[Mapbender-users] Antw: Vortragsfolien QGIS2Mapbender sind online | Where2B Konferenz 2024
Daniel Grohmann Daniel.Grohmann at va.magdeburg.de
Fri Dec 13 02:52:01 PST 2024
Hallo Astrid,
nachdem ich gestern deinen Vortrag gesehen hatte, habe ich mir das
PlugIn QGIS2Mapbender (aus dem Repository) installiert.
Es kam sofort eine Fehlermeldung, dass das Modul "fabric2" nicht
installiert sei.
Mit
import pip
pip.main(['install', 'fabric2'])
in der Python-Console erschienen die folgenden Fehler:
import pip
WARNING: pip is being invoked by an old script wrapper. This will fail
in a future version of pip.
Please see https://github.com/pypa/pip/issues/5599 for advice on fixing
the underlying issue.
To avoid this problem you can invoke Python with '-m pip' instead of
running pip directly.
WARNING: Retrying (Retry(total=4, connect=None, read=None,
redirect=None, status=None)) after connection broken by
'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection
object at 0x0000011AB12BEF00>: Failed to establish a new connection:
[Errno 11001] getaddrinfo failed')': /simple/fabric2/
WARNING: Retrying (Retry(total=3, connect=None, read=None,
object at 0x0000011AB1042870>: Failed to establish a new connection:
WARNING: Retrying (Retry(total=2, connect=None, read=None,
object at 0x0000011AB12DC2F0>: Failed to establish a new connection:
WARNING: Retrying (Retry(total=1, connect=None, read=None,
object at 0x0000011AB12DC500>: Failed to establish a new connection:
WARNING: Retrying (Retry(total=0, connect=None, read=None,
object at 0x0000011AB12DC710>: Failed to establish a new connection:
ERROR: Could not find a version that satisfies the requirement fabric2
(from versions: none)
ERROR: No matching distribution found for fabric2
Anscheinend ist mit Python oder pip etwas nicht in Ordnung.
Ich verwende folgende QGIS-Umgebung (installiert über osgeo4w-setup):
QGIS-Version
3.38.3-Grenoble
QGIS-Codeversion
37f9e6efee
Qt-Version
5.15.13
Python-Version
3.12.6
GDAL-Version
3.9.2
PROJ-Version
9.4.0
EPSG-Registraturdatenbankversion
v11.004 (2024-02-24)
GEOS-Version
3.12.2-CAPI-1.18.2
SQLite-Version
3.45.1
PDAL-Version
2.6.3
PostgreSQL-Client-Version
16.2
SpatiaLite-Version
5.1.0
QWT-Version
6.2.0
QScintilla2-Version
2.14.1
BS-Version
Windows 10 Version 1809
Beste Grüße
Daniel Grohmann
"Astrid Emde (WhereGroup) via Mapbender_users"
<mapbender_users at lists.osgeo.org> schrieb am 13.12.2024 um 10:20:
Hallo,
gestern fand die Where2B Konferenz 2024 in Bonn | Online statt.
https://where2b-conference.com/
Ich habe dort in einem Vortrag das QGIS Plugin
QGIS2Mapbendervorgestellt, mit dem ganz einfach QGIS Projekte
veröffentlicht und in Mapbender eingebunden werden können.
Die Folien finden sich auf GitHub unter
https://github.com/astroidex/presentations/blob/master/Where2B2024/Where2B_2024_QGIS2Mapbender_Astrid_Emde.pdf
Die Folien werden bald auch im Archiv der Where2B Konferenz verlinkt
https://where2b-conference.com/archiv/
Ich hoffe, dass das Plugin QGIS2Mapbender den Prozess der
Veröffentlichung von Diensten vereinfachen wird und freue mich über
Rückmeldung und Ideen zum neuen Plugin.
Anbei auch noch der Link zur ReadMe mit Hinweisen zur Einrichtuung
(derzeit wird noch fabric2 benötigt)
https://github.com/WhereGroup/QGIS2Mapbender/blob/main/README.md
Und hier noch Links zu den Vorträgen der letzen Jahr auf der Where2B
In 2023 gab es einen Vortrag zum Thema "Mapbender 4 – spannende
Features
des neuen Major Release".
https://github.com/astroidex/presentations/blob/master/Where2B2023/Where2B_2023_Mapbender_Version_4_Astrid_Emde.pdf
In 2022 gab es einen Vortrag zum Thema "Versteckte Schätze - neue und
weniger bekannter Feature in Mapbender".
https://where2b-conference.com/fileadmin/where2b/resources/documets/archive/2022/Where2B_2022_Mapbender_Astrid_Emde_HK_compressed.pdf
english
Hello,
yesterday the Where2B Conference 2024 took place in Bonn | Online.
In a presentation there I presented the QGIS plugin QGIS2Mapbender,
with
which QGIS projects can be easily published and integrated into
Mapbender.
The slides can be found on GitHub at
The slides will soon also be linked in the archive of the Where2B
conference
I hope that the QGIS2Mapbender plugin will simplify the process of
publishing services and look forward to receiving feedback and ideas on
the new plugin.
Here is also the link to the ReadMe with instructions on how to set it
up (currently fabric2 is still required)
And here are links to last year's presentations at Where2B
In 2023 there was a presentation on “Mapbender 4 - exciting features of
the new major release”.
In 2022 there was a presentation on “Hidden treasures - new and lesser
known features in Mapbender”.
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Where2B 2024 - die Open-Source-GIS-Konferenz
12. Dezember 2024 vor Ort in Bonn und online
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   Tel: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   astrid.emde at wheregroup.com
   www.wheregroup.com
   Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
   Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
   Geschäftsführer:
   Olaf Knopp, Peter Stamm
   Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20241213/f5e8bdbc/attachment.htm>
More information about the Mapbender_users mailing list
