[Mapbender-users] Installation doesn't seem to work
Thorsten Hack (WhereGroup)
thorsten.hack at wheregroup.com
Wed May 22 03:05:54 PDT 2024
if you try to open the css file directly
(/application/manager/assets/css or
/application/<slug-of-your-app>/assets/css), what is the error message?
If you only see an internal server error, try to use app_dev.php as your
entrypoint (/app_dev.php/application/manager/assets/css). If this gives
you a permission denied error, temporarily comment the lines 11 through
17 in the web/app_dev.php directory.
Best regards,
Thorsten Hack
FOSS Academy Sommerschule: Kompaktkurs zum Aufbau einer GDI
02.-06. September 2024, Präsenzveranstaltung in Bonn
https://www.foss-academy.com/kompaktkurse
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Tel.: +49 (0)761 / 519 102 - 67
Fax: +49 (0)761 / 519 102 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Am 22.05.24 um 10:56 schrieb Fabio Curman via Mapbender_users:
> Dear all,
> I've been working on a QGIS project (with a POSTGIS DB in the
> background) for a couple of months. Now I am at a certain point, where
> I want to publish this project and Mapbender seems to be a pretty cool
> tool therefore.
> I set up a test environment in a virtual machine using Ubuntu Server
> 20.04. and followed the documentation. The installation seemed to work
> without any errors, but for some reason my CSS is not loaded
> correctly. This causes malfunction in displaying the whole
> application, so that I cannot work with it.
> I believe it might have something to do with access rights on specific
> folders, but I wasn't able to find any similar problem or solution on
> the web.
> Has anybody encountered this issue yet and has an advice how to fix that?
> Best regards from Austria,
> Fabio Curman
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users
