[mapguide-commits] r1134 - in trunk/MgDev:
Common/MapGuideCommon/System Server/src/Services/Resource
svn_mapguide at osgeo.org
Fri Feb 23 14:01:55 EST 2007
Author: stevedang
Date: 2007-02-23 14:01:55 -0500 (Fri, 23 Feb 2007)
New Revision: 1134
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h
trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp
trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp
trunk/MgDev/Server/src/Services/Resource/ServerResourceService.h
Updated resource service with RetryAttempts/RetryInterval configurable settings to ease database access performance tuning.
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2007-02-23 18:53:06 UTC (rev 1133)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2007-02-23 19:01:55 UTC (rev 1134)
@@ -147,7 +147,7 @@
const STRING MgConfigProperties::DefaultGeneralPropertyWfsDocumentPath = L"Wfs/";
const STRING MgConfigProperties::GeneralPropertyWmsDocumentPath = L"WmsDocumentPath";
const STRING MgConfigProperties::DefaultGeneralPropertyWmsDocumentPath = L"Wms/";
-const STRING MgConfigProperties::GeneralPropertyWorkerThreadPoolSize = L"WorkerThreadPoolSize";
+const STRING MgConfigProperties::GeneralPropertyWorkerThreadPoolSize = L"WorkerThreadPoolSize"; // for internal use only
const INT32 MgConfigProperties::DefaultGeneralPropertyWorkerThreadPoolSize = 10;
@@ -289,14 +289,18 @@
const INT32 MgConfigProperties::DefaultResourceServicePropertyResourcePermissionCacheSize = 1000;
const STRING MgConfigProperties::ResourceServicePropertyResourceSchemaFilePath = L"ResourceSchemaFilePath";
const STRING MgConfigProperties::DefaultResourceServicePropertyResourceSchemaFilePath = L"Schema/";
-const STRING MgConfigProperties::ResourceServicePropertyResourceValidationEnabled = L"ResourceValidationEnabled"; // for internal use only
-const bool MgConfigProperties::DefaultResourceServicePropertyResourceValidationEnabled = true;
const STRING MgConfigProperties::ResourceServicePropertySessionRepositoryPath = L"SessionRepositoryPath";
const STRING MgConfigProperties::DefaultResourceServicePropertySessionRepositoryPath = L"Repositories/Session/";
const STRING MgConfigProperties::ResourceServicePropertySessionResourceDataFilePath = L"SessionResourceDataFilePath";
const STRING MgConfigProperties::DefaultResourceServicePropertySessionResourceDataFilePath = L"Repositories/Session/DataFiles/";
const STRING MgConfigProperties::ResourceServicePropertySiteRepositoryPath = L"SiteRepositoryPath";
const STRING MgConfigProperties::DefaultResourceServicePropertySiteRepositoryPath = L"Repositories/Site/";
+const STRING MgConfigProperties::ResourceServicePropertyResourceValidationEnabled = L"ResourceValidationEnabled"; // for internal use only
+const bool MgConfigProperties::DefaultResourceServicePropertyResourceValidationEnabled = true;
+const STRING MgConfigProperties::ResourceServicePropertyRetryAttempts = L"RetryAttempts"; // for internal use only
+const INT32 MgConfigProperties::DefaultResourceServicePropertyRetryAttempts = 10;
+const STRING MgConfigProperties::ResourceServicePropertyRetryInterval = L"RetryInterval"; // for internal use only
+const INT32 MgConfigProperties::DefaultResourceServicePropertyRetryInterval = 10;
// Site Service Properties
@@ -319,11 +323,11 @@
const INT32 MgConfigProperties::DefaultTileServicePropertyTileColumnsPerFolder = 30;
const STRING MgConfigProperties::TileServicePropertyTileRowsPerFolder = L"TileRowsPerFolder";
const INT32 MgConfigProperties::DefaultTileServicePropertyTileRowsPerFolder = 30;
-const STRING MgConfigProperties::TileServicePropertyCreationCutoffTime = L"CreationCutoffTime";
+const STRING MgConfigProperties::TileServicePropertyCreationCutoffTime = L"CreationCutoffTime";// for internal use only
const INT32 MgConfigProperties::DefaultTileServicePropertyCreationCutoffTime = 120;
-const STRING MgConfigProperties::TileServicePropertyPollingInterval = L"PollingInterval";
+const STRING MgConfigProperties::TileServicePropertyPollingInterval = L"PollingInterval"; // for internal use only
const INT32 MgConfigProperties::DefaultTileServicePropertyPollingInterval = 1;
-const STRING MgConfigProperties::TileServicePropertyTiledMapCacheSize = L"TiledMapCacheSize";
