[Mapbender-users] Mapbender Version 3.3.4 released 2023-05-03
Tjiko Schutte
tjikoschutte at hotmail.com
Thu May 25 22:55:46 PDT 2023
Hi Astrid,
Thank you for the reply.
I will try to manualy replace the files.
I already deleted the cache. That didn't work.
Kind regards,
Tjiko Schutte
-----Oorspronkelijk bericht-----
Van: Mapbender_users <mapbender_users-bounces at lists.osgeo.org> Namens Astrid Emde (WhereGroup)
Verzonden: vrijdag 26 mei 2023 07:53
Aan: Mapbender Users <mapbender_users at lists.osgeo.org>
CC: Mapbender Developer List <mapbender_dev at lists.osgeo.org>
Onderwerp: Re: [Mapbender-users] Mapbender Version 3.3.4 released 2023-05-03
Hello,
the translations come from the translation files located for example at
https://github.com/mapbender/mapbender/blob/master/src/Mapbender/CoreBundle/Resources/translations/
https://github.com/mapbender/mapbender/blob/master/src/Mapbender/CoreBundle/Resources/translations/messages.de.yml
It looks like the text that you refer to is there.
Maybe delete the cache and try again.
See you Astrid Emde
Am 2023-05-15 08:20, schrieb Tjiko Schutte:
> Goodmorning,
> After updating mapbender to this version 2 buttons in object
> information don't have a label: (mb.actions.print and
> mb.actions.close).
> How can I fix this?
> Kind regards,
> Tjiko Schutte
> Verzonden: woensdag 3 mei 2023 14:24
> Aan: Mapbender Users <mapbender_users at lists.osgeo.org>; Mapbender
> Onderwerp: [Mapbender-users] Mapbender Version 3.3.4 released
> 2023-05-03
> ============= Deutsch ===============
> Hallo Mapbender-Community,
> das Mapbender-Entwicklungsteam hat die neue Mapbender-Version 3.3.4
> veröffentlicht. Herzlichen Dank an alle Beteiligten.
> Die neue Version enthält neben vielen Bugfixes auch einige neue
> Features.
> Folgende sollen an dieser Stelle hervorgehoben werden:
> - WMS Update verfügt über 2 neue Optionen, die steuern, ob neue Layer
> in bestehenden Konfigurationen aktiviert/selektiert werden sollen.
> Diese Optionen sind über das Administration-Backend und ebenso über
> die app/console-Befehle wms:reload:file und wms:reload:file verfügbar.
> Siehe auch
> https://doc.mapbender.org/en/customization/commands.html#app-console-m
> apbender-wms-reload-url
> [1]
> - Setzen des Status von Layersets. Sofern thematische Layer verwendet
> werden, kann der Status der thematischen Layers gesetzt werden, d.h.
> Thematische Layer können beim Start ausgewählt oder nicht ausgewählt
> sein. Dies wird über eine zusätzliche Option beim Layerset definiert.
> - Das Element Einfache Suche (SimpleSearch) wurde verbessert. Es
> ermöglicht nun die Definition von mehreren Suchen, die in der
> Anwendung ausgewählt werden können. Das Kopieren von einzelnen Suchen
> im Element ist möglich. Das Element unterstützt nun auch die Anzeige
> von Polygonen und Linien. Außerdem können Suchtreffer aus der Karte
> entfernt werden.
> (PR#1446)
> - Mapbender liegt nun auch auf Ukrainisch vor. Sie können auch weitere
> Sprachen hinzufügen oder neue Features in bestehenden Sprachen
> übersetzen. Folgen Sie der Anleitung unter
> https://doc.mapbender.org/en/architecture/translation.html [2]
> - Anzeige einer Symbolvorschau in der Symbolauswahl in den Elementen
> Button und Link (PR#1450)
> - [LayerTree] Das Sortieren von Layern ist nun auch auf mobilen
> Geräten möglich (PR#1457)
> - [SearchRouter] Wenn nur ein Ergebnis vorliegt, wird jetzt
> automatisch auf dieses Ergebnis gezoomt (PR#1454)
> - [ScaleSelect], [ScaleDisplay] Zahlen werden jetzt mit
> Tausendertrennzeichen formatiert. (PR#1453)
> - [Ruler] Ein optionaler Hilfetext wurde hinzugefügt. Alle Farben und
> die Schriftgröße sind jetzt konfigurierbar (PR#1463)
> Das vollständige Changelog findet sich auf GitHub [1].
> Eine Übersicht mit ausführlichen Erklärungen und Screenshots folgt in
> Kürze unter [4].
