_core_application_element","id":"as","action":"granted","_controller":"Mapbender\\CoreBundle\\Controller\\ElementController::elementAction","slug":"mapbender_user"},"request_uri":"http://localhost/mapbender/app_dev.php/application/mapbender_user/element/as/granted","method":"GET"} []
[2022-09-21 16:04:37] security.INFO: Populated the TokenStorage with an anonymous Token. [] []
[2022-09-21 16:04:37] php.INFO: User Deprecated: The "templating" service is deprecated since Symfony 4.4 and will be removed in 5.0. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"templating\" service is deprecated since Symfony 4.4 and will be removed in 5.0. at C:\\mapbender\\app\\cache\\dev\\ContainerSuMvwfB\\appAppKernelDevDebugContainer.php:1495)"} []
[2022-09-21 16:04:37] php.INFO: User Deprecated: The Symfony\Bundle\TwigBundle\Loader\FilesystemLoader class is deprecated since version 4.3 and will be removed in 5.0; use Twig notation for templates instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The Symfony\\Bundle\\TwigBundle\\Loader\\FilesystemLoader class is deprecated since version 4.3 and will be removed in 5.0; use Twig notation for templates instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\TwigBundle\\Loader\\FilesystemLoader.php:14)"} []
[2022-09-21 16:04:37] php.INFO: User Deprecated: The "templating.locator" service is deprecated since Symfony 4.3 and will be removed in 5.0. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"templating.locator\" service is deprecated since Symfony 4.3 and will be removed in 5.0. at C:\\mapbender\\app\\cache\\dev\\ContainerSuMvwfB\\appAppKernelDevDebugContainer.php:4843)"} []
[2022-09-21 16:04:37] php.INFO: User Deprecated: The Symfony\Bundle\FrameworkBundle\Templating\Loader\TemplateLocator class is deprecated since version 4.3 and will be removed in 5.0; use Twig instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The Symfony\\Bundle\\FrameworkBundle\\Templating\\Loader\\TemplateLocator class is deprecated since version 4.3 and will be removed in 5.0; use Twig instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\FrameworkBundle\\Templating\\Loader\\TemplateLocator.php:14)"} []
[2022-09-21 16:04:37] php.INFO: User Deprecated: The "templating.name_parser" service is deprecated since Symfony 4.3 and will be removed in 5.0. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"templating.name_parser\" service is deprecated since Symfony 4.3 and will be removed in 5.0. at C:\\mapbender\\app\\cache\\dev\\ContainerSuMvwfB\\appAppKernelDevDebugContainer.php:4857)"} []
[2022-09-21 16:04:37] php.INFO: User Deprecated: The Symfony\Bundle\FrameworkBundle\Templating\TemplateNameParser class is deprecated since version 4.3 and will be removed in 5.0; use Twig instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The Symfony\\Bundle\\FrameworkBundle\\Templating\\TemplateNameParser class is deprecated since version 4.3 and will be removed in 5.0; use Twig instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\FrameworkBundle\\Templating\\TemplateNameParser.php:14)"} []
[2022-09-21 16:04:37] php.INFO: User Deprecated: The Symfony\Bundle\TwigBundle\TwigEngine class is deprecated since version 4.3 and will be removed in 5.0; use \Twig\Environment instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The Symfony\\Bundle\\TwigBundle\\TwigEngine class is deprecated since version 4.3 and will be removed in 5.0; use \\Twig\\Environment instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\TwigBundle\\TwigEngine.php:14)"} []
[2022-09-21 16:04:37] php.INFO: User Deprecated: The Symfony\Bridge\Twig\TwigEngine class is deprecated since version 4.3 and will be removed in 5.0; use \Twig\Environment instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The Symfony\\Bridge\\Twig\\TwigEngine class is deprecated since version 4.3 and will be removed in 5.0; use \\Twig\\Environment instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bridge\\Twig\\TwigEngine.php:14)"} []
