[mapguide-commits] r1075 - in trunk/MgDev: Common/Foundation/System
Common/MapGuideCommon/Services Common/PlatformBase/Services
Common/Schema Server/src/Common/Manager
Server/src/Services/Resource Server/src/Services/ServerAdmin
UnitTest/WebTier/MapAgent/MapAgentForms Web/src/HttpHandler
Web/src/mapadmin
svn_mapguide at osgeo.org
Fri Jan 26 19:26:59 EST 2007
Author: tonyfang
Date: 2007-01-26 19:26:59 -0500 (Fri, 26 Jan 2007)
New Revision: 1075
Added:
trunk/MgDev/Common/Schema/UnmanagedDataList-1.0.0.xsd
trunk/MgDev/Server/src/Services/ServerAdmin/OpRemoveConfigurationProperties.cpp
trunk/MgDev/Server/src/Services/ServerAdmin/OpRemoveConfigurationProperties.h
trunk/MgDev/Web/src/mapadmin/addunmanageddata.php
trunk/MgDev/Web/src/mapadmin/editunmanageddata.php
trunk/MgDev/Web/src/mapadmin/unmanageddatamanagement.php
Removed:
trunk/MgDev/Server/src/Services/Resource/OpEnumerateUnmanagedDataMappings.cpp
trunk/MgDev/Server/src/Services/Resource/OpEnumerateUnmanagedDataMappings.h
trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/enumerateunmanageddatamappingsform.html
trunk/MgDev/Web/src/HttpHandler/HttpEnumerateUnmanagedDataMappings.cpp
trunk/MgDev/Web/src/HttpHandler/HttpEnumerateUnmanagedDataMappings.h
trunk/MgDev/Common/Foundation/System/FileUtil.cpp
trunk/MgDev/Common/MapGuideCommon/Services/ProxyResourceService.cpp
trunk/MgDev/Common/MapGuideCommon/Services/ProxyResourceService.h
trunk/MgDev/Common/MapGuideCommon/Services/ServerAdmin.cpp
trunk/MgDev/Common/MapGuideCommon/Services/ServerAdmin.h
trunk/MgDev/Common/MapGuideCommon/Services/ServerAdminDefs.h
trunk/MgDev/Common/PlatformBase/Services/ResourceService.cpp
trunk/MgDev/Common/PlatformBase/Services/ResourceService.h
trunk/MgDev/Server/src/Common/Manager/ServerManager.cpp
trunk/MgDev/Server/src/Common/Manager/ServerManager.h
trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.cpp
trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.h
trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp
trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.h
trunk/MgDev/Server/src/Services/Resource/Makefile.am
trunk/MgDev/Server/src/Services/Resource/OpEnumerateUnmanagedData.cpp
trunk/MgDev/Server/src/Services/Resource/OperationInfo.cpp
trunk/MgDev/Server/src/Services/Resource/OperationInfo.h
trunk/MgDev/Server/src/Services/Resource/ResourceOperationFactory.cpp
trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp
trunk/MgDev/Server/src/Services/Resource/ServerResourceService.h
trunk/MgDev/Server/src/Services/Resource/ServerResourceService.vcproj
trunk/MgDev/Server/src/Services/Resource/ServerResourceServiceBuild.cpp
trunk/MgDev/Server/src/Services/ServerAdmin/Makefile.am
trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminOperationFactory.cpp
trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.cpp
trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.h
trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.vcproj
trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminServiceBuild.cpp
trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/enumerateunmanageddataform.html
trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/resourceserviceapi.html
trunk/MgDev/Web/src/HttpHandler/HttpEnumerateUnmanagedData.cpp
trunk/MgDev/Web/src/HttpHandler/HttpEnumerateUnmanagedData.h
trunk/MgDev/Web/src/HttpHandler/HttpHandler.vcproj
trunk/MgDev/Web/src/HttpHandler/HttpHandlerBuild.cpp
trunk/MgDev/Web/src/HttpHandler/HttpRequest.cpp
trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp
trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.h
trunk/MgDev/Web/src/HttpHandler/Makefile.am
trunk/MgDev/Web/src/mapadmin/msgs.php
trunk/MgDev/Web/src/mapadmin/resizablepagecomponents.php
trunk/MgDev/Web/src/mapadmin/serverdatafunctions.php
trunk/MgDev/Web/src/mapadmin/sessionvars.php
MapGuide RFC 12 - Unmanaged Data API Changes
Modified: trunk/MgDev/Common/Foundation/System/FileUtil.cpp
--- trunk/MgDev/Common/Foundation/System/FileUtil.cpp 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Common/Foundation/System/FileUtil.cpp 2007-01-27 00:26:59 UTC (rev 1075)
@@ -135,7 +135,7 @@
/// path to file name, e.g. "c:\temp\readme.txt"
/// </param>
/// <param name="extension">
-/// file extension, e.g. ".txt"
+/// file extension, e.g. ".txt" or "txt"
/// </param>
bool MgFileUtil::EndsWithExtension(CREFSTRING pathname, CREFSTRING extension)
@@ -147,8 +147,13 @@
bool result = false;
+ size_t offset = 0;
+ if (!BeginsWithDot(extension))
+ offset = 1;
size_t len = extension.length();
- size_t pos = pathname.find_last_of(L'.');
+ size_t pos = pathname.find_last_of(L'.') + offset;
if (STRING::npos != pos && (pathname.length() == pos + len))
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyResourceService.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyResourceService.cpp 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyResourceService.cpp 2007-01-27 00:26:59 UTC (rev 1075)
@@ -1059,48 +1059,26 @@
/// \brief
-/// Enumerates the unmanaged data files
-/// Resources of all types can be enumerated all at once, or only
-/// resources of a given type.
+/// Enumerates the unmanaged data
-MgStringCollection* MgProxyResourceService::EnumerateUnmanagedData(
- CREFSTRING mappingName, CREFSTRING dataTypeFilter, INT32 depth)
+MgByteReader* MgProxyResourceService::EnumerateUnmanagedData(
+ CREFSTRING path, bool recursive, CREFSTRING select, CREFSTRING filter)
MgCommand cmd;
cmd.ExecuteCommand(m_connProp,
MgCommand::knObject,
MgResourceService::opIdEnumerateUnmanagedData,
- 3,
+ 4,
Resource_Service,
1,
- MgCommand::knString, &mappingName,
- MgCommand::knString, &dataTypeFilter,
- MgCommand::knInt32, depth,
+ MgCommand::knString, &path,
+ MgCommand::knInt8, (int)recursive,
+ MgCommand::knString, &select,
+ MgCommand::knString, &filter,
MgCommand::knNone);
SetWarning(cmd.GetWarningObject());
- return (MgStringCollection*)cmd.GetReturnValue().val.m_obj;
+ return (MgByteReader*)cmd.GetReturnValue().val.m_obj;
-/// \brief
-/// Enumerates the unmanaged data mappings
-MgStringCollection* MgProxyResourceService::EnumerateUnmanagedDataMappings()
- MgCommand cmd;
- cmd.ExecuteCommand(m_connProp,
- MgCommand::knObject,
- MgResourceService::opIdEnumerateUnmanagedDataMappings,
- 0,
- Resource_Service,
- 1,
- MgCommand::knNone);
- SetWarning(cmd.GetWarningObject());
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyResourceService.h
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyResourceService.h 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyResourceService.h 2007-01-27 00:26:59 UTC (rev 1075)
@@ -667,11 +667,16 @@
virtual MgByteReader* EnumerateReferences(MgResourceIdentifier* resource);
- virtual MgStringCollection* EnumerateUnmanagedData(CREFSTRING mappingName,
- CREFSTRING dataTypeFilter, INT32 depth);
+ /// \brief
+ /// Enumerates unmanaged data
+ /// \return
+ /// MgByteReader object representing unmanaged data
+ virtual MgByteReader* EnumerateUnmanagedData(CREFSTRING path, bool recursive,
+ CREFSTRING select, CREFSTRING filter);
- virtual MgStringCollection* EnumerateUnmanagedDataMappings();
protected:
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ServerAdmin.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ServerAdmin.cpp 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ServerAdmin.cpp 2007-01-27 00:26:59 UTC (rev 1075)
@@ -205,6 +205,43 @@
/// <summary>
+/// Removes the configuration properties for the specified property section.
+/// If the properties are not specified, then the entire section will be removed.
+/// </summary>
+/// <param name="propertySection">
+/// The property section to set.
+/// </param>
+/// <param name="properties">
+/// The collection of configuration properties associated with the specified property section that you want to remove.
+/// </param>
+/// <returns>
+/// Nothing
+/// </returns>
+/// EXCEPTIONS:
+/// MgConnectionNotOpenException
+/// MgInvalidPropertySectionException
+/// MgPropertySectionNotAvailableException
+/// MgPropertySectionReadOnlyException
+/// MgInvalidPropertyException
+void MgServerAdmin::RemoveConfigurationProperties(CREFSTRING propertySection, MgPropertyCollection* properties)
+ MgCommand cmd;
+ cmd.ExecuteCommand(m_connProp, // Connection
+ MgCommand::knVoid, // Return type expected
+ MgServerAdminServiceOpId::RemoveConfigurationProperties, // Command Code
+ 2, // No of arguments
+ ServerAdmin_Service, // Service Id
+ 1, // Operation version
+ MgCommand::knString, &propertySection, // Argument#1
+ MgCommand::knObject, properties, // Argument#2
+ MgCommand::knNone);
+ SetWarning(cmd.GetWarningObject());
+/// <summary>
/// Clears the specified log.
/// </summary>
/// <param name="log">
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ServerAdmin.h
--- trunk/MgDev/Common/MapGuideCommon/Services/ServerAdmin.h 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ServerAdmin.h 2007-01-27 00:26:59 UTC (rev 1075)
@@ -150,6 +150,27 @@
void SetConfigurationProperties(CREFSTRING propertySection, MgPropertyCollection* properties);
+ /// \brief
+ /// Removes the configuration properties for the specified property section.
+ /// If the properties are not specified, then the entire section will be removed.
+ /// \param propertySection
+ /// The property section to remove.
+ /// \param properties
+ /// The collection of configuration properties associated with the specified property section that you want to remove.
+ /// \return
+ /// Nothing
+ /// \exception MgConnectionNotOpenException
+ /// \exception MgInvalidPropertySectionException
+ /// \exception MgPropertySectionNotAvailableException
+ /// \exception MgPropertySectionReadOnlyException
+ /// \exception MgInvalidPropertyException
+ void RemoveConfigurationProperties(CREFSTRING propertySection, MgPropertyCollection* properties);
/// \brief
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ServerAdminDefs.h
--- trunk/MgDev/Common/MapGuideCommon/Services/ServerAdminDefs.h 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ServerAdminDefs.h 2007-01-27 00:26:59 UTC (rev 1075)
@@ -208,6 +208,7 @@
static const int SetDocument = 0x1111EA19;
static const int NotifyResourcesChanged = 0x1111EA1A;
static const int MakePackage = 0x1111EA1B;
+ static const int RemoveConfigurationProperties = 0x1111EA1C;
#define DECLARE_DYNCREATE_SERVERADMIN() \
Modified: trunk/MgDev/Common/PlatformBase/Services/ResourceService.cpp
--- trunk/MgDev/Common/PlatformBase/Services/ResourceService.cpp 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Common/PlatformBase/Services/ResourceService.cpp 2007-01-27 00:26:59 UTC (rev 1075)
@@ -204,17 +204,7 @@
-MgStringCollection* MgResourceService::EnumerateUnmanagedData(
+MgByteReader* MgResourceService::EnumerateUnmanagedData(CREFSTRING path, bool recursive, CREFSTRING select, CREFSTRING filter)
throw new MgNotImplementedException(L"MgResourceService.EnumerateUnmanagedData", __LINE__, __WFILE__, NULL, L"", NULL);
-/// \brief
-MgStringCollection* MgResourceService::EnumerateUnmanagedDataMappings()
- throw new MgNotImplementedException(L"MgResourceService.EnumerateUnmanagedDataMappings", __LINE__, __WFILE__, NULL, L"", NULL);
Modified: trunk/MgDev/Common/PlatformBase/Services/ResourceService.h
--- trunk/MgDev/Common/PlatformBase/Services/ResourceService.h 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Common/PlatformBase/Services/ResourceService.h 2007-01-27 00:26:59 UTC (rev 1075)
@@ -1679,20 +1679,10 @@
/// Enumerate unmanaged data
/// \return
- /// MgStringCollection list of unmanaged data paths
+ /// MgByteReader of unmanaged data
- CREFSTRING mappingName, CREFSTRING dataTypeFilter, INT32 depth);
+ virtual MgByteReader* EnumerateUnmanagedData(CREFSTRING path, bool recursive, CREFSTRING select, CREFSTRING filter);
- /// \brief
- /// Enumerate unmanaged data mappings
- /// \return
- /// MgStringCollection list of unmanaged data mappings
protected:
@@ -1763,7 +1753,6 @@
opIdGetResourceModifiedDate = 0x1111EF18,
opIdEnumerateParentMapDefinitions = 0x1111EF19,
opIdEnumerateUnmanagedData = 0x1111EF1A,
- opIdEnumerateUnmanagedDataMappings = 0x1111EF1B,
Added: trunk/MgDev/Common/Schema/UnmanagedDataList-1.0.0.xsd
--- trunk/MgDev/Common/Schema/UnmanagedDataList-1.0.0.xsd 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Common/Schema/UnmanagedDataList-1.0.0.xsd 2007-01-27 00:26:59 UTC (rev 1075)
@@ -0,0 +1,33 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified">
+ <xs:element name="UnmanagedDataList">
+ <xs:annotation>
+ <xs:documentation>Unmanaged data list</xs:documentation>
+ </xs:annotation>
+ <xs:complexType>
+ <xs:choice minOccurs="0" maxOccurs="unbounded">
+ <xs:element name="UnmanagedDataFolder">
+ <xs:complexType>
+ <xs:sequence>
+ <xs:element name="UnmanagedDataId" type="xs:string"/>
+ <xs:element name="CreatedDate" type="xs:dateTime"/>
+ <xs:element name="ModifiedDate" type="xs:dateTime"/>
+ <xs:element name="NumberOfFolders" type="xs:integer"/>
+ <xs:element name="NumberOfFiles" type="xs:integer"/>
+ </xs:sequence>
+ </xs:complexType>
+ </xs:element>
+ <xs:element name="UnmanagedDataFile">
+ <xs:complexType>
+ <xs:sequence>
+ <xs:element name="Size" type="xs:integer"/>
+ </xs:sequence>
+ </xs:complexType>
+ </xs:element>
+ </xs:choice>
+ </xs:complexType>
+ </xs:element>
+</xs:schema>
\ No newline at end of file
Modified: trunk/MgDev/Server/src/Common/Manager/ServerManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/ServerManager.cpp 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Common/Manager/ServerManager.cpp 2007-01-27 00:26:59 UTC (rev 1075)
@@ -334,6 +334,57 @@
/// <summary>
+/// </summary>
+void MgServerManager::RemoveConfigurationProperties(CREFSTRING propertySection,
+ MgPropertyCollection* properties)
+ MG_TRY()
+ MG_LOG_TRACE_ENTRY(L"MgServerManager::SetConfigurationProperties()");
+ if (NULL == properties)
+ throw new MgNullArgumentException(
+ L"MgServerManager::SetConfigurationProperties",
+ __LINE__, __WFILE__, NULL, L"", NULL);
+ MgConfiguration* pConfiguration = MgConfiguration::GetInstance();
+ if (NULL == pConfiguration)
+ throw new MgNullReferenceException(
+ // Set the properties
+ pConfiguration->RemoveProperties(propertySection, properties);
+ // Enable/disable specified services for this local server if applicable.
