[Mapbender-users] vector-tiles Mapbender5
Preuß, Sylvia
Sylvia.Preuss at obk.de
Fri Oct 30 04:04:15 PDT 2026
fortunately, vector tiles integration in Mapbender 5.0.1 is now functional in EPSG:3857 (WGS84 Pseudo-Mercator).
Sylvia
Von: Mapbender_users <mapbender_users-bounces at lists.osgeo.org> Im Auftrag von Thorsten Hack (WhereGroup) via Mapbender_users
Gesendet: Mittwoch, 26. August 2026 11:48
An: mapbender_users at lists.osgeo.org
Cc: Thorsten Hack (WhereGroup) <thorsten.hack at wheregroup.com>
Betreff: Re: [Mapbender-users] vector-tiles Mapbender5
Achtung: Diese E-Mail stammt von einem externen Mailserver. Bitte klicken Sie keine verdächtigen Links an und seien Sie vorsichtig beim Umgang mit Anlagen!
Hello Sylvia,
thanks for reporting the issue, it is very useful for us developers to receive these kinds of reports. There was a bug in both 4.2 and 5.0 related to the rendering of metadata of vector tile sources that is fixed now. The fix will be included in the main release for the 5.0 version and in the next bugfix release for 4.2.
The HTTP Referer can stay empty in most cases, it only needs to be set for special vector tiles servers that filter requests based on the HTTP Referer header.
Best regards,
Thorsten Hack
Thorsten Hack
Software-Entwicklung
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
+49 761 519 102 67
thorsten.hack at wheregroup.com<mailto:thorsten.hack at wheregroup.com>
www.wheregroup.com<http://www.wheregroup.com>
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Am 25.08.26 um 14:47 schrieb Preuß, Sylvia via Mapbender_users:
Hello,
I tried to load https://wms.wheregroup.com/tileserver/style/osm-bright.json
as a new datasource in Mapbender5. It seems to add this layer to an application. Unfortunateley the title appears transparent, and the map is not rendered. Could anyone explain?
URL zur JSON-Style-Definition: https://wms.wheregroup.com/tileserver/style/osm-bright.json
HTTP-Referer: https://wms.wheregroup.com/tileserver/style/osm-bright.json
Mapbender_users mailing list
Mapbender_users at lists.osgeo.org<mailto:Mapbender_users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/mapbender_users
Der E-Mail-Dienst des Oberbergischen Kreises dient ausschließlich der dienstlichen Kommunikation.
Senden Sie deshalb keine E-Mails privaten Inhalts an E-Mail-Adressen des Oberbergischen Kreises.
Es wird darauf hingewiesen, dass neben der Person, an die Ihre E-Mail gerichtet ist, auch deren Vertretung im Amt einen unmittelbaren Zugriff auf Ihre Nachricht hat. Für Berufsgeheimnisträger und besondere Funktionsträger gelten abweichende Regelungen.
Es wird außerdem darauf hingewiesen, dass die Kommunikation per E-Mail ohne Authentifizierung und Verschlüsselung unsicher ist, da für unberechtigte Dritte grundsätzlich die Möglichkeit der Kenntnisnahme und Manipulation besteht.
Es wird deshalb keine Verantwortung für den Inhalt dieser Nachricht übernommen, da eine Manipulation nicht ausgeschlossen werden kann.
Obwohl alle angemessenen Vorkehrungen getroffen wurden, um sicherzustellen, dass Anlagen dieser E-Mail virusgeprüft sind, wird empfohlen, anhängende Dateien vor dem Öffnen durch Ihr eigenes Virus-Programm zu prüfen, da keinerlei Haftung für Schäden übernommen wird, die infolge etwaiger Software-Viren entstehen könnten.
Der Inhalt dieser E-Mail ist ausschließlich für die bezeichnete Person bestimmt. Wenn Sie nicht der vorgesehene Adressat dieser E-Mail oder dessen Vertretung sein sollten, beachten Sie bitte, dass jede Form der Kenntnisnahme, Veröffentlichung, Vervielfältigung oder Weitergabe des Inhalts dieser E-Mail unzulässig ist. In diesem Fall wird darum gebeten, sich mit der absendenden Person der E-Mail in Verbindung zu setzen.
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20261030/38ecc27e/attachment-0001.htm>
More information about the Mapbender_users
