[mapguide-commits] r1117 - in trunk/MgDev/Oem/SQLite/src:
Exceptions SQLitePhpApi SqliteDotNet SqliteVM Unicode
svn_mapguide at osgeo.org
Fri Feb 16 18:36:16 EST 2007
Author: philipsharman
Date: 2007-02-16 18:36:16 -0500 (Fri, 16 Feb 2007)
New Revision: 1117
trunk/MgDev/Oem/SQLite/src/Exceptions/CantCloseDbException.cpp
trunk/MgDev/Oem/SQLite/src/Exceptions/CantCloseDbException.h
trunk/MgDev/Oem/SQLite/src/Exceptions/CantOpenDbException.cpp
trunk/MgDev/Oem/SQLite/src/Exceptions/CantOpenDbException.h
trunk/MgDev/Oem/SQLite/src/Exceptions/ColumnNotFoundException.cpp
trunk/MgDev/Oem/SQLite/src/Exceptions/ColumnNotFoundException.h
trunk/MgDev/Oem/SQLite/src/Exceptions/ExecuteErrorException.cpp
trunk/MgDev/Oem/SQLite/src/Exceptions/ExecuteErrorException.h
trunk/MgDev/Oem/SQLite/src/Exceptions/InvalidArgumentException.cpp
trunk/MgDev/Oem/SQLite/src/Exceptions/InvalidArgumentException.h
trunk/MgDev/Oem/SQLite/src/Exceptions/NoDbConnectionException.cpp
trunk/MgDev/Oem/SQLite/src/Exceptions/NoDbConnectionException.h
trunk/MgDev/Oem/SQLite/src/Exceptions/OutOfMemoryException.cpp
trunk/MgDev/Oem/SQLite/src/Exceptions/OutOfMemoryException.h
trunk/MgDev/Oem/SQLite/src/Exceptions/SQLiteExceptions.h
trunk/MgDev/Oem/SQLite/src/Exceptions/SQLiteFinalizeException.cpp
trunk/MgDev/Oem/SQLite/src/Exceptions/SQLiteFinalizeException.h
trunk/MgDev/Oem/SQLite/src/Exceptions/SQLitePrepareException.cpp
trunk/MgDev/Oem/SQLite/src/Exceptions/SQLitePrepareException.h
trunk/MgDev/Oem/SQLite/src/Exceptions/SQLiteVMConstructException.cpp
trunk/MgDev/Oem/SQLite/src/Exceptions/SQLiteVMConstructException.h
trunk/MgDev/Oem/SQLite/src/Exceptions/SqliteException.cpp
trunk/MgDev/Oem/SQLite/src/Exceptions/SqliteException.h
trunk/MgDev/Oem/SQLite/src/Exceptions/TypeMismatchException.cpp
trunk/MgDev/Oem/SQLite/src/Exceptions/TypeMismatchException.h
trunk/MgDev/Oem/SQLite/src/SQLitePhpApi/php.i
trunk/MgDev/Oem/SQLite/src/SqliteDotNet/AssemblyInfo.cpp
trunk/MgDev/Oem/SQLite/src/SqliteDotNet/SqliteDotNet.cpp
trunk/MgDev/Oem/SQLite/src/SqliteDotNet/SqliteDotNet.h
trunk/MgDev/Oem/SQLite/src/SqliteDotNet/Stdafx.cpp
trunk/MgDev/Oem/SQLite/src/SqliteDotNet/Stdafx.h
trunk/MgDev/Oem/SQLite/src/SqliteVM/ClassId.h
trunk/MgDev/Oem/SQLite/src/SqliteVM/CommonDefs.h
trunk/MgDev/Oem/SQLite/src/SqliteVM/SQLiteDefs.h
trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteBlob.cpp
trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteBlob.h
trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteDB.cpp
trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteDB.h
trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteDisposable.cpp
trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteDisposable.h
trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteVM.cpp
trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteVM.h
trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteWrap.h
trunk/MgDev/Oem/SQLite/src/Unicode/UnicodeString.cpp
trunk/MgDev/Oem/SQLite/src/Unicode/UnicodeString.h
Updated the copyright date to 2007.
