[mapguide-commits] r1091 - in trunk/MgDev:
Common/PlatformBase/Services Server/src/Common/Manager
Server/src/Services/Resource
svn_mapguide at osgeo.org
Sat Feb 3 19:42:09 EST 2007
Author: tonyfang
Date: 2007-02-03 19:42:08 -0500 (Sat, 03 Feb 2007)
New Revision: 1091
trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.cpp
trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.h
trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp
trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.cpp
trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.h
trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp
trunk/MgDev/Server/src/Services/Resource/DataBindingInfo.cpp
trunk/MgDev/Server/src/Services/Resource/DataBindingInfo.h
trunk/MgDev/Server/src/Services/Resource/TagManager.cpp
trunk/MgDev/Server/src/Services/Resource/TagManager.h
MapGuide RFC 12 - Unmanaged Data API Changes
- remove unmanaged data substitution from FdoConnectionManager
- add unmanaged data substitution to TagManager, format: %MG_[alias]%
- store unmanaged data mappings in UnmanagedDataManager
Modified: trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.cpp
--- trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.cpp 2007-02-03 01:06:39 UTC (rev 1090)
+++ trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.cpp 2007-02-04 00:42:08 UTC (rev 1091)
@@ -63,6 +63,8 @@
const STRING MgResourceTag::Username = L"%MG_USERNAME%";
const STRING MgResourceTag::Password = L"%MG_PASSWORD%";
const STRING MgResourceTag::DataFilePath = L"%MG_DATA_FILE_PATH%";
+const STRING MgResourceTag::MappingBegin = L"%MG_[";
+const STRING MgResourceTag::MappingEnd = L"]%";
Modified: trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.h
--- trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.h 2007-02-03 01:06:39 UTC (rev 1090)
+++ trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.h 2007-02-04 00:42:08 UTC (rev 1091)
@@ -270,6 +270,20 @@
/// given resource. The trailing "/" is included.
static const STRING DataFilePath; ///\if INTERNAL value("%MG_DATA_FILE_PATH%") \endif
+ /// \brief
+ /// This tag signifies beginning of unmanaged data mapping name.
+ static const STRING MappingBegin; ///\if INTERNAL value("%MG_[") \endif
+ /// \brief
+ /// This tag signifies end of unmanaged data mapping name.
+ static const STRING MappingEnd; ///\if INTERNAL value("]%") \endif
Modified: trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp 2007-02-03 01:06:39 UTC (rev 1090)
+++ trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp 2007-02-04 00:42:08 UTC (rev 1091)
@@ -21,7 +21,6 @@
#include "ServiceManager.h"
#include "LogManager.h"
#include "LongTransactionManager.h"
-#include "UnmanagedDataManager.h"
ACE_Recursive_Thread_Mutex MgFdoConnectionManager::sm_mutex;
@@ -539,11 +538,6 @@
// Property value can be null ( optional properties may not have values )
if (!value.empty())
- // if it's a "File" property, check for unmanaged data alias
- // and replace the alias with the mapped value
- if (name.compare(L"File") == 0)
- MgUnmanagedDataManager::ConvertUnmanagedDataMappingName(value);
FdoString* propertyValue = value.c_str();
