[mapguide-commits] r1101 - in trunk/MgDev:
Common/MapGuideCommon/System Server/src/Core
Server/src/Services/Tile
svn_mapguide at osgeo.org
Fri Feb 9 18:31:25 EST 2007
Author: chrisclaydon
Date: 2007-02-09 18:31:24 -0500 (Fri, 09 Feb 2007)
New Revision: 1101
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h
trunk/MgDev/Server/src/Core/serverconfig.ini
trunk/MgDev/Server/src/Services/Tile/ServerTileService.cpp
trunk/MgDev/Server/src/Services/Tile/TileCache.cpp
trunk/MgDev/Server/src/Services/Tile/TileCache.h
Group cached tile images in subfolders to improve file access performance and avoid problems associated with storing very large numbers of files in a single folder.
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2007-02-09 22:59:13 UTC (rev 1100)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2007-02-09 23:31:24 UTC (rev 1101)
@@ -310,14 +310,16 @@
const STRING MgConfigProperties::DefaultTileServicePropertyTileCachePath = L"Repositories/TileCache/";
const STRING MgConfigProperties::TileServicePropertyCreationCutoffTime = L"CreationCutoffTime";
const INT32 MgConfigProperties::DefaultTileServicePropertyCreationCutoffTime = 120;
-const STRING MgConfigProperties::TileServicePropertyLockFolderName = L"LockFolderName";
-const STRING MgConfigProperties::DefaultTileServicePropertyLockFolderName = L"Lock";
const STRING MgConfigProperties::TileServicePropertyPollingInterval = L"PollingInterval";
const INT32 MgConfigProperties::DefaultTileServicePropertyPollingInterval = 1;
const STRING MgConfigProperties::TileServicePropertyRenderOnly = L"RenderOnly";
const bool MgConfigProperties::DefaultTileServicePropertyRenderOnly = false;
const STRING MgConfigProperties::TileServicePropertyTiledMapCacheSize = L"TiledMapCacheSize";
const INT32 MgConfigProperties::DefaultTileServicePropertyTiledMapCacheSize = 10;
+const STRING MgConfigProperties::TileServicePropertyTileRowsPerFolder = L"TileRowsPerFolder";
+const INT32 MgConfigProperties::DefaultTileServicePropertyTileRowsPerFolder = 30;
+const STRING MgConfigProperties::TileServicePropertyTileColumnsPerFolder = L"TileColumnsPerFolder";
+const INT32 MgConfigProperties::DefaultTileServicePropertyTileColumnsPerFolder = 30;
// Access Log Properties
@@ -548,7 +550,8 @@
{ MgConfigProperties::TileServicePropertyTileCachePath , MgPropertyType::String , MG_CONFIG_MIN_PATH_LENGTH , MG_CONFIG_MAX_PATH_LENGTH , MG_CONFIG_PATH_RESERVED_CHARACTERS },
{ MgConfigProperties::TileServicePropertyCreationCutoffTime , MgPropertyType::Int32 , 1 , 600 , L"" },
- { MgConfigProperties::TileServicePropertyLockFolderName , MgPropertyType::String , MG_CONFIG_MIN_FOLDER_NAME_LENGTH , MG_CONFIG_MAX_FOLDER_NAME_LENGTH , MG_CONFIG_FOLDER_NAME_RESERVED_CHARACTERS },
+ { MgConfigProperties::TileServicePropertyTileRowsPerFolder , MgPropertyType::Int32 , 1 , 1000 , L"" },
+ { MgConfigProperties::TileServicePropertyTileColumnsPerFolder , MgPropertyType::Int32 , 1 , 1000 , L"" },
{ MgConfigProperties::TileServicePropertyPollingInterval , MgPropertyType::Int32 , 1 , 60 , L"" },
{ MgConfigProperties::TileServicePropertyRenderOnly , MgPropertyType::Boolean , 0 , 1 , L"" },
