[mapguide-commits] r1083 - in trunk/MgDev: Common/Foundation/System
Common/MapGuideCommon Common/MapGuideCommon/Resources
Server/src Server/src/Core Server/src/PostBuild Web/src/mapagent
svn_mapguide at osgeo.org
Wed Jan 31 16:21:41 EST 2007
Author: brucedechant
Date: 2007-01-31 16:21:41 -0500 (Wed, 31 Jan 2007)
New Revision: 1083
Added:
trunk/MgDev/Common/MapGuideCommon/Resources/
trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res
Removed:
trunk/MgDev/Server/src/Resources/
trunk/MgDev/Web/src/mapagent/Resources/
trunk/MgDev/Common/Foundation/System/Resources.cpp
trunk/MgDev/Common/Foundation/System/Resources.h
trunk/MgDev/Server/src/Core/Makefile.am
trunk/MgDev/Server/src/Core/Server.cpp
trunk/MgDev/Server/src/PostBuild/PostBuild.mak
This change makes the server/web use a common resource file when building to facilitate easier updating.
They will still have their own copy of the resource file when executing.
Filename changes:
web_en.res --> mapguide_en.res
server_en.res --> mapguide_en.res
Modified: trunk/MgDev/Common/Foundation/System/Resources.cpp
--- trunk/MgDev/Common/Foundation/System/Resources.cpp 2007-01-31 18:33:44 UTC (rev 1082)
+++ trunk/MgDev/Common/Foundation/System/Resources.cpp 2007-01-31 21:21:41 UTC (rev 1083)
@@ -23,8 +23,7 @@
const STRING MgResources::DefaultLocale = L"en"; // Do not translate (ISO 639-1)
const STRING MgResources::ResourceFilenameExtension = L".res"; // Do not translate
const STRING MgResources::ResourceFilenameUnderscore = L"_"; // Do not translate
-const STRING MgResources::ResourceComponentServer = L"server"; // Do not translate
-const STRING MgResources::ResourceComponentWeb = L"web"; // Do not translate
+const STRING MgResources::ResourceComponent = L"mapguide"; // Do not translate
// The following resouce messages are not in the resource file because there may be the case where the resource file failed to load.
const STRING MgResources::FailedToLoadResourcesFile = L"Failed to load the resource file \"%1\" for locale \"%2\".";
@@ -159,7 +158,7 @@
m_path = L"../Resources/";
// default component
- m_component = MgResources::ResourceComponentWeb;
+ m_component = MgResources::ResourceComponent;
Modified: trunk/MgDev/Common/Foundation/System/Resources.h
--- trunk/MgDev/Common/Foundation/System/Resources.h 2007-01-31 18:33:44 UTC (rev 1082)
+++ trunk/MgDev/Common/Foundation/System/Resources.h 2007-01-31 21:21:41 UTC (rev 1083)
@@ -91,8 +91,8 @@
/// \brief
/// Gets the resource filename for the component and locale specified.
/// The resource filenames use the following format:
- /// <component>_<ISO 639-2 name>.res
- /// Ex: server_eng.res
+ /// <component>_<ISO 639-1 name>.res
+ /// Ex: mapguide_en.res
/// \param locale
/// The locale.
@@ -166,8 +166,7 @@
MgStringCollection* arguments);
/// Resource Components
- static const STRING ResourceComponentServer;
- static const STRING ResourceComponentWeb;
+ static const STRING ResourceComponent;
/// Default locale
static const STRING DefaultLocale;
Added: trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res
--- trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res (rev 0)
+++ trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res 2007-01-31 21:21:41 UTC (rev 1083)
@@ -0,0 +1,338 @@
+# MapGuide Resource File
+# Copyright (C) 2004-2007 Autodesk, Inc.
+# WARNING: DO NOT MODIFY THIS FILE
+# The following is the format for resources contained in this file:
+# [SectionName]
+# ResourceName = ResourceText
+# The terms used above are explained below:
+# SectionName - This defines the name of a resource section
+# ResourceName - This defines the name of a resource
+# ResourceText - This defines the text associated with the resource
+# E X C E P T I O N S
+[Exceptions]
+MgArgumentOutOfRangeException = Argument is out of range.
+MgArrayTypeMismatchException = Array type mismatch.
+MgAuthenticationFailedException = Authentication failed. Please enter a valid username and password.
+MgClassNotFoundException = The specified class was not found.
+MgConfigurationException = Configuration exception: %1
+MgConfigurationSaveFailedException = Failed to save configuration file %1
+MgConnectionFailedException = Cannot establish connection.
