[mapguide-commits] r1086 - in trunk/MgDev/Web/src: . PostBuild
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Feb 1 12:51:47 EST 2007
Author: brucedechant
Date: 2007-02-01 12:51:45 -0500 (Thu, 01 Feb 2007)
New Revision: 1086
Added:
   trunk/MgDev/Web/src/PostBuild/
   trunk/MgDev/Web/src/PostBuild/PostBuild.mak
   trunk/MgDev/Web/src/PostBuild/PostBuild.vcproj
   trunk/MgDev/Web/src/WebTier.sln
Add PostBuild project to web tier solution.
The PostBuild.mak file creates the Resources folder in the mapagent folder and copies the needed resource file into this location. This is for developer convenience so that the mapagent can be run from where it is built.
Added: trunk/MgDev/Web/src/PostBuild/PostBuild.mak
--- trunk/MgDev/Web/src/PostBuild/PostBuild.mak	                        (rev 0)
+++ trunk/MgDev/Web/src/PostBuild/PostBuild.mak	2007-02-01 17:51:45 UTC (rev 1086)
@@ -0,0 +1,7 @@
+CopyResources : ..\..\..\Common\MapGuideCommon\Resources\mapguide_en.res
+    if NOT EXIST ..\mapagent\Resources\nul mkdir ..\mapagent\Resources
+    xcopy /r /d /y "..\..\..\Common\MapGuideCommon\Resources\mapguide_en.res" ..\mapagent\Resources\
+debug : CopyResources
+release : CopyResources
Property changes on: trunk/MgDev/Web/src/PostBuild/PostBuild.mak
___________________________________________________________________
   + native
Added: trunk/MgDev/Web/src/PostBuild/PostBuild.vcproj
--- trunk/MgDev/Web/src/PostBuild/PostBuild.vcproj	                        (rev 0)
+++ trunk/MgDev/Web/src/PostBuild/PostBuild.vcproj	2007-02-01 17:51:45 UTC (rev 1086)
@@ -0,0 +1,70 @@
+<?xml version="1.0" encoding="Windows-1252"?>
+<VisualStudioProject
+	ProjectType="Visual C++"
+	Version="8.00"
+	Name="PostBuild"
+	ProjectGUID="{F486B768-640A-445D-8C09-437C896EFFAD}"
+	Keyword="MakeFileProj"
+	<Platforms>
+		<Platform
+			Name="Win32"
+	</Platforms>
+	<ToolFiles>
+	</ToolFiles>
+	<Configurations>
+		<Configuration
+			Name="Debug|Win32"
+			OutputDirectory="..\..\bin\debug"
+			IntermediateDirectory="..\..\obj\debug\PostBuild"
+			ConfigurationType="0"
+			InheritedPropertySheets="$(VCInstallDir)VCProjectDefaults\UpgradeFromVC71.vsprops"
+			<Tool
+				Name="VCNMakeTool"
+				BuildCommandLine="nmake /F PostBuild.mak debug"
+				ReBuildCommandLine="nmake /F PostBuild.mak cleandebug debug"
+				CleanCommandLine="nmake /F PostBuild.mak cleandebug"
+				Output=""
+				PreprocessorDefinitions=""
+				IncludeSearchPath=""
+				ForcedIncludes=""
+				AssemblySearchPath=""
+				ForcedUsingAssemblies=""
+				CompileAsManaged=""
+		</Configuration>
+		<Configuration
+			Name="Release|Win32"
+			OutputDirectory="..\..\bin\release"
+			IntermediateDirectory="..\..\obj\release\PostBuild"
+			<Tool
+				BuildCommandLine="nmake /F PostBuild.mak release"
+				ReBuildCommandLine="nmake /F PostBuild.mak cleanrelease release"
+				CleanCommandLine="nmake /F PostBuild.mak cleanrelease"
+				Output=""
+				ForcedIncludes=""
+		</Configuration>
+	</Configurations>
+	<References>
+	</References>
+	<Files>
+		<File