{ MgConfigProperties::TileServicePropertyTiledMapCacheSize , MgPropertyType::Int32 , MG_CONFIG_MIN_CACHE_SIZE , MG_CONFIG_MAX_CACHE_SIZE , L"" },
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h 2007-02-09 22:59:13 UTC (rev 1100)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h 2007-02-09 23:31:24 UTC (rev 1101)
@@ -396,24 +396,28 @@
static const STRING TileServicePropertyTileCachePath; /// value("TileCachePath")
static const STRING DefaultTileServicePropertyTileCachePath; /// value("Repositories/TileCache/")
+ /// Specifies whether the tile is only rendered
+ static const STRING TileServicePropertyRenderOnly; /// value("RenderOnly")
+ static const bool DefaultTileServicePropertyRenderOnly; /// value(true)
+ // Sets the number of rows of tiles per folder
+ static const STRING TileServicePropertyTileRowsPerFolder; /// value("TileRowsPerFolder")
+ static const INT32 DefaultTileServicePropertyTileRowsPerFolder; /// value(30)
+ // Sets the number of columns of tiles per folder
+ static const STRING TileServicePropertyTileColumnsPerFolder; /// value("TileColumnsPerFolder")
+ static const INT32 DefaultTileServicePropertyTileColumnsPerFolder; /// value(30)
INTERNAL_API:
/// Sets the maximum amount of time (in seconds) to create a tile
static const STRING TileServicePropertyCreationCutoffTime; /// value("CreationCutoffTime")
static const INT32 DefaultTileServicePropertyCreationCutoffTime; /// value(120)
- /// Sets the folder name for locks
- static const STRING TileServicePropertyLockFolderName; /// value("LockFolderName")
- static const STRING DefaultTileServicePropertyLockFolderName; /// value("Lock")
/// Sets the time duration (in seconds) between lock checks
static const STRING TileServicePropertyPollingInterval; /// value("PollingInterval")
static const INT32 DefaultTileServicePropertyPollingInterval; /// value(1)
- /// Specifies whether the tile is only rendered
- static const STRING TileServicePropertyRenderOnly; /// value("RenderOnly")
- static const bool DefaultTileServicePropertyRenderOnly; /// value(true)
/// Sets the limit on the number of cached MgMap objects used for tile generation
static const STRING TileServicePropertyTiledMapCacheSize; /// value("TiledMapCacheSize")
static const INT32 DefaultTileServicePropertyTiledMapCacheSize; /// value(10)
Modified: trunk/MgDev/Server/src/Core/serverconfig.ini
--- trunk/MgDev/Server/src/Core/serverconfig.ini 2007-02-09 22:59:13 UTC (rev 1100)
+++ trunk/MgDev/Server/src/Core/serverconfig.ini 2007-02-09 23:31:24 UTC (rev 1101)
@@ -342,6 +342,9 @@
# TileCachePath Root path of the image tile cache
TileCachePath = Repositories/TileCache/
+RenderOnly = 0
+TileRowsPerFolder = 30
+TileColumnsPerFolder = 30
[AccessLogProperties]
Modified: trunk/MgDev/Server/src/Services/Tile/ServerTileService.cpp
--- trunk/MgDev/Server/src/Services/Tile/ServerTileService.cpp 2007-02-09 22:59:13 UTC (rev 1100)
+++ trunk/MgDev/Server/src/Services/Tile/ServerTileService.cpp 2007-02-09 23:31:24 UTC (rev 1101)
@@ -200,7 +200,7 @@
// Create the lock file and close it right away.