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/CantCloseDbException.cpp
--- trunk/MgDev/Oem/SQLite/src/Exceptions/CantCloseDbException.cpp 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/CantCloseDbException.cpp 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
-// Copyright (C) 2004-2006 Autodesk, Inc.
+// Copyright (C) 2004-2007 by Autodesk, Inc.
// This library is free software; you can redistribute it and/or
// modify it under the terms of version 2.1 of the GNU Lesser
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/CantCloseDbException.h
--- trunk/MgDev/Oem/SQLite/src/Exceptions/CantCloseDbException.h 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/CantCloseDbException.h 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/CantOpenDbException.cpp
--- trunk/MgDev/Oem/SQLite/src/Exceptions/CantOpenDbException.cpp 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/CantOpenDbException.cpp 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/CantOpenDbException.h
--- trunk/MgDev/Oem/SQLite/src/Exceptions/CantOpenDbException.h 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/CantOpenDbException.h 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/ColumnNotFoundException.cpp
--- trunk/MgDev/Oem/SQLite/src/Exceptions/ColumnNotFoundException.cpp 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/ColumnNotFoundException.cpp 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/ColumnNotFoundException.h
--- trunk/MgDev/Oem/SQLite/src/Exceptions/ColumnNotFoundException.h 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/ColumnNotFoundException.h 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/ExecuteErrorException.cpp
--- trunk/MgDev/Oem/SQLite/src/Exceptions/ExecuteErrorException.cpp 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/ExecuteErrorException.cpp 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/ExecuteErrorException.h
--- trunk/MgDev/Oem/SQLite/src/Exceptions/ExecuteErrorException.h 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/ExecuteErrorException.h 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/InvalidArgumentException.cpp
--- trunk/MgDev/Oem/SQLite/src/Exceptions/InvalidArgumentException.cpp 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/InvalidArgumentException.cpp 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/InvalidArgumentException.h
--- trunk/MgDev/Oem/SQLite/src/Exceptions/InvalidArgumentException.h 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/InvalidArgumentException.h 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/NoDbConnectionException.cpp
--- trunk/MgDev/Oem/SQLite/src/Exceptions/NoDbConnectionException.cpp 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/NoDbConnectionException.cpp 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/NoDbConnectionException.h
--- trunk/MgDev/Oem/SQLite/src/Exceptions/NoDbConnectionException.h 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/NoDbConnectionException.h 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/OutOfMemoryException.cpp
--- trunk/MgDev/Oem/SQLite/src/Exceptions/OutOfMemoryException.cpp 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/OutOfMemoryException.cpp 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/OutOfMemoryException.h
--- trunk/MgDev/Oem/SQLite/src/Exceptions/OutOfMemoryException.h 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/OutOfMemoryException.h 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/SQLiteExceptions.h
--- trunk/MgDev/Oem/SQLite/src/Exceptions/SQLiteExceptions.h 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/SQLiteExceptions.h 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/SQLiteFinalizeException.cpp
--- trunk/MgDev/Oem/SQLite/src/Exceptions/SQLiteFinalizeException.cpp 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/SQLiteFinalizeException.cpp 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/SQLiteFinalizeException.h
--- trunk/MgDev/Oem/SQLite/src/Exceptions/SQLiteFinalizeException.h 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/SQLiteFinalizeException.h 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/SQLitePrepareException.cpp
--- trunk/MgDev/Oem/SQLite/src/Exceptions/SQLitePrepareException.cpp 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/SQLitePrepareException.cpp 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/SQLitePrepareException.h
--- trunk/MgDev/Oem/SQLite/src/Exceptions/SQLitePrepareException.h 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/SQLitePrepareException.h 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/SQLiteVMConstructException.cpp
--- trunk/MgDev/Oem/SQLite/src/Exceptions/SQLiteVMConstructException.cpp 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/SQLiteVMConstructException.cpp 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/SQLiteVMConstructException.h
--- trunk/MgDev/Oem/SQLite/src/Exceptions/SQLiteVMConstructException.h 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/SQLiteVMConstructException.h 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/SqliteException.cpp
--- trunk/MgDev/Oem/SQLite/src/Exceptions/SqliteException.cpp 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/SqliteException.cpp 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/SqliteException.h
--- trunk/MgDev/Oem/SQLite/src/Exceptions/SqliteException.h 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/SqliteException.h 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/TypeMismatchException.cpp
--- trunk/MgDev/Oem/SQLite/src/Exceptions/TypeMismatchException.cpp 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/TypeMismatchException.cpp 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Exceptions/TypeMismatchException.h
--- trunk/MgDev/Oem/SQLite/src/Exceptions/TypeMismatchException.h 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Exceptions/TypeMismatchException.h 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/SQLitePhpApi/php.i
--- trunk/MgDev/Oem/SQLite/src/SQLitePhpApi/php.i 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/SQLitePhpApi/php.i 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
-// Copyright (C) 2004-2005 Autodesk, Inc.
