[mapguide-commits] r1127 - trunk/MgDev/Server/src/Core
svn_mapguide at osgeo.org
Thu Feb 22 14:51:00 EST 2007
Author: brucedechant
Date: 2007-02-22 14:51:00 -0500 (Thu, 22 Feb 2007)
New Revision: 1127
trunk/MgDev/Server/src/Core/Server.cpp
Update the server by altering the startup sequence so that when running as a Windows service it will report to the Windows SCM that it has started much sooner and therefore avoid a service startup timeout.
Modified: trunk/MgDev/Server/src/Core/Server.cpp
--- trunk/MgDev/Server/src/Core/Server.cpp 2007-02-22 19:44:43 UTC (rev 1126)
+++ trunk/MgDev/Server/src/Core/Server.cpp 2007-02-22 19:51:00 UTC (rev 1127)
@@ -93,363 +93,17 @@
int nResult = 0;
- MG_TRY()
+ // Update the server service status
+ #ifdef WIN32
+ if(svc_handle_)
- // Parse arguments
- ParseArgs(argc, argv);
- // Load the configuration file into memory
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::init() - Loading configuration.\n")));
- MgConfiguration* pConfiguration = MgConfiguration::GetInstance();
- pConfiguration->LoadConfiguration(MgConfigProperties::ServerConfigurationFilename);
- // Get the resources path.
- STRING resourcesPath;
- pConfiguration->GetStringValue(MgConfigProperties::GeneralPropertiesSection, MgConfigProperties::GeneralPropertyResourcesPath, resourcesPath, MgConfigProperties::DefaultGeneralPropertyResourcesPath);
- // Get the default locale.
- STRING defaultLocale;
- pConfiguration->GetStringValue(MgConfigProperties::GeneralPropertiesSection, MgConfigProperties::GeneralPropertyDefaultLocale, defaultLocale, MgConfigProperties::DefaultGeneralPropertyDefaultLocale);
- // Initialize the Log Manager
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::init() - Initializing Log Manager.\n")));
- MgLogManager* pLogManager = MgLogManager::GetInstance();
- pLogManager->Initialize();
- // Load the resources
- // This will load the specified locale or default locale if one is not specified.
- // If additional locales are needed they will be loaded/cached on demand.
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::init() - Loading resources.\n")));
- MgResources* pResources = MgResources::GetInstance();
- pResources->Initialize(resourcesPath);
- // Try loading the specified locale resource. If it fails default to loading "en".
- // If that fails then we will not start the server because we need our resources.
- try
- pResources->LoadResources(defaultLocale);
- catch(MgException* e)
- SAFE_RELEASE(e);
- // Log error message about failing to load the specified locale resources
- MgStringCollection arguments;
- arguments.Add(pResources->GetResourceFilename(defaultLocale));
- arguments.Add(defaultLocale);
- STRING message = pResources->FormatMessage(MgResources::FailedToLoadResourcesFile, &arguments);
- ACE_DEBUG((LM_INFO, ACE_TEXT("(%P|%t) %W\n"), message.c_str()));
- MG_LOG_ERROR_ENTRY(message.c_str());
- // Check to see if we were attempting to load the "en" locale resources.
- if(MgResources::DefaultLocale == defaultLocale)
- // The server needs to fail to start because the specified default locale was
- // the same as "en"
- nResult = -1;
- else
- // Try loading the "en" locale resources instead
- defaultLocale = MgResources::DefaultLocale;
- try
- // Log message indicating that we defaulted to using the "en" resources.
- message = MgResources::UsingDefaultResourceFile;
- SAFE_RELEASE(e);
- nResult = -1;
- // We also failed to load the default "en" resource
- if(0 == nResult)
- // Check Coordinate System initialization
- MgCoordinateSystem coordSys;
- LibraryStatus libraryStatus = coordSys.GetLibraryStatus();
- if (libraryStatus == lsInitializationFailed)
- throw new MgCoordinateSystemInitializationFailedException(L"MgServer.Init", __LINE__, __WFILE__, NULL, L"", NULL);
- else if (libraryStatus == lsLoadFailed)
- throw new MgCoordinateSystemLoadFailedException(L"MgServer.Init", __LINE__, __WFILE__, NULL, L"", NULL);
- // Initialize the License Manager.