+ if (MgConfigProperties::HostPropertiesSection == propertySection)
+ MgServiceManager* serviceManager = MgServiceManager::GetInstance();
+ assert(NULL != serviceManager);
+ serviceManager->EnableServices(properties);
+ // Certain properties can be updated without requiring a server restart
+ LoadConfigurationProperties();
+ MgLogManager* logManager = MgLogManager::GetInstance();
+ assert(NULL != logManager);
+ logManager->LoadConfigurationProperties();
+ MG_CATCH_AND_THROW(L"MgServerManager.SetConfigurationProperties")
+/// <summary>
/// Gets the information properties for the server.
/// </summary>
MgPropertyCollection* MgServerManager::GetInformationProperties()
Modified: trunk/MgDev/Server/src/Common/Manager/ServerManager.h
--- trunk/MgDev/Server/src/Common/Manager/ServerManager.h 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Common/Manager/ServerManager.h 2007-01-27 00:26:59 UTC (rev 1075)
@@ -57,6 +57,7 @@
MgPropertyCollection* GetConfigurationProperties(CREFSTRING propertySection);
MgPropertyCollection* GetInformationProperties();
Modified: trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.cpp 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.cpp 2007-01-27 00:26:59 UTC (rev 1075)
@@ -24,25 +24,9 @@
// Process-wide MgUnmanagedDataManager
Ptr<MgUnmanagedDataManager> MgUnmanagedDataManager::sm_unmanagedDataManager = (MgUnmanagedDataManager*)NULL;
-const STRING MgUnmanagedDataManager::Sdf = L".SDF";
-const STRING MgUnmanagedDataManager::Shp = L".SHP";
-const STRING MgUnmanagedDataManager::Dwf = L".DWF";
-const STRING MgUnmanagedDataManager::Raster = L".RASTER";
-const STRING MgUnmanagedDataManager::Odbc = L"ODBC";
-const STRING MgUnmanagedDataManager::Folder = L"FOLDER";
-const STRING MgUnmanagedDataManager::Jpg = L".JPG";
-const STRING MgUnmanagedDataManager::Jpeg = L".JPEG";
-const STRING MgUnmanagedDataManager::Jpe = L".JPE";
-const STRING MgUnmanagedDataManager::Png = L".PNG";
-const STRING MgUnmanagedDataManager::Bmp = L".BMP";
-const STRING MgUnmanagedDataManager::Cal = L".CAL";
-const STRING MgUnmanagedDataManager::Tga = L".TGA";
-const STRING MgUnmanagedDataManager::Tif = L".TIF";
-const STRING MgUnmanagedDataManager::Tiff = L".TIFF";
-const STRING MgUnmanagedDataManager::Sid = L".SID";
-const STRING MgUnmanagedDataManager::Ecw = L".ECW";
-const STRING MgUnmanagedDataManager::Bil = L".BIL";
-const STRING MgUnmanagedDataManager::Mdb = L".MDB";
+const STRING MgUnmanagedDataManager::Folders = L"FOLDERS";
+const STRING MgUnmanagedDataManager::Files = L"FILES";
+const STRING MgUnmanagedDataManager::Both = L"BOTH";
const STRING MgUnmanagedDataManager::OpenSquareBracket = L"[";
const STRING MgUnmanagedDataManager::ClosedSquareBracket = L"]";
@@ -75,20 +59,114 @@
/// \brief
-/// Recursive method that returns all files for a given mapping name
+/// Parses the path into mappingName and subfolder
+/// The path must be in the form of:
+/// "[mappingName]subfolder1/subfolder2"
-void MgUnmanagedDataManager::GetFiles(MgStringCollection* files, CREFSTRING mappingName, CREFSTRING rootdir, CREFSTRING subdir, CREFSTRING dataTypeFilter, INT32 depth)
+bool MgUnmanagedDataManager::ParsePath(CREFSTRING path, REFSTRING mappingName, REFSTRING subfolder)
+ bool result = false;
+ if (path.empty())
+ result = true;
+ else
+ // the first character must be open square bracket '['
+ if (path.at(0) == L'[')
+ // find the first closed square bracket ']'
+ size_t pos = path.find_first_of(L']');
+ size_t pathlen = path.length();
+ if (pos > 1 && pos < pathlen)
+ // extract the mapping name
+ mappingName = path.substr(1, pos - 1);
+ if (pos + 1 < pathlen)
+ subfolder = path.substr(pos + 1, pathlen - pos + 1);
+ result = true;
+ return result;
+/// \brief
+/// Parses the filter into an MgStringCollection
+void MgUnmanagedDataManager::ParseFilter(CREFSTRING filter, MgStringCollection* filters)
+ if (!filter.empty())
+ wchar_t* token = const_cast<wchar_t*>(filter.c_str());
+ const wchar_t* delimit = L"; \t\r\n\v\f";
+ wchar_t* state = NULL;
+ for (token = _wcstok(token, delimit, &state);
+ token != NULL;
+ token = _wcstok(NULL, delimit, &state))
+ filters->Add(token);
+/// \brief
+/// Returns true is file ends in one of the extensions in filters
+bool MgUnmanagedDataManager::FilterFile(CREFSTRING file, const MgStringCollection* filters)
+ INT32 numFilters = filters->GetCount();
+ if (numFilters == 0)
+ // no filters, return all files
+ result = true;
+ else
+ for (int i = 0; i < numFilters; i++)
+ if (MgFileUtil::EndsWithExtension(file, filters->GetItem(i)))
+ result = true;
+ break;
+ return result;
+/// \brief
+/// Recursive method that returns all files and/or folders for a given mapping
+/// name
+void MgUnmanagedDataManager::GetFilesAndFolders(string& list, CREFSTRING mappingName, CREFSTRING rootdir, CREFSTRING subdir, const MgStringCollection* filters, bool storeFolders, bool storeFiles, bool recursive)
STRING fulldir = rootdir;
- MgFileUtil::AppendSlashToEndOfPath(fulldir);
+ if (!MgFileUtil::EndsWithSlash(fulldir))
+ MgFileUtil::AppendSlashToEndOfPath(fulldir);
if (!subdir.empty())
fulldir += subdir;
// Open the directory
- ACE_DIR* directory = directory = ACE_OS::opendir(ACE_TEXT_WCHAR_TO_TCHAR(fulldir.c_str()));
+ ACE_DIR* directory = ACE_OS::opendir(ACE_TEXT_WCHAR_TO_TCHAR(fulldir.c_str()));
if (directory != NULL)
@@ -99,23 +177,34 @@
STRING entryName = MG_TCHAR_TO_WCHAR(direntry->d_name);
STRING fullDataPathname = fulldir + entryName;
+ MgDateTime createdDate = MgFileUtil::GetFileCreationTime(fullDataPathname);
+ MgDateTime modifiedDate = MgFileUtil::GetFileModificationTime(fullDataPathname);
if (MgFileUtil::IsFile(fullDataPathname)
- && IsValidFileType(entryName, dataTypeFilter))
+ && storeFiles
+ && FilterFile(entryName, filters))
- // Add to list of files
- files->Add(FormatMappingName(mappingName) + FormatSubdir(subdir) + entryName);
+ INT64 fileSize = MgFileUtil::GetFileSize(fullDataPathname);
+ AddFile(list, mappingName, subdir, entryName, fileSize, createdDate, modifiedDate);
else if (MgFileUtil::IsDirectory(fullDataPathname)
&& entryName.compare(L"..") != 0 // skip ..
- && entryName.compare(L".") != 0 // skip .
- && (depth == -1 || depth > 0))
+ && entryName.compare(L".") != 0) // skip .
- if (depth > 0)
- depth--;
+ if (storeFolders)
+ // Add folders
+ INT32 numFolders = 0;
+ INT32 numFiles = 0;
+ GetNumberOfFilesAndSubfolders(fullDataPathname, numFolders, numFiles);
- // recursive call to get files in subdirecories
- GetFiles(files, mappingName, rootdir, FormatSubdir(subdir) + entryName, dataTypeFilter, depth);
+ AddFolder(list, mappingName, subdir, entryName, numFolders, numFiles, createdDate, modifiedDate);
+ // recursive call to get files in subfolders
+ if (recursive)
+ GetFilesAndFolders(list, mappingName, rootdir, FormatSubdir(subdir) + entryName, filters, storeFolders, storeFiles, recursive);
@@ -125,6 +214,111 @@
/// \brief
+/// Appends folder details to xml string
+void MgUnmanagedDataManager::AddFolder(string& list, CREFSTRING mappingName, CREFSTRING subdir, CREFSTRING entryName, INT32 numFolders, INT32 numFiles, MgDateTime createdDate, MgDateTime modifiedDate)
+ list += "\t<UnmanagedDataFolder>\n";
+ STRING id = FormatMappingName(mappingName) + FormatSubdir(subdir) + entryName;
+ // append a slash to the folder if is NOT just the [alias]
+ if (!entryName.empty() && !MgFileUtil::EndsWithSlash(id))
+ MgFileUtil::AppendSlashToEndOfPath(id);
+ string unmanagedDataId = MgUtil::WideCharToMultiByte(id);
+ list += "\t\t<UnmanagedDataId>";
+ list += unmanagedDataId;
+ list += "</UnmanagedDataId>\n";
+ list += "\t\t<CreatedDate>";
+ list += createdDate.ToXmlStringUtf8();
+ list += "</CreatedDate>\n";
+ list += "\t\t<ModifiedDate>";
+ list += modifiedDate.ToXmlStringUtf8();
+ list += "</ModifiedDate>\n";
+ STRING numFoldersStr;
+ MgUtil::Int32ToString(numFolders, numFoldersStr);
+ list += "\t\t<NumberOfFolders>";
+ list += MgUtil::WideCharToMultiByte(numFoldersStr);
+ list += "</NumberOfFolders>\n";
+ string numFilesStr;
+ MgUtil::Int32ToString(numFiles, numFilesStr);
+ list += "\t\t<NumberOfFiles>";
+ list += numFilesStr;
+ list += "</NumberOfFiles>\n";
+ list += "\t</UnmanagedDataFolder>\n";
+void MgUnmanagedDataManager::AddFile(string& list, CREFSTRING mappingName, CREFSTRING subdir, CREFSTRING entryName, INT64 fileSize, MgDateTime createdDate, MgDateTime modifiedDate)
+ list += "\t<UnmanagedDataFile>\n";
+ string fileSizeStr;
+ MgUtil::Int64ToString(fileSize, fileSizeStr);
+ list += "\t\t<Size>";
+ list += fileSizeStr;
+ list += "</Size>\n";
+ list += "\t</UnmanagedDataFile>\n";
+/// \brief
+/// Retrieves number of folders and files in the specified folder path
+/// pre-condition: assumes dirpath is a valid folder
+void MgUnmanagedDataManager::GetNumberOfFilesAndSubfolders(CREFSTRING dirpath, INT32& numFolders, INT32& numFiles)
+ ACE_DIR* directory = ACE_OS::opendir(ACE_TEXT_WCHAR_TO_TCHAR(dirpath.c_str()));
+ if (directory != NULL)
+ dirent* direntry = NULL;
+ // Go through the directory entries
+ while ((direntry = ACE_OS::readdir(directory)) != NULL)
+ STRING entryName = MG_TCHAR_TO_WCHAR(direntry->d_name);
+ STRING fullDataPathname = dirpath;
+ if (!MgFileUtil::EndsWithSlash(fullDataPathname))
+ MgFileUtil::AppendSlashToEndOfPath(fullDataPathname);
+ fullDataPathname += entryName;
+ if (MgFileUtil::IsFile(fullDataPathname))
+ ++numFiles;
+ else if (MgFileUtil::IsDirectory(fullDataPathname)
+ && entryName.compare(L"..") != 0 // skip ..