- m_tileCache->CreateFullPath(mapDefinition, scaleIndex, baseMapLayerGroupName);
+ m_tileCache->CreateFullPath(mapDefinition, scaleIndex, baseMapLayerGroupName, tileColumn, tileRow);
lockFile = ACE_OS::fopen(MG_WCHAR_TO_TCHAR(lockPathname), ACE_TEXT("wb"));
if (NULL == lockFile)
@@ -335,7 +335,7 @@
- m_tileCache->CreateFullPath(map, scaleIndex, baseMapLayerGroupName);
+ m_tileCache->CreateFullPath(map, scaleIndex, baseMapLayerGroupName, tileColumn, tileRow);
Modified: trunk/MgDev/Server/src/Services/Tile/TileCache.cpp
--- trunk/MgDev/Server/src/Services/Tile/TileCache.cpp 2007-02-09 22:59:13 UTC (rev 1100)
+++ trunk/MgDev/Server/src/Services/Tile/TileCache.cpp 2007-02-09 23:31:24 UTC (rev 1101)
@@ -18,8 +18,13 @@
#include "MapGuideCommon.h"
#include "TileCache.h"
-STRING MgTileCache::sm_lockFolderName = L"Lock"; // name of file folder for locks
+const STRING SCALE_INDEX_PREFIX = L"S";
+const STRING ROW_PREFIX = L"R";
+const STRING COLUMN_PREFIX = L"C";
STRING MgTileCache::sm_path = L"";
+INT32 MgTileCache::sm_tileColumnsPerFolder = 30;
+INT32 MgTileCache::sm_tileRowsPerFolder = 30;
// default constructor
MgTileCache::MgTileCache()
@@ -33,16 +38,20 @@
pConf->GetStringValue(
MgConfigProperties::TileServicePropertiesSection,
- MgConfigProperties::TileServicePropertyLockFolderName,
- sm_lockFolderName,
- MgConfigProperties::DefaultTileServicePropertyLockFolderName);
- pConf->GetStringValue(
- MgConfigProperties::TileServicePropertiesSection,
MgConfigProperties::TileServicePropertyTileCachePath,
sm_path,
MgConfigProperties::DefaultTileServicePropertyTileCachePath);
+ pConf->GetIntValue(MgConfigProperties::TileServicePropertiesSection,
+ MgConfigProperties::TileServicePropertyTileRowsPerFolder,
+ sm_tileRowsPerFolder,
+ MgConfigProperties::DefaultTileServicePropertyTileRowsPerFolder);
+ MgConfigProperties::TileServicePropertyTileColumnsPerFolder,
+ sm_tileColumnsPerFolder,
+ MgConfigProperties::DefaultTileServicePropertyTileColumnsPerFolder);
// generate directory location for tile cache
MgFileUtil::AppendSlashToEndOfPath(sm_path);
@@ -60,31 +69,24 @@
CREFSTRING group, int tileColumn, int tileRow,
STRING& tilePathname, STRING& lockPathname, bool createFullPath)
- wchar_t fileName[MAXPATHLEN] = { 0 };
- ::swprintf(fileName, MAXPATHLEN, L"/%d_%d.", tileRow, tileColumn);
+ STRING fileName = L"/" + GetTileName(tileRow, tileColumn) + L".";
+ STRING basePath = GetBasePath(mapDef);
- lockPathname = GetBasePath(mapDef);
- tilePathname;
if (createFullPath)
- tilePathname = CreateFullPath(lockPathname, scaleIndex, group);
+ tilePathname = CreateFullPath(basePath, scaleIndex, group, tileColumn, tileRow);
else
- tilePathname = GetFullPath(lockPathname, scaleIndex, group);
+ tilePathname = GetFullPath(basePath, scaleIndex, group, tileColumn, tileRow);
- // Generate the tile pathname using format "%ls/%d_%d.png":
+ // Generate the tile and lock pathnames
// <tilePathname> = <fullPath>/<row>_<column>.png
+ // <lockPathname> = <fullPath>/<row>_<column>.lck
tilePathname += fileName;
+ lockPathname = tilePathname;
tilePathname += L"png";
- // Generate the lock pathname using format "%ls/%d_%d.lck":
- // <lockPathname> = <basePath>/<row>_<column>.lck
- lockPathname += L"/";
- lockPathname += sm_lockFolderName;
- lockPathname += fileName;
lockPathname += L"lck";
@@ -227,57 +229,53 @@
// gets the full path to use with the tile cache for the given base path / scale index / group
-STRING MgTileCache::GetFullPath(CREFSTRING basePath, int scaleIndex, CREFSTRING group)
+STRING MgTileCache::GetFullPath(CREFSTRING basePath, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow)
- // Build full path using format "%ls/%d/%ls":
- // <fullPath> = <basePath>/<scaleIndex>/<group>
+ // Build full path
+ // <fullPath> = <basePath>/<scaleIndex>/<group>/<rowFolder>/<columnFolder>
assert(!basePath.empty());
STRING fullPath = basePath;
- STRING buffer;
