[Mapbender-users] Fwd: Installation issues + Uncaught PHP Exception Twig\Error\RuntimeError (code 0)
Norbert Farago
norbert.farago at gmail.com
Thu May 16 01:23:00 PDT 2024
Dear Mapbender Team,
last week I asked for a little help on the mail list, but unfortunately, I
didn't get a response until now. Since then, together with the
administrators, we solved the .htaccess and Apache problems, but the ones
with code 0 remained. I copied here the error lines from prod.log, I am
sure it will provide some extra hint for you (definitely it did not for me).
[2024-05-15 23:12:52] request.INFO: Matched route "mapbender_start".
{"route":"mapbender_start","route_parameters":{"_route":"mapbender_start","_controller":"Mapbender\\CoreBundle\\Controller\\WelcomeController::listAction"},"request_uri":"https://(...)/","method":"GET"}
[2024-05-15 23:12:52] security.INFO: Populated the TokenStorage with an
anonymous Token. [] []
[2024-05-15 23:12:54] request.CRITICAL: Uncaught PHP Exception
Twig\Error\RuntimeError: "An exception has been thrown during the rendering
of a template ("Failed to start the session.")." at
/afs/(...)/mapbender/mapbender/src/Mapbender/ManagerBundle/Resources/views/manager.html.twig
line 19 {"exception":"[object] (Twig\\Error\\RuntimeError(code: 0): An
exception has been thrown during the rendering of a template (\"Failed to
start the session.\"). at
/afs/(...)/mapbender/mapbender/src/Mapbender/ManagerBundle/Resources/views/manager.html.twig:19,
RuntimeException(code: 0): Failed to start the session. at
/afs/(...)/mapbender/vendor/symfony/symfony/src/Symfony/Component/HttpFoundation/Session/Storage/NativeSessionStorage.php:193)"}
[2024-05-15 23:12:55] request.ERROR: Uncaught PHP Exception
Symfony\Component\HttpKernel\Exception\NotFoundHttpException: "No route
found for "GET /favicon.ico" (from "https://(...)")" at
/afs/(...)/mapbender/vendor/symfony/symfony/src/Symfony/Component/HttpKernel/EventListener/RouterListener.php
line 136 {"exception":"[object]
(Symfony\\Component\\HttpKernel\\Exception\\NotFoundHttpException(code: 0):
No route found for \"GET /favicon.ico\" (from \"https://(....)") at
/afs/(...)/mapbender/vendor/symfony/symfony/src/Symfony/Component/HttpKernel/EventListener/RouterListener.php:136,
Symfony\\Component\\Routing\\Exception\\ResourceNotFoundException(code: 0):
No routes found for \"/favicon.ico/\". at
/afs/(...)/mapbender/vendor/symfony/symfony/src/Symfony/Component/Routing/Matcher/Dumper/CompiledUrlMatcherTrait.php:70)"}
Thank you in advance!
Best
Norbert Faragó
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20240516/18ec6e72/attachment.htm>
More information about the Mapbender_users