+ ++numFolders;
+ ACE_OS::closedir(directory);
+/// \brief
/// Recursive method that returns all subdirectories for a given mapping name
void MgUnmanagedDataManager::GetDirectories(MgStringCollection* dirs, CREFSTRING mappingName, CREFSTRING rootdir, CREFSTRING subdir, INT32 depth)
@@ -174,116 +368,6 @@
/// \brief
-/// Is valid data type filter
-bool MgUnmanagedDataManager::IsValidDataTypeFilter(CREFSTRING dataTypeFilter)
- // TODO: other file types?
- return (dataTypeFilter.empty()
- || ACE_OS::strcasecmp(dataTypeFilter.c_str(), MgUnmanagedDataManager::Sdf.c_str()) == 0
- || ACE_OS::strcasecmp(dataTypeFilter.c_str(), MgUnmanagedDataManager::Shp.c_str()) == 0
- || ACE_OS::strcasecmp(dataTypeFilter.c_str(), MgUnmanagedDataManager::Dwf.c_str()) == 0
- || ACE_OS::strcasecmp(dataTypeFilter.c_str(), MgUnmanagedDataManager::Raster.c_str()) == 0
- || ACE_OS::strcasecmp(dataTypeFilter.c_str(), MgUnmanagedDataManager::Odbc.c_str()) == 0
- || ACE_OS::strcasecmp(dataTypeFilter.c_str(), MgUnmanagedDataManager::Folder.c_str()) == 0);
-/// \brief
-/// checks that a given file is of a specified type
-bool MgUnmanagedDataManager::IsValidFileType(CREFSTRING file, CREFSTRING dataTypeFilter)
- bool result = false;
- if (ACE_OS::strcasecmp(dataTypeFilter.c_str(), MgUnmanagedDataManager::Sdf.c_str()) == 0)
- result = IsSdfFile(file);
- else if (ACE_OS::strcasecmp(dataTypeFilter.c_str(), MgUnmanagedDataManager::Shp.c_str()) == 0)
- result = IsShpFile(file);
- else if (ACE_OS::strcasecmp(dataTypeFilter.c_str(), MgUnmanagedDataManager::Dwf.c_str()) == 0)
- result = IsDwfFile(file);
- else if (ACE_OS::strcasecmp(dataTypeFilter.c_str(), MgUnmanagedDataManager::Raster.c_str()) == 0)
- result = IsRasterFile(file);
- else if (ACE_OS::strcasecmp(dataTypeFilter.c_str(), MgUnmanagedDataManager::Odbc.c_str()) == 0)
- result = IsOdbcFile(file);
- else if (dataTypeFilter.empty())
- result = IsAnyValidFile(file);
- return result;
-/// \brief
-/// Is valid sdf data file
-bool MgUnmanagedDataManager::IsSdfFile(CREFSTRING file)
- return MgFileUtil::EndsWithExtension(file, MgUnmanagedDataManager::Sdf);
-/// \brief
-/// Is valid shp data file
-bool MgUnmanagedDataManager::IsShpFile(CREFSTRING file)
- return MgFileUtil::EndsWithExtension(file, MgUnmanagedDataManager::Shp);
-/// \brief
-/// Is valid dwf data file
-bool MgUnmanagedDataManager::IsDwfFile(CREFSTRING file)
- return MgFileUtil::EndsWithExtension(file, MgUnmanagedDataManager::Dwf);
-/// \brief
-/// Is valid raster data file
-bool MgUnmanagedDataManager::IsRasterFile(CREFSTRING file)
- return MgFileUtil::EndsWithExtension(file, MgUnmanagedDataManager::Jpg)
- || MgFileUtil::EndsWithExtension(file, MgUnmanagedDataManager::Jpeg)
- || MgFileUtil::EndsWithExtension(file, MgUnmanagedDataManager::Jpe)
- || MgFileUtil::EndsWithExtension(file, MgUnmanagedDataManager::Png)
- || MgFileUtil::EndsWithExtension(file, MgUnmanagedDataManager::Bmp)
- || MgFileUtil::EndsWithExtension(file, MgUnmanagedDataManager::Cal)
- || MgFileUtil::EndsWithExtension(file, MgUnmanagedDataManager::Tga)
- || MgFileUtil::EndsWithExtension(file, MgUnmanagedDataManager::Tif)
- || MgFileUtil::EndsWithExtension(file, MgUnmanagedDataManager::Tiff)
- || MgFileUtil::EndsWithExtension(file, MgUnmanagedDataManager::Sid)
- || MgFileUtil::EndsWithExtension(file, MgUnmanagedDataManager::Ecw)
- || MgFileUtil::EndsWithExtension(file, MgUnmanagedDataManager::Bil);
-/// \brief
-/// Is valid odbc data file
-bool MgUnmanagedDataManager::IsOdbcFile(CREFSTRING file)
- return MgFileUtil::EndsWithExtension(file, MgUnmanagedDataManager::Mdb);
-/// \brief
-/// Is valid unmanaged data file
-bool MgUnmanagedDataManager::IsAnyValidFile(CREFSTRING file)
- || MgFileUtil::EndsWithExtension(file, MgUnmanagedDataManager::Shp)
- || MgFileUtil::EndsWithExtension(file, MgUnmanagedDataManager::Dwf)
- || IsRasterFile(file)
- || IsOdbcFile(file);
-/// \brief
/// Surrounds name with square brackets
STRING MgUnmanagedDataManager::FormatMappingName(CREFSTRING name)
@@ -336,11 +420,11 @@
/// \brief
-/// Returns string collection containing unmanaged data
+/// Returns unmanaged data
-MgStringCollection* MgUnmanagedDataManager::EnumerateUnmanagedData(CREFSTRING mappingName, CREFSTRING dataTypeFilter, INT32 depth)
+MgByteReader* MgUnmanagedDataManager::EnumerateUnmanagedData(CREFSTRING path, bool recursive, CREFSTRING select, CREFSTRING filter)
- Ptr<MgStringCollection> dataPaths = new MgStringCollection();
+ Ptr<MgByteReader> byteReader;
MG_TRY()
@@ -348,20 +432,61 @@
MgConfiguration* config = MgConfiguration::GetInstance();
Ptr<MgPropertyCollection> properties = config->GetProperties(MgConfigProperties::UnmanagedDataMappingsSection);
if (properties != NULL)
- if (!IsValidDataTypeFilter(dataTypeFilter))
+ // this XML follows the ResourceList-1.0.0.xsd schema
+ string list = "<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n";
+ list += "<ResourceList xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"ResourceList-1.0.0.xsd\">\n";
+ // check arguments...
+ // pull out the mapping name from the path
+ // path must be in the form of:
+ // "[alias1]"
+ // "[alias1]subfolder1"
+ // "[alias1]subfolder1/"
+ // "[alias1]subfolder1/subfolder2/"
+ STRING mappingName = L"", subfolder = L"";
+ if (!ParsePath(path, mappingName, subfolder))
MgStringCollection arguments;
arguments.Add(L"1");
- arguments.Add(dataTypeFilter);
+ arguments.Add(path);
throw new MgInvalidArgumentException(L"MgUnmanagedDataManager::EnumerateUnmanagedData",
__LINE__, __WFILE__, &arguments, L"", NULL);
- // are we looking in a specific mapping?
+ // select must be:
+ // "FOLDERS"
+ // "FILES"
+ // "BOTH"
+ bool storeFolders = ACE_OS::strcasecmp(select.c_str(), MgUnmanagedDataManager::Folders.c_str()) == 0
+ || ACE_OS::strcasecmp(select.c_str(), MgUnmanagedDataManager::Both.c_str()) == 0;
+ bool storeFiles = ACE_OS::strcasecmp(select.c_str(), MgUnmanagedDataManager::Files.c_str()) == 0
+ ACE_ASSERT(storeFolders || storeFiles);
+ // filter is ignored if select = "FOLDERS"
+ // filter can be:
+ // ".sdf"
+ // ".sdf;.pdf;.shp"
+ // "sdf"
+ // "sdf;dwf;png"
+ MgStringCollection filters;
+ if (storeFiles)
+ ParseFilter(filter, &filters);
+ // are we looking in a specific path?
if (!mappingName.empty())
STRING mappingDir = L"";
@@ -386,26 +511,20 @@
- arguments.Add(mappingName);
else
- // get the files from that directory (recursive) --> use another method
- dataPaths = new MgStringCollection();
- if (ACE_OS::strcasecmp(dataTypeFilter.c_str(), MgUnmanagedDataManager::Folder.c_str()) == 0)
- GetDirectories(dataPaths, mappingName, mappingDir, L"", depth);
- else
- GetFiles(dataPaths, mappingName, mappingDir, L"", dataTypeFilter, depth);
+ // get the files and/or folders from that folder and subfolder (recursive)
+ GetFilesAndFolders(list, mappingName, mappingDir, subfolder, &filters, storeFolders, storeFiles, recursive);
else
- // getting files from all available mappings
+ // getting files starting from virtual root (all mappings)
// iterate thru mappings
for (int i = 0; i < properties->GetCount(); i++)
@@ -414,41 +533,38 @@
STRING mapName = stringProp->GetName();
STRING mapDir = stringProp->GetValue();
- GetDirectories(dataPaths, mapName, mapDir, L"", depth);
- else
- GetFiles(dataPaths, mapName, mapDir, L"", dataTypeFilter, depth);
+ if (MgFileUtil::IsDirectory(mapDir))
+ if (storeFolders)
+ MgDateTime createdDate = MgFileUtil::GetFileCreationTime(mapDir);
+ MgDateTime modifiedDate = MgFileUtil::GetFileModificationTime(mapDir);
+ GetNumberOfFilesAndSubfolders(mapDir, numFolders, numFiles);
+ // add top-level mappings
+ AddFolder(list, mapName, L"", L"", numFolders, numFiles, createdDate, modifiedDate);
+ if (recursive)
+ GetFilesAndFolders(list, mapName, mapDir, L"", &filters, storeFolders, storeFiles, recursive);
- MG_CATCH_AND_THROW(L"MgUnmanagedDataManager.EnumerateUnmanagedData")
- return dataPaths.Detach();
+ list += "</ResourceList>";
+ Ptr<MgByteSource> byteSource = new MgByteSource(
+ (unsigned char*)list.c_str(), (INT32)list.length());
-/// \brief
-/// Returns string collection containing unmanaged data mappings
-MgStringCollection* MgUnmanagedDataManager::EnumerateUnmanagedDataMappings()
- Ptr<MgStringCollection> mappings = new MgStringCollection();
- MgConfiguration* config = MgConfiguration::GetInstance();
- Ptr<MgPropertyCollection> properties = config->GetProperties(MgConfigProperties::UnmanagedDataMappingsSection);
- if (properties != NULL)
- for (int i = 0; i < properties->GetCount(); i++)
- Ptr<MgStringProperty> stringProp = (MgStringProperty*)properties->GetItem(i);
- STRING name = stringProp->GetName();
- mappings->Add(name);
+ byteSource->SetMimeType(MgMimeType::Xml);
+ byteReader = byteSource->GetReader();
+ MG_CATCH_AND_THROW(L"MgUnmanagedDataManager.EnumerateUnmanagedData")
- return mappings.Detach();
+ return byteReader.Detach();
Modified: trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.h
--- trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.h 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.h 2007-01-27 00:26:59 UTC (rev 1075)
@@ -36,18 +36,20 @@
MgUnmanagedDataManager(const MgUnmanagedDataManager&);
MgUnmanagedDataManager& operator=(const MgUnmanagedDataManager&);
- void GetFiles(MgStringCollection* files, CREFSTRING mappingName, CREFSTRING rootdir, CREFSTRING subdir, CREFSTRING dataTypeFilter, INT32 depth);
+ bool ParsePath(CREFSTRING path, REFSTRING mappingName, REFSTRING subfolder);
+ void ParseFilter(CREFSTRING filter, MgStringCollection* filters);
+ bool FilterFile(CREFSTRING file, const MgStringCollection* filters);
+ void GetFilesAndFolders(string& list, CREFSTRING mappingName, CREFSTRING rootdir, CREFSTRING subdir, const MgStringCollection* filters, bool storeFolders, bool storeFiles, bool recursive);
+ // TODO: delete
void GetDirectories(MgStringCollection* dirs, CREFSTRING mappingName, CREFSTRING rootdir, CREFSTRING subdir, INT32 depth);
- bool IsValidDataTypeFilter(CREFSTRING dataTypeFilter);
- bool IsValidFileType(CREFSTRING file, CREFSTRING dataTypeFilter);
+ void AddFolder(string& list, CREFSTRING mappingName, CREFSTRING subdir, CREFSTRING entryName, INT32 numFolders, INT32 numFiles, MgDateTime createdDate, MgDateTime modifiedDate);
+ void AddFile(string& list, CREFSTRING mappingName, CREFSTRING subdir, CREFSTRING entryName, INT64 fileSize, MgDateTime createdDate, MgDateTime modifiedDate);
- bool IsSdfFile(CREFSTRING file);
- bool IsShpFile(CREFSTRING file);
- bool IsDwfFile(CREFSTRING file);
- bool IsRasterFile(CREFSTRING file);
- bool IsOdbcFile(CREFSTRING file);
- bool IsAnyValidFile(CREFSTRING file);
+ void GetNumberOfFilesAndSubfolders(CREFSTRING dirpath, INT32& numFolders, INT32& numFiles);
STRING FormatMappingName(CREFSTRING name);
STRING FormatSubdir(CREFSTRING subdir);
@@ -59,8 +61,7 @@