[2022-09-21 16:04:37] php.INFO: User Deprecated: The Symfony\Bundle\FrameworkBundle\Templating\EngineInterface interface is deprecated since version 4.3 and will be removed in 5.0; use Twig instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The Symfony\\Bundle\\FrameworkBundle\\Templating\\EngineInterface interface is deprecated since version 4.3 and will be removed in 5.0; use Twig instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\FrameworkBundle\\Templating\\EngineInterface.php:14)"} []
[2022-09-21 16:04:37] php.INFO: User Deprecated: Using the "Twig_Extension_StringLoader" class is deprecated since Twig version 2.7, use "Twig\Extension\StringLoaderExtension" instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: Using the \"Twig_Extension_StringLoader\" class is deprecated since Twig version 2.7, use \"Twig\\Extension\\StringLoaderExtension\" instead. at C:\\mapbender\\vendor\\twig\\twig\\lib\\Twig\\Extension\\StringLoader.php:7)"} []
[2022-09-21 16:04:37] php.INFO: Deprecated: Return type of Mapbender\DataSourceBundle\Entity\DataItem::offsetExists($offset) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice {"exception":"[object] (ErrorException(code: 0): Deprecated: Return type of Mapbender\\DataSourceBundle\\Entity\\DataItem::offsetExists($offset) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at C:\\mapbender\\vendor\\mapbender\\data-source\\Entity\\DataItem.php:107)"} []
[2022-09-21 16:04:37] php.INFO: Deprecated: Return type of Mapbender\DataSourceBundle\Entity\DataItem::offsetGet($offset) should either be compatible with ArrayAccess::offsetGet(mixed $offset): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice {"exception":"[object] (ErrorException(code: 0): Deprecated: Return type of Mapbender\\DataSourceBundle\\Entity\\DataItem::offsetGet($offset) should either be compatible with ArrayAccess::offsetGet(mixed $offset): mixed, or the #[\\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at C:\\mapbender\\vendor\\mapbender\\data-source\\Entity\\DataItem.php:112)"} []
[2022-09-21 16:04:37] php.INFO: Deprecated: Return type of Mapbender\DataSourceBundle\Entity\DataItem::offsetSet($offset, $value) should either be compatible with ArrayAccess::offsetSet(mixed $offset, mixed $value): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice {"exception":"[object] (ErrorException(code: 0): Deprecated: Return type of Mapbender\\DataSourceBundle\\Entity\\DataItem::offsetSet($offset, $value) should either be compatible with ArrayAccess::offsetSet(mixed $offset, mixed $value): void, or the #[\\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at C:\\mapbender\\vendor\\mapbender\\data-source\\Entity\\DataItem.php:117)"} []
[2022-09-21 16:04:37] php.INFO: Deprecated: Return type of Mapbender\DataSourceBundle\Entity\DataItem::offsetUnset($offset) should either be compatible with ArrayAccess::offsetUnset(mixed $offset): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice {"exception":"[object] (ErrorException(code: 0): Deprecated: Return type of Mapbender\\DataSourceBundle\\Entity\\DataItem::offsetUnset($offset) should either be compatible with ArrayAccess::offsetUnset(mixed $offset): void, or the #[\\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at C:\\mapbender\\vendor\\mapbender\\data-source\\Entity\\DataItem.php:122)"} []
[2022-09-21 16:04:37] php.INFO: User Deprecated: Auto-injection of the container for "Mapbender\CoreBundle\Controller\ElementController" is deprecated since Symfony 4.2. Configure it as a service instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: Auto-injection of the container for \"Mapbender\\CoreBundle\\Controller\\ElementController\" is deprecated since Symfony 4.2. Configure it as a service instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\FrameworkBundle\\Controller\\ControllerResolver.php:77)"} []
[2022-09-21 16:04:37] php.INFO: User Deprecated: The "twig.exception_listener" service is deprecated since Symfony 4.4. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"twig.exception_listener\" service is deprecated since Symfony 4.4. at C:\\mapbender\\app\\cache\\dev\\ContainerSuMvwfB\\appAppKernelDevDebugContainer.php:5120)"} []
[2022-09-21 16:04:37] php.INFO: User Deprecated: The "Symfony\Component\HttpKernel\EventListener\ExceptionListener" class is deprecated since Symfony 4.4, use "ErrorListener" instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"Symfony\\Component\\HttpKernel\\EventListener\\ExceptionListener\" class is deprecated since Symfony 4.4, use \"ErrorListener\" instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Component\\HttpKernel\\EventListener\\ExceptionListener.php:25)"} []