+MgConnectionNotOpenException = The connection is not open.
+MgCoordinateSystemComputationFailedException = The coordinate system computation failed.
+MgCoordinateSystemConversionFailedException = The coordinate system conversion failed.
+MgCoordinateSystemInitializationFailedException = The coordinate system initialization failed.
+MgCoordinateSystemLoadFailedException = The coordinate system load failed.
+MgCoordinateSystemMeasureFailedException = The coordinate system measure failed.
+MgCoordinateSystemTransformFailedException = The coordinate system transform failed.
+MgDateTimeException = A date and/or time exception occurred.
+MgDbException = An exception occurred in DB component.
+MgDbXmlException = An exception occurred in DB XML component.
+MgDecryptionException = A decryption exception occurred.
+MgDirectoryNotFoundException = The specified directory was not found: %1
+MgDivideByZeroException = Divide by zero.
+MgDomainException = A domain exception occurred.
+MgDuplicateDirectoryException = Directory already exists: %1
+MgDuplicateFileException = File already exists: %1
+MgDuplicateGroupException = The specified group already exists: %1
+MgDuplicateNameException = Duplicate name: %1
+MgDuplicateObjectException = Duplicate object.
+MgDuplicateParameterException = Duplicate parameter: %1
+MgDuplicateRepositoryException = An existing repository was detected: %1
+MgDuplicateResourceDataException = An existing resource data was detected: %1
+MgDuplicateResourceException = An existing resource was detected: %1
+MgDuplicateRoleException = The specified role already exists: %1
+MgDuplicateServerException = Server already exists: %1
+MgDuplicateSessionException = Session already exists.
+MgDuplicateUserException = The specified user already exists: %1
+MgDwfException = An exception occurred in DWF component.
+MgDwfSectionNotFoundException = The specified section was not found: %1
+MgDwfSectionResourceNotFoundException = The specified section resource was not found: %1
+MgEmptyFeatureSetException = The feature set is empty.
+MgEncryptionException = An encryption exception occurred.
+MgEndOfStreamException = End of stream exception.
+MgEvaluationExpiredException = This evaluation version expired on: %1
+MgFdoException = An exception occurred in FDO component.
+MgFeatureServiceException = Feature Service exception - %1
+MgFileIoException = A file IO exception occurred: %1
+MgFileNotFoundException = The specified file was not found: %1
+MgGeometryException = A geometry exception occurred.
+MgGroupNotFoundException = The specified group was not found: %1
+MgIndexOutOfRangeException = Index is out of range.
+MgInvalidArgumentException = Invalid argument(s):
+MgInvalidCastException = Invalid cast.
+MgInvalidCoordinateSystemException = The coordinate system is invalid. %1
+MgInvalidCoordinateSystemTypeException = The coordinate system type is invalid.
+MgInvalidCoordinateSystemUnitsException = The coordinate system units are invalid.
+MgInvalidDwfPackageException = Invalid DWF package: %1
+MgInvalidDwfSectionException = Invalid DWF section: %1
+MgInvalidFeatureSourceException = Feature Source - %1
+MgInvalidIpAddressException = Invalid IP address: %1
+MgInvalidLicenseException = Invalid license.
+MgInvalidLogEntryException = An invalid log entry was found.
+MgInvalidMapDefinitionException = The map definition is invalid.
+MgInvalidMimeTypeException = Invalid mime type: %1
+MgInvalidOperationException = The requested operation is invalid.
+MgInvalidOperationVersionException = The requested operation version is invalid.
+MgInvalidPasswordException = The password is invalid.
+MgInvalidPrintLayoutFontSizeUnitsException = The Print Layout has invalid Font Size Units.
+MgInvalidPrintLayoutPositionUnitsException = The Print Layout has invalid Position Units.
+MgInvalidPrintLayoutSizeUnitsException = The Print Layout has invalid Size Units.
+MgInvalidPropertyTypeException = The Property Type is invalid.
+MgInvalidRepositoryNameException = Invalid repository name: %1
+MgInvalidRepositoryTypeException = Invalid repository type.
+MgInvalidResourceDataNameException = Invalid resource data name: %1
+MgInvalidResourceDataTypeException = Invalid resource data type.
+MgInvalidResourceNameException = Invalid resource name: %1
+MgInvalidResourcePathException = Invalid resource path: %1
+MgInvalidResourcePreProcessingTypeException = Invalid resource pre-processing type.
+MgInvalidResourceTypeException = Invalid resource type.
+MgInvalidServerNameException = Invalid server name: %1
+MgInvalidSerialNumberException = Invalid serial number: %1
+MgInvalidStreamHeaderException = Invalid stream header exception.