static MgUnmanagedDataManager* GetInstance();
virtual void Dispose();
- MgStringCollection* EnumerateUnmanagedData(CREFSTRING mappingName, CREFSTRING dataTypeFilter, INT32 depth);
- MgStringCollection* EnumerateUnmanagedDataMappings();
+ MgByteReader* EnumerateUnmanagedData(CREFSTRING path, bool recursive, CREFSTRING select, CREFSTRING filter);
/// Data Members
@@ -68,25 +69,10 @@
static Ptr<MgUnmanagedDataManager> sm_unmanagedDataManager;
- static const STRING Sdf;
- static const STRING Shp;
- static const STRING Dwf;
- static const STRING Raster;
- static const STRING Odbc;
- static const STRING Folder;
- static const STRING Jpg;
- static const STRING Jpeg;
- static const STRING Jpe;
- static const STRING Png;
- static const STRING Bmp;
- static const STRING Cal;
- static const STRING Tga;
- static const STRING Tif;
- static const STRING Tiff;
- static const STRING Sid;
- static const STRING Ecw;
- static const STRING Bil;
- static const STRING Mdb;
+ static const STRING Folders;
+ static const STRING Files;
+ static const STRING Both;
static const STRING OpenSquareBracket;
static const STRING ClosedSquareBracket;
Modified: trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp
--- trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp 2007-01-27 00:26:59 UTC (rev 1075)
@@ -1467,43 +1467,4 @@
destResourceTags = destTagMan.GetTags();
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgApplicationRepositoryManager.CopyResourceData")
-MgStringCollection* MgApplicationRepositoryManager::EnumerateUnmanagedData(
- // TODO:
- //throw new MgNotImplementedException(L"MgResourceService.EnumerateUnmanagedData", __LINE__, __WFILE__, NULL, L"", NULL);
- Ptr<MgStringCollection> dataPaths;
- dataPaths->Add(L"Ueto Aya");
- dataPaths->Add(L"Ito Misaki");
-/// \brief
-MgStringCollection* MgApplicationRepositoryManager::EnumerateUnmanagedDataMappings()
- // TODO:
- //throw new MgNotImplementedException(L"MgResourceService.EnumerateUnmanagedDataMappings", __LINE__, __WFILE__, NULL, L"", NULL);
- Ptr<MgStringCollection> mappings;
- mappings = new MgStringCollection();
- mappings->Add(L"Song Hye Gyo");
- mappings->Add(L"Kim Tae Hee");
- mappings->Add(L"Kim Sun Ah");
Modified: trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.h
--- trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.h 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.h 2007-01-27 00:26:59 UTC (rev 1075)
@@ -85,12 +85,6 @@
MgByteReader* GetResourceData(MgResourceIdentifier* resource,
CREFSTRING dataName, CREFSTRING preProcessTags);
- // Unmanaged Data APIs
-// virtual MgStringCollection* EnumerateUnmanagedData(CREFSTRING mappingName,
-// CREFSTRING dataTypeFilter, UINT32 depth);
-// virtual MgStringCollection* EnumerateUnmanagedDataMappings();
// Helper Methods
void DeleteResourceData(CREFSTRING resourceTags, MgResourceIdentifier* resource);
Modified: trunk/MgDev/Server/src/Services/Resource/Makefile.am
--- trunk/MgDev/Server/src/Services/Resource/Makefile.am 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Services/Resource/Makefile.am 2007-01-27 00:26:59 UTC (rev 1075)
@@ -57,7 +57,6 @@
OpEnumerateResourceReferences.cpp \
OpEnumerateResources.cpp \
OpEnumerateUnmanagedData.cpp \
- OpEnumerateUnmanagedDataMappings.cpp \
OperationInfo.cpp \
OperationParameter.cpp \
OpGetRepositoryContent.cpp \
@@ -135,7 +134,6 @@
OpEnumerateResourceReferences.h \
OpEnumerateResources.h \
OpEnumerateUnmanagedData.h \
- OpEnumerateUnmanagedDataMappings.h \
OperationInfo.h \
OperationParameter.h \
OpGetRepositoryContent.h \
Modified: trunk/MgDev/Server/src/Services/Resource/OpEnumerateUnmanagedData.cpp
--- trunk/MgDev/Server/src/Services/Resource/OpEnumerateUnmanagedData.cpp 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Services/Resource/OpEnumerateUnmanagedData.cpp 2007-01-27 00:26:59 UTC (rev 1075)
@@ -67,30 +67,33 @@
ACE_ASSERT(m_stream != NULL);
- if (3 == m_packet.m_NumArguments)
+ if (4 == m_packet.m_NumArguments)
- STRING mappingName, dataTypeFilter;
- INT32 depth;
- m_stream->GetString(mappingName);
- m_stream->GetString(dataTypeFilter);
- m_stream->GetInt32(depth);
+ STRING path, select, filter;
+ bool recursive;
+ m_stream->GetString(path);
+ m_stream->GetBoolean(recursive);
+ m_stream->GetString(select);
+ m_stream->GetString(filter);
BeginExecution();
MG_LOG_OPERATION_MESSAGE_PARAMETERS_START();
- MG_LOG_OPERATION_MESSAGE_ADD_STRING(mappingName.c_str());
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(path.c_str());
MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
- MG_LOG_OPERATION_MESSAGE_ADD_STRING(dataTypeFilter.c_str());
+ MG_LOG_OPERATION_MESSAGE_ADD_BOOL(recursive);
- MG_LOG_OPERATION_MESSAGE_ADD_INT32(depth);
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(select.c_str());
+ MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(filter.c_str());
MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
Validate();
- m_service->EnumerateUnmanagedData(mappingName, dataTypeFilter, depth);
+ Ptr<MgByteReader> byteReader =
+ m_service->EnumerateUnmanagedData(path, recursive, select, filter);
- EndExecution(dataPaths);
+ EndExecution(byteReader);
else
Deleted: trunk/MgDev/Server/src/Services/Resource/OpEnumerateUnmanagedDataMappings.cpp
--- trunk/MgDev/Server/src/Services/Resource/OpEnumerateUnmanagedDataMappings.cpp 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Services/Resource/OpEnumerateUnmanagedDataMappings.cpp 2007-01-27 00:26:59 UTC (rev 1075)
@@ -1,112 +0,0 @@
-// Copyright (C) 2004-2006 Autodesk, Inc.
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of version 2.1 of the GNU Lesser
-// General Public License as published by the Free Software Foundation.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
-#include "ResourceServiceDefs.h"
-#include "OpEnumerateUnmanagedDataMappings.h"
-#include "ServerResourceService.h"
-#include "LogManager.h"
-/// <summary>
-/// Constructs the object.
-/// </summary>
-MgOpEnumerateUnmanagedDataMappings::MgOpEnumerateUnmanagedDataMappings()
-/// <summary>
-/// Destructs the object.
-/// </summary>
-MgOpEnumerateUnmanagedDataMappings::~MgOpEnumerateUnmanagedDataMappings()
-/// <summary>
-/// Executes the operation.
-/// </summary>
-/// <exceptions>
-/// MgException
-/// </exceptions>
-void MgOpEnumerateUnmanagedDataMappings::Execute()
- ACE_DEBUG((LM_DEBUG, ACE_TEXT(" (%t) MgOpEnumerateUnmanagedDataMappings::Execute()\n")));
- MG_LOG_OPERATION_MESSAGE(L"EnumerateUnmanagedDataMappings");
- MG_RESOURCE_SERVICE_TRY()
- MG_LOG_OPERATION_MESSAGE_INIT(m_packet.m_OperationVersion, m_packet.m_NumArguments);
- ACE_ASSERT(m_stream != NULL);
- if (0 == m_packet.m_NumArguments)
- BeginExecution();
- MG_LOG_OPERATION_MESSAGE_PARAMETERS_START();
- MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
- Validate();
- Ptr<MgStringCollection> mappings = m_service->EnumerateUnmanagedDataMappings();
- EndExecution(mappings);
- else
- if (!m_argsRead)
- throw new MgOperationProcessingException(L"MgOpEnumerateUnmanagedDataMappings.Execute",
- __LINE__, __WFILE__, NULL, L"", NULL);
- // Successful operation
- MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Success.c_str());
- MG_RESOURCE_SERVICE_CATCH(L"MgOpEnumerateUnmanagedDataMappings.Execute")
- if (mgException != NULL)
- // Failed operation
- MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Failure.c_str());
- // Add access log entry for operation
- MG_LOG_OPERATION_MESSAGE_ACCESS_ENTRY();
- MG_RESOURCE_SERVICE_THROW()
Deleted: trunk/MgDev/Server/src/Services/Resource/OpEnumerateUnmanagedDataMappings.h
--- trunk/MgDev/Server/src/Services/Resource/OpEnumerateUnmanagedDataMappings.h 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Services/Resource/OpEnumerateUnmanagedDataMappings.h 2007-01-27 00:26:59 UTC (rev 1075)
@@ -1,33 +0,0 @@
-#ifndef MGOPENUMERATEUNMANAGEDDATAMAPPINGS_H
-#define MGOPENUMERATEUNMANAGEDDATAMAPPINGS_H
-#include "ResourceOperation.h"
-class MgOpEnumerateUnmanagedDataMappings : public MgResourceOperation
-public:
- MgOpEnumerateUnmanagedDataMappings();
- virtual ~MgOpEnumerateUnmanagedDataMappings();
- virtual void Execute();
-#endif
Modified: trunk/MgDev/Server/src/Services/Resource/OperationInfo.cpp
--- trunk/MgDev/Server/src/Services/Resource/OperationInfo.cpp 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Services/Resource/OperationInfo.cpp 2007-01-27 00:26:59 UTC (rev 1075)
@@ -47,7 +47,6 @@
const STRING MgOperationName::GetResourceData=L"GETRESOURCEDATA";
const STRING MgOperationName::EnumerateUnmanagedData=L"ENUMERATEUNMANAGEDDATA";
-const STRING MgOperationName::EnumerateUnmanagedDataMappings=L"ENUMERATEUNMANAGEDDATAMAPPINGS";
const STRING MgOperationInfo::sm_currentVersion = L"1.0.0";
const MgOperationParameter MgOperationInfo::sm_blankParameter;
Modified: trunk/MgDev/Server/src/Services/Resource/OperationInfo.h
--- trunk/MgDev/Server/src/Services/Resource/OperationInfo.h 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Services/Resource/OperationInfo.h 2007-01-27 00:26:59 UTC (rev 1075)
@@ -52,7 +52,6 @@
static const STRING GetResourceData;
static const STRING EnumerateUnmanagedData;
- static const STRING EnumerateUnmanagedDataMappings;
class MgOperationInfo
Modified: trunk/MgDev/Server/src/Services/Resource/ResourceOperationFactory.cpp
--- trunk/MgDev/Server/src/Services/Resource/ResourceOperationFactory.cpp 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Services/Resource/ResourceOperationFactory.cpp 2007-01-27 00:26:59 UTC (rev 1075)
@@ -46,7 +46,6 @@
#include "OpGetResourceData.h"
#include "OpEnumerateUnmanagedData.h"
/// <summary>
@@ -397,19 +396,6 @@
break;
- case MgResourceService::opIdEnumerateUnmanagedDataMappings:
- switch (operationVersion)
- case 1:
- handler.reset(new MgOpEnumerateUnmanagedDataMappings());
- break;
- default:
- throw new MgInvalidOperationVersionException(
- L"MgResourceOperationFactory.GetOperation", __LINE__, __WFILE__, NULL, L"", NULL);
- break;
default:
throw new MgInvalidOperationException(
Modified: trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp
--- trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp 2007-01-27 00:26:59 UTC (rev 1075)
@@ -1808,49 +1808,22 @@
-MgStringCollection* MgServerResourceService::EnumerateUnmanagedData(
+MgByteReader* MgServerResourceService::EnumerateUnmanagedData(
MG_LOG_TRACE_ENTRY(L"MgServerResourceService::EnumerateUnmanagedData()");
- dataPaths = MgUnmanagedDataManager::GetInstance()->EnumerateUnmanagedData(mappingName, dataTypeFilter, depth);
+ byteReader = MgUnmanagedDataManager::GetInstance()->EnumerateUnmanagedData(path, recursive, select, filter);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.EnumerateUnmanagedData")
-/// <summary>
-/// Gets a list of unmanaged data mappings
-/// </summary>
-/// <returns>
-/// Result containing the list of data mappings.