[2022-09-21 16:04:53] php.INFO: User Deprecated: Using the WebserverBundle is deprecated since Symfony 4.4. The new Symfony local server has more features, you can use it instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: Using the WebserverBundle is deprecated since Symfony 4.4. The new Symfony local server has more features, you can use it instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\WebServerBundle\\WebServerBundle.php:23)"} []
[2022-09-21 16:04:53] request.INFO: Matched route "mapbender_core_application_element". {"route":"mapbender_core_application_element","route_parameters":{"_route":"mapbender_core_application_element","id":"wmsloader","action":"loadWms","_controller":"Mapbender\\CoreBundle\\Controller\\ElementController::elementAction","slug":"mapbender_user"},"request_uri":"http://localhost/mapbender/app_dev.php/application/mapbender_user/element/wmsloader/loadWms?url=https%3A%2F%2Fwms.wheregroup.com%2Fcgi-bin%2Fmapbender_user.xml%3FVERSION%3D1.3.0%26REQUEST%3DGetCapabilities%26SERVICE%3DWMS","method":"GET"} []
[2022-09-21 16:04:53] security.INFO: Populated the TokenStorage with an anonymous Token. [] []
[2022-09-21 16:04:53] php.INFO: User Deprecated: The "templating" service is deprecated since Symfony 4.4 and will be removed in 5.0. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"templating\" service is deprecated since Symfony 4.4 and will be removed in 5.0. at C:\\mapbender\\app\\cache\\dev\\ContainerSuMvwfB\\appAppKernelDevDebugContainer.php:1495)"} []
[2022-09-21 16:04:53] php.INFO: User Deprecated: The Symfony\Bundle\TwigBundle\Loader\FilesystemLoader class is deprecated since version 4.3 and will be removed in 5.0; use Twig notation for templates instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The Symfony\\Bundle\\TwigBundle\\Loader\\FilesystemLoader class is deprecated since version 4.3 and will be removed in 5.0; use Twig notation for templates instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\TwigBundle\\Loader\\FilesystemLoader.php:14)"} []
[2022-09-21 16:04:53] php.INFO: User Deprecated: The "templating.locator" service is deprecated since Symfony 4.3 and will be removed in 5.0. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"templating.locator\" service is deprecated since Symfony 4.3 and will be removed in 5.0. at C:\\mapbender\\app\\cache\\dev\\ContainerSuMvwfB\\appAppKernelDevDebugContainer.php:4843)"} []
[2022-09-21 16:04:53] php.INFO: User Deprecated: The Symfony\Bundle\FrameworkBundle\Templating\Loader\TemplateLocator class is deprecated since version 4.3 and will be removed in 5.0; use Twig instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The Symfony\\Bundle\\FrameworkBundle\\Templating\\Loader\\TemplateLocator class is deprecated since version 4.3 and will be removed in 5.0; use Twig instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\FrameworkBundle\\Templating\\Loader\\TemplateLocator.php:14)"} []
[2022-09-21 16:04:53] php.INFO: User Deprecated: The "templating.name_parser" service is deprecated since Symfony 4.3 and will be removed in 5.0. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"templating.name_parser\" service is deprecated since Symfony 4.3 and will be removed in 5.0. at C:\\mapbender\\app\\cache\\dev\\ContainerSuMvwfB\\appAppKernelDevDebugContainer.php:4857)"} []
[2022-09-21 16:04:53] php.INFO: User Deprecated: The Symfony\Bundle\FrameworkBundle\Templating\TemplateNameParser class is deprecated since version 4.3 and will be removed in 5.0; use Twig instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The Symfony\\Bundle\\FrameworkBundle\\Templating\\TemplateNameParser class is deprecated since version 4.3 and will be removed in 5.0; use Twig instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\FrameworkBundle\\Templating\\TemplateNameParser.php:14)"} []