- MgUtil::Int32ToString(scaleIndex, buffer);
fullPath += L"/";
- fullPath += buffer;
+ fullPath += GetScaleIndexFolder(scaleIndex);
fullPath += L"/";
fullPath += group;
+ fullPath += L"/";
+ fullPath += GetRowFolder(tileRow);
+ fullPath += L"/";
+ fullPath += GetColumnFolder(tileColumn);
return fullPath;
// gets the full path to use with the tile cache for the given map definition / scale index / group
-STRING MgTileCache::GetFullPath(MgResourceIdentifier* mapDef, int scaleIndex, CREFSTRING group)
+STRING MgTileCache::GetFullPath(MgResourceIdentifier* mapDef, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow)
- return GetFullPath(GetBasePath(mapDef), scaleIndex, group);
+ return GetFullPath(GetBasePath(mapDef), scaleIndex, group, tileColumn, tileRow);
// gets the full path to use with the tile cache for the given map / scale index / group
-STRING MgTileCache::GetFullPath(MgMap* map, int scaleIndex, CREFSTRING group)
+STRING MgTileCache::GetFullPath(MgMap* map, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow)
assert(NULL != map);
Ptr<MgResourceIdentifier> mapDef = map->GetMapDefinition();
- return GetFullPath(mapDef, scaleIndex, group);
+ return GetFullPath(mapDef, scaleIndex, group, tileColumn, tileRow);
-STRING MgTileCache::CreateFullPath(CREFSTRING basePath, int scaleIndex, CREFSTRING group)
+STRING MgTileCache::CreateFullPath(CREFSTRING basePath, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow)
// Create base directory if it does not exist.
MgFileUtil::CreateDirectory(fullPath, false);
- fullPath += L"/";
- // Create lock directory if it does not exist.
- STRING lockPath = fullPath;
- lockPath += sm_lockFolderName;
- MgFileUtil::CreateDirectory(lockPath, false);
// Create scale directory if it does not exist.
- STRING buffer;
+ fullPath += L"/";
// Create group directory if it does not exist.
@@ -285,15 +283,97 @@
fullPath += group;
+ // Create row directory if it does not exist.
+ fullPath += L"/";
+ MgFileUtil::CreateDirectory(fullPath, false);
+ // Create column directory if it does not exist.
+ fullPath += L"/";
return fullPath;
-STRING MgTileCache::CreateFullPath(MgResourceIdentifier* mapDef, int scaleIndex, CREFSTRING group)
+STRING MgTileCache::CreateFullPath(MgResourceIdentifier* mapDef, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow)
- return CreateFullPath(GetBasePath(mapDef), scaleIndex, group);
+ return CreateFullPath(GetBasePath(mapDef), scaleIndex, group, tileColumn, tileRow);
-STRING MgTileCache::CreateFullPath(MgMap* map, int scaleIndex, CREFSTRING group)
+STRING MgTileCache::CreateFullPath(MgMap* map, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow)
- return CreateFullPath(GetBasePath(map), scaleIndex, group);
+ return CreateFullPath(GetBasePath(map), scaleIndex, group, tileColumn, tileRow);
+// Get the folder name corresponding to the specified scale index
+STRING MgTileCache::GetScaleIndexFolder(int scaleIndex)
+ STRING scaleIndexString;
+ MgUtil::Int32ToString(scaleIndex, scaleIndexString);
+ return SCALE_INDEX_PREFIX + scaleIndexString;
+// Get the folder name corresponding to the specified tile row
+STRING MgTileCache::GetRowFolder(int tileRow)
+ return GetFolder(ROW_PREFIX, tileRow, sm_tileRowsPerFolder);
+// Get the folder name corresponding to the specified tile column
+STRING MgTileCache::GetColumnFolder(int tileColumn)
+ return GetFolder(COLUMN_PREFIX, tileColumn, sm_tileColumnsPerFolder);
+// Get the parent folder for a given row or column
+STRING MgTileCache::GetFolder(STRING prefix, int tileIndex, int tilesPerFolder)
+ STRING folder;
+ // Determine which folder contains this tile
+ int folderIndex = tileIndex / tilesPerFolder;
+ int firstTileIndex = folderIndex * tilesPerFolder;
+ if(tileIndex < 0 && firstTileIndex == 0)
+ folder = L"-0";
+ else
+ MgUtil::Int32ToString(firstTileIndex, folder);
+ return prefix + folder;
+// Get the filename corresponding to the specified row and column.