if (propertyValue != NULL)
Modified: trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.cpp 2007-02-03 01:06:39 UTC (rev 1090)
+++ trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.cpp 2007-02-04 00:42:08 UTC (rev 1091)
@@ -24,6 +24,8 @@
// Process-wide MgUnmanagedDataManager
Ptr<MgUnmanagedDataManager> MgUnmanagedDataManager::sm_unmanagedDataManager = (MgUnmanagedDataManager*)NULL;
+//Ptr<MgPropertyCollection> MgUnmanagedDataManager::m_unmanagedDataMappings = (MgPropertyCollection*)NULL;
const STRING MgUnmanagedDataManager::Folders = L"FOLDERS";
const STRING MgUnmanagedDataManager::Files = L"FILES";
const STRING MgUnmanagedDataManager::Both = L"BOTH";
@@ -37,6 +39,7 @@
MgUnmanagedDataManager::MgUnmanagedDataManager(void)
+ Initialize();
@@ -59,6 +62,17 @@
/// \brief
+/// Initialize the mappings
+void MgUnmanagedDataManager::Initialize(void)
+ MgConfiguration* config = MgConfiguration::GetInstance();
+ m_unmanagedDataMappings = config->GetProperties(MgConfigProperties::UnmanagedDataMappingsSection);
+/// \brief
/// Parses the path into mappingName and subfolder
/// The path must be in the form of:
/// "[mappingName]subfolder1/subfolder2"
@@ -369,50 +383,16 @@
return MgUnmanagedDataManager::sm_unmanagedDataManager;
/// \brief
-/// Converts mapped drive in path to its mapped value
+/// Returns unmanaged data mappings
-void MgUnmanagedDataManager::ConvertUnmanagedDataMappingName(REFSTRING path)
+MgPropertyCollection* MgUnmanagedDataManager::GetUnmanagedDataMappings()
- STRING mappingName, subpath;
- if (MgUnmanagedDataManager::ParsePath(path, mappingName, subpath)
- && !mappingName.empty())
- MgConfiguration* config = MgConfiguration::GetInstance();
- Ptr<MgPropertyCollection> properties = config->GetProperties(MgConfigProperties::UnmanagedDataMappingsSection);
- if (properties != NULL)
- STRING mappingDir;
- // check to make sure it's a valid mapping name
- // cycle thru mappings until we have a match
- for (int i = 0; i < properties->GetCount(); i++)
- Ptr<MgStringProperty> stringProp = (MgStringProperty*)properties->GetItem(i);
- if (mappingName.compare(stringProp->GetName()) == 0)
- // we have a match!
- mappingDir = stringProp->GetValue();
- break;
- if (!mappingDir.empty())
- // replace the mappingName with the actual directory
- if (!MgFileUtil::EndsWithSlash(mappingDir))
- MgFileUtil::AppendSlashToEndOfPath(mappingDir);
- path = mappingDir + subpath;
+ return m_unmanagedDataMappings;
/// \brief
@@ -425,10 +405,7 @@
ACE_TRACE("MgUnmanagedDataManager::EnumerateUnmanagedData");
+ if (m_unmanagedDataMappings != NULL)
// this XML follows the ResourceList-1.0.0.xsd schema
string list = "<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n";
@@ -468,7 +445,6 @@
ACE_ASSERT(storeFolders || storeFiles);
// filter is ignored if select = "FOLDERS"
// filter can be:
@@ -484,22 +460,16 @@
// are we looking in a specific path?
if (!mappingName.empty())
- STRING mappingDir = L"";
+ Ptr<MgStringProperty> stringProp = dynamic_cast<MgStringProperty*>(m_unmanagedDataMappings->FindItem(mappingName));
+ if (stringProp != NULL)
- break;
+ // we have a match!
