[Mapbender-users] Example simple search OGC
Tjiko Schutte tjikoschutte at hotmail.com
Tue Feb 14 02:05:34 PST 2023
Still have some questions about simple search. Hope someone can help.
I have the basic running. But I'm not sure how to implement the query.
I have this for the query url:
https://geoserver.igoview.nl/geoserver/ogc/features/collections/OD_EXTERN:GEO_VEEHOUDERIJEN_BRABANT/items?f=json&limit=10&filter=Bedrijfstype%3D%27Melkrundvee%27&
In the end melkrundvee should be the query value (in between the %27 and %27).
But again not sure how to configure this. When I put q there. It doesnt do anything.
A seperate question.
Is filtering also possible. For example I have a map with 9000 points.
3000 have value A, 3000 value B and 3000 value C.
Can I filter (not search) the map on only value B.
So the points on the map will be reduced to 3000 (and not 9000).
Thanks in advance.
Kind regards,
Tjiko Schutte
-----Oorspronkelijk bericht-----
Van: Mapbender_users <mapbender_users-bounces at lists.osgeo.org> Namens Astrid Emde (WhereGroup)
Verzonden: maandag 23 januari 2023 08:47
Aan: Mapbender User List <mapbender_users at lists.osgeo.org>
Onderwerp: Re: [Mapbender-users] Example simple search OGC
Hello Tjiko,
you are welcome to give feedback.
I guess that OGC API Feature is getting more and more popular. And it is great that Mapbender already allows to use OGC API Feature for searching.
Best regards
Astrid Emde
Am 2023-01-18 13:59, schrieb Tjiko Schutte:
> Thanks will try this.
> Verzonden: woensdag 18 januari 2023 13:10
> Hello,
> here is a blog article about Simple Search
> https://wheregroup.com/blog/details/mapbender-bietet-neue-suchmoeglich
> keiten-mit-dem-such-element-simplesearch/
> You find an OGC API Configuration in the workshop bundle see
> https://github.com/mapbender/mapbender-workshop/blob/master/app/config
> /applications/mapbender_demo_nrw_simple_search_api_feature.yml#L248
> It uses an OGC API Feature Servive from NRW
> https://ogc-api.nrw.de/lika/v1/
> https://ogc-api.nrw.de/lika/v1/collections/verwaltungseinheit/items?f=
> json&limit=100
> Hope the information helps
> Best regards
> Astrid Emde
> Am 2023-01-18 09:22, schrieb Tjiko Schutte:
>> Goodmorning,
>> We use mapbender and have multiple geoserver maps.
>> I want to implement simple search but I can't figure out how to do
>> this.
>> I checked the documentation:
>> https://doc.mapbender.org/en/functions/search/simplesearch.html
>> This should work 'Several projects support OGC API Features like
>> QGIS, GeoServer, pygeoapi.'
>> Does anyone have a simple example of step by step guide?
>> When I check the layer/map in geoserver I can set the OGC filter like
>> this:
>> '<Filter><PropertyIsEqualTo><PropertyName>Color</PropertyName><Literal>Blue</Literal></PropertyIsEqualTo></Filter>'
>> Kind regards,
>> Tjiko Schutte
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
> Aufwind durch Wissen!
> Web-Seminare und Online-Schulungen
> bei der www.foss-academy.com/
>    Astrid Emde
>    WhereGroup GmbH
>    Eifelstraße 7
>    53119 Bonn
>    Germany
>    Tel: +49(0)228 90 90 38 - 22
>    Fax: +49(0)228 90 90 38 - 11
>    astrid.emde at wheregroup.com
>    www.wheregroup.com
>    Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
> https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
>    Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>    Folgen Sie der WhereGroup auf twitter:
>    http://twitter.com/WhereGroup_com
>    Geschäftsführer:
>    Olaf Knopp, Peter Stamm
>    Amtsgericht Bonn, HRB 9885
Astrid Emde
GIS-Consultant
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   www.wheregroup.com
   Geschäftsführer:
More information about the Mapbender_users mailing list