-/// </returns>
-MgStringCollection* MgServerResourceService::EnumerateUnmanagedDataMappings()
- MG_LOG_TRACE_ENTRY(L"MgServerResourceService::EnumerateUnmanagedDataMappings()");
- mappings = MgUnmanagedDataManager::GetInstance()->EnumerateUnmanagedDataMappings();
- MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.EnumerateUnmanagedDataMappings")
/// <summary>
/// Grants the specified roles to the specified users.
Modified: trunk/MgDev/Server/src/Services/Resource/ServerResourceService.h
--- trunk/MgDev/Server/src/Services/Resource/ServerResourceService.h 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Services/Resource/ServerResourceService.h 2007-01-27 00:26:59 UTC (rev 1075)
@@ -146,8 +146,7 @@
- virtual MgStringCollection* EnumerateUnmanagedData(CREFSTRING mappingName, CREFSTRING dataTypeFilter, INT32 depth);
// Site Security related methods
Modified: trunk/MgDev/Server/src/Services/Resource/ServerResourceService.vcproj
--- trunk/MgDev/Server/src/Services/Resource/ServerResourceService.vcproj 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Services/Resource/ServerResourceService.vcproj 2007-01-27 00:26:59 UTC (rev 1075)
@@ -500,30 +500,6 @@
</File>
<File
- RelativePath=".\OpEnumerateUnmanagedDataMappings.cpp"
- <FileConfiguration
- Name="Debug|Win32"
- ExcludedFromBuild="true"
- <Tool
- Name="VCCLCompilerTool"
- </FileConfiguration>
- Name="Release|Win32"
- <Tool
- </File>
- <File
- RelativePath=".\OpEnumerateUnmanagedDataMappings.h"
- </File>
- <File
RelativePath=".\OperationInfo.cpp"
<FileConfiguration
Modified: trunk/MgDev/Server/src/Services/Resource/ServerResourceServiceBuild.cpp
--- trunk/MgDev/Server/src/Services/Resource/ServerResourceServiceBuild.cpp 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Services/Resource/ServerResourceServiceBuild.cpp 2007-01-27 00:26:59 UTC (rev 1075)
@@ -55,7 +55,6 @@
#include "OpSetResourceData.cpp"
#include "OpUpdateRepository.cpp"
#include "OpEnumerateUnmanagedData.cpp"
-#include "OpEnumerateUnmanagedDataMappings.cpp"
#include "Repository.cpp"
#include "RepositoryManager.cpp"
#include "ResourceContainer.cpp"
Modified: trunk/MgDev/Server/src/Services/ServerAdmin/Makefile.am
--- trunk/MgDev/Server/src/Services/ServerAdmin/Makefile.am 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Services/ServerAdmin/Makefile.am 2007-01-27 00:26:59 UTC (rev 1075)
@@ -42,6 +42,7 @@
OpRegisterServicesOnServers.cpp \
OpRenameLog.cpp \
OpSetConfigurationProperties.cpp \
+ OpRemoveConfigurationProperties.cpp \
OpSetDocument.cpp \
OpTakeOffline.cpp \
OpUnregisterServicesOnServers.cpp \
Added: trunk/MgDev/Server/src/Services/ServerAdmin/OpRemoveConfigurationProperties.cpp
--- trunk/MgDev/Server/src/Services/ServerAdmin/OpRemoveConfigurationProperties.cpp 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Services/ServerAdmin/OpRemoveConfigurationProperties.cpp 2007-01-27 00:26:59 UTC (rev 1075)
@@ -0,0 +1,120 @@
+// Copyright (C) 2004-2006 Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#include "MapGuideCommon.h"
+#include "ServerAdminService.h"
+#include "OpRemoveConfigurationProperties.h"
+#include "LogManager.h"
+/// <summary>
+/// Constructs the object.
+/// </summary>
+MgOpRemoveConfigurationProperties::MgOpRemoveConfigurationProperties()
+/// <summary>
+/// Destructs the object.
+/// </summary>
+MgOpRemoveConfigurationProperties::~MgOpRemoveConfigurationProperties()
+/// <summary>
+/// Executes the operation.
+/// </summary>
+/// <exceptions>
+/// MgException
+/// </exceptions>
+void MgOpRemoveConfigurationProperties::Execute()
+ ACE_DEBUG((LM_DEBUG, ACE_TEXT(" (%t) MgOpRemoveConfigurationProperties::Execute()\n")));
+ MG_LOG_OPERATION_MESSAGE(L"RemoveConfigurationProperties");
+ MG_TRY()
+ MG_LOG_OPERATION_MESSAGE_INIT(m_packet.m_OperationVersion, m_packet.m_NumArguments);
+ ACE_ASSERT(m_stream != NULL);
+ if (2 == m_packet.m_NumArguments)
+ STRING propertySection;
+ m_stream->GetString(propertySection);
+ Ptr<MgPropertyCollection> pPropertyCollection;
+ pPropertyCollection = (MgPropertyCollection*)m_stream->GetObject();
+ BeginExecution();
+ MG_LOG_OPERATION_MESSAGE_PARAMETERS_START();
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(propertySection.c_str());
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"MgPropertyCollection");
+ MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
+ // Validate operation
+ Validate();
+ m_service->RemoveConfigurationProperties(propertySection, pPropertyCollection);
+ EndExecution();
+ else
+ if (!m_argsRead)
+ throw new MgOperationProcessingException(L"MgOpRemoveConfigurationProperties.Execute",
+ // Successful operation
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Success.c_str());
+ MG_CATCH(L"MgOpRemoveConfigurationProperties.Execute")
+ if (mgException != NULL)
+ // Failed operation
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Failure.c_str());
+ // Add admin log entry for operation
+ MG_LOG_OPERATION_MESSAGE_ADMIN_ENTRY();
+ MG_THROW()
Added: trunk/MgDev/Server/src/Services/ServerAdmin/OpRemoveConfigurationProperties.h
--- trunk/MgDev/Server/src/Services/ServerAdmin/OpRemoveConfigurationProperties.h 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Services/ServerAdmin/OpRemoveConfigurationProperties.h 2007-01-27 00:26:59 UTC (rev 1075)
@@ -0,0 +1,33 @@
+#ifndef MGOPREMOVECONFIGURATIONPROPERTIES_H
+#define MGOPREMOVECONFIGURATIONPROPERTIES_H
+#include "ServerAdminOperation.h"
+class MgOpRemoveConfigurationProperties : public MgServerAdminOperation
+public:
+ MgOpRemoveConfigurationProperties();
+ virtual ~MgOpRemoveConfigurationProperties();
+ virtual void Execute();
+#endif
Modified: trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminOperationFactory.cpp
--- trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminOperationFactory.cpp 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminOperationFactory.cpp 2007-01-27 00:26:59 UTC (rev 1075)
@@ -43,6 +43,7 @@
#include "OpRegisterServicesOnServers.h"
#include "OpRenameLog.h"
#include "OpSetConfigurationProperties.h"
#include "OpSetDocument.h"
#include "OpSetLogDelimiter.h"
#include "OpSetMaximumLogSize.h"
@@ -113,6 +114,17 @@
break;
+ case MgServerAdminServiceOpId::RemoveConfigurationProperties:
+ switch (operationVersion)
+ case 1:
+ handler.reset(new MgOpRemoveConfigurationProperties());
+ break;
+ default:
+ break;
+ break;
case MgServerAdminServiceOpId::BringOnline:
Modified: trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.cpp
--- trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.cpp 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.cpp 2007-01-27 00:26:59 UTC (rev 1075)
@@ -504,6 +504,28 @@
/// <summary>
+/// </summary>
+void MgServerAdminService::RemoveConfigurationProperties(CREFSTRING propertySection, MgPropertyCollection* properties)
+ MG_TRY()
+ MG_LOG_TRACE_ENTRY(L"MgServerAdminService::SetConfigurationProperties()");
+ MgServerManager* pMan = MgServerManager::GetInstance();
+ if (NULL == pMan)
+ throw new MgNullReferenceException(L"MgServerAdminService::SetConfigurationProperties", __LINE__, __WFILE__, NULL, L"", NULL);
+ pMan->RemoveConfigurationProperties(propertySection, properties);
+ MG_CATCH_AND_THROW(L"MgServerAdminService.SetConfigurationProperties");
+/// <summary>
/// </summary>
MgPropertyCollection* MgServerAdminService::GetInformationProperties()
Modified: trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.h
--- trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.h 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.h 2007-01-27 00:26:59 UTC (rev 1075)
@@ -39,6 +39,7 @@
public:
void BringOnline();
void TakeOffline();
Modified: trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.vcproj
--- trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.vcproj 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.vcproj 2007-01-27 00:26:59 UTC (rev 1075)
@@ -706,6 +706,30 @@
</File>
<File
+ RelativePath=".\OpRemoveConfigurationProperties.cpp"
+ <FileConfiguration
+ Name="Debug|Win32"
+ ExcludedFromBuild="true"
+ <Tool
+ Name="VCCLCompilerTool"
+ </FileConfiguration>
+ Name="Release|Win32"
+ <Tool
+ </File>
+ <File
+ RelativePath=".\OpRemoveConfigurationProperties.h"
+ </File>
+ <File
RelativePath=".\OpRenameLog.cpp"
<FileConfiguration
Modified: trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminServiceBuild.cpp
--- trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminServiceBuild.cpp 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminServiceBuild.cpp 2007-01-27 00:26:59 UTC (rev 1075)
@@ -40,6 +40,7 @@
#include "OpRegisterServicesOnServers.cpp"
#include "OpRenameLog.cpp"
#include "OpSetConfigurationProperties.cpp"
+#include "OpRemoveConfigurationProperties.cpp"
#include "OpSetDocument.cpp"
#include "OpSetLogDelimiter.cpp"
#include "OpSetMaximumLogSize.cpp"
Modified: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/enumerateunmanageddataform.html
--- trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/enumerateunmanageddataform.html 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/enumerateunmanageddataform.html 2007-01-27 00:26:59 UTC (rev 1075)
@@ -12,12 +12,14 @@
<input type="text" name="VERSION" value="1.0.0" size="10">
<p> Locale:
<input type="text" name="LOCALE" value="en" size="10">
-<p> Mapping Name:
-<input type="text" name="MAPPINGNAME" value="" size="30">
-<p> Data Filter Type:
-<input type="text" name="DATATYPEFILTER" value="" size="30">
-<p> Depth:
-<input type="text" name="DEPTH" value="-1" size="10">
+<p> Path:
+<input type="text" name="PATH" value="" size="30">
+<p> Recursive:
+<input type="text" name="RECURSIVE" value="FALSE" size="30">
+<p> Select:
+<input type="text" name="SELECT" value="FOLDERS" size="30">
+<p> Filter:
+<input type="text" name="FILTER" value="" size="30">
<p>
<input type="submit" value="Submit" onclick="SetActionTarget()"> <input type="reset">
</form>
Deleted: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/enumerateunmanageddatamappingsform.html
--- trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/enumerateunmanageddatamappingsform.html 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/enumerateunmanageddatamappingsform.html 2007-01-27 00:26:59 UTC (rev 1075)
@@ -1,19 +0,0 @@
-<html>
-<head>
-<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
-<script type="text/javascript" src="setactiontarget.js" >
-</script>
-</head>
-<body>
-<form name="input" action="" method="get">
-<b>Operation:</b>
-<input type="text" name="OPERATION" value="ENUMERATEUNMANAGEDDATAMAPPINGS" size="50">
-<p> Version:
-<input type="text" name="VERSION" value="1.0.0" size="10">
-<p> Locale:
-<input type="text" name="LOCALE" value="en" size="10">
-<p>
-<input type="submit" value="Submit" onclick="SetActionTarget()"> <input type="reset">
-</form>
-</body>
-</html>
Modified: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/resourceserviceapi.html
--- trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/resourceserviceapi.html 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/resourceserviceapi.html 2007-01-27 00:26:59 UTC (rev 1075)
@@ -29,7 +29,6 @@
<li><a href="changeresourceownerform.html" target="showform">ChangeResourceOwner</a>
<li><a href="inheritpermissionsfromform.html" target="showform">InheritPermissionsFrom</a>
<p>
-<li><a href="enumerateunmanageddatamappingsform.html" target="showform">EnumerateUnmanagedDataMappings</a>
<li><a href="enumerateunmanageddataform.html" target="showform">EnumerateUnmanagedData</a>
</ul>
</body>
Modified: trunk/MgDev/Web/src/HttpHandler/HttpEnumerateUnmanagedData.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpEnumerateUnmanagedData.cpp 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Web/src/HttpHandler/HttpEnumerateUnmanagedData.cpp 2007-01-27 00:26:59 UTC (rev 1075)
@@ -36,15 +36,18 @@
Ptr<MgHttpRequestParam> hrParam = m_hRequest->GetRequestParam();
- // Get mapping name
- m_mappingName = hrParam->GetParameterValue(MgHttpResourceStrings::reqMappingName);
+ // Get path
+ m_path = hrParam->GetParameterValue(MgHttpResourceStrings::reqPath);
- // Get data type filter
- m_dataTypeFilter = hrParam->GetParameterValue(MgHttpResourceStrings::reqDataTypeFilter);
+ // Get the recursive flag
+ STRING recursive = hrParam->GetParameterValue(MgHttpResourceStrings::reqRecursive);
+ m_recursive = SZ_EQI(recursive.c_str(), L"TRUE");
- // Get depth and convert to integer
- string depth_str = MgUtil::WideCharToMultiByte(hrParam->GetParameterValue(MgHttpResourceStrings::reqDepth));
- m_depth = atoi(depth_str.c_str());
+ // Get select
+ m_select = hrParam->GetParameterValue(MgHttpResourceStrings::reqSelect);
+ // Get filter
+ m_filter = hrParam->GetParameterValue(MgHttpResourceStrings::reqFilter);
/// <summary>
@@ -69,8 +72,8 @@
Ptr<MgResourceService> mgprService = (MgResourceService*)(CreateService(MgServiceType::ResourceService));
// call the C++ API
- Ptr<MgStringCollection> dataPaths = mgprService->EnumerateUnmanagedData(m_mappingName, m_dataTypeFilter, m_depth);
- hResult->SetResultObject(dataPaths, MgMimeType::Xml);
+ Ptr<MgByteReader> byteReaderResult = mgprService->EnumerateUnmanagedData(m_path, m_recursive, m_select, m_filter);
+ hResult->SetResultObject(byteReaderResult, byteReaderResult->GetMimeType());
MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpEnumerateUnmanagedData.Execute")
Modified: trunk/MgDev/Web/src/HttpHandler/HttpEnumerateUnmanagedData.h
--- trunk/MgDev/Web/src/HttpHandler/HttpEnumerateUnmanagedData.h 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Web/src/HttpHandler/HttpEnumerateUnmanagedData.h 2007-01-27 00:26:59 UTC (rev 1075)
@@ -44,9 +44,10 @@
void Execute(MgHttpResponse& hResponse);
private:
- STRING m_mappingName;
- STRING m_dataTypeFilter;
- INT32 m_depth;
+ STRING m_path;
+ bool m_recursive;
+ STRING m_select;
+ STRING m_filter;
#endif
Deleted: trunk/MgDev/Web/src/HttpHandler/HttpEnumerateUnmanagedDataMappings.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpEnumerateUnmanagedDataMappings.cpp 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Web/src/HttpHandler/HttpEnumerateUnmanagedDataMappings.cpp 2007-01-27 00:26:59 UTC (rev 1075)
@@ -1,64 +0,0 @@
-#include "HttpHandler.h"
-#include "HttpEnumerateUnmanagedDataMappings.h"
-HTTP_IMPLEMENT_CREATE_OBJECT(MgHttpEnumerateUnmanagedDataMappings)
-/// <summary>
-/// Initializes the common parameters and parameters specific to this request.