> Umstieg auf die neue Version
> Wir empfehlen ein Update auf die Mapbender Version 3.3.4 und wünschen
> Ihnen viel Spaß mit der neuen Version.
> Bitte beachten Sie, dass der Migrationsleitfaden in die Dokumentation
> [2] übertragen wurde. Er enthält zusätzliche Hinweise für das Update
> auf
> neue Versionen.
> Alle weiteren wichtigen Informationen sowie Links zum Download und zur
> Doku finden sich auf der Mapbender-Webseite [3].
> Was kommt als Nächstes
> Das Mapbender Team plant als Nächstes eine umfassende Überarbeitung
> des
> Codes und eine Aktualisierung der Komponenten wie z.B. Symfony,
> Bootstrap und jQuery. Außerdem soll die Unterstützung von OGC API
> Features als neuer Datenquelle erfolgen. Die Anpassungen werden einige
> Zeit in Anspruch nehmen, so dass erst Ende 2023 mit einer neuen
> Major-Version zu rechnen ist.
> Kommen Sie gerne auf uns zu, wenn Sie die Entwicklung unterstützen
> möchten.
> Viel Spaß mit der neuen Version wünscht
> Das Mapbender Team
> [1] https://github.com/mapbender/mapbender-starter/releases/tag/v3.3.4
> [3]
> [2] https://doc.mapbender.org/en/installation/migration.html [4]
> [3] https://mapbender.org/ [5]
> [4] https://mapbender.org/aktuelles/ [6]
> ============ English =================
> Hello Mapbender community,
> the Mapbender development team has released the new Mapbender version
> 3.3.4. Thank you to everyone involved.
> In addition to many bug fixes, the new version also contains some new
> features.
> The following should be highlighted at this point:
> - WMS update has 2 new options that control whether to enable and
> select
> new layers in existing instances. These options are available via the
> administration backend and also via the app/console commands
> wms:reload:file and wms:reload:file. See also
> [1]
> - Setting the state of layer sets. If thematic layers are used, the
> state of the thematic layer can be set. I.e. thematic layers can be
> displayed as selected or not selected at startup. This is defined by
> an
> additional checkbox option in the backend.
> - The SimpleSearch element has been improved. It now allows defining
> multiple searches that can be selected in the application. Duplicating
> individual search configurations in the element is possible. The
> element
> now supports displaying polygons and lines. In addition, search hits
> can
> be removed from the map. (PR#1446)
> - Ukranian translations is available. You are welcome to add another
> language to Mapbender or translate new features into the existing
> languages. Please follow the instruction at
> - Icon previews are now shown in the icon selection dropdown in the
> button and link element
> ([PR#1450](https://github.com/mapbender/mapbender/pull/1450) [7])
> - [LayerTree] Sorting layers is now also possible on mobile devices
> (PR#1457)
> - [SearchRouter] When a search yields only a single result, the maps
> now
> zooms in on it automatically (PR#1454)
> - [ScaleSelect], [ScaleDisplay] Numbers are now formatted with
> thousand
> separators (PR#1453)
> - [Ruler] Added optional help text. All colors and the font size are
> now
> configurable (PR#1463)
> The full change log can be found on GitHub. [1]
> An overview with detailed explanations and screenshots will follow
> soon
> at [4].
> Upgrade to the new version
> We recommend an update to Mapbender version 3.3.4 and wish you a lot
> of
> fun with the new version.
> Please note that the migration guide moved to the documentation [2].
> It
> gives additional advise for the update to the new version.
> All important information as well as links for download and
> documentation can be found on the Mapbender website. [3]
> What's next
> The Mapbender team is planning a major code overhaul and an update of
> components such as Symfony, Bootstrap and jQuery next. There will also
> be support for OGC API features as a new data source. The adjustments
> will take some time, therefore, a new major version is not to be
> expected until the end of 2023.
> Feel free to contact us if you would like to support the development.
> We wish you a lot of fun with the new version
> The Mapbender Team
> [1] https://github.com/mapbender/mapbender/releases/tag/v3.3.4 [8]
> Links:
> [1]
> apbender-wms-reload-url [2]
> [3] https://github.com/mapbender/mapbender-starter/releases/tag/v3.3.4
> [4] https://doc.mapbender.org/en/installation/migration.html
> [5] https://mapbender.org/
> [6] https://mapbender.org/aktuelles/
> [7] https://github.com/mapbender/mapbender/pull/1450)
> [8] https://github.com/mapbender/mapbender/releases/tag/v3.3.4
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei der www.foss-academy.com/
Astrid Emde
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
Tel: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
astrid.emde at wheregroup.com
www.wheregroup.com
Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the Mapbender_users