+const STRING MgConfigProperties::TileServicePropertyTiledMapCacheSize = L"TiledMapCacheSize"; // for internal use only
const INT32 MgConfigProperties::DefaultTileServicePropertyTiledMapCacheSize = 10;
@@ -538,10 +542,12 @@
{ MgConfigProperties::ResourceServicePropertyResourceDataFileTrashFolderName , MgPropertyType::String , MG_CONFIG_MIN_FOLDER_NAME_LENGTH , MG_CONFIG_MAX_FOLDER_NAME_LENGTH , MG_CONFIG_FOLDER_NAME_RESERVED_CHARACTERS },
{ MgConfigProperties::ResourceServicePropertyResourcePermissionCacheSize , MgPropertyType::Int32 , MG_CONFIG_MIN_CACHE_SIZE , MG_CONFIG_MAX_CACHE_SIZE , L"" },
{ MgConfigProperties::ResourceServicePropertyResourceSchemaFilePath , MgPropertyType::String , MG_CONFIG_MIN_PATH_LENGTH , MG_CONFIG_MAX_PATH_LENGTH , MG_CONFIG_PATH_RESERVED_CHARACTERS },
- { MgConfigProperties::ResourceServicePropertyResourceValidationEnabled , MgPropertyType::Boolean , 0 , 1 , L"" },
{ MgConfigProperties::ResourceServicePropertySessionRepositoryPath , MgPropertyType::String , MG_CONFIG_MIN_PATH_LENGTH , MG_CONFIG_MAX_PATH_LENGTH , MG_CONFIG_PATH_RESERVED_CHARACTERS },
{ MgConfigProperties::ResourceServicePropertySessionResourceDataFilePath , MgPropertyType::String , MG_CONFIG_MIN_PATH_LENGTH , MG_CONFIG_MAX_PATH_LENGTH , MG_CONFIG_PATH_RESERVED_CHARACTERS },
{ MgConfigProperties::ResourceServicePropertySiteRepositoryPath , MgPropertyType::String , MG_CONFIG_MIN_PATH_LENGTH , MG_CONFIG_MAX_PATH_LENGTH , MG_CONFIG_PATH_RESERVED_CHARACTERS },
+ { MgConfigProperties::ResourceServicePropertyResourceValidationEnabled , MgPropertyType::Boolean , 0 , 1 , L"" },
+ { MgConfigProperties::ResourceServicePropertyRetryAttempts , MgPropertyType::Int32 , 0 , 1000 , L"" },
+ { MgConfigProperties::ResourceServicePropertyRetryInterval , MgPropertyType::Int32 , 0 , 60000 , L"" },
{ L"" , 0 , 0.0 , 0.0 , L"" }
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h 2007-02-23 18:53:06 UTC (rev 1133)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h 2007-02-23 19:01:55 UTC (rev 1134)
@@ -364,6 +364,14 @@
static const STRING ResourceServicePropertyResourceValidationEnabled; /// value("ResourceValidationEnabled")
static const bool DefaultResourceServicePropertyResourceValidationEnabled; /// value(true)
+ /// Sets the number of retry attempts per operation
+ static const STRING ResourceServicePropertyRetryAttempts; /// value("RetryAttempts")
+ static const INT32 DefaultResourceServicePropertyRetryAttempts; /// value(10)
+ /// Sets the time duration (in milliseconds) between retry attempts
+ static const STRING ResourceServicePropertyRetryInterval; /// value("RetryInterval")
+ static const INT32 DefaultResourceServicePropertyRetryInterval; /// value(10)
EXTERNAL_API:
/// Sets the root of the session repository
Modified: trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp
--- trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp 2007-02-23 18:53:06 UTC (rev 1133)
+++ trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp 2007-02-23 19:01:55 UTC (rev 1134)
@@ -1471,4 +1471,4 @@
destResourceTags = destTagMan.GetTags();
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgApplicationRepositoryManager.CopyResourceData")
\ No newline at end of file
Modified: trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp
--- trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp 2007-02-23 18:53:06 UTC (rev 1133)
+++ trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp 2007-02-23 19:01:55 UTC (rev 1134)
@@ -27,7 +27,8 @@
#include "SiteResourceContentManager.h"
#include "UnmanagedDataManager.h"
-const int MgServerResourceService::sm_maxOpRetries = 10;
+INT32 MgServerResourceService::sm_retryAttempts = 10;
+ACE_Time_Value MgServerResourceService::sm_retryInterval;
MgSiteRepository* MgServerResourceService::sm_siteRepository = NULL;
MgSessionRepository* MgServerResourceService::sm_sessionRepository = NULL;
@@ -80,8 +81,7 @@
throw; \
- ACE_Time_Value timeValue(0, 10000); \
- ACE_OS::sleep(timeValue); \
+ ACE_OS::sleep(sm_retryInterval); \
repositoryMan->Terminate(); \
@@ -118,6 +118,26 @@
ACE_ASSERT(NULL == sm_siteRepository && NULL == sm_sessionRepository && NULL == sm_libraryRepository);
+ // Initialize performance tuning settings.