- ACE_DEBUG((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::init() - Initializing License Manager.\n")));
- MgLicenseManager* licenseManager = MgLicenseManager::GetInstance();
- ACE_ASSERT(NULL != licenseManager);
- licenseManager->Initialize();
- // Initialize the Server Manager
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::init() - Initializing Server Manager.\n")));
- MgServerManager* pServerManager = MgServerManager::GetInstance();
- pServerManager->Initialize(defaultLocale);
- // We cannot add trace statements until the log manager is initialized.
- MG_LOG_TRACE_ENTRY(L"MgServer::init() - Start");
- // Initialize the Load Balance Manager.
- ACE_DEBUG((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::init() - Initializing Load Balance Manager.\n")));
- MgLoadBalanceManager* loadBalanceManager = MgLoadBalanceManager::GetInstance();
- loadBalanceManager->Initialize();
- // Initialize the Service Manager
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::init() - Initializing Service Manager.\n")));
- MgServiceManager* pServiceManager = MgServiceManager::GetInstance();
- pServiceManager->Initialize();
- // Initialize the Event Timer Manager.
- ACE_DEBUG((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::init() - Initializing Event Timer Manager.\n")));
- m_eventTimerManager.Initialize();
- // Feature Service
- bool bDataConnectionPoolEnabled = MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolEnabled;
- INT32 nDataConnectionPoolSize = MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolSize;
- STRING dataConnectionPoolExcludedProviders = MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolExcludedProviders;
- pConfiguration->GetBoolValue(MgConfigProperties::FeatureServicePropertiesSection, MgConfigProperties::FeatureServicePropertyDataConnectionPoolEnabled, bDataConnectionPoolEnabled, MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolEnabled);
- pConfiguration->GetIntValue(MgConfigProperties::FeatureServicePropertiesSection, MgConfigProperties::FeatureServicePropertyDataConnectionPoolSize, nDataConnectionPoolSize, MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolSize);
- pConfiguration->GetStringValue(MgConfigProperties::FeatureServicePropertiesSection, MgConfigProperties::FeatureServicePropertyDataConnectionPoolExcludedProviders, dataConnectionPoolExcludedProviders, MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolExcludedProviders);
- // Add additional font mappings to the FontManager
- ACE_DEBUG((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::init() - Adding Font Manager Mappings.\n")));
- AddFontManagerFontAliases();
- // Initialize and load the FDO library
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::init() - Initializing FDO.\n")));
- STRING fdoPath;
- pConfiguration->GetStringValue(MgConfigProperties::GeneralPropertiesSection, MgConfigProperties::GeneralPropertyFdoPath, fdoPath, MgConfigProperties::DefaultGeneralPropertyFdoPath);
- // Check if path ends with a '/' if not, add one if needed
- MgFileUtil::AppendSlashToEndOfPath(fdoPath);
- #ifdef WIN32
- HMODULE hlib = NULL;
- // Get the size of the PATH environment variable for this process
- DWORD size = GetEnvironmentVariableW(L"PATH", NULL, 0) + 1;
- wchar_t* pathBuffer = new wchar_t[size];
- if(pathBuffer)
- // Get the PATH environment variable for this process
- size = GetEnvironmentVariableW(L"PATH", pathBuffer, size);
- // Add our own FDO path to the start because we want it searched 1st
- STRING updatedPath = fdoPath;
- updatedPath += L";";
- updatedPath += pathBuffer;
- // Set the PATH environment variable for this process
- SetEnvironmentVariableW(L"PATH", updatedPath.c_str());
- delete [] pathBuffer;
- pathBuffer = NULL;
- // Dump the paths to the trace log
- MG_LOG_TRACE_ENTRY(L"PATH = " + updatedPath);
- #else
- void* hlib = NULL;
- string updatedPath;
- char* ldlibpath = getenv("LD_LIBRARY_PATH");
- if (ldlibpath != NULL)
- updatedPath = ldlibpath;
- updatedPath += ":";
- else
- updatedPath = "";
- updatedPath += MgUtil::WideCharToMultiByte(fdoPath);
- setenv("LD_LIBRARY_PATH", updatedPath.c_str(), 1);
- STRING libraryPath = MgUtil::MultiByteToWideChar(updatedPath);
- MG_LOG_TRACE_ENTRY(L"LD_LIBRARY_PATH = " + libraryPath);
- #endif
- // Load the Fdo library
- STRING fdoLibrary = fdoPath;
- #ifdef WIN32
- fdoLibrary += L"fdo.dll";
- hlib = LoadLibraryW(fdoLibrary.c_str());
- #else
- fdoLibrary += L"libFDO.so";
- hlib = dlopen(MG_WCHAR_TO_TCHAR(fdoLibrary), RTLD_NOW);
- #endif
- if (NULL == hlib)
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::init() - Failed to load FDO library.\n")));
- throw new MgFdoException(L"MgServer.svc",
- __LINE__, __WFILE__, NULL, L"MgFailedToLoadFdoLibrary", NULL);
- // Initialize the FDO Connection Manager
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::init() - Initializing FDO Connection Manager.\n")));
- MgEventTimer& dataConnectionTimer = m_eventTimerManager.GetEventTimer(MgEventTimer::DataConnectionTimeout);
- MgFdoConnectionManager* pFdoConnectionManager = MgFdoConnectionManager::GetInstance();
- pFdoConnectionManager->Initialize(bDataConnectionPoolEnabled, nDataConnectionPoolSize, dataConnectionTimer.GetEventTimeout(), dataConnectionPoolExcludedProviders);
- // Initialize the Feature Service Cache