+MgIoException = An IO exception occurred.
+MgLayerNotFoundException = The specified layer was not found: %1
+MgLengthException = A length exception occurred.
+MgLicenseException = License exception.
+MgLicenseExpiredException = License has expired on %1.
+MgLogicException = Logic exception.
+MgLogOpenFailedException = Failed to open package log file %1. Check permissions on folder.
+MgNotFiniteNumberException = Not a finite number.
+MgNotImplementedException = Not implemented.
+MgNullArgumentException = Argument is null.
+MgNullPropertyValueException = Value for %1 property is null.
+MgNullReferenceException = Null reference.
+MgObjectNotFoundException = The specified object was not found.
+MgOperationProcessingException = Unable to process the operation.
+MgOutOfMemoryException = Out of memory.
+MgOutOfRangeException = Out of range.
+MgOverflowException = Overflow exception.
+MgParameterNotFoundException = Parameter was not found: %1
+MgPathTooLongException = The specified path is too long: %1
+MgPermissionDeniedException = Permission denied to resource: %1
+MgPlatformNotSupportedException = Platform is not supported.
+MgPortNotAvailableException = Port %1 is not available, please try using a different port.
+MgPrintToScaleModeNotSelectedException = The print to scale mode is not selected.
+MgRepositoryCreationFailedException = Cannot create repository: %1
+MgRepositoryNotFoundException = Repository was not found: %1
+MgRepositoryNotOpenException = Repository is not open: %1
+MgRepositoryOpenFailedException = Cannot open repository: %1
+MgResourceBusyException = Please try your operation later as the resource was busy: %1
+MgResourceDataNotFoundException = Resource data was not found: %1
+MgResourceNotFoundException = Resource was not found: %1
+MgResourcesException = Resources exception: %1 %2
+MgResourceTagNotFoundException = Resource tag was not found: %1
+MgRoleNotFoundException = The specified role was not found: %1
+MgRuntimeException = Runtime exception.
+MgServerNotFoundException = Server was not found: %1
+MgServerNotOnlineException = The Server is not online.
+MgServiceNotAvailableException = The specified service is not available.
+MgServiceNotSupportedException = The specified service is not supported.
+MgSessionExpiredException = Session has expired or is invalid. Please log in again.
+MgSessionNotFoundException = A required session was not found.
+MgStreamIoException = A stream IO exception occurred.
+MgStylizeLayerFailedException = Failed to stylize layer: %1
+MgTemporaryFileNotAvailableException = Temporary file is not available.
+MgUnauthorizedAccessException = Unauthorized access.
+MgUnclassifiedException = An unclassified exception occurred.
+MgUnderflowException = Underflow exception.
+MgUriFormatException = Uri format exception.
+MgUserNotFoundException = The specified user was not found: %1
+MgXmlException = An XML exception occurred.
+MgXmlParserException = An exception occurred in the XML parser.
+# E R R O R D E S C R I P T I O N
+[ErrorDescription]
+MgArgumentsMismatch = The arguments needed do not match the arguments provided.
+MgClassWOIdentity = A class definition has no identity property.
+MgCollectionEmpty = The collection cannot be empty.
+MgConfigurationPropertyLengthIsInvalid = The value of property %1 under section %2 is %3. Its length must be %4
+MgConfigurationPropertyLengthIsOutOfRange = The value of property %1 under section %2 is %3. Its length must be between %4 and %5
+MgConfigurationPropertyValueContainsReservedCharacters= The value of property %1 under section %2 is %3. It must not contain any of the following reserved characters %4
+MgConfigurationPropertyValueIsNotSpecified = The value of property %1 under section %2 must be specified.
+MgConfigurationPropertyValueIsOutOfRange = The value of property %1 under section %2 is %3. It must be between %4 and %5
+MgContentDocumentNotEmpty = The content document is not empty.
+MgContentNotNull = The content is not null.
+MgCoordinateDimensionDifferent = The coordinate dimensions are different.
+MgDataReaderIdNotFound = The data reader ID was not found.
+MgDocumentIdentifierFilenameFailed = Failed to get the filename from the document identifier because no matching document path found.
+MgFailedToGetFileNameForDates = Failed to get the filename for the specified dates.
+MgFailedToLoadFdoLibrary = Failed to load FDO library.
+MgFailedToRetrieveSystemExceptionMesage = Failed to retrieve the system exception mesage. This message may not be unicode compliant.
+MgFailedToRetrieveThirdPartyExceptionMesage = Failed to retrieve the third party exception mesage. This message may not be unicode compliant.