+ INT32 retryInterval = 10; // in milliseconds
+ MgConfiguration* configuration = MgConfiguration::GetInstance();
+ assert(NULL != configuration);
+ configuration->GetIntValue(
+ MgConfigProperties::ResourceServicePropertiesSection,
+ MgConfigProperties::ResourceServicePropertyRetryAttempts,
+ sm_retryAttempts,
+ MgConfigProperties::DefaultResourceServicePropertyRetryAttempts);
+ MgConfigProperties::ResourceServicePropertyRetryInterval,
+ retryInterval,
+ MgConfigProperties::DefaultResourceServicePropertyRetryInterval);
+ sm_retryInterval.msec((long)retryInterval);
// Clean up the Session repository after creating the Site repository
// to eliminate unnecessary XMLPlatformUtils::Initialize/Terminate calls
// made by the BDB XmlManager.
@@ -227,7 +247,7 @@
byteReader = repositoryMan->EnumerateRepositories();
- MG_RESOURCE_SERVICE_END_OPERATION(sm_maxOpRetries)
+ MG_RESOURCE_SERVICE_END_OPERATION(sm_retryAttempts)
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.EnumerateRepositories")
@@ -266,7 +286,7 @@
ACE_ASSERT(!resource->GetRepositoryName().empty());
auto_ptr<MgSessionRepositoryManager> repositoryMan(
new MgSessionRepositoryManager(*sm_sessionRepository));
- int maxRetries = sm_maxOpRetries;
+ int maxRetries = sm_retryAttempts;
if ((NULL != content && !content->IsRewindable())
|| (NULL != header && !header->IsRewindable()))
@@ -329,7 +349,7 @@
repositoryMan->DeleteRepository(resource);
// Update the current set of changed resources.
UpdateChangedResources(repositoryMan->GetChangedResources());
@@ -362,7 +382,7 @@
auto_ptr<MgApplicationRepositoryManager> repositoryMan(
CreateApplicationRepositoryManager(resource));
@@ -422,7 +442,7 @@
byteReader = repositoryMan->GetRepositoryContent(resource);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.GetRepositoryContent")
@@ -470,7 +490,7 @@
byteReader = repositoryMan->GetRepositoryHeader(resource);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.GetRepositoryHeader")
@@ -496,7 +516,7 @@
auto_ptr<MgLibraryRepositoryManager> repositoryMan(
new MgLibraryRepositoryManager(*sm_libraryRepository));
if (!packageStream->IsRewindable())
@@ -548,7 +568,7 @@
repositoryMan->LoadResourcePackage(packagePathname, logActivities);
@@ -598,7 +618,7 @@
repositoryMan->MakeResourcePackage(resource, packagePathname,
packageDescription, logActivities);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.MakeResourcePackage")
@@ -646,7 +666,7 @@
byteReader = repositoryMan->EnumerateResources(resource, depth, type,
properties, fromDate, toDate);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.EnumerateResources")
@@ -678,7 +698,7 @@
@@ -737,7 +757,7 @@
repositoryMan->DeleteResource(resource);
@@ -775,7 +795,7 @@
repositoryMan->MoveResource(sourceResource, destResource, overwrite);
@@ -813,7 +833,7 @@
repositoryMan->CopyResource(sourceResource, destResource, overwrite);
@@ -853,7 +873,7 @@
byteReader = repositoryMan->GetResourceContent(resource, preProcessTags);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.GetResourceContent")
@@ -899,7 +919,7 @@
byteReader = repositoryMan->GetResourceHeader(resource);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.GetResourceHeader")
@@ -948,7 +968,7 @@
dateTime = repositoryMan->GetResourceModifiedDate(resource);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.GetResourceModifiedDate")
@@ -987,7 +1007,7 @@
byteReader = repositoryMan->EnumerateReferences(resource);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.EnumerateReferences")
@@ -1144,7 +1164,7 @@
repositoryMan->ChangeResourceOwner(resource, owner, includeDescendants);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.ChangeResourceOwner")
@@ -1188,7 +1208,7 @@
