[Mapbender-users] Encountering a problem while attempting to display data from multiple dates simultaneously using the time dimension handler
Marcin Niemyjski
mniemyjski at cloudferro.com
Mon Aug 7 05:06:21 PDT 2023
Hello,
I encountered a problem while adding a WMS containing an active time dimension. Specifically, I am only able to navigate along the time axis day by day. However, I would like to navigate using a time range, for example, displaying data from a weekly period. Is this possible?
This is my mapfile (for understanding how I configured the time dimension):
https://pastecode.io/s/hbcz3z7p
and WMS url:
http://64.225.135.141.nip.io/?map=/etc/mapserver/piramida_cloudless.map
Also, I do not understand why in mapbender I cannot select other query types than nearest?
WMS instance configuration tab:
https://pasteboard.co/lxatPoUo2vtL.png
So basically, what I want to achieve is to have ability to get data from multiple dates using time slider (time dimension handler).
Best,
Marcin
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20230807/db3f75f9/attachment.htm>
More information about the Mapbender_users
