[mapguide-commits] r1060 - in trunk/MgDev:
Common/MapGuideCommon/Controller Web/src/HttpHandler
svn_mapguide at osgeo.org
Thu Jan 18 22:46:04 EST 2007
Author: waltweltonlair
Date: 2007-01-18 22:46:04 -0500 (Thu, 18 Jan 2007)
New Revision: 1060
trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp
trunk/MgDev/Web/src/HttpHandler/HttpGetMapImage.cpp
We are currently generating track changes in the context of AJAX Viewer, but
these are never getting cleared. Over time the number of track changes stored
in the MgMap could potentially grow large. Track changes are only needed for
DWF. Ideally MgMap would have a flag which indicated whether the map is being
used in the context of DWF or AJAX, and then we could simply check that flag in
MgMapBase::TrackChange and not track if AJAX is active.
For now I've added calls to clear the track changes for all rendering APIs used
by AJAX Viewer:
GetDynamicMapOverlayImage
GetMapImage
GetMapLegendImage
GetMapVisibleExtent
QueryMapFeatures
Modified: trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp
--- trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp 2007-01-19 02:07:28 UTC (rev 1059)
+++ trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp 2007-01-19 03:46:04 UTC (rev 1060)
@@ -37,6 +37,14 @@
Ptr<MgMap> map = new MgMap();
map->Open(resourceService, mapName);
+ // Make sure we clear any track changes - these are not applicable for AJAX.
+ Ptr<MgNamedCollection> changeLists = map->GetChangeLists();
+ if (changeLists->GetCount() > 0)
+ map->ClearChanges();
+ map->Save(resourceService);
// Get the selection
Ptr<MgSelection> selection = new MgSelection(map);
selection->Open(resourceService, mapName);
@@ -57,6 +65,10 @@
// Apply map view commands
ApplyMapViewCommands(map, mapViewCommands);
+ if (NULL != map)
// Get Proxy Rendering Service instance
Ptr<MgRenderingService> service = (MgRenderingService*)(GetService(MgServiceType::RenderingService));
@@ -80,6 +92,9 @@
// Save the MgMap state
@@ -128,6 +143,14 @@
// Create Proxy Rendering Service instance
@@ -153,6 +176,14 @@
Modified: trunk/MgDev/Web/src/HttpHandler/HttpGetMapImage.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpGetMapImage.cpp 2007-01-19 02:07:28 UTC (rev 1059)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGetMapImage.cpp 2007-01-19 03:46:04 UTC (rev 1060)
@@ -67,11 +67,15 @@
Ptr<MgResourceService> resourceService = dynamic_cast<MgResourceService*>(CreateService(MgServiceType::ResourceService));
+ bool openedMap = false;
// Create MgMap and selection
Ptr<MgSelection> selection;
if (!m_mapName.empty() && !sessionId.empty())
+ openedMap = true;
map->Open(resourceService, m_mapName);
@@ -93,6 +97,12 @@
MgHtmlController controller(m_siteConn);
Ptr<MgByteReader> reader = controller.GetMapImage(map, selection, m_mapFormat, commands);
+ // If we opened the map from the repository then save it back to ensure
+ // any track changes are removed from the persisted version, since these
+ // are not applicable for AJAX.
+ if (openedMap)
// Set the result
hResult->SetResultObject(reader, reader->GetMimeType());
More information about the mapguide-commits