repositoryMan->InheritPermissionsFrom(resource);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.InheritPermissionsFrom")
@@ -1225,7 +1245,7 @@
byteReader = repositoryMan->EnumerateResourceData(resource);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.EnumerateResourceData")
@@ -1257,7 +1277,7 @@
if (!data->IsRewindable())
@@ -1311,7 +1331,7 @@
repositoryMan->DeleteResourceData(resource, dataName);
@@ -1349,7 +1369,7 @@
repositoryMan->RenameResourceData(resource, oldDataName, newDataName, overwrite);
@@ -1391,7 +1411,7 @@
byteReader = repositoryMan->GetResourceData(resource, dataName,
preProcessTags);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.GetResourceData")
@@ -1467,7 +1487,7 @@
byteReader = repositoryMan->EnumerateUsers(group, role, includePassword,
includeGroups);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.EnumerateUsers")
@@ -1498,7 +1518,7 @@
repositoryMan->AddUser(userId, username, password, description);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.AddUser")
@@ -1526,7 +1546,7 @@
repositoryMan->DeleteUsers(users);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.DeleteUsers")
@@ -1555,7 +1575,7 @@
repositoryMan->UpdateUser(userId, newUserId, newUsername, newPassword, newDescription);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.UpdateUser")
@@ -1587,7 +1607,7 @@
byteReader = repositoryMan->EnumerateGroups(user, role);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.EnumerateGroups")
@@ -1616,7 +1636,7 @@
repositoryMan->AddGroup(group, description);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.AddGroup")
@@ -1643,7 +1663,7 @@
repositoryMan->DeleteGroups(groups);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.DeleteGroups")
@@ -1672,7 +1692,7 @@
repositoryMan->UpdateGroup(group, newGroup, newDescription);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.UpdateGroup")
@@ -1710,7 +1730,7 @@
repositoryMan->GrantGroupMembershipsToUsers(groups, users);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.GrantGroupMembershipsToUsers")
@@ -1748,7 +1768,7 @@
repositoryMan->RevokeGroupMembershipsFromUsers(groups, users);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.RevokeGroupMembershipsFromUsers")
@@ -1794,7 +1814,7 @@
roles = repositoryMan->EnumerateRoles(user, group);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.EnumerateRoles")
@@ -1860,7 +1880,7 @@
repositoryMan->GrantRoleMembershipsToUsers( roles, users );
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.GrantRoleMembershipsToUsers")
@@ -1898,7 +1918,7 @@
repositoryMan->RevokeRoleMembershipsFromUsers( roles, users );
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.RevokeRoleMembershipsFromUsers")
@@ -1936,7 +1956,7 @@
repositoryMan->GrantRoleMembershipsToGroups( roles, groups );
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.GrantRoleMembershipsToGroups")
@@ -1974,7 +1994,7 @@
repositoryMan->RevokeRoleMembershipsFromGroups( roles, groups );
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.RevokeRoleMembershipsFromGroups")
@@ -2062,7 +2082,7 @@
permitted = resourceContentMan->CheckPermission(*resource, permission);
MG_RESOURCE_SERVICE_CATCH(L"MgServerResourceService.HasPermission")
Modified: trunk/MgDev/Server/src/Services/Resource/ServerResourceService.h
--- trunk/MgDev/Server/src/Services/Resource/ServerResourceService.h 2007-02-23 18:53:06 UTC (rev 1133)
+++ trunk/MgDev/Server/src/Services/Resource/ServerResourceService.h 2007-02-23 19:01:55 UTC (rev 1134)
@@ -178,7 +178,8 @@
private:
- static const int sm_maxOpRetries;
+ static INT32 sm_retryAttempts;
+ static ACE_Time_Value sm_retryInterval;
static MgSiteRepository* sm_siteRepository;
static MgSessionRepository* sm_sessionRepository;
More information about the mapguide-commits