+// No file extension is added.
+STRING MgTileCache::GetTileName(int tileRow, int tileColumn)
+ return GetTileIndexString(tileRow, sm_tileRowsPerFolder) + L"_" +
+ GetTileIndexString(tileColumn, sm_tileColumnsPerFolder);
+// When a tile is stored in a folder, the index value of the parent folder
+// is subtracted from the overall tile index.
+// e.g. If we store 30 rows of tiles per folder, a tile with overall row
+// index 73 will be stored in the row folder "R60" with a row index of 13.
+// Note: Negative values are maintained even near the origin, so a tile with
+// an overall row index of -13 would be stored in row folder "R-0" with a
+// row index of -13.
+STRING MgTileCache::GetTileIndexString(int tileIndex, int tilesPerFolder)
+ STRING name;
+ // Determine the offset of this tile within the folder
+ int tileNameIndex = tileIndex % tilesPerFolder;
+ if(tileIndex < 0 && tileNameIndex == 0)
+ name = L"-0";
+ else
+ MgUtil::Int32ToString(tileNameIndex, name);
+ return name;
Modified: trunk/MgDev/Server/src/Services/Tile/TileCache.h
--- trunk/MgDev/Server/src/Services/Tile/TileCache.h 2007-02-09 22:59:13 UTC (rev 1100)
+++ trunk/MgDev/Server/src/Services/Tile/TileCache.h 2007-02-09 23:31:24 UTC (rev 1101)
@@ -33,8 +33,8 @@
STRING& tilePathname, STRING& lockPathname, bool createFullPath);
- STRING CreateFullPath(MgResourceIdentifier* mapDef, int scaleIndex, CREFSTRING group);
- STRING CreateFullPath(MgMap* map, int scaleIndex, CREFSTRING group);
+ STRING CreateFullPath(MgResourceIdentifier* mapDef, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow);
+ STRING CreateFullPath(MgMap* map, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow);
MgByteReader* Get(CREFSTRING tilePathname);
void Set(MgByteReader* img, CREFSTRING tilePathname);
@@ -56,15 +56,24 @@
STRING GetBasePath(MgResourceIdentifier* mapDef);
STRING GetBasePath(MgMap* map);
- STRING GetFullPath(CREFSTRING basePath, int scaleIndex, CREFSTRING group);
- STRING GetFullPath(MgResourceIdentifier* mapDef, int scaleIndex, CREFSTRING group);
- STRING GetFullPath(MgMap* map, int scaleIndex, CREFSTRING group);
+ STRING GetFullPath(CREFSTRING basePath, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow);
+ STRING GetFullPath(MgResourceIdentifier* mapDef, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow);
+ STRING GetFullPath(MgMap* map, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow);
- STRING CreateFullPath(CREFSTRING basePath, int scaleIndex, CREFSTRING group);
+ STRING CreateFullPath(CREFSTRING basePath, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow);
+ STRING GetScaleIndexFolder(int scaleIndex);
+ STRING GetRowFolder(int tileRow);
+ STRING GetColumnFolder(int tileColumn);
+ STRING GetFolder(STRING prefix, int tileIndex, int tilesPerFolder);
+ STRING GetTileName(int tileRow, int tileColumn);
+ STRING GetTileIndexString(int tileIndex, int tilesPerFolder);
ACE_RW_Thread_Mutex m_rwMutex;
static STRING sm_path;
- static STRING sm_lockFolderName;
+ static INT32 sm_tileColumnsPerFolder;
+ static INT32 sm_tileRowsPerFolder;
#endif
More information about the mapguide-commits