+MgFeatureReaderIdNotFound = The feature reader ID was not found.
+MgFilenamesIdentical = The filenames cannot be the same.
+MgFormatExceptionStackTrace = Exception occurred in method %1 at line %2 in file %3
+MgFormatAllExceptionStackTrace = - %1 line %2 file %3
+MgFormatInnerExceptionMessage = %1
+MgGeometryEmpty = The geometry cannot be empty.
+MgGeometryPropertyEmpty = The geometry property cannot be empty.
+MgGroupAndRoleNotEmpty = Both the group and role are not empty.
+MgHeaderDocumentNotEmpty = The header document is not empty.
+MgInvalidAgfText = The AGF text is invalid because it failed to parse into a valid geometry object.
+MgInvalidCollectionSize = The collection is invalid because the size was not what was expected.
+MgInvalidDateDifference = The date is invalid because there cannot be more than a 24 hour difference.
+MgInvalidDataType = The data type is invalid because it is not recognized.
+MgInvalidDay = The day is invalid because it must be between 1 and 31.
+MgInvalidEnvelope = The envelope contains the incorrect number of points.
+MgInvalidEnvelopeCoordinates = The coordinates cannot be used because they are not matched to the lower left and the upper right of an envelope.
+MgInvalidFdoDataType = The FDO data type is invalid because it is not recognized.
+MgInvalidFdoDateTime = The FDO date time is invalid because not all of the fields were found.
+MgInvalidFeatureSpatialOperation = The feature spatial operation is invalid because it is not recognized.
+MgInvalidFromDate = The from date is invalid because it comes after the to date.
+MgInvalidGeometryBadProportion = The geometry is invalid because the proportion must be between 0.0 and 1.0.
+MgInvalidGeometryComponentType = The geometry component type is invalid because it is not recognized.
+MgInvalidGeometryNoDimension = The geometry is invalid because the dimension is 0.
+MgInvalidGeometryTooFewCoordinates = The geometry is invalid because it has too few coordinates.
+MgInvalidGeometryType = The geometry type is invalid because it is not recognized.
+MgInvalidHour = The hour is invalid because it must be between 0 and 23.
+MgInvalidImageSizeTooBig = The requested image size exceeds the maximum.
+MgInvalidIpConfigurationForLocalMachine = The machine IP is not a local host.
+MgInvalidIpConfigurationForSiteServer = This server (%1) is configured as a site server but has a different IP address than the site server (%2).
+MgInvalidIpConfigurationForSupportServer = This server (%1) is configured as a support server but has the same IP address as the site server (%2).
+MgInvalidLogType = The log type is invalid because it is not recognized.
+MgInvalidMapPlotCollectionMapPlotInstruction = The map plot is invalid because it contains an unrecognized map plot instruction.
+MgInvalidMicroSecond = The microsecond is invalid because it must be between 0 and 999999.
+MgInvalidMinute = The minute is invalid because it must be between 0 and 59.
+MgInvalidMonth = The month is invalid because it must be between 1 and 12.
+MgInvalidNode = The node is invalid because it is not an element node or a document node.
+MgInvalidPrintLayoutPageSizeUnits = The print layout is invalid because it contains unrecognized page size units.
+MgInvalidPropertyType = The property type is invalid because it is not recognized.
+MgInvalidPropertyTypeForCommand = The property type is invalid for the command because it was of a different type then expected.
+MgInvalidResourceCannotBeRoot = The resource is invalid because it cannot be the root.
+MgInvalidSecond = The second is invalid because it must be between 0 and 59.
+MgInvalidServiceType = The service type is invalid because it is not recognized.
+MgInvalidSessionsId = The session ID is invalid because the session separator character was not found.
+MgInvalidStringConversion = The string is invalid and cannot be converted.
+MgInvalidStringTrim = The string was trimmed and it's size now differs from the original.
+MgInvalidTCPProtocol = The TCP/IP protocol is mismatched between the Server and Web Extensions. Please install the same version of Server and Web Extensions.
+MgInvalidValueOutsideRange = The value is invalid because it must be between the valid range of values.
+MgInvalidValueTooBig = The value is invalid because it is too large.
+MgInvalidValueTooSmall = The value is invalid because it is too small.
+MgInvalidWebAction = The web action is invalid because it is not recognized.
+MgInvalidWebTargetType = The web target type is invalid because it is not recognized.
+MgInvalidWebTargetViewerType = The web target viewer type is invalid because it is not recognized.
+MgInvalidWebWidgetType = The web widget type is invalid because it is not recognized.