-/// </summary>
-/// <param name="name">Input
-/// MgHttpRequest
-/// This contains all the parameters of the request.
-/// </param>
-/// <returns>
-/// nothing
-/// </returns>
-MgHttpEnumerateUnmanagedDataMappings::MgHttpEnumerateUnmanagedDataMappings(MgHttpRequest *hRequest)
- InitializeCommonParameters(hRequest);
-/// <summary>
-/// Executes the specific request.
-/// </summary>
-/// <returns>
-/// MgHttpResponse
-/// This contains the response (including MgHttpResult and StatusCode) from the server.
-/// </returns>
-void MgHttpEnumerateUnmanagedDataMappings::Execute(MgHttpResponse& hResponse)
- Ptr<MgHttpResult> hResult;
- MG_HTTP_HANDLER_TRY()
- hResult = hResponse.GetResult();
- // Check common parameters
- ValidateCommonParameters();
- // Create ProxyResourceService instance
- Ptr<MgResourceService> mgprService = (MgResourceService*)(CreateService(MgServiceType::ResourceService));
- // call the C++ API
- Ptr<MgStringCollection> mappings = mgprService->EnumerateUnmanagedDataMappings();
- hResult->SetResultObject(mappings, MgMimeType::Xml);
- MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpEnumerateUnmanagedDataMappings.Execute")
Deleted: trunk/MgDev/Web/src/HttpHandler/HttpEnumerateUnmanagedDataMappings.h
--- trunk/MgDev/Web/src/HttpHandler/HttpEnumerateUnmanagedDataMappings.h 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Web/src/HttpHandler/HttpEnumerateUnmanagedDataMappings.h 2007-01-27 00:26:59 UTC (rev 1075)
@@ -1,47 +0,0 @@
-#ifndef _RS_ENUMERATE_UNMANAGED_DATA_MAPPINGS_H
-#define _RS_ENUMERATE_UNMANAGED_DATA_MAPPINGS_H
-class MgHttpEnumerateUnmanagedDataMappings : public MgHttpRequestResponseHandler
-HTTP_DECLARE_CREATE_OBJECT()
-public:
- /// <summary>
- /// Initializes the common parameters of the request.
- /// </summary>
- /// <param name="name">Input
- /// MgHttpRequest
- /// This contains all the parameters of the request.
- /// </param>
- /// <returns>
- /// nothing
- /// </returns>
- MgHttpEnumerateUnmanagedDataMappings(MgHttpRequest *hRequest);
- /// <summary>
- /// Executes the specific request.
- /// </summary>
- /// <param name="hResponse">Input
- /// This contains the response (including MgHttpResult and StatusCode) from the server.
- /// </param>
- void Execute(MgHttpResponse& hResponse);
-#endif
Modified: trunk/MgDev/Web/src/HttpHandler/HttpHandler.vcproj
--- trunk/MgDev/Web/src/HttpHandler/HttpHandler.vcproj 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Web/src/HttpHandler/HttpHandler.vcproj 2007-01-27 00:26:59 UTC (rev 1075)
@@ -474,30 +474,6 @@
</File>
<File
- RelativePath=".\HttpEnumerateUnmanagedDataMappings.cpp"
- <Tool
- <Tool
- </File>
- <File
- RelativePath=".\HttpEnumerateUnmanagedDataMappings.h"
- </File>
- <File
RelativePath=".\HttpGetRepositoryContent.cpp"
<FileConfiguration
Modified: trunk/MgDev/Web/src/HttpHandler/HttpHandlerBuild.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpHandlerBuild.cpp 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Web/src/HttpHandler/HttpHandlerBuild.cpp 2007-01-27 00:26:59 UTC (rev 1075)
@@ -113,7 +113,6 @@
#include "HttpKmlGetLayer.cpp"
#include "HttpKmlGetFeatures.cpp"
#include "HttpEnumerateUnmanagedData.cpp"
-#include "HttpEnumerateUnmanagedDataMappings.cpp"
#include "WmsMapUtil.cpp"
Modified: trunk/MgDev/Web/src/HttpHandler/HttpRequest.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpRequest.cpp 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Web/src/HttpHandler/HttpRequest.cpp 2007-01-27 00:26:59 UTC (rev 1075)
@@ -38,7 +38,6 @@
#include "HttpEnumerateUsers.h"
#include "HttpEnumerateGroups.h"
#include "HttpEnumerateUnmanagedData.h"
// Http Drawing Service operations
#include "HttpGetDrawing.h"
@@ -386,7 +385,6 @@
httpClassCreators[MgHttpResourceStrings::opCsGetBaseLibrary] = MgHttpCsGetBaseLibrary::CreateObject;
httpClassCreators[MgHttpResourceStrings::opCsIsValid] = MgHttpCsIsValid::CreateObject;
httpClassCreators[MgHttpResourceStrings::opEnumerateUnmanagedData] = MgHttpEnumerateUnmanagedData::CreateObject;
- httpClassCreators[MgHttpResourceStrings::opEnumerateUnmanagedDataMappings] = MgHttpEnumerateUnmanagedDataMappings::CreateObject;
httpPostHandlerCreators.push_back(MgHttpWfsGetCapabilities::ProcessPostRequest);
httpPostHandlerCreators.push_back(MgHttpWfsDescribeFeatureType::ProcessPostRequest);
Modified: trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp 2007-01-27 00:26:59 UTC (rev 1075)
@@ -98,8 +98,10 @@
const STRING MgHttpResourceStrings::reqPackage = L"PACKAGE";
const STRING MgHttpResourceStrings::reqOwner = L"OWNER";
const STRING MgHttpResourceStrings::reqIncludeDescendants = L"INCLUDEDESCENDANTS";
-const STRING MgHttpResourceStrings::reqMappingName = L"MAPPINGNAME";
-const STRING MgHttpResourceStrings::reqDataTypeFilter = L"DATATYPEFILTER";
+const STRING MgHttpResourceStrings::reqPath = L"PATH";
+const STRING MgHttpResourceStrings::reqRecursive = L"RECURSIVE";
+const STRING MgHttpResourceStrings::reqSelect = L"SELECT";
+const STRING MgHttpResourceStrings::reqFilter = L"FILTER";
// Resource Service Operation Requests
const STRING MgHttpResourceStrings::opEnumerateRepositories = L"ENUMERATEREPOSITORIES";
@@ -128,7 +130,6 @@
const STRING MgHttpResourceStrings::opGetResourceData = L"GETRESOURCEDATA";
const STRING MgHttpResourceStrings::opEnumerateUnmanagedData = L"ENUMERATEUNMANAGEDDATA";
-const STRING MgHttpResourceStrings::opEnumerateUnmanagedDataMappings = L"ENUMERATEUNMANAGEDDATAMAPPINGS";
// Predefined Feature Service Request Parameters
const STRING MgHttpResourceStrings::reqFeatProperty = L"PROPERTY";
Modified: trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.h
--- trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.h 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.h 2007-01-27 00:26:59 UTC (rev 1075)
@@ -102,8 +102,10 @@
static const STRING reqPackage;
static const STRING reqOwner;
static const STRING reqIncludeDescendants;
- static const STRING reqMappingName;
- static const STRING reqDataTypeFilter;
+ static const STRING reqPath;
+ static const STRING reqRecursive;
+ static const STRING reqSelect;
+ static const STRING reqFilter;
// PREDEFINED FEATURE REQUEST PARAMETERS
static const STRING reqFeatProperty;
@@ -241,7 +243,6 @@
static const STRING opGetResourceData;
static const STRING opEnumerateUnmanagedData;
- static const STRING opEnumerateUnmanagedDataMappings;
// Feature services
static const STRING opGetFeatureProviders;
Modified: trunk/MgDev/Web/src/HttpHandler/Makefile.am
--- trunk/MgDev/Web/src/HttpHandler/Makefile.am 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Web/src/HttpHandler/Makefile.am 2007-01-27 00:26:59 UTC (rev 1075)
@@ -45,7 +45,6 @@
HttpEnumerateResourceReferences.cpp \
HttpEnumerateResources.cpp \
HttpEnumerateUnmanagedData.cpp \
- HttpEnumerateUnmanagedDataMappings.cpp \
HttpEnumerateUsers.cpp \
HttpExecuteSqlQuery.cpp \
HttpGetCapabilities.cpp \
@@ -159,7 +158,6 @@
HttpEnumerateResourceReferences.h \
HttpEnumerateResources.h \
HttpEnumerateUnmanagedData.h \
- HttpEnumerateUnmanagedDataMappings.h \
HttpEnumerateUsers.h \
HttpExecuteSqlQuery.h \
HttpGetCapabilities.h \
Added: trunk/MgDev/Web/src/mapadmin/addunmanageddata.php
--- trunk/MgDev/Web/src/mapadmin/addunmanageddata.php 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Web/src/mapadmin/addunmanageddata.php 2007-01-27 00:26:59 UTC (rev 1075)
@@ -0,0 +1,163 @@
+<?php // PHP Preprocessing --------------------------------------------------------------------------------------------------------------
+try
+ include 'resizableadmin.php';
+ LoadSessionVars();
+ // Did the user logout?
+ CheckForLogout();
+ // Are we cancelling? If so, there is nothing to do.
+ CheckForCancel( 'unmanageddatamanagement.php' );
+ // Define local vars
+ $menuCategory = UNMANAGEDDATA_MANAGEMENT_MENU_ITEM;
+ $menuItem = ADD_UNMANAGEDDATA_MENU_ITEM;
+ $pageTitle = ADD_UNMANAGEDDATA_TITLE;
+ $helpPage = 'HelpDocs/adding_and_deleting_unmanageddata.htm';
+ $pageName = 'AddUnmanagedDataPage';
+ $formName = 'AddUnmanagedDataForm';
+ $homePage = 'unmanageddatamanagement.php';
+ $mappingName = "";
+ $mappingNameID = 'mappingName';
+ $location = "";
+ $locationID = 'location';
+ $confirmationMsg = "";
+ $errorMsg = "";
+ $mappings = array();
+ $siteServerAddress = "";
+ $selectedServerID = "Server";
+ $serverAdmin = 0;
+ $errorMsg = "";
+ $pageEnabled = false;
+ // Get Server
+ $siteServerAddress = $site->GetCurrentSiteAddress();
+ GetServerSelection( $selectedServerID, $selectedServer );
+ $serverRec = GetDataForServer( $selectedServer );
+ if ( $serverRec == NULL )
+ throw new Exception( sprintf( $errNotFound, $selectedServer ) );
+ if ( !$serverRec->poweredUp )
+ throw new Exception( sprintf( $errServerIsDown, $selectedServer ) );
+ // Get props values from server
+ $serverAdmin = new MgServerAdmin();
+ $serverAdmin->Open( $selectedServer, $userInfo );
+ $mappings = GetUnmanagedDataMappings( $serverAdmin );
+ // Is this our first time here?
