[mapguide-commits] r1077 - trunk/MgDev/Server/src/Common/Manager
svn_mapguide at osgeo.org
Mon Jan 29 02:40:38 EST 2007
Author: tonyfang
Date: 2007-01-29 02:40:38 -0500 (Mon, 29 Jan 2007)
New Revision: 1077
trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp
trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.cpp
trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.h
MapGuide RFC 12 - Unmanaged Data API Changes
- convert unmanaged data mapping to mapped value
- code cleanup
- add , as delimiter for EnumerateUnmanagedData filter
Modified: trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp 2007-01-29 06:38:33 UTC (rev 1076)
+++ trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp 2007-01-29 07:40:38 UTC (rev 1077)
@@ -21,6 +21,7 @@
#include "ServiceManager.h"
#include "LogManager.h"
#include "LongTransactionManager.h"
+#include "UnmanagedDataManager.h"
ACE_Recursive_Thread_Mutex MgFdoConnectionManager::sm_mutex;
@@ -538,6 +539,11 @@
// Property value can be null ( optional properties may not have values )
if (!value.empty())
+ // if it's a "File" property, check for unmanaged data alias
+ // and replace the alias with the mapped value
+ if (name.compare(L"File") == 0)
+ MgUnmanagedDataManager::ConvertUnmanagedDataMappingName(value);
FdoString* propertyValue = value.c_str();
if (propertyValue != NULL)
Modified: trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.cpp 2007-01-29 06:38:33 UTC (rev 1076)
+++ trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.cpp 2007-01-29 07:40:38 UTC (rev 1077)
@@ -63,7 +63,7 @@
/// The path must be in the form of:
/// "[mappingName]subfolder1/subfolder2"
-bool MgUnmanagedDataManager::ParsePath(CREFSTRING path, REFSTRING mappingName, REFSTRING subfolder)
+bool MgUnmanagedDataManager::ParsePath(CREFSTRING path, REFSTRING mappingName, REFSTRING subpath)
bool result = false;
@@ -87,7 +87,7 @@
if (pos + 1 < pathlen)
- subfolder = path.substr(pos + 1, pathlen - pos + 1);
+ subpath = path.substr(pos + 1, pathlen - pos + 1);
result = true;
@@ -106,7 +106,7 @@
if (!filter.empty())
wchar_t* token = const_cast<wchar_t*>(filter.c_str());
- const wchar_t* delimit = L"; \t\r\n\v\f";
+ const wchar_t* delimit = L";, \t\r\n\v\f";
wchar_t* state = NULL;
for (token = _wcstok(token, delimit, &state);
@@ -319,55 +319,6 @@
/// \brief
-/// Recursive method that returns all subdirectories for a given mapping name
-void MgUnmanagedDataManager::GetDirectories(MgStringCollection* dirs, CREFSTRING mappingName, CREFSTRING rootdir, CREFSTRING subdir, INT32 depth)
- STRING fulldir = rootdir;
- MgFileUtil::AppendSlashToEndOfPath(fulldir);
- if (!subdir.empty())
- fulldir += subdir;
- // Open the directory
- ACE_DIR* directory = directory = ACE_OS::opendir(ACE_TEXT_WCHAR_TO_TCHAR(fulldir.c_str()));
- if (directory != NULL)
- dirent* direntry = NULL;
- // Go through the directory entries
- while ((direntry = ACE_OS::readdir(directory)) != NULL)
- STRING entryName = MG_TCHAR_TO_WCHAR(direntry->d_name);
- STRING fullDataPathname = fulldir + entryName;
- if (MgFileUtil::IsDirectory(fullDataPathname)
- && entryName.compare(L"..") != 0 // skip ..
- && entryName.compare(L".") != 0) // skip .