- INT32 cacheLimit;
- INT32 cacheTimeLimit;
- // Get the cache size
- MgConfigProperties::FeatureServicePropertyCacheSize,
- cacheLimit,
- MgConfigProperties::DefaultFeatureServicePropertyCacheSize);
- // Get the cache entry timelimit
- MgConfigProperties::FeatureServicePropertyCacheTimeLimit,
- cacheTimeLimit,
- MgConfigProperties::DefaultFeatureServicePropertyCacheTimeLimit);
- MgFeatureServiceCache* featureServiceCache = MgFeatureServiceCache::GetInstance();
- featureServiceCache->Initialize(cacheLimit, cacheTimeLimit);
- // On startup, perform the service registration for the Site server.
- // Note that this event will be perfomed by a timer for the Support server.
- ACE_DEBUG((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::init() - Registering Services.\n")));
- if (pServerManager->IsSiteServer() && loadBalanceManager->RegisterServices())
- m_eventTimerManager.GetEventTimer(
- MgEventTimer::ServiceRegistration).Terminate();
- // Register the MgException locale callback so that exception messages will be generated in the
- // user's locale. The Server uses thread locale storage to save user information so this callback
- // is easy to implement.
- MgException::RegisterLocaleCallback(MgServer::LocaleCallback);
-#ifdef _DEBUG
- MgEventTimer& connectionTimer = m_eventTimerManager.GetEventTimer(MgEventTimer::ConnectionTimeout);
- STRING strResourceFilename = pResources->GetResourceFilename(pServerManager->GetDefaultLocale());
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("Server Information:\n")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Commandline Options:\n")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Client Request Limit : %d\n"), m_nClientRequestLimit));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Test Mode : %s\n"), m_bTestMode == true ? ACE_TEXT("true") : ACE_TEXT("false")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Test FDO : %s\n"), m_bTestFdo == true ? ACE_TEXT("true") : ACE_TEXT("false")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n General Properties:\n")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Machine IP : %s\n"), MG_WCHAR_TO_TCHAR(loadBalanceManager->GetLocalServerAddress())));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Fdo path : %s\n"), MG_WCHAR_TO_TCHAR(fdoPath)));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Logs path : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetLogsPath())));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Locale (Default) : %s\n"), MG_WCHAR_TO_TCHAR(pServerManager->GetDefaultLocale())));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Locale Resources File Loaded : %s\n"), MG_WCHAR_TO_TCHAR(strResourceFilename)));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Client Service Properties:\n")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Connection Timeout : %d\n"), connectionTimer.GetEventTimeout()));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Connection Timer Interval : %d\n"), connectionTimer.GetInterval()));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Drawing Service Properties:\n")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Feature Service Properties:\n")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Data Connection Pool Enabled : %s\n"), bDataConnectionPoolEnabled == true ? ACE_TEXT("true") : ACE_TEXT("false")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Data Connection Pool Excluded Providers: %s\n"), MG_WCHAR_TO_TCHAR(dataConnectionPoolExcludedProviders)));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Data Connection Pool Size : %d\n"), nDataConnectionPoolSize));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Data Connection Timeout : %d\n"), dataConnectionTimer.GetEventTimeout()));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Data Connection Timer Interval : %d\n"), dataConnectionTimer.GetInterval()));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Mapping Service Properties:\n")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Rendering Service Properties:\n")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Resource Service Properties:\n")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Site Service Properties:\n")));
- if (pServerManager->IsSiteServer())
- MgEventTimer& sessionTimer = m_eventTimerManager.GetEventTimer(MgEventTimer::SessionTimeout);
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Session Timeout : %d\n"), sessionTimer.GetEventTimeout()));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Session Timer Interval : %d\n"), sessionTimer.GetInterval()));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Administrative Connection Properties:\n")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Port : %d\n"), pServerManager->GetAdminPort()));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Thread Pool Size : %d\n"), pServerManager->GetAdminThreads()));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Email Address : %W\n"), pServerManager->GetAdminEmail().c_str()));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Client Connection Properties:\n")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Port : %d\n"), pServerManager->GetClientPort()));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Thread Pool Size : %d\n"), pServerManager->GetClientThreads()));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Site Connection Properties:\n")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Port : %d\n"), pServerManager->GetSitePort()));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Thread Pool Size : %d\n"), pServerManager->GetSiteThreads()));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" IP Address : %s\n"), MG_WCHAR_TO_TCHAR(pServerManager->GetSiteServerAddress())));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Access Log Properties:\n")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Enabled : %s\n"), pLogManager->IsAccessLogEnabled() == true ? ACE_TEXT("true") : ACE_TEXT("false")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Filename : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetAccessLogFileName())));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Parameters : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetAccessLogParameters())));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Admin Log Properties:\n")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Enabled : %s\n"), pLogManager->IsAdminLogEnabled() == true ? ACE_TEXT("true") : ACE_TEXT("false")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Filename : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetAdminLogFileName())));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Parameters : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetAdminLogParameters())));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Authentication Log Properties:\n")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Enabled : %s\n"), pLogManager->IsAuthenticationLogEnabled() == true ? ACE_TEXT("true") : ACE_TEXT("false")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Filename : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetAuthenticationLogFileName())));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Parameters : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetAuthenticationLogParameters())));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Error Log Properties:\n")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Enabled : %s\n"), pLogManager->IsErrorLogEnabled() == true ? ACE_TEXT("true") : ACE_TEXT("false")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Filename : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetErrorLogFileName())));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Parameters : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetErrorLogParameters())));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Session Log Properties:\n")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Enabled : %s\n"), pLogManager->IsSessionLogEnabled() == true ? ACE_TEXT("true") : ACE_TEXT("false")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Filename : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetSessionLogFileName())));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Parameters : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetSessionLogParameters())));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Trace Log Properties:\n")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Enabled : %s\n"), pLogManager->IsTraceLogEnabled() == true ? ACE_TEXT("true") : ACE_TEXT("false")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Filename : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetTraceLogFileName())));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Parameters : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetTraceLogParameters())));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n")));
-#endif
+ report_status(SERVICE_START_PENDING, 10000);
+ #endif
- MG_CATCH(L"MgServer.init")
+ // Parse arguments
+ ParseArgs(argc, argv);
- if (mgException != NULL)
- // Server will shutdown if we are here.
- MgServerManager* serverManager = MgServerManager::GetInstance();
- STRING locale = (NULL == serverManager) ?
- MgResources::DefaultLocale : serverManager->GetDefaultLocale();
- STRING message = mgException->GetMessage(locale);
- STRING details = mgException->GetDetails(locale);
- STRING stackTrace = mgException->GetStackTrace(locale);
- ACE_DEBUG((LM_ERROR, ACE_TEXT("(%P|%t) %W\n"), details.c_str()));
- MG_LOG_SYSTEM_ENTRY(LM_ERROR, details.c_str());
- MG_LOG_EXCEPTION_ENTRY(message.c_str(), stackTrace.c_str());
- nResult = -1;
- MG_LOG_TRACE_ENTRY(L"MgServer::init() - End");
return nResult;
@@ -877,11 +531,6 @@
nResult = siteThreads.Activate();
if(nResult == 0)
- // Update the server service status
- #ifdef WIN32
- report_status(SERVICE_RUNNING);
- #endif
MG_LOG_TRACE_ENTRY(L"MgServer::svc() - Before Event Loop");
nResult = ACE_Reactor::instance()->run_reactor_event_loop();
MG_LOG_TRACE_ENTRY(L"MgServer::svc() - After Event Loop");
@@ -1036,30 +685,387 @@
int MgServer::open(void *args)
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::open()\n")));
ACE_UNUSED_ARG(args);
+ int nResult = 0;
- MG_LOG_TRACE_ENTRY(L"MgServer::open() - Start");
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::open()\n")));
+ MG_TRY()
+ // We report that the server service is running here because the server can sometimes
+ // take longer then the Windows Service Control Manager limit of 30 seconds allows.