+ if ( FirstTimeHere( $pageName ) )
+ // do nothing here
+ // Otherwise, Save button must have been hit
+ else
+ // Get submitted data
+ if ( array_key_exists( $mappingNameID, $_POST ) )
+ $mappingName = $_POST[ $mappingNameID ];
+ if ( array_key_exists( $locationID, $_POST ) )
+ $location = $_POST[ $locationID ];
+ // Validate inputs.
+ if ( empty( $mappingName ) )
+ throw new Exception( $errMappingNameMissing );
+ if ( array_key_exists( $mappingName, $mappings ) )
+ throw new Exception( $errMappingNameExists );
+ if ( empty( $location ) )
+ throw new Exception( $errLocationMissing );
+ // Add new mapping.
+ SetUnmanagedDataMapping( $serverAdmin, $mappingName, $location );
+ $serverAdmin->Close();
+ // Everything is OK.
+ $confirmationMsg = sprintf( $confSuccessfulAddition, $mappingName );
+ $selectedMapping = $mappingName;
+ SaveSessionVars();
+ header( 'Location: unmanageddatamanagement.php?'.strip_tags(SID) );
+ exit();
+catch ( MgException $e )
+ CheckForFatalMgException( $e );
+ $errorMsg = $e->GetMessage();
+catch ( Exception $e )
+ $errorMsg = $e->getMessage();
+<!-- PAGE DEFINITION ----------------------------------------------------------------------------------------------------->
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+ <?php OutputHeader( $pageTitle ); ?>
+<body>
+ <table cellspacing="0" cellpadding="0" border="0" class="main">
+ <tr>
+ <?php DisplaySiteHeader( true, true, true, true, $formName, $homePage ); ?>
+ </tr>
+ <tr>
+ <?php DisplayLefthandSash( $menuItem ); ?>
+ <!-- Contents Area ------------------------------------------------------------------------------------------------->
+ <?php BeginContentArea( $formName ); ?>
+ <?php
+ DeclareHiddenVars( $pageName );
+ DisplayTitleBar( $pageTitle, $helpPage );
+ DisplaySaveCancelBar();
+ DisplayConfirmationMsg( $confirmationMsg );
+ DisplayErrorMsg( $errorMsg );
+ <!-- Input Area -->
+ <table border="0" cellspacing="0" class="inputForm">
+ <tr>
+ <td class="addUserInputLabel">Mapping Name :</td>
+ <td class="inputFormValue"><input class="inputFormValue" name="<?php echo $mappingNameID?>" type="text" value="<?php echo $mappingName?>"></td>
+ </tr>
+ <tr>
+ <td class="addUserInputLabel">Location :</td>
+ <td class="inputFormValue"><input class="inputFormValue" name="<?php echo $locationID?>" type="text" value="<?php echo $location?>"></td>
+ </tr>
+ </table>
+ <?php EndContentArea( true, $formName, $mappingNameID ); ?>
+ <!-- End of Contents Area --------------------------------------------------------------------------------------------->
+ </tr>
+ </table>
+</body>
+</html>
Added: trunk/MgDev/Web/src/mapadmin/editunmanageddata.php
--- trunk/MgDev/Web/src/mapadmin/editunmanageddata.php 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Web/src/mapadmin/editunmanageddata.php 2007-01-27 00:26:59 UTC (rev 1075)
@@ -0,0 +1,175 @@
+try
+ CheckForLogout();
+ // Local global vals.
+ $menuItem = EDIT_UNMANAGEDDATA_MENU_ITEM;
+ $pageTitle = EDIT_UNMANAGEDDATA_TITLE;
+ $pageName = 'EditUnmanagedDataPage';
+ $formName = 'EditUnmanagedDataForm';
+ $selectedMappingID = 'SelectedMapping';
+ $location = "";
+ $errorMsg = "";
+ $serverAdmin = 0;
+ $errorMsg = "";
+ // Get Server
+ // Was the selected user passed in the URL?
+ if ( array_key_exists( $selectedMappingID, $_GET ) )
+ $selectedMapping = $_GET[ $selectedMappingID ];
+ // Get info for selected user
+ $mappingName = $selectedMapping;
+ $location = $mappings[ $mappingName ];
+ // The save button was hit.
+ else
+ // Update parameters of user.
+ if ($mappingName != $selectedMapping)
+ DeleteUnmanagedDataMapping( $serverAdmin, $selectedMapping );
+ exit();
+<html>
+<body>
+ <tr>
+ </tr>
+ <tr>
+ <?php
+ <tr>
+ <td class="editUserInputLabel">Mapping Name :</td>
+ <td class="inputFormValue"><input class="inputFormValue" name="<?php echo $mappingNameID?>" type="text" value="<?php echo $mappingName?>" size="60"></td>
+ </tr>
+ <tr>
+ <td class="editUserInputLabel">Location :</td>
+ <td class="inputFormValue"><input class="inputFormValue" name="<?php echo $locationID?>" type="text" value="<?php echo $location?>" size="60"></td>
+ </tr>
+ </table>
+ <?php EndContentArea( true, $formName, $mappingNameID );?>
+ </tr>
+ </table>
+</body>
+</html>
Modified: trunk/MgDev/Web/src/mapadmin/msgs.php
--- trunk/MgDev/Web/src/mapadmin/msgs.php 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Web/src/mapadmin/msgs.php 2007-01-27 00:26:59 UTC (rev 1075)
@@ -29,6 +29,9 @@
$errUserNameMissing = "User's name is not specified.";
$errNoGroupSelectionForDelete = "Group must be selected in order to delete.";
$errGroupNameMissing = "Group's name is not specified.";
+ $errMappingNameMissing = "Mapping name is not specified.";
+ $errMappingNameExists = "Mapping name already exists.";
+ $errLocationMissing = "Location is not specified.";
$errInvalidInput = "Input values are invalid.";
$errInvalidServerName = "Server name must be specified.";
$errInvalidServerAddress = "Server IP address must be specified.";
@@ -67,9 +70,9 @@
$errServerAddressMissing = "Server address is not specified.";
$errServerIsDown = "%s is down.";
$errCannotOpenFolder = 'Cannot access "%s". Please ensure that the path exists and you have access permission.';
- $errNoPackageSpecified = "No package specified.";
- $errNoResourceSpecified = "No resource folder specified.";
- $errCannotCreatePackage = "Cannot create package %s from folder %s: ";
+ $errNoPackageSpecified = "No package specified.";
+ $errNoResourceSpecified = "No resource folder specified.";
+ $errCannotCreatePackage = "Cannot create package %s from folder %s: ";
$errNoPackagesFound = "No packages found.";
$errNoPackageLog = "No package log specified.";
$errNoPackageSelectionForDelete = "Package must be selected in order to delete.";
@@ -83,7 +86,7 @@
$errInvalidTileCachePath = "Tile service tile cache path must be specified.";
$errInvalidSessionTimeOut = "Site service session timeout is invalid.";
$errInvalidSessionTimerInt = "Site service session timer interval is invalid.";
- $errCannotGetPackageStatus = "Cannot get package status: %s";
+ $errCannotGetPackageStatus = "Cannot get package status: %s";
// Confirmation Messages:
$confSuccessfulDeletion = "%s has been successfully deleted.";
Modified: trunk/MgDev/Web/src/mapadmin/resizablepagecomponents.php
--- trunk/MgDev/Web/src/mapadmin/resizablepagecomponents.php 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Web/src/mapadmin/resizablepagecomponents.php 2007-01-27 00:26:59 UTC (rev 1075)
@@ -68,6 +68,9 @@
define( 'CONFIGURE_SERVICES_TITLE', "Configure Services" );
define( 'LOG_MANAGEMENT_TITLE', "Manage Logs" );
define( 'SELECT_SITE_SERVER_TITLE', "Select Site Server" );
+ define( 'UNMANAGEDDATA_MANAGEMENT_TITLE', "Configure Unmanaged Data" );
+ define( 'ADD_UNMANAGEDDATA_TITLE', "Add Mapping" );
+ define( 'EDIT_UNMANAGEDDATA_TITLE', "Edit Mapping" );
define( 'ADD_GROUP_TITLE', "Add Group" );
define( 'EDIT_GROUP_TITLE', "Edit Group" );
@@ -84,6 +87,14 @@
define( 'CONFIGURE_WFS_TITLE', "Configure WFS" );
+ define( 'UNMANAGEDDATA_MANAGEMENT_MENU_ITEM', "Configure Unmanaged Data" );
+ define( 'ADD_UNMANAGEDDATA_MENU_ITEM', "Add Mapping" );
+ define( 'EDIT_UNMANAGEDDATA_MENU_ITEM', "Edit Mapping" );
+ $unmanagedDataMenuGroup[ UNMANAGEDDATA_MANAGEMENT_MENU_ITEM ] = 'unmanageddatamanagement.php';
+ $unmanagedDataMenuGroup[ ADD_UNMANAGEDDATA_MENU_ITEM ] = 'addunmanageddata.php';
+ $unmanagedDataMenuGroup[ EDIT_UNMANAGEDDATA_MENU_ITEM ] = 'editunmanageddata.php';
define( 'HELP_TITLE', "Help" );
@@ -343,7 +354,7 @@
$class = "navLinkHeading";
foreach( $menuGroup as $menuItem => $href )
- if ( $currMenuItem != $menuItem && ($menuItem == EDIT_GROUP_MENU_ITEM || $menuItem == EDIT_USER_MENU_ITEM) )
+ if ( $currMenuItem != $menuItem && ($menuItem == EDIT_GROUP_MENU_ITEM || $menuItem == EDIT_USER_MENU_ITEM || $menuItem == EDIT_UNMANAGEDDATA_MENU_ITEM ) )
continue;
echo ' <tr>',"\n";
if ( $currMenuItem == $menuItem )
@@ -366,6 +377,7 @@
global $packagesMenuGroup;
global $wmsMenuGroup;
global $wfsMenuGroup;
+ global $unmanagedDataMenuGroup;
echo '<td class="lhSash">',"\n";
echo ' <table cellspacing="0" cellpadding="0" border="0">',"\n";
@@ -384,7 +396,8 @@
echo "<tr><td><hr></td></tr>\n";
DisplayMenuGroup( $currMenuItem, CONFIGURE_WFS_MENU_ITEM, $wfsMenuGroup );
+ DisplayMenuGroup( $currMenuItem, UNMANAGEDDATA_MANAGEMENT_MENU_ITEM, $unmanagedDataMenuGroup );
+ echo "<tr><td><hr></td></tr>\n";
echo ' </table>',"\n";
echo '</td>',"\n";
@@ -455,11 +468,11 @@
echo '<br>',"\n";
function DisplaySiteServerSelector( $selectedSiteServerID )
global $site;
echo '<select class="serverSelector" name="',$selectedSiteServerID.NO_PERSISTENCE_FLAG,'" size="1" >', "\n";
for($i = 0; $i < $site->GetSiteServerCount(); $i++)
@@ -474,7 +487,7 @@
echo '</select>', "\n";
function GetSiteServerSelection( $selectedSiteServerID )
global $site;
@@ -1291,6 +1304,7 @@
$props->dataCacheSize = $post[ FEATURE_SERVICE_DATA_CACHE_SIZE_ID ];
function DisplayFeatureServicePropVals( $enabled, $props )
$sectionFields = array( FEATURE_SERVICE_CONN_POOL_SIZE_ID, FEATURE_SERVICE_CONN_TIMEOUT_ID, FEATURE_SERVICE_CONN_TIMER_INT_ID, FEATURE_SERVICE_DATA_CACHE_SIZE_ID );
Modified: trunk/MgDev/Web/src/mapadmin/serverdatafunctions.php
--- trunk/MgDev/Web/src/mapadmin/serverdatafunctions.php 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Web/src/mapadmin/serverdatafunctions.php 2007-01-27 00:26:59 UTC (rev 1075)
@@ -143,6 +143,11 @@
// Parse XML in $buffer
parseUnicodeData( $buffer, $targetTable, 'User', 'userRecParser' );
+ // test
+ echo '$targetTable==> ';
+ echo print_r($targetTable);
SortTable( $targetTable, $userSortColumn, $userSortDirection );
@@ -858,6 +863,64 @@
return $versionProp->GetValue();
+ function GetUnmanagedDataMappings( $serverAdmin )
+ $props = $serverAdmin->GetConfigurationProperties( MgConfigProperties::UnmanagedDataMappingsSection );
+ for ( $i = 0; $i < $props->GetCount(); $i++)
+ $prop = $props->GetItem($i);
+ $mappings[$prop->GetName()] = $prop->GetValue();
+ return $mappings;