+			RelativePath=".\PostBuild.mak"
+		</File>
+	</Files>
+	<Globals>
+	</Globals>
+</VisualStudioProject>
Property changes on: trunk/MgDev/Web/src/PostBuild/PostBuild.vcproj
   + native
Modified: trunk/MgDev/Web/src/WebTier.sln
--- trunk/MgDev/Web/src/WebTier.sln	2007-02-01 17:41:48 UTC (rev 1085)
+++ trunk/MgDev/Web/src/WebTier.sln	2007-02-01 17:51:45 UTC (rev 1086)
@@ -122,6 +122,27 @@
 		{F7334B1B-0EFA-47E3-8E66-DF158E61B7E4} = {F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}
 	EndProjectSection
 EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "PostBuild", "PostBuild\PostBuild.vcproj", "{F486B768-640A-445D-8C09-437C896EFFAD}"
+	ProjectSection(ProjectDependencies) = postProject
+		{795B1B0E-4EC8-469D-B641-E26324266FBF} = {795B1B0E-4EC8-469D-B641-E26324266FBF}
+		{78619D0E-D3F9-4DDF-B90E-F99CB03DFC44} = {78619D0E-D3F9-4DDF-B90E-F99CB03DFC44}
+		{F7334B1B-0EFA-47E3-8E66-DF158E61B7E4} = {F7334B1B-0EFA-47E3-8E66-DF158E61B7E4}
+		{85882748-DD71-4D2B-9E5A-03AF8C8D91B7} = {85882748-DD71-4D2B-9E5A-03AF8C8D91B7}
+		{9DD27E51-E427-48D9-859E-4A5E56854867} = {9DD27E51-E427-48D9-859E-4A5E56854867}
+		{0D09DB57-3E55-4D53-A111-6BCF71C49002} = {0D09DB57-3E55-4D53-A111-6BCF71C49002}
+		{696D2664-D17F-4357-8A19-2B5DC4B29962} = {696D2664-D17F-4357-8A19-2B5DC4B29962}
+		{B797917B-6842-467C-8B14-E00B76A91247} = {B797917B-6842-467C-8B14-E00B76A91247}
+		{A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425} = {A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}
+		{671F648B-3538-4706-9DBA-B4BDB21BD458} = {671F648B-3538-4706-9DBA-B4BDB21BD458}
+		{5287A594-4D4F-43FE-A281-E279AB708CF1} = {5287A594-4D4F-43FE-A281-E279AB708CF1}
+		{7C1C5695-C51C-4017-ABEF-BC3032CBAF3B} = {7C1C5695-C51C-4017-ABEF-BC3032CBAF3B}
+		{EE7B8899-52B6-4D6D-8003-8953DB52E0FB} = {EE7B8899-52B6-4D6D-8003-8953DB52E0FB}
+		{D954DAAC-E305-40CE-B3F3-C229A0BEF4F0} = {D954DAAC-E305-40CE-B3F3-C229A0BEF4F0}
+		{C50254F2-654A-48DE-AF5B-20605AEF8D10} = {C50254F2-654A-48DE-AF5B-20605AEF8D10}
+		{C50254F2-765B-48DE-AF5B-31716BFF8D21} = {C50254F2-765B-48DE-AF5B-31716BFF8D21}
+		{5FE54BF6-2939-46BB-A811-277D46C901C4} = {5FE54BF6-2939-46BB-A811-277D46C901C4}
+	EndProjectSection
+EndProject
 Global
 	GlobalSection(SolutionConfigurationPlatforms) = preSolution
 		Debug|Win32 = Debug|Win32
@@ -196,6 +217,10 @@
 		{5287A594-4D4F-43FE-A281-E279AB708CF1}.Debug|Win32.Build.0 = Debug|Win32
 		{5287A594-4D4F-43FE-A281-E279AB708CF1}.Release|Win32.ActiveCfg = Release|Win32
 		{5287A594-4D4F-43FE-A281-E279AB708CF1}.Release|Win32.Build.0 = Release|Win32
+		{F486B768-640A-445D-8C09-437C896EFFAD}.Debug|Win32.ActiveCfg = Debug|Win32
+		{F486B768-640A-445D-8C09-437C896EFFAD}.Debug|Win32.Build.0 = Debug|Win32
+		{F486B768-640A-445D-8C09-437C896EFFAD}.Release|Win32.ActiveCfg = Release|Win32
+		{F486B768-640A-445D-8C09-437C896EFFAD}.Release|Win32.Build.0 = Release|Win32
 	EndGlobalSection
 	GlobalSection(SolutionProperties) = preSolution
 		HideSolutionNode = FALSE
More information about the mapguide-commits mailing list