+ // This startup delay can be due to repository integrity check which cannot be avoided.
+ #ifdef WIN32
+ if(svc_handle_)
+ report_status(SERVICE_RUNNING);
+ #endif
- STRING message = pResources->FormatMessage(MgResources::ServerStarting, 0);
+ // Load the configuration file into memory
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::open() - Loading configuration.\n")));
+ MgConfiguration* pConfiguration = MgConfiguration::GetInstance();
+ pConfiguration->LoadConfiguration(MgConfigProperties::ServerConfigurationFilename);
- ACE_DEBUG ((LM_INFO, ACE_TEXT("(%P|%t) %W\n"), message.c_str()));
- MG_LOG_SYSTEM_ENTRY(LM_INFO, message.c_str());
+ // Get the resources path.
+ STRING resourcesPath;
+ pConfiguration->GetStringValue(MgConfigProperties::GeneralPropertiesSection, MgConfigProperties::GeneralPropertyResourcesPath, resourcesPath, MgConfigProperties::DefaultGeneralPropertyResourcesPath);
- // Identify the coordinate system base library
- message = coordSys.GetBaseLibrary();
- int nResult = 0;
+ // Get the default locale.
+ STRING defaultLocale;
+ pConfiguration->GetStringValue(MgConfigProperties::GeneralPropertiesSection, MgConfigProperties::GeneralPropertyDefaultLocale, defaultLocale, MgConfigProperties::DefaultGeneralPropertyDefaultLocale);
-#ifdef WIN32
- report_status(SERVICE_START_PENDING, 10000);
+ // Initialize the Log Manager
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::open() - Initializing Log Manager.\n")));
+ MgLogManager* pLogManager = MgLogManager::GetInstance();
+ pLogManager->Initialize();
+ // Load the resources
+ // This will load the specified locale or default locale if one is not specified.
+ // If additional locales are needed they will be loaded/cached on demand.
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::open() - Loading resources.\n")));
+ MgResources* pResources = MgResources::GetInstance();
+ pResources->Initialize(resourcesPath);
+ // Try loading the specified locale resource. If it fails default to loading "en".
+ // If that fails then we will not start the server because we need our resources.
+ try
+ pResources->LoadResources(defaultLocale);
+ catch(MgException* e)
+ SAFE_RELEASE(e);
+ // Log error message about failing to load the specified locale resources
+ MgStringCollection arguments;
+ arguments.Add(pResources->GetResourceFilename(defaultLocale));
+ arguments.Add(defaultLocale);
+ STRING message = pResources->FormatMessage(MgResources::FailedToLoadResourcesFile, &arguments);
+ ACE_DEBUG((LM_INFO, ACE_TEXT("(%P|%t) %W\n"), message.c_str()));
+ MG_LOG_ERROR_ENTRY(message.c_str());
+ // Check to see if we were attempting to load the "en" locale resources.
+ if(MgResources::DefaultLocale == defaultLocale)
+ // The server needs to fail to start because the specified default locale was
+ // the same as "en"
+ nResult = -1;
+ else
+ // Try loading the "en" locale resources instead
+ defaultLocale = MgResources::DefaultLocale;
+ try
+ // Log message indicating that we defaulted to using the "en" resources.
+ message = MgResources::UsingDefaultResourceFile;
+ SAFE_RELEASE(e);
+ nResult = -1;
+ // We also failed to load the default "en" resource
+ if(0 == nResult)
+ // Check Coordinate System initialization
+ MgCoordinateSystem coordSys;
+ LibraryStatus libraryStatus = coordSys.GetLibraryStatus();
+ if (libraryStatus == lsInitializationFailed)
+ throw new MgCoordinateSystemInitializationFailedException(L"MgServer.open", __LINE__, __WFILE__, NULL, L"", NULL);
+ else if (libraryStatus == lsLoadFailed)
+ throw new MgCoordinateSystemLoadFailedException(L"MgServer.open", __LINE__, __WFILE__, NULL, L"", NULL);
+ // Initialize the License Manager.
+ ACE_DEBUG((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::open() - Initializing License Manager.\n")));
+ MgLicenseManager* licenseManager = MgLicenseManager::GetInstance();
+ ACE_ASSERT(NULL != licenseManager);
+ licenseManager->Initialize();
+ // Initialize the Server Manager
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::open() - Initializing Server Manager.\n")));
+ MgServerManager* pServerManager = MgServerManager::GetInstance();
+ pServerManager->Initialize(defaultLocale);
+ // We cannot add trace statements until the log manager is initialized.