Modified: trunk/MgDev/Oem/SQLite/src/SqliteDotNet/AssemblyInfo.cpp
--- trunk/MgDev/Oem/SQLite/src/SqliteDotNet/AssemblyInfo.cpp 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/SqliteDotNet/AssemblyInfo.cpp 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/SqliteDotNet/SqliteDotNet.cpp
--- trunk/MgDev/Oem/SQLite/src/SqliteDotNet/SqliteDotNet.cpp 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/SqliteDotNet/SqliteDotNet.cpp 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/SqliteDotNet/SqliteDotNet.h
--- trunk/MgDev/Oem/SQLite/src/SqliteDotNet/SqliteDotNet.h 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/SqliteDotNet/SqliteDotNet.h 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/SqliteDotNet/Stdafx.cpp
--- trunk/MgDev/Oem/SQLite/src/SqliteDotNet/Stdafx.cpp 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/SqliteDotNet/Stdafx.cpp 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/SqliteDotNet/Stdafx.h
--- trunk/MgDev/Oem/SQLite/src/SqliteDotNet/Stdafx.h 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/SqliteDotNet/Stdafx.h 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/SqliteVM/ClassId.h
--- trunk/MgDev/Oem/SQLite/src/SqliteVM/ClassId.h 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/SqliteVM/ClassId.h 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/SqliteVM/CommonDefs.h
--- trunk/MgDev/Oem/SQLite/src/SqliteVM/CommonDefs.h 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/SqliteVM/CommonDefs.h 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/SqliteVM/SQLiteDefs.h
--- trunk/MgDev/Oem/SQLite/src/SqliteVM/SQLiteDefs.h 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/SqliteVM/SQLiteDefs.h 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteBlob.cpp
--- trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteBlob.cpp 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteBlob.cpp 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteBlob.h
--- trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteBlob.h 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteBlob.h 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteDB.cpp
--- trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteDB.cpp 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteDB.cpp 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteDB.h
--- trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteDB.h 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteDB.h 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteDisposable.cpp
--- trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteDisposable.cpp 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteDisposable.cpp 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteDisposable.h
--- trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteDisposable.h 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteDisposable.h 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteVM.cpp
--- trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteVM.cpp 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteVM.cpp 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteVM.h
--- trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteVM.h 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteVM.h 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteWrap.h
--- trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteWrap.h 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/SqliteVM/SqliteWrap.h 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Unicode/UnicodeString.cpp
--- trunk/MgDev/Oem/SQLite/src/Unicode/UnicodeString.cpp 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Unicode/UnicodeString.cpp 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Oem/SQLite/src/Unicode/UnicodeString.h
--- trunk/MgDev/Oem/SQLite/src/Unicode/UnicodeString.h 2007-02-16 23:32:47 UTC (rev 1116)
+++ trunk/MgDev/Oem/SQLite/src/Unicode/UnicodeString.h 2007-02-16 23:36:16 UTC (rev 1117)
@@ -1,5 +1,5 @@
More information about the mapguide-commits
