[Mapbender-users] Mapbender Version 3.3.4 released 2023-05-03
Tjiko Schutte
tjikoschutte at hotmail.com
Thu May 25 23:38:38 PDT 2023
Hi Astrid,
That's correct.
Kind regards,
Tjiko
-----Oorspronkelijk bericht-----
Van: Mapbender_users <mapbender_users-bounces at lists.osgeo.org> Namens Astrid Emde (WhereGroup)
Verzonden: vrijdag 26 mei 2023 08:09
Aan: Mapbender User List <mapbender_users at lists.osgeo.org>
Onderwerp: Re: [Mapbender-users] Mapbender Version 3.3.4 released 2023-05-03
Hello Tjiko,
which element does not show the translation? Is it in the featureInfo dialog?
Astrid
Am 2023-05-26 07:55, schrieb Tjiko Schutte:
> Hi Astrid,
> Thank you for the reply.
> I will try to manualy replace the files.
> I already deleted the cache. That didn't work.
> Kind regards,
> Tjiko Schutte
> Verzonden: vrijdag 26 mei 2023 07:53
> Aan: Mapbender Users <mapbender_users at lists.osgeo.org>
> CC: Mapbender Developer List <mapbender_dev at lists.osgeo.org>
> 2023-05-03
> Hello,
> the translations come from the translation files located for example
> at
> https://github.com/mapbender/mapbender/blob/master/src/Mapbender/CoreB
> undle/Resources/translations/
> undle/Resources/translations/messages.de.yml
> It looks like the text that you refer to is there.
> Maybe delete the cache and try again.
> See you Astrid Emde
> Am 2023-05-15 08:20, schrieb Tjiko Schutte:
>> Goodmorning,
>> After updating mapbender to this version 2 buttons in object
>> information don't have a label: (mb.actions.print and
>> mb.actions.close).
>> How can I fix this?
>> Kind regards,
>> Tjiko Schutte
>> Verzonden: woensdag 3 mei 2023 14:24
>> Aan: Mapbender Users <mapbender_users at lists.osgeo.org>; Mapbender
>> Onderwerp: [Mapbender-users] Mapbender Version 3.3.4 released
>> 2023-05-03
>> ============= Deutsch ===============
>> Hallo Mapbender-Community,
>> das Mapbender-Entwicklungsteam hat die neue Mapbender-Version 3.3.4
>> veröffentlicht. Herzlichen Dank an alle Beteiligten.
>> Die neue Version enthält neben vielen Bugfixes auch einige neue
>> Features.
>> Folgende sollen an dieser Stelle hervorgehoben werden:
>> - WMS Update verfügt über 2 neue Optionen, die steuern, ob neue Layer
>> in bestehenden Konfigurationen aktiviert/selektiert werden sollen.
>> Diese Optionen sind über das Administration-Backend und ebenso über
>> die app/console-Befehle wms:reload:file und wms:reload:file verfügbar.
>> Siehe auch
>> https://doc.mapbender.org/en/customization/commands.html#app-console-
>> m
>> apbender-wms-reload-url
>> [1]
>> - Setzen des Status von Layersets. Sofern thematische Layer verwendet
>> werden, kann der Status der thematischen Layers gesetzt werden, d.h.
>> Thematische Layer können beim Start ausgewählt oder nicht ausgewählt
>> sein. Dies wird über eine zusätzliche Option beim Layerset definiert.
>> - Das Element Einfache Suche (SimpleSearch) wurde verbessert. Es
>> ermöglicht nun die Definition von mehreren Suchen, die in der
>> Anwendung ausgewählt werden können. Das Kopieren von einzelnen Suchen
>> im Element ist möglich. Das Element unterstützt nun auch die Anzeige
>> von Polygonen und Linien. Außerdem können Suchtreffer aus der Karte
>> entfernt werden.
>> (PR#1446)
>> - Mapbender liegt nun auch auf Ukrainisch vor. Sie können auch
>> weitere Sprachen hinzufügen oder neue Features in bestehenden
>> Sprachen übersetzen. Folgen Sie der Anleitung unter
>> https://doc.mapbender.org/en/architecture/translation.html [2]
>> - Anzeige einer Symbolvorschau in der Symbolauswahl in den Elementen
>> Button und Link (PR#1450)
>> - [LayerTree] Das Sortieren von Layern ist nun auch auf mobilen
>> Geräten möglich (PR#1457)
>> - [SearchRouter] Wenn nur ein Ergebnis vorliegt, wird jetzt
>> automatisch auf dieses Ergebnis gezoomt (PR#1454)
>> - [ScaleSelect], [ScaleDisplay] Zahlen werden jetzt mit
>> Tausendertrennzeichen formatiert. (PR#1453)
>> - [Ruler] Ein optionaler Hilfetext wurde hinzugefügt. Alle Farben und
>> die Schriftgröße sind jetzt konfigurierbar (PR#1463)
>> Das vollständige Changelog findet sich auf GitHub [1].
>> Eine Übersicht mit ausführlichen Erklärungen und Screenshots folgt in
>> Kürze unter [4].
>> Umstieg auf die neue Version
>> Wir empfehlen ein Update auf die Mapbender Version 3.3.4 und wünschen
>> Ihnen viel Spaß mit der neuen Version.