+ MG_LOG_TRACE_ENTRY(L"MgServer::open() - Start");
+ // Initialize the Load Balance Manager.
+ ACE_DEBUG((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::open() - Initializing Load Balance Manager.\n")));
+ MgLoadBalanceManager* loadBalanceManager = MgLoadBalanceManager::GetInstance();
+ loadBalanceManager->Initialize();
+ // Initialize the Service Manager
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::open() - Initializing Service Manager.\n")));
+ MgServiceManager* pServiceManager = MgServiceManager::GetInstance();
+ pServiceManager->Initialize();
+ // Initialize the Event Timer Manager.
+ ACE_DEBUG((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::open() - Initializing Event Timer Manager.\n")));
+ m_eventTimerManager.Initialize();
+ // Feature Service
+ bool bDataConnectionPoolEnabled = MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolEnabled;
+ INT32 nDataConnectionPoolSize = MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolSize;
+ STRING dataConnectionPoolExcludedProviders = MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolExcludedProviders;
+ pConfiguration->GetBoolValue(MgConfigProperties::FeatureServicePropertiesSection, MgConfigProperties::FeatureServicePropertyDataConnectionPoolEnabled, bDataConnectionPoolEnabled, MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolEnabled);
+ pConfiguration->GetIntValue(MgConfigProperties::FeatureServicePropertiesSection, MgConfigProperties::FeatureServicePropertyDataConnectionPoolSize, nDataConnectionPoolSize, MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolSize);
+ pConfiguration->GetStringValue(MgConfigProperties::FeatureServicePropertiesSection, MgConfigProperties::FeatureServicePropertyDataConnectionPoolExcludedProviders, dataConnectionPoolExcludedProviders, MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolExcludedProviders);
+ // Add additional font mappings to the FontManager
+ ACE_DEBUG((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::open() - Adding Font Manager Mappings.\n")));
+ AddFontManagerFontAliases();
+ // Initialize and load the FDO library
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::open() - Initializing FDO.\n")));
+ STRING fdoPath;
+ pConfiguration->GetStringValue(MgConfigProperties::GeneralPropertiesSection, MgConfigProperties::GeneralPropertyFdoPath, fdoPath, MgConfigProperties::DefaultGeneralPropertyFdoPath);
+ // Check if path ends with a '/' if not, add one if needed
+ MgFileUtil::AppendSlashToEndOfPath(fdoPath);
+ #ifdef WIN32
+ HMODULE hlib = NULL;
+ // Get the size of the PATH environment variable for this process
+ DWORD size = GetEnvironmentVariableW(L"PATH", NULL, 0) + 1;
+ wchar_t* pathBuffer = new wchar_t[size];
+ if(pathBuffer)
+ // Get the PATH environment variable for this process
+ size = GetEnvironmentVariableW(L"PATH", pathBuffer, size);
+ // Add our own FDO path to the start because we want it searched 1st
+ STRING updatedPath = fdoPath;
+ updatedPath += L";";
+ updatedPath += pathBuffer;
+ // Set the PATH environment variable for this process
+ SetEnvironmentVariableW(L"PATH", updatedPath.c_str());
+ delete [] pathBuffer;
+ pathBuffer = NULL;
+ // Dump the paths to the trace log
+ MG_LOG_TRACE_ENTRY(L"PATH = " + updatedPath);
+ #else
+ void* hlib = NULL;
+ string updatedPath;
+ char* ldlibpath = getenv("LD_LIBRARY_PATH");
+ if (ldlibpath != NULL)
+ updatedPath = ldlibpath;
+ updatedPath += ":";
+ else
+ updatedPath = "";
+ updatedPath += MgUtil::WideCharToMultiByte(fdoPath);
+ setenv("LD_LIBRARY_PATH", updatedPath.c_str(), 1);
+ STRING libraryPath = MgUtil::MultiByteToWideChar(updatedPath);
+ MG_LOG_TRACE_ENTRY(L"LD_LIBRARY_PATH = " + libraryPath);
+ #endif
+ // Load the Fdo library
+ STRING fdoLibrary = fdoPath;
+ #ifdef WIN32
+ fdoLibrary += L"fdo.dll";
+ hlib = LoadLibraryW(fdoLibrary.c_str());
+ #else
+ fdoLibrary += L"libFDO.so";
+ hlib = dlopen(MG_WCHAR_TO_TCHAR(fdoLibrary), RTLD_NOW);
+ #endif
+ if (NULL == hlib)
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::open() - Failed to load FDO library.\n")));
+ throw new MgFdoException(L"MgServer.svc",
+ __LINE__, __WFILE__, NULL, L"MgFailedToLoadFdoLibrary", NULL);
+ // Initialize the FDO Connection Manager
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::open() - Initializing FDO Connection Manager.\n")));
+ MgEventTimer& dataConnectionTimer = m_eventTimerManager.GetEventTimer(MgEventTimer::DataConnectionTimeout);
+ MgFdoConnectionManager* pFdoConnectionManager = MgFdoConnectionManager::GetInstance();
+ pFdoConnectionManager->Initialize(bDataConnectionPoolEnabled, nDataConnectionPoolSize, dataConnectionTimer.GetEventTimeout(), dataConnectionPoolExcludedProviders);
+ // Initialize the Feature Service Cache
+ INT32 cacheLimit;
+ INT32 cacheTimeLimit;
+ // Get the cache size
+ MgConfigProperties::FeatureServicePropertyCacheSize,
+ cacheLimit,
+ MgConfigProperties::DefaultFeatureServicePropertyCacheSize);
+ // Get the cache entry timelimit
+ MgConfigProperties::FeatureServicePropertyCacheTimeLimit,