+ STRING mappingDir = stringProp->GetValue();
- if (mappingDir.empty())
+ // get the files and/or folders from that folder and subfolder (recursive)
+ GetFilesAndFolders(list, mappingName, mappingDir, subfolder, &filters, storeFolders, storeFiles, recursive);
+ else
MgStringCollection arguments;
arguments.Add(L"1");
@@ -508,19 +478,14 @@
throw new MgInvalidArgumentException(L"MgUnmanagedDataManager::EnumerateUnmanagedData",
__LINE__, __WFILE__, &arguments, L"", NULL);
- else
- // get the files and/or folders from that folder and subfolder (recursive)
- GetFilesAndFolders(list, mappingName, mappingDir, subfolder, &filters, storeFolders, storeFiles, recursive);
else
// getting files starting from virtual root (all mappings)
// iterate thru mappings
+ for (int i = 0; i < m_unmanagedDataMappings->GetCount(); i++)
+ Ptr<MgStringProperty> stringProp = dynamic_cast<MgStringProperty*>(m_unmanagedDataMappings->GetItem(i));
STRING mapName = stringProp->GetName();
STRING mapDir = stringProp->GetValue();
Modified: trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.h
--- trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.h 2007-02-03 01:06:39 UTC (rev 1090)
+++ trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.h 2007-02-04 00:42:08 UTC (rev 1091)
@@ -55,7 +55,10 @@
public:
static MgUnmanagedDataManager* GetInstance();
- static void ConvertUnmanagedDataMappingName(REFSTRING path);
+ MgPropertyCollection* GetUnmanagedDataMappings();
+// static void ConvertUnmanagedDataMappingName(REFSTRING path); // TODO: remove
+ void Initialize();
virtual void Dispose();
MgByteReader* EnumerateUnmanagedData(CREFSTRING path, bool recursive, CREFSTRING select, CREFSTRING filter);
@@ -65,6 +68,7 @@
private:
static Ptr<MgUnmanagedDataManager> sm_unmanagedDataManager;
+ Ptr<MgPropertyCollection> m_unmanagedDataMappings;
static const STRING Folders;
static const STRING Files;
Modified: trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp
--- trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp 2007-02-03 01:06:39 UTC (rev 1090)
+++ trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp 2007-02-04 00:42:08 UTC (rev 1091)
@@ -360,6 +360,12 @@
dataBindingInfo.SetLoginUsername(m_currUserInfo->GetUserName());
dataBindingInfo.SetLoginPassword(m_currUserInfo->GetPassword());
+ if (resource->IsResourceTypeOf(MgResourceType::FeatureSource))
+ // turn on substitute unmanaged data mappings
+ dataBindingInfo.SetSubstituteUnmanagedDataMappings(true);
byteReader = resourceContentMan->GetResource(resource,
&dataBindingInfo);
Modified: trunk/MgDev/Server/src/Services/Resource/DataBindingInfo.cpp
--- trunk/MgDev/Server/src/Services/Resource/DataBindingInfo.cpp 2007-02-03 01:06:39 UTC (rev 1090)
+++ trunk/MgDev/Server/src/Services/Resource/DataBindingInfo.cpp 2007-02-04 00:42:08 UTC (rev 1091)
@@ -85,6 +85,7 @@
m_resourceDataFilePath = dataBindingInfo.m_resourceDataFilePath;
m_loginUsername = dataBindingInfo.m_loginUsername;
m_loginPassword = dataBindingInfo.m_loginPassword;
+ m_substituteUnmanagedDataMappings = dataBindingInfo.m_substituteUnmanagedDataMappings;
return *this;
@@ -133,3 +134,14 @@
m_loginPassword = loginPassword;
+/// <summary>
+/// Enable unmanaged data mapping substitution
+/// </summary>
+void MgDataBindingInfo::SetSubstituteUnmanagedDataMappings(bool value)
+ m_substituteUnmanagedDataMappings = value;
Modified: trunk/MgDev/Server/src/Services/Resource/DataBindingInfo.h
--- trunk/MgDev/Server/src/Services/Resource/DataBindingInfo.h 2007-02-03 01:06:39 UTC (rev 1090)
+++ trunk/MgDev/Server/src/Services/Resource/DataBindingInfo.h 2007-02-04 00:42:08 UTC (rev 1091)