>> Bitte beachten Sie, dass der Migrationsleitfaden in die Dokumentation
>> [2] übertragen wurde. Er enthält zusätzliche Hinweise für das Update
>> auf
>> neue Versionen.
>> Alle weiteren wichtigen Informationen sowie Links zum Download und
>> zur
>> Doku finden sich auf der Mapbender-Webseite [3].
>> Was kommt als Nächstes
>> Das Mapbender Team plant als Nächstes eine umfassende Überarbeitung
>> des
>> Codes und eine Aktualisierung der Komponenten wie z.B. Symfony,
>> Bootstrap und jQuery. Außerdem soll die Unterstützung von OGC API
>> Features als neuer Datenquelle erfolgen. Die Anpassungen werden
>> einige
>> Zeit in Anspruch nehmen, so dass erst Ende 2023 mit einer neuen
>> Major-Version zu rechnen ist.
>> Kommen Sie gerne auf uns zu, wenn Sie die Entwicklung unterstützen
>> möchten.
>> Viel Spaß mit der neuen Version wünscht
>> Das Mapbender Team
>> [1]
>> https://github.com/mapbender/mapbender-starter/releases/tag/v3.3.4
>> [3]
>> [2] https://doc.mapbender.org/en/installation/migration.html [4]
>> [3] https://mapbender.org/ [5]
>> [4] https://mapbender.org/aktuelles/ [6]
>> ============ English =================
>> Hello Mapbender community,
>> the Mapbender development team has released the new Mapbender version
>> 3.3.4. Thank you to everyone involved.
>> In addition to many bug fixes, the new version also contains some new
>> features.
>> The following should be highlighted at this point:
>> - WMS update has 2 new options that control whether to enable and
>> select
>> new layers in existing instances. These options are available via the
>> administration backend and also via the app/console commands
>> wms:reload:file and wms:reload:file. See also
>> m
>> [1]
>> - Setting the state of layer sets. If thematic layers are used, the
>> state of the thematic layer can be set. I.e. thematic layers can be
>> displayed as selected or not selected at startup. This is defined by
>> an
>> additional checkbox option in the backend.
>> - The SimpleSearch element has been improved. It now allows defining
>> multiple searches that can be selected in the application.
>> Duplicating
>> individual search configurations in the element is possible. The
>> element
>> now supports displaying polygons and lines. In addition, search hits
>> can
>> be removed from the map. (PR#1446)
>> - Ukranian translations is available. You are welcome to add another
>> language to Mapbender or translate new features into the existing
>> languages. Please follow the instruction at
>> - Icon previews are now shown in the icon selection dropdown in the
>> button and link element
>> ([PR#1450](https://github.com/mapbender/mapbender/pull/1450) [7])
>> - [LayerTree] Sorting layers is now also possible on mobile devices
>> (PR#1457)
>> - [SearchRouter] When a search yields only a single result, the maps
>> now
>> zooms in on it automatically (PR#1454)
>> - [ScaleSelect], [ScaleDisplay] Numbers are now formatted with
>> thousand
>> separators (PR#1453)
>> - [Ruler] Added optional help text. All colors and the font size are
>> now
>> configurable (PR#1463)
>> The full change log can be found on GitHub. [1]
>> An overview with detailed explanations and screenshots will follow
>> soon
>> at [4].
>> Upgrade to the new version
>> We recommend an update to Mapbender version 3.3.4 and wish you a lot
>> of
>> fun with the new version.
>> Please note that the migration guide moved to the documentation [2].
>> It
>> gives additional advise for the update to the new version.
>> All important information as well as links for download and
>> documentation can be found on the Mapbender website. [3]
>> What's next
>> The Mapbender team is planning a major code overhaul and an update of
>> components such as Symfony, Bootstrap and jQuery next. There will
>> also
>> be support for OGC API features as a new data source. The adjustments
>> will take some time, therefore, a new major version is not to be
>> expected until the end of 2023.
>> Feel free to contact us if you would like to support the development.
>> We wish you a lot of fun with the new version
>> The Mapbender Team
>> [1] https://github.com/mapbender/mapbender/releases/tag/v3.3.4 [8]
>> Links:
>> [1]
>> m
>> apbender-wms-reload-url [2]
>> [3]
>> [4] https://doc.mapbender.org/en/installation/migration.html
>> [5] https://mapbender.org/
>> [6] https://mapbender.org/aktuelles/
>> [7] https://github.com/mapbender/mapbender/pull/1450)
>> [8] https://github.com/mapbender/mapbender/releases/tag/v3.3.4
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
> Aufwind durch Wissen!
> Web-Seminare und Online-Schulungen
> bei der www.foss-academy.com/
> Astrid Emde
> WhereGroup GmbH
> Eifelstraße 7
> 53119 Bonn
> Germany
> Tel: +49(0)228 90 90 38 - 22
> Fax: +49(0)228 90 90 38 - 11
> astrid.emde at wheregroup.com
> www.wheregroup.com
> Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
> https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
> Folgen Sie der WhereGroup auf twitter:
> http://twitter.com/WhereGroup_com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
Astrid Emde
GIS-Consultant
Astrid Emde
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
www.wheregroup.com
Geschäftsführer:
More information about the Mapbender_users