[2022-09-21 16:04:53] php.INFO: User Deprecated: The Symfony\Bundle\TwigBundle\TwigEngine class is deprecated since version 4.3 and will be removed in 5.0; use \Twig\Environment instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The Symfony\\Bundle\\TwigBundle\\TwigEngine class is deprecated since version 4.3 and will be removed in 5.0; use \\Twig\\Environment instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\TwigBundle\\TwigEngine.php:14)"} []
[2022-09-21 16:04:53] php.INFO: User Deprecated: The Symfony\Bridge\Twig\TwigEngine class is deprecated since version 4.3 and will be removed in 5.0; use \Twig\Environment instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The Symfony\\Bridge\\Twig\\TwigEngine class is deprecated since version 4.3 and will be removed in 5.0; use \\Twig\\Environment instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bridge\\Twig\\TwigEngine.php:14)"} []
[2022-09-21 16:04:53] php.INFO: User Deprecated: The Symfony\Bundle\FrameworkBundle\Templating\EngineInterface interface is deprecated since version 4.3 and will be removed in 5.0; use Twig instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The Symfony\\Bundle\\FrameworkBundle\\Templating\\EngineInterface interface is deprecated since version 4.3 and will be removed in 5.0; use Twig instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\FrameworkBundle\\Templating\\EngineInterface.php:14)"} []
[2022-09-21 16:04:53] php.INFO: User Deprecated: Using the "Twig_Extension_StringLoader" class is deprecated since Twig version 2.7, use "Twig\Extension\StringLoaderExtension" instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: Using the \"Twig_Extension_StringLoader\" class is deprecated since Twig version 2.7, use \"Twig\\Extension\\StringLoaderExtension\" instead. at C:\\mapbender\\vendor\\twig\\twig\\lib\\Twig\\Extension\\StringLoader.php:7)"} []
[2022-09-21 16:04:53] php.INFO: Deprecated: Return type of Mapbender\DataSourceBundle\Entity\DataItem::offsetExists($offset) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice {"exception":"[object] (ErrorException(code: 0): Deprecated: Return type of Mapbender\\DataSourceBundle\\Entity\\DataItem::offsetExists($offset) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at C:\\mapbender\\vendor\\mapbender\\data-source\\Entity\\DataItem.php:107)"} []
[2022-09-21 16:04:53] php.INFO: Deprecated: Return type of Mapbender\DataSourceBundle\Entity\DataItem::offsetGet($offset) should either be compatible with ArrayAccess::offsetGet(mixed $offset): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice {"exception":"[object] (ErrorException(code: 0): Deprecated: Return type of Mapbender\\DataSourceBundle\\Entity\\DataItem::offsetGet($offset) should either be compatible with ArrayAccess::offsetGet(mixed $offset): mixed, or the #[\\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at C:\\mapbender\\vendor\\mapbender\\data-source\\Entity\\DataItem.php:112)"} []
[2022-09-21 16:04:53] php.INFO: Deprecated: Return type of Mapbender\DataSourceBundle\Entity\DataItem::offsetSet($offset, $value) should either be compatible with ArrayAccess::offsetSet(mixed $offset, mixed $value): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice {"exception":"[object] (ErrorException(code: 0): Deprecated: Return type of Mapbender\\DataSourceBundle\\Entity\\DataItem::offsetSet($offset, $value) should either be compatible with ArrayAccess::offsetSet(mixed $offset, mixed $value): void, or the #[\\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at C:\\mapbender\\vendor\\mapbender\\data-source\\Entity\\DataItem.php:117)"} []
[2022-09-21 16:04:53] php.INFO: Deprecated: Return type of Mapbender\DataSourceBundle\Entity\DataItem::offsetUnset($offset) should either be compatible with ArrayAccess::offsetUnset(mixed $offset): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice {"exception":"[object] (ErrorException(code: 0): Deprecated: Return type of Mapbender\\DataSourceBundle\\Entity\\DataItem::offsetUnset($offset) should either be compatible with ArrayAccess::offsetUnset(mixed $offset): void, or the #[\\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at C:\\mapbender\\vendor\\mapbender\\data-source\\Entity\\DataItem.php:122)"} []