@@ -38,11 +38,13 @@
CREFSTRING GetResourceDataFilePath() const;
CREFSTRING GetLoginUsername() const;
CREFSTRING GetLoginPassword() const;
+ bool GetSubstituteUnmanagedDataMappings() const;
void SetPreProcessTags(CREFSTRING preProcessTags);
void SetResourceDataFilePath(CREFSTRING resourceDataFilePath);
void SetLoginUsername(CREFSTRING loginUsername);
void SetLoginPassword(CREFSTRING loginPassword);
+ void SetSubstituteUnmanagedDataMappings(bool value);
/// Data Members
@@ -52,6 +54,7 @@
STRING m_resourceDataFilePath;
STRING m_loginUsername;
STRING m_loginPassword;
+ bool m_substituteUnmanagedDataMappings;
/// Inline Methods
@@ -76,4 +79,9 @@
return m_loginPassword;
+inline bool MgDataBindingInfo::GetSubstituteUnmanagedDataMappings() const
+ return m_substituteUnmanagedDataMappings;
#endif
Modified: trunk/MgDev/Server/src/Services/Resource/TagManager.cpp
--- trunk/MgDev/Server/src/Services/Resource/TagManager.cpp 2007-02-03 01:06:39 UTC (rev 1090)
+++ trunk/MgDev/Server/src/Services/Resource/TagManager.cpp 2007-02-04 00:42:08 UTC (rev 1091)
@@ -18,6 +18,7 @@
#include "ResourceServiceDefs.h"
#include "TagManager.h"
#include "CryptographyUtil.h"
+#include "UnmanagedDataManager.h"
static const STRING MgTagReservedCharacterSet = L"\t\n";
static const int MgTagMaxLength = 1024;
@@ -320,6 +321,14 @@
count += SubstituteTag(MgResourceTag::LoginPassword,
dataBindingInfo.GetLoginPassword(), doc);
+ if (dataBindingInfo.GetSubstituteUnmanagedDataMappings())
+ count += SubstituteMappingTag(
+ MgUtil::WideCharToMultiByte(MgResourceTag::MappingBegin),
+ MgUtil::WideCharToMultiByte(MgResourceTag::MappingEnd),
+ doc);
CheckTagStrings(doc);
return count;
@@ -359,6 +368,53 @@
return SubstituteTag(tagName, tagValue, doc);
+/// \brief
+/// Substitutes the mapping tag.
+int MgTagManager::SubstituteMappingTag(const string& beginTag, const string& endTag, string& doc)
+ int count = 0;
+ size_t startPos, endPos;
+ size_t len1 = beginTag.length();
+ size_t len2 = endTag.length();
+ while (string::npos != (startPos = doc.find(beginTag)))
+ // beginTag found, now look for endTag
+ while (string::npos != (endPos = doc.find(endTag)))
+ // extract out the mapping name
+ string mappingName = doc.substr(startPos + len1, endPos - startPos - len1);
+ size_t nameLen = mappingName.length();
+ // find the mapping name in the map, and then replace it
+ MgPropertyCollection* mappings = MgUnmanagedDataManager::GetInstance()->GetUnmanagedDataMappings();
+ if (mappings != NULL)
+ Ptr<MgStringProperty> stringProp = dynamic_cast<MgStringProperty*>(mappings->FindItem(MgUtil::MultiByteToWideChar(mappingName)));
+ // replace the mappingName with the actual directory
+ if (!MgFileUtil::EndsWithSlash(mappingDir))
+ MgFileUtil::AppendSlashToEndOfPath(mappingDir);
+ size_t dirLen = mappingDir.length();
+ doc.replace(startPos, len1 + nameLen + len2, MgUtil::WideCharToMultiByte(mappingDir), 0, dirLen);
+ ++count;
+ break;
+ return count;
/// <summary>
/// Gets the specified tag.
Modified: trunk/MgDev/Server/src/Services/Resource/TagManager.h
--- trunk/MgDev/Server/src/Services/Resource/TagManager.h 2007-02-03 01:06:39 UTC (rev 1090)
+++ trunk/MgDev/Server/src/Services/Resource/TagManager.h 2007-02-04 00:42:08 UTC (rev 1091)
@@ -58,6 +58,7 @@
int SubstituteTag(const string& name, const string& value, string& doc);
int SubstituteTag(CREFSTRING name, CREFSTRING value, string& doc);
+ int SubstituteMappingTag(const string& beginMapping, const string& endMapping, string& doc);
void AddTag(CREFSTRING name, const MgTagInfo& tagInfo);
private:
More information about the mapguide-commits