+ // if $mappingName already exists, then that mapping is updated
+ // if $mappingName does NOT exist, it is added
+ function SetUnmanagedDataMapping( $serverAdmin, $mappingName, $location )
+ $props = new MgPropertyCollection();
+ $prop = new MgStringProperty( $mappingName, $location );
+ $props->Add( $prop );
+ $serverAdmin->SetConfigurationProperties( MgConfigProperties::UnmanagedDataMappingsSection, $props );
+ function DeleteUnmanagedDataMapping( $serverAdmin, $mappingName )
+ $success = false;
+ $prop = new MgStringProperty( $mappingName, "" ); // value doesn't matter
+ $serverAdmin->RemoveConfigurationProperties( MgConfigProperties::UnmanagedDataMappingsSection, $props );
+ $success = true;
+ return $success;
+ function LoadMappingTable( &$targetTable, $table, $firstIndex, $lastIndex )
+ $targetTable = array();
+ $iMapping = -1;
+ foreach ( $table as $key => $val )
+ $iMapping++;
+ if ( $iMapping < $firstIndex )
+ continue;
+ if ( $iMapping > $lastIndex )
+ break;
+ $targetTable[ $key ] = $val;
////// Properties //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
class GeneralPropsRecord
@@ -1454,12 +1517,12 @@
$logDelimiters[ SPACE_DELIMITER ] = " ";
$logDelimiters[ NO_DELIMITER ] = "";
- define( 'ARCHIVE_NONE', "None" );
+ define( 'ARCHIVE_NONE', "None" );
define( 'ARCHIVE_DAILY', "Day" );
define( 'ARCHIVE_MONTHLY', "Month" );
define( 'ARCHIVE_YEARLY', "Year" );
- $archiveFrequencies[ ARCHIVE_NONE ] = "";
- $archiveFrequencies[ ARCHIVE_DAILY ] = "%d";
+ $archiveFrequencies[ ARCHIVE_NONE ] = "";
+ $archiveFrequencies[ ARCHIVE_DAILY ] = "%d";
$archiveFrequencies[ ARCHIVE_MONTHLY ] = "%m";
$archiveFrequencies[ ARCHIVE_YEARLY ] = "%y";
@@ -1767,19 +1830,19 @@
function PackageTableRecord( $serverAdmin, $packageName )
- global $errCannotGetPackageStatus;
- $this->status = "";
- try
- $statusInfo = $serverAdmin->GetPackageStatus( $packageName );
- $this->status = ( $statusInfo != NULL ) ? $statusInfo->GetStatusMessage() : "";
- catch ( MgException $e )
- $this->status = sprintf( $errCannotGetPackageStatus, $e->GetMessage() );
+ global $errCannotGetPackageStatus;
+ $this->status = "";
+ try
+ $statusInfo = $serverAdmin->GetPackageStatus( $packageName );
+ $this->status = ( $statusInfo != NULL ) ? $statusInfo->GetStatusMessage() : "";
+ catch ( MgException $e )
+ $this->status = sprintf( $errCannotGetPackageStatus, $e->GetMessage() );
Modified: trunk/MgDev/Web/src/mapadmin/sessionvars.php
--- trunk/MgDev/Web/src/mapadmin/sessionvars.php 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Web/src/mapadmin/sessionvars.php 2007-01-27 00:26:59 UTC (rev 1075)
@@ -30,6 +30,7 @@
$selectedService = "";
$selectedLog = ACCESS_LOG;
$selectedPackage = "";
+ $selectedMapping = "";
$packageLoadErrorMsg = "";
$packageMakeErrorMsg = "";
$packageLoadConfirmationMsg = "";
@@ -59,6 +60,7 @@
global $selectedService;
global $selectedLog;
global $selectedPackage;
+ global $selectedMapping;
global $packageLoadErrorMsg;
global $packageMakeErrorMsg;
global $packageLoadConfirmationMsg;
@@ -84,6 +86,7 @@
@@ -123,6 +126,7 @@
@@ -153,6 +157,7 @@
$selectedService = $_SESSION[ 'selectedService' ];
$selectedLog = $_SESSION[ 'selectedLog' ];
$selectedPackage = $_SESSION[ 'selectedPackage' ];
+ $selectedMapping = $_SESSION[ 'selectedMapping' ];
$packageLoadErrorMsg = $_SESSION[ 'packageLoadErrorMsg' ];
$packageMakeErrorMsg = $_SESSION[ 'packageMakeErrorMsg' ];
$packageLoadConfirmationMsg = $_SESSION[ 'packageLoadConfirmationMsg' ];
@@ -200,6 +205,7 @@
@@ -225,6 +231,7 @@
$_SESSION[ 'selectedService' ] = $selectedService;
$_SESSION[ 'selectedLog' ] = $selectedLog;
$_SESSION[ 'selectedPackage' ] = $selectedPackage;
+ $_SESSION[ 'selectedMapping' ] = $selectedMapping;
$_SESSION[ 'packageLoadErrorMsg' ] = $packageLoadErrorMsg;
$_SESSION[ 'packageMakeErrorMsg' ] = $packageMakeErrorMsg;
$_SESSION[ 'packageLoadConfirmationMsg' ] = $packageLoadConfirmationMsg;
Added: trunk/MgDev/Web/src/mapadmin/unmanageddatamanagement.php
--- trunk/MgDev/Web/src/mapadmin/unmanageddatamanagement.php 2007-01-26 19:37:39 UTC (rev 1074)
+++ trunk/MgDev/Web/src/mapadmin/unmanageddatamanagement.php 2007-01-27 00:26:59 UTC (rev 1075)
@@ -0,0 +1,270 @@
+try
+ CheckForLogout();
+ // Define Local values
+ $pageTitle = UNMANAGEDDATA_MANAGEMENT_MENU_ITEM;
+ $helpPage = 'HelpDocs/managing_unmanageddata.htm';
+ $pageName = 'UnmanagedDataManagementPage';
+ $formName = 'UnmanagedDataManagementForm';
+ $homePage = NULL;
+ $mappingTable = array();
+ $pageSize = 25;
+ $firstPageIndex = -1;
+ $lastPageIndex = -1;
+ $numMappings = 0;
+ $currPage = 1;
+ $sortDirection= DEFAULT_SORT_DIRECTION;
+ $sortDirectionID = SORT_DIRECTION_ID;
+ $sortColumn = NAME_SORT_COLUMN;
+ $sortColumnID = SORT_COLUMN_ID;
+ $serverAdmin = 0;
+ $refreshRequested = false;
+ $errorMsg = "";
+ // Get Server
+ // Get input values
+ $selectedMapping = $_GET[$selectedMappingID];
+ else
+ if ( array_key_exists( $selectedMappingID, $_POST ) )
+ $selectedMapping = $_POST[$selectedMappingID];
+ if ( array_key_exists( $sortDirectionID, $_GET ) )
+ $sortDirection = $_GET[$sortDirectionID];
+ else
+ if ( array_key_exists( $sortDirectionID, $_POST ) )
+ $sortDirection = $_POST[$sortDirectionID];
+ SetUserSortDirection( $sortDirection );
+ if ( array_key_exists( $sortColumnID, $_GET ) )
+ $sortColumn = $_GET[$sortColumnID];
+ else
+ if ( array_key_exists( $sortColumnID, $_POST ) )
+ $sortColumn = $_POST[$sortColumnID];
+ SetUserSortColumn( $sortColumn );
+ // Are we switching to another page?
+ CheckForPageSwitch();
+ // Are we deleting the selected mapping?
+ //if ( CheckForDeleteSelection() && DeleteUnmanagedDataMapping( $serverAdmin, $mappings, $selectedMapping ) )
+ if ( CheckForDeleteSelection() && DeleteUnmanagedDataMapping( $serverAdmin, $selectedMapping ) )
+ $confirmationMsg = sprintf( $confSuccessfulDeletion, $selectedMapping );
+// Load display data
+try
+ // sort mappings
+ if ($sortColumn == NAME_SORT_COLUMN)
+ if ($sortDirection == ASCENDING_SORT_DIRECTION)
+ ksort($mappings);
+ else
+ krsort($mappings);
+ else
+ asort($mappings);
+ else
+ arsort($mappings);
+ $numMappings = sizeof( $mappings );
+ $mappingsKeys = array_keys( $mappings );
+ $currPage = GetPageNumber( $mappingsKeys, $selectedMapping, $pageSize );
+ GetPageRange( $currPage, $numMappings, $pageSize, $firstPageIndex, $lastPageIndex );
+ LoadMappingTable( $mappingTable, $mappings, $firstPageIndex, $lastPageIndex );
+ if ( !array_key_exists( $selectedMapping, $mappingTable ) && $numMappings > 0 )
+ $selectedMapping = $mappingsKeys[ $firstPageIndex ];
+ else if ( $numMappings == 0 )
+ $selectedMapping = '';
+ if ( empty( $errorMsg ) )
+<html>
+<body>
+ <tr>
+ </tr>
+ <tr>
+ <?php DisplayLefthandSash( $menuCategory ); ?>
+ <?php
+ <input type="hidden" name="<?php echo TABLE_PAGE_ID?>" value="<?php echo $currPage?>">
+ <input type="hidden" name="<?php echo $sortColumnID?>" value="<?php echo $sortColumn?>">
+ <input type="hidden" name="<?php echo $sortDirectionID?>" value="<?php echo $sortDirection?>">
+ <input type="hidden" name="<?php echo $selectedMappingID?>" value="<?php echo $selectedMapping?>">
+ <?php
+ DisplayPaginationControl( $currPage, $numMappings, $pageSize, 'unmanageddatamanagement.php', $sortColumn, $sortDirection );
+ // Toolbar
+ $buttons = array();
+ $button = new ToolbarButtonRecord();
+ $button->label = "Add Mapping";
+ $button->icon = "images/new.gif";
+ $button->action = "SetElementValue('".NEXT_PAGE_ID."', 'addunmanageddata.php');";
+ $buttons[0] = $button;
+ $button->label = "Edit Mapping";
+ $button->icon = "images/edit.gif";
+ $button->disabled = !empty( $selectedMapping ) ? false : true;
+ $button->action = "SetElementValue('".NEXT_PAGE_ID."', 'editunmanageddata.php');";
+ $buttons[1] = $button;
+ $button->label = "Delete Mapping";
+ $button->icon = "images/delete.gif";
+ $button->submitForm = false;
+ $button->action = "ConditionalSubmitForm( '".$formName."', 'Are you sure you want to delete the selected mapping?', '".DELETE_SELECTION_ID."', true );";
+ $buttons[2] = $button;
+ DisplayToolbar( $buttons, $formName );
+ <!-- Unmanaged Data Table-->
+ <table border="0" cellspacing="2" cellpadding="2" class="dataTable">
+ <tr>
+ <?php
+ $mappingNameSortIconStr = ( $sortColumn === NAME_SORT_COLUMN ) ? ' <img src="'.GetSortIcon( $sortDirection ).'">' : '';
+ $locationSortIconStr = ( $sortColumn === ID_SORT_COLUMN ) ? ' <img src="'.GetSortIcon( $sortDirection ).'">' : '';
+ $sortDirectionStr = "SetElementValue( '".$sortDirectionID."', '".GetSortDirection( $sortDirection )."' );";
+ $sortByMappingNameStr = "SetElementValue( '".$sortColumnID."', '".NAME_SORT_COLUMN."');";
+ $sortByLocationStr = "SetElementValue( '".$sortColumnID."', '".ID_SORT_COLUMN."');";
+ <td class="dataHeader"> </td>
+ <td class="dataHeader"><a href="#" onClick="<?php echo $sortDirectionStr.$sortByMappingNameStr?>SubmitForm('<?php echo $formName?>');">Mapping Name<?php echo $mappingNameSortIconStr ?></a> </td>
+ <td class="dataHeader"><a href="#" onClick="<?php echo $sortDirectionStr.$sortByLocationStr?>SubmitForm('<?php echo $formName?>');">Location<?php echo $locationSortIconStr ?></a> </td>
+ </tr>
+ <?php
+ $initOkToDeleteVal = 'true';
+ foreach ( $mappingTable as $key => $val )
+ if ( $key == $selectedMapping )
+ $checkedStr = " checked ";
+ else
+ $checkedStr = "";
+ $mappingSelectionOnClickStr = "SetElementValue( '".$selectedMappingID."', '".$key."');";
+ <tr>
+ <td class="dataCell"><input name="mappingSelector" type="radio" value="<?php echo $key ?>" <?php echo $checkedStr ?> onClick="<?php echo $mappingSelectionOnClickStr ?>" ></td>
+ <td class="dataCell"><a href="editunmanageddata.php?<?php echo $selectedMappingID?>=<?php echo $key?>"><?php echo $key ?></a></td>
+ <td class="dataCell"><?php echo $val ?></td>
+ </tr>
+ <?php
+ </table>
+ <?php DisplayPaginationControl( $currPage, $numMappings, $pageSize, 'unmanageddatamanagement.php', $sortColumn, $sortDirection ); ?>
+ <?php EndContentArea( true, $formName, NULL ); ?>
+ </tr>
+ </table>
+</body>
+</html>
More information about the mapguide-commits