[2022-09-21 16:04:53] php.INFO: User Deprecated: Auto-injection of the container for "Mapbender\CoreBundle\Controller\ElementController" is deprecated since Symfony 4.2. Configure it as a service instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: Auto-injection of the container for \"Mapbender\\CoreBundle\\Controller\\ElementController\" is deprecated since Symfony 4.2. Configure it as a service instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\FrameworkBundle\\Controller\\ControllerResolver.php:77)"} []
[2022-09-21 16:04:53] php.INFO: Deprecated: rawurlencode(): Passing null to parameter #1 ($string) of type string is deprecated {"exception":"[object] (ErrorException(code: 0): Deprecated: rawurlencode(): Passing null to parameter #1 ($string) of type string is deprecated at C:\\mapbender\\mapbender\\src\\Mapbender\\CoreBundle\\Utils\\UrlUtil.php:156)"} []
[2022-09-21 16:04:53] php.INFO: Deprecated: rawurlencode(): Passing null to parameter #1 ($string) of type string is deprecated {"exception":"[object] (ErrorException(code: 0): Deprecated: rawurlencode(): Passing null to parameter #1 ($string) of type string is deprecated at C:\\mapbender\\mapbender\\src\\Mapbender\\CoreBundle\\Utils\\UrlUtil.php:157)"} []
[2022-09-21 16:04:54] php.CRITICAL: Uncaught Error: DOMDocument::loadXML(): Argument #1 ($source) must not be empty {"exception":"[object] (ValueError(code: 0): DOMDocument::loadXML(): Argument #1 ($source) must not be empty at C:\\mapbender\\mapbender\\src\\Mapbender\\WmsBundle\\Component\\WmsCapabilitiesParser.php:100)"} []
[2022-09-21 16:04:54] php.INFO: User Deprecated: The "twig.exception_listener" service is deprecated since Symfony 4.4. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"twig.exception_listener\" service is deprecated since Symfony 4.4. at C:\\mapbender\\app\\cache\\dev\\ContainerSuMvwfB\\appAppKernelDevDebugContainer.php:5120)"} []
[2022-09-21 16:04:54] php.INFO: User Deprecated: The "Symfony\Component\HttpKernel\EventListener\ExceptionListener" class is deprecated since Symfony 4.4, use "ErrorListener" instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"Symfony\\Component\\HttpKernel\\EventListener\\ExceptionListener\" class is deprecated since Symfony 4.4, use \"ErrorListener\" instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Component\\HttpKernel\\EventListener\\ExceptionListener.php:25)"} []
[2022-09-21 16:04:54] php.INFO: User Deprecated: The "Symfony\Component\HttpKernel\Event\GetResponseForExceptionEvent::getException()" method is deprecated since Symfony 4.4, use "getThrowable()" instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"Symfony\\Component\\HttpKernel\\Event\\GetResponseForExceptionEvent::getException()\" method is deprecated since Symfony 4.4, use \"getThrowable()\" instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Component\\HttpKernel\\Event\\GetResponseForExceptionEvent.php:57)"} []
[2022-09-21 16:04:54] php.INFO: User Deprecated: The "Symfony\Component\Debug\Exception\FatalThrowableError" class is deprecated since Symfony 4.4. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"Symfony\\Component\\Debug\\Exception\\FatalThrowableError\" class is deprecated since Symfony 4.4. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Component\\Debug\\Exception\\FatalThrowableError.php:14)"} []
[2022-09-21 16:04:54] php.INFO: User Deprecated: The "Symfony\Component\Debug\Exception\FatalErrorException" class is deprecated since Symfony 4.4, use "Symfony\Component\ErrorHandler\Error\FatalError" instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"Symfony\\Component\\Debug\\Exception\\FatalErrorException\" class is deprecated since Symfony 4.4, use \"Symfony\\Component\\ErrorHandler\\Error\\FatalError\" instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Component\\Debug\\Exception\\FatalErrorException.php:14)"} []
[2022-09-21 16:04:54] request.CRITICAL: Uncaught PHP Exception ValueError: "DOMDocument::loadXML(): Argument #1 ($source) must not be empty" at C:\mapbender\mapbender\src\Mapbender\WmsBundle\Component\WmsCapabilitiesParser.php line 100 {"exception":"[object] (Symfony\\Component\\Debug\\Exception\\FatalThrowableError(code: 0): DOMDocument::loadXML(): Argument #1 ($source) must not be empty at C:\\mapbender\\mapbender\\src\\Mapbender\\WmsBundle\\Component\\WmsCapabilitiesParser.php:100)"} []
