[Mapbender-users] Can't add a new source or update an existing source
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Tue Mar 5 23:08:39 PST 2024
Hello,
please delete the cached files in the directory mapbender/app/cache/
After that the applications should not be there anymore.
Astrid
Am 2024-03-05 19:56, schrieb Joel Blizzard:
> I've done both of those things, my application folder is empty, but
> still they show up? Is there a different place these could be pulled
> from?
> They don't appear once I am logged into Mapbender, but on the
> Applications page which is displayed before logging in I see them. Is
> that normal? No way to remove them from that initial page?
> On Tue, Mar 5, 2024 at 11:25 AM Astrid Emde (WhereGroup) via
> Mapbender_users <mapbender_users at lists.osgeo.org> wrote:
>> Hello,
>> you could remove the files from the applications folder.
>> Maybe keep the files somewhere so if you need them you can restore
>> them.
>> In the yml files you find published: true (see row 7). Here you
>> could
>> change the setting to false.
>> See you Astrid
>> Am 2024-03-05 17:43, schrieb Joel Blizzard:
>>> That seems to have resolved the issue.
>>> Although after the upgrade, I cannot seem to disable the demo
>>> applications from the applications list (prior to logging in). I
>> have
>>> changed visibility to false in the yml files, cleared prod cache,
>> and
>>> then even deleted the .yml files from /app/config/applications,
>> and
>>> still they show up. Is there a different way to disable these now?
>> I
>>> don't want them showing up in the list of applications.
>>> Thanks,
>>> -Joel
>>> On Wed, Feb 28, 2024 at 7:54 AM Astrid Emde (WhereGroup)
>>> <astrid.emde at wheregroup.com> wrote:
>>>> Hallo,
>>>> es gab mal einen Bug in der Richtung
>>>> https://github.com/mapbender/mapbender/issues/1441
>>>> Am Besten du aktualisierst auf die Version 3.3.5
>> https://doc.mapbender.org/de/installation/installation_update.html
>>>> Viele Grüße
>>>> Astrid Emde
>>>> Am 2024-02-28 14:45, schrieb Joel Blizzard:
>>>>> I am running 3.3.3. Is this some kind of bug related to this
>>>> version?
>>>>> On Wed, Feb 28, 2024 at 2:13 AM Astrid Emde (WhereGroup)
>>>>>> Hello Joel,
>>>>>> which version of Mapbender do you use?
>>>>>> The error should not occur with Mapbender 3.3.5.
>>>>>> See you Astrid
>>>>>> Am 2024-02-27 23:21, schrieb Joel Blizzard via Mapbender_users:
>>>>>>> Hello,
>>>>>>> When I go into the sources section of Mapbender and try to add
>> a
>>>>>> new
>>>>>>> source I get the message:
>>>>>>> Unrecognized boolean literal "
>>>>>>> When I go into dev mode to look at the messages after I get
>> this
>>>>>>> error, it says there are 4 missing messages
>>>>>>> (These messages are not available for the given locale and
>>>> cannot
>>>>>> be
>>>>>>> found in the fallback locales. Add them to the translation
>>>>>> catalogue
>>>>>>> to avoid Symfony outputting untranslated contents. )
>>>>>>> en
>>>>>>> messages
>>>>>>> 1
>>>>>>> Unrecognized boolean literal ''
>>>>>>> en
>>>>>>> messages
>>>>>>> 3
>>>>>>> OGC WMS
>>>>>>> OGC WMS
>>>>>>> en
>>>>>>> messages
>>>>>>> 2
>>>>>>> OGC WMTS / TMS
>>>>>>> OGC WMTS / TMS
>>>>>>> en
>>>>>>> messages
>>>>>>> 1
>>>>>>> The GetCapabilities url
>>>>>>> Does anyone know what might be happening here? Maybe there is
>> a
>>>>>> more
>>>>>>> comprehensive way I could be using Dev mode?
>>>>>>> _______________________________________________
>>>>>>> Mapbender_users mailing list
>>>>>>> Mapbender_users at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
>>>>>> Mit freundlichen Grüßen
>>>>>> Astrid Emde
>>>>>> GIS-Consultant
>>>>>> FOSSGIS Konferenz
>>>>>> 20.-23. März 2024 in Hamburg
>>>>>> https://www.fossgis-konferenz.de/2024/
>>>>>> WhereGroup-Beiträge auf der FOSSGIS
>>>>>> https://wheregroup.com/unternehmen/aktuelles/
>>>>>> Astrid Emde
>>>>>> WhereGroup GmbH
>>>>>> Eifelstraße 7
>>>>>> 53119 Bonn
>>>>>> Germany
>>>>>> Tel: +49(0)228 90 90 38 - 22
>>>>>> Fax: +49(0)228 90 90 38 - 11
>>>>>> www.wheregroup.com [1] [1] [1]
>>>>>> Meinen PGP Public-Key können Sie unter pgp.mit.edu [2] [2] [2]
>>>>>> herunterladen:
> https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
>>>>>> Signierte und/oder verschlüsselte Nachrichten sind sehr
>>>>>> willkommen
>>>>>> Folgen Sie der WhereGroup auf twitter:
>>>>>> http://twitter.com/WhereGroup_com
>>>>>> Geschäftsführer:
>>>>>> Olaf Knopp, Peter Stamm
>>>>>> Amtsgericht Bonn, HRB 9885
>>>>> Links:
>>>>> [1] http://www.wheregroup.com
>>>>> [2] http://pgp.mit.edu
>>>> Astrid Emde
>>>> GIS-Consultant
>>>> FOSSGIS Konferenz
>>>> Astrid Emde
>>>> WhereGroup GmbH
>>>> Eifelstraße 7
>>>> 53119 Bonn
>>>> Germany
>>>> herunterladen:
>>>> willkommen
>>>> Geschäftsführer:
>>> Links:
>> Astrid Emde
>> GIS-Consultant
>> FOSSGIS Konferenz
>> Astrid Emde
>> WhereGroup GmbH
>> Eifelstraße 7
>> 53119 Bonn
>> Germany
>> herunterladen:
>> willkommen
>> Geschäftsführer:
> -------------------------------_______________________________________________
> Links:
Astrid Emde
GIS-Consultant
FOSSGIS Konferenz
Astrid Emde
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
www.wheregroup.com
Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Geschäftsführer:
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20240306/2e4c27f6/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20240306/2e4c27f6/attachment.sig>
More information about the Mapbender_users