+ cacheTimeLimit,
+ MgConfigProperties::DefaultFeatureServicePropertyCacheTimeLimit);
+ MgFeatureServiceCache* featureServiceCache = MgFeatureServiceCache::GetInstance();
+ featureServiceCache->Initialize(cacheLimit, cacheTimeLimit);
+ // On startup, perform the service registration for the Site server.
+ // Note that this event will be perfomed by a timer for the Support server.
+ ACE_DEBUG((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::open() - Registering Services.\n")));
+ if (pServerManager->IsSiteServer() && loadBalanceManager->RegisterServices())
+ m_eventTimerManager.GetEventTimer(
+ MgEventTimer::ServiceRegistration).Terminate();
+ // Register the MgException locale callback so that exception messages will be generated in the
+ // user's locale. The Server uses thread locale storage to save user information so this callback
+ // is easy to implement.
+ MgException::RegisterLocaleCallback(MgServer::LocaleCallback);
+#ifdef _DEBUG
+ MgEventTimer& connectionTimer = m_eventTimerManager.GetEventTimer(MgEventTimer::ConnectionTimeout);
+ STRING strResourceFilename = pResources->GetResourceFilename(pServerManager->GetDefaultLocale());
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("Server Information:\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Commandline Options:\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Client Request Limit : %d\n"), m_nClientRequestLimit));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Test Mode : %s\n"), m_bTestMode == true ? ACE_TEXT("true") : ACE_TEXT("false")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Test FDO : %s\n"), m_bTestFdo == true ? ACE_TEXT("true") : ACE_TEXT("false")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n General Properties:\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Machine IP : %s\n"), MG_WCHAR_TO_TCHAR(loadBalanceManager->GetLocalServerAddress())));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Fdo path : %s\n"), MG_WCHAR_TO_TCHAR(fdoPath)));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Logs path : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetLogsPath())));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Locale (Default) : %s\n"), MG_WCHAR_TO_TCHAR(pServerManager->GetDefaultLocale())));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Locale Resources File Loaded : %s\n"), MG_WCHAR_TO_TCHAR(strResourceFilename)));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Client Service Properties:\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Connection Timeout : %d\n"), connectionTimer.GetEventTimeout()));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Connection Timer Interval : %d\n"), connectionTimer.GetInterval()));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Drawing Service Properties:\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Feature Service Properties:\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Data Connection Pool Enabled : %s\n"), bDataConnectionPoolEnabled == true ? ACE_TEXT("true") : ACE_TEXT("false")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Data Connection Pool Excluded Providers: %s\n"), MG_WCHAR_TO_TCHAR(dataConnectionPoolExcludedProviders)));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Data Connection Pool Size : %d\n"), nDataConnectionPoolSize));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Data Connection Timeout : %d\n"), dataConnectionTimer.GetEventTimeout()));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Data Connection Timer Interval : %d\n"), dataConnectionTimer.GetInterval()));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Mapping Service Properties:\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Rendering Service Properties:\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Resource Service Properties:\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Site Service Properties:\n")));
+ if (pServerManager->IsSiteServer())
+ MgEventTimer& sessionTimer = m_eventTimerManager.GetEventTimer(MgEventTimer::SessionTimeout);
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Session Timeout : %d\n"), sessionTimer.GetEventTimeout()));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Session Timer Interval : %d\n"), sessionTimer.GetInterval()));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Administrative Connection Properties:\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Port : %d\n"), pServerManager->GetAdminPort()));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Thread Pool Size : %d\n"), pServerManager->GetAdminThreads()));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Email Address : %W\n"), pServerManager->GetAdminEmail().c_str()));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Client Connection Properties:\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Port : %d\n"), pServerManager->GetClientPort()));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Thread Pool Size : %d\n"), pServerManager->GetClientThreads()));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Site Connection Properties:\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Port : %d\n"), pServerManager->GetSitePort()));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Thread Pool Size : %d\n"), pServerManager->GetSiteThreads()));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" IP Address : %s\n"), MG_WCHAR_TO_TCHAR(pServerManager->GetSiteServerAddress())));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Access Log Properties:\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Enabled : %s\n"), pLogManager->IsAccessLogEnabled() == true ? ACE_TEXT("true") : ACE_TEXT("false")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Filename : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetAccessLogFileName())));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Parameters : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetAccessLogParameters())));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Admin Log Properties:\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Enabled : %s\n"), pLogManager->IsAdminLogEnabled() == true ? ACE_TEXT("true") : ACE_TEXT("false")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Filename : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetAdminLogFileName())));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Parameters : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetAdminLogParameters())));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Authentication Log Properties:\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Enabled : %s\n"), pLogManager->IsAuthenticationLogEnabled() == true ? ACE_TEXT("true") : ACE_TEXT("false")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Filename : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetAuthenticationLogFileName())));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Parameters : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetAuthenticationLogParameters())));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Error Log Properties:\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Enabled : %s\n"), pLogManager->IsErrorLogEnabled() == true ? ACE_TEXT("true") : ACE_TEXT("false")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Filename : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetErrorLogFileName())));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Parameters : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetErrorLogParameters())));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Session Log Properties:\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Enabled : %s\n"), pLogManager->IsSessionLogEnabled() == true ? ACE_TEXT("true") : ACE_TEXT("false")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Filename : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetSessionLogFileName())));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Parameters : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetSessionLogParameters())));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Trace Log Properties:\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Enabled : %s\n"), pLogManager->IsTraceLogEnabled() == true ? ACE_TEXT("true") : ACE_TEXT("false")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Filename : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetTraceLogFileName())));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Parameters : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetTraceLogParameters())));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n")));
#endif
+ MG_CATCH(L"MgServer.open")
- // Start the service execution thread
- nResult = svc();
+ if (mgException != NULL)
+ // Server will shutdown if we are here.
+ MgServerManager* serverManager = MgServerManager::GetInstance();
+ STRING locale = (NULL == serverManager) ?
+ MgResources::DefaultLocale : serverManager->GetDefaultLocale();
+ STRING message = mgException->GetMessage(locale);
+ STRING details = mgException->GetDetails(locale);
+ STRING stackTrace = mgException->GetStackTrace(locale);
+ ACE_DEBUG((LM_ERROR, ACE_TEXT("(%P|%t) %W\n"), details.c_str()));
+ MG_LOG_SYSTEM_ENTRY(LM_ERROR, details.c_str());
+ MG_LOG_EXCEPTION_ENTRY(message.c_str(), stackTrace.c_str());
+ nResult = -1;
+ if(0 == nResult)
+ STRING message = pResources->FormatMessage(MgResources::ServerStarting, 0);
+ ACE_DEBUG ((LM_INFO, ACE_TEXT("(%P|%t) %W\n"), message.c_str()));
+ MG_LOG_SYSTEM_ENTRY(LM_INFO, message.c_str());
+ // Identify the coordinate system base library
+ message = coordSys.GetBaseLibrary();
+ // Start the service execution thread
+ nResult = svc();
MG_LOG_TRACE_ENTRY(L"MgServer::open() - End");
return nResult;
@@ -1092,7 +1098,11 @@
ACE_UNUSED_ARG(controlCode);
- report_status(SERVICE_STOP_PENDING);
+ if(svc_handle_)
+ report_status(SERVICE_STOP_PENDING);
ACE_Reactor::instance()->end_reactor_event_loop();
#endif
More information about the mapguide-commits