[2022-09-21 16:04:54] php.INFO: User Deprecated: The "twig.controller.exception" service is deprecated since Symfony 4.4. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"twig.controller.exception\" service is deprecated since Symfony 4.4. at C:\\mapbender\\app\\cache\\dev\\ContainerSuMvwfB\\appAppKernelDevDebugContainer.php:1659)"} []
[2022-09-21 16:04:54] php.INFO: User Deprecated: The "Symfony\Bundle\TwigBundle\Controller\ExceptionController" class is deprecated since Symfony 4.4, use "Symfony\Component\HttpKernel\Controller\ErrorController" instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"Symfony\\Bundle\\TwigBundle\\Controller\\ExceptionController\" class is deprecated since Symfony 4.4, use \"Symfony\\Component\\HttpKernel\\Controller\\ErrorController\" instead. at C:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Bundle\\TwigBundle\\Controller\\ExceptionController.php:23)"} []
[2022-09-21 16:04:54] php.INFO: User Deprecated: The template "@Twig/layout.html.twig" is deprecated since Symfony 4.4, will be removed in 5.0. ("@Twig/layout.html.twig" at line 1). {"exception":"[object] (ErrorException(code: 0): User Deprecated: The template \"@Twig/layout.html.twig\" is deprecated since Symfony 4.4, will be removed in 5.0. (\"@Twig/layout.html.twig\" at line 1). at C:\\mapbender\\app\\cache\\dev\\twig\\63\\6315bba44ddfdbac4955b582e1138f64.php:49)"} []
[2022-09-21 16:04:54] php.INFO: User Deprecated: The template "@Twig/exception.css.twig" is deprecated since Symfony 4.4, will be removed in 5.0. ("@Twig/exception.css.twig" at line 1). {"exception":"[object] (ErrorException(code: 0): User Deprecated: The template \"@Twig/exception.css.twig\" is deprecated since Symfony 4.4, will be removed in 5.0. (\"@Twig/exception.css.twig\" at line 1). at C:\\mapbender\\app\\cache\\dev\\twig\\47\\47fbe4b046928577757a22c57baf1d29.php:44)"} []
[2022-09-21 16:04:54] php.INFO: User Deprecated: The template "@Twig/base_js.html.twig" is deprecated since Symfony 4.4, will be removed in 5.0. ("@Twig/base_js.html.twig" at line 1). {"exception":"[object] (ErrorException(code: 0): User Deprecated: The template \"@Twig/base_js.html.twig\" is deprecated since Symfony 4.4, will be removed in 5.0. (\"@Twig/base_js.html.twig\" at line 1). at C:\\mapbender\\app\\cache\\dev\\twig\\c9\\c99ef7872d24f5fb8dc3186dd7425d3a.php:44)"} []
Viele Grüße
Danilo
-----Ursprüngliche Nachricht-----
Von: Mapbender_users <mapbender_users-bounces at lists.osgeo.org> Im Auftrag von Jörg Thomsen (WhereGroup)
Gesendet: Dienstag, 19. Juli 2022 09:43
An: mapbender_users at lists.osgeo.org
Betreff: Re: [Mapbender-users] issues uploading a WMS Service-URL (XML document cannot be parsed)
Am 19.07.22 um 09:17 schrieb de Lima Guimaraes, Danilo:
> Hello Jörg,
> thanks for the fast answer. Unfortunately there are no logs in the logfile.
you might try app_dev.php
https://urldefense.com/v3/__https://doc.mapbender.org/en/installation/installation_configuration.html*production-and-development-environment-and-caching-app-php-and-app-dev-php__;Iw!!AET-MAtkkZz4ZWY!O423SeyVkstTooRMEBMZUbLUr6g4_gYRzP2_KPbn0h4ljEjXfy5qUuWAhzg7hd29C74BxpkzVnJcUmrlplumK2TMlI7j8Hbb$
or at first ask your admin, whether the server is allowed to reach other servers in the internet.
jörg
> Danilo
> Gesendet: Montag, 18. Juli 2022 14:21
> Hello Danilo,
> I guess your Mb-server is not allowed to connect to the wms-server. It is the server, not the client-pc which has to parse the xml.
> Perhaps there are some more hints in mapbenders logfile?
> Jörg
> Am 18.07.22 um 13:41 schrieb de Lima Guimaraes, Danilo:
>> Hello Mapbender-Community,
>> I’m having issues uploading a WMS Service-URL at the “sources”-Tab on
>> Mapbender where it gives me a fail massage with the feedback that the
>> XML document cannot be parsed (“Das XML Dokument kann nicht geparst
>> warden”).
>> This Mapbender 3.3.1 (new) installation was made from MS4W version
>> 4.0.5 which contains Apache 2.4.46 and PHP 7.4.13. I made the same
>> installation on my private computer and it worked.
>> Does anybody else already had this issue? Has anybody any idea, what
>> could have gone wrong by the installation / configuration?