- // Add to list of directories
- dirs->Add(FormatMappingName(mappingName) + FormatSubdir(subdir) + entryName);
- if (depth == -1 || depth > 0)
- if (depth > 0)
- depth--;
- // recursive call to get directories in subdirecories
- GetDirectories(dirs, mappingName, rootdir, FormatSubdir(subdir) + entryName, depth);
- ACE_OS::closedir(directory);
-/// \brief
/// Surrounds name with square brackets
STRING MgUnmanagedDataManager::FormatMappingName(CREFSTRING name)
@@ -420,6 +371,50 @@
/// \brief
+/// Converts mapped drive in path to its mapped value
+void MgUnmanagedDataManager::ConvertUnmanagedDataMappingName(REFSTRING path)
+ STRING mappingName, subpath;
+ if (MgUnmanagedDataManager::ParsePath(path, mappingName, subpath)
+ && !mappingName.empty())
+ MgConfiguration* config = MgConfiguration::GetInstance();
+ Ptr<MgPropertyCollection> properties = config->GetProperties(MgConfigProperties::UnmanagedDataMappingsSection);
+ if (properties != NULL)
+ STRING mappingDir;
+ // check to make sure it's a valid mapping name
+ // cycle thru mappings until we have a match
+ for (int i = 0; i < properties->GetCount(); i++)
+ Ptr<MgStringProperty> stringProp = (MgStringProperty*)properties->GetItem(i);
+ if (mappingName.compare(stringProp->GetName()) == 0)
+ // we have a match!
+ mappingDir = stringProp->GetValue();
+ break;
+ if (!mappingDir.empty())
+ // replace the mappingName with the actual directory
+ if (!MgFileUtil::EndsWithSlash(mappingDir))
+ MgFileUtil::AppendSlashToEndOfPath(mappingDir);
+ path = mappingDir + subpath;
+/// \brief
/// Returns unmanaged data
MgByteReader* MgUnmanagedDataManager::EnumerateUnmanagedData(CREFSTRING path, bool recursive, CREFSTRING select, CREFSTRING filter)
@@ -450,7 +445,7 @@
// "[alias1]subfolder1/subfolder2/"
STRING mappingName = L"", subfolder = L"";
- if (!ParsePath(path, mappingName, subfolder))
+ if (!MgUnmanagedDataManager::ParsePath(path, mappingName, subfolder))
MgStringCollection arguments;
arguments.Add(L"1");
@@ -492,18 +487,15 @@
STRING mappingDir = L"";
- if (properties != NULL)
- // cycle thru mappings until we have a match
- for (int i = 0; i < properties->GetCount(); i++)
- Ptr<MgStringProperty> stringProp = (MgStringProperty*)properties->GetItem(i);
- if (mappingName.compare(stringProp->GetName()) == 0)
- // we have a match!
- mappingDir = stringProp->GetValue();
- break;
+ break;
Modified: trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.h
--- trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.h 2007-01-29 06:38:33 UTC (rev 1076)
+++ trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.h 2007-01-29 07:40:38 UTC (rev 1077)
@@ -36,16 +36,12 @@
MgUnmanagedDataManager(const MgUnmanagedDataManager&);
MgUnmanagedDataManager& operator=(const MgUnmanagedDataManager&);
- bool ParsePath(CREFSTRING path, REFSTRING mappingName, REFSTRING subfolder);
+ static bool ParsePath(CREFSTRING path, REFSTRING mappingName, REFSTRING subpath);
void ParseFilter(CREFSTRING filter, MgStringCollection* filters);
bool FilterFile(CREFSTRING file, const MgStringCollection* filters);
void GetFilesAndFolders(string& list, CREFSTRING mappingName, CREFSTRING rootdir, CREFSTRING subdir, const MgStringCollection* filters, bool storeFolders, bool storeFiles, bool recursive);
- // TODO: delete
- void GetDirectories(MgStringCollection* dirs, CREFSTRING mappingName, CREFSTRING rootdir, CREFSTRING subdir, INT32 depth);
void AddFolder(string& list, CREFSTRING mappingName, CREFSTRING subdir, CREFSTRING entryName, INT32 numFolders, INT32 numFiles, MgDateTime createdDate, MgDateTime modifiedDate);
void AddFile(string& list, CREFSTRING mappingName, CREFSTRING subdir, CREFSTRING entryName, INT64 fileSize, MgDateTime createdDate, MgDateTime modifiedDate);
@@ -59,6 +55,7 @@
public:
static MgUnmanagedDataManager* GetInstance();
+ static void ConvertUnmanagedDataMappingName(REFSTRING path);
virtual void Dispose();
MgByteReader* EnumerateUnmanagedData(CREFSTRING path, bool recursive, CREFSTRING select, CREFSTRING filter);
More information about the mapguide-commits