>> Best Regards,
>> Danilo
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> https://urldefense.com/v3/__https://lists.osgeo.org/mailman/listinfo/
>> m
>> apbender_users__;!!AET-MAtkkZz4ZWY!P4HTRWNFduKmprC9EWMqVtI9du5p-9slyi
>> 0 fbuYfwvDKdaAkHJyuPzI9f9NF2jadNM1qIZqN_NxREzcgCI4Vs0zd4oqMklpJ$
> Viele Grüße,
> Jörg Thomsen
> Aufwind durch Wissen!
> Jetzt neu: Web-Seminare und Online-Schulungen bei der
> https://urldefense.com/v3/__http://www.foss-academy.com__;!!AET-MAtkkZ
> z4ZWY!P4HTRWNFduKmprC9EWMqVtI9du5p-9slyi0fbuYfwvDKdaAkHJyuPzI9f9NF2jad
> NM1qIZqN_NxREzcgCI4Vs0zd4po6sQ5y$
> Jörg Thomsen
> WhereGroup GmbH
> Bundesallee 23
> 10717 Berlin
> Germany
> Tel: +49 (0)30 / 5130 278 74
> Fax: +49 (0)30 / 5130 278 11
> joerg.thomsen at wheregroup.com
> https://urldefense.com/v3/__http://www.wheregroup.com__;!!AET-MAtkkZz4
> ZWY!P4HTRWNFduKmprC9EWMqVtI9du5p-9slyi0fbuYfwvDKdaAkHJyuPzI9f9NF2jadNM
> 1qIZqN_NxREzcgCI4Vs0zd4nKPsBPu$
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Folgen Sie der WhereGroup auf twitter:
> https://urldefense.com/v3/__http://twitter.com/WhereGroup_com__;!!AET-
> MAtkkZz4ZWY!P4HTRWNFduKmprC9EWMqVtI9du5p-9slyi0fbuYfwvDKdaAkHJyuPzI9f9
> NF2jadNM1qIZqN_NxREzcgCI4Vs0zd4rTmAQad$
> https://urldefense.com/v3/__https://lists.osgeo.org/mailman/listinfo/m
> apbender_users__;!!AET-MAtkkZz4ZWY!P4HTRWNFduKmprC9EWMqVtI9du5p-9slyi0
> apbender_users__;!!AET-MAtkkZz4ZWY!O423SeyVkstTooRMEBMZUbLUr6g4_gYRzP2
> _KPbn0h4ljEjXfy5qUuWAhzg7hd29C74BxpkzVnJcUmrlplumK2TMlJMeijvO$
Viele Grüße,
Jörg Thomsen
Jetzt neu: Web-Seminare und Online-Schulungen bei der https://urldefense.com/v3/__http://www.foss-academy.com__;!!AET-MAtkkZz4ZWY!O423SeyVkstTooRMEBMZUbLUr6g4_gYRzP2_KPbn0h4ljEjXfy5qUuWAhzg7hd29C74BxpkzVnJcUmrlplumK2TMlKa3D7DO$
Jörg Thomsen
WhereGroup GmbH
Bundesallee 23
10717 Berlin
Germany
https://urldefense.com/v3/__http://www.wheregroup.com__;!!AET-MAtkkZz4ZWY!O423SeyVkstTooRMEBMZUbLUr6g4_gYRzP2_KPbn0h4ljEjXfy5qUuWAhzg7hd29C74BxpkzVnJcUmrlplumK2TMlPp7i4gu$
Geschäftsführer:
Folgen Sie der WhereGroup auf twitter: https://urldefense.com/v3/__http://twitter.com/WhereGroup_com__;!!AET-MAtkkZz4ZWY!O423SeyVkstTooRMEBMZUbLUr6g4_gYRzP2_KPbn0h4ljEjXfy5qUuWAhzg7hd29C74BxpkzVnJcUmrlplumK2TMlGuwtCT0$
https://urldefense.com/v3/__https://lists.osgeo.org/mailman/listinfo/mapbender_users__;!!AET-MAtkkZz4ZWY!O423SeyVkstTooRMEBMZUbLUr6g4_gYRzP2_KPbn0h4ljEjXfy5qUuWAhzg7hd29C74BxpkzVnJcUmrlplumK2TMlJMeijvO$
More information about the Mapbender_users