+MgInvalidXmlDateTime = The Xml date time is invalid because not all of the fields were found.
+MgInvalidYear = The year is invalid because it must be between 1 and 9999.
+MgMapLayerGroupNameNotFound = The map layer group name was not found.
+MgMissingClassDef = No class definition specified.
+MgMissingSchema = No schema specified.
+MgMissingSrs = No coordinate system specified.
+MgNameNotFound = The name was not found.
+MgPropertyValuesEmpty = The property values cannot be empty.
+MgReaderIdNotFound = The reader ID was not found.
+MgRepositoryAlreadyOpened = The repository is already opened by another process (e.g. If you are running the server interactively as an application from the command line, are you also running the server as a service?).
+MgResourceDataFilePathEmpty = The resource data file path is empty.
+MgResourceNameDoesNotContainSectionName = The resource name does not contain a section name.
+MgResourceNameSeparatorNotFound = The resource name separator was not found.
+MgResourceRootPathsDifferent = The resource root paths cannot be different.
+MgResourceTypesDifferent = The resource types cannot be different.
+MgResourcesIdentical = The resources cannot be the same.
+MgSqlReaderIdNotFound = The SQL reader ID was not found.
+MgStringContainsReservedCharacters = The string cannot contain reserved characters %1
+MgStringEmpty = The string cannot be empty.
+MgStringTooLong = The string is too long.
+MgTagFieldNotFound = The tag contained no fields.
+MgUnsupportedService = The site/resource services cannot be enabled/disabled.
+MgUserAndGroupNotEmpty = Both the user and group are not empty.
+MgUserAndRoleNotEmpty = Both the user and role are not empty.
+MgValueCannotBeLessThanOrEqualToZero = The value cannot be less than or equal to zero.
+MgValueCannotBeLessThanZero = The value cannot be less than zero.
+MgValueCannotBeZero = The value cannot be zero.
+# D R A W I N G S E R V I C E
+[DrawingService]
+# F E A T U R E S E R V I C E
+[FeatureService]
+MgBatchInsertNotSupported = Provider does not support batch insert. Only one Feature instance is allowed.
+MgCommandNotSupported = Command is not supported by Provider.
+MgCustomFunctionNotSupported = Aggregate function specified not supported or invalid data type
+MgGroupingNotSupported = Grouping is not supported by provider
+MgInsertError = Error occurred while insert operation, no ID to retrieve
+MgInvalidComputedProperty = Invalid Computed property specified, Make sure valid no of arguments are specified
+MgInvalidConnectionString = Invalid Connection String.
+MgInvalidFdoProvider = Invalid Feature Provider specified.
+MgInvalidPropertyName = Invalid Property Name found.
+MgMissingConfiguration = No configuration specified.
+MgMissingPropertyAlias = Alias for computed property is missing
+MgMissingRasterProperty = No Raster Property available in the class.
+MgNoFeaturesForInsert = No Features for Insert supplied
+MgOnlyOnePropertyAllowed = Only one aggregate function of this kind is supported
+MgOrderingOptionNotSupported = Ordering Option is not supported by provider
+MgPropertyNotEnumerable = Property specified is not enumerable.
+# K M L S E R V I C E
+[KmlService]
+# M A P P I N G S E R V I C E
+[MappingService]
+# R E N D E R I N G S E R V I C E
+[RenderingService]
+# R E S O U R C E S E R V I C E
+[ResourceService]
+MgPackageStatusMessageLoadPackageFailed = LOAD FAILED: %1 failed to load package on %2
+MgPackageStatusMessageLoadPackageInProgress = Loading package %1 ...
+MgPackageStatusMessageLoadPackageSucceeded = LOAD SUCCEEDED: %1 successfully loaded package on %2
+MgPackageStatusMessageMakePackageFailed = MAKE FAILED: %1 failed to make package on %2
+MgPackageStatusMessageMakePackageInProgress = Making package %1 ...
+MgPackageStatusMessageMakePackageSucceeded = MAKE SUCCEEDED: %1 successfully made package on %2
+MgPackageStatusMessageNotStarted = Not started
+MgPackageStatusMessageUnknown = Unknown
+MgRepositoryBusy = Please try your operation later as the repository was busy.
+MgSchemaFileNotFound = The specified schema file is not found: %1
+MgSchemaFileNotSpecified = No schema file is specified in the XML document.
+# S E R V E R A D M I N S E R V I C E
+[ServerAdminService]
+# S I T E S E R V I C E
+[SiteService]
+MgGroupDescriptionEveryone = Built-in group to include all users
+MgRoleDescriptionAdministrator = Administrator role
+MgRoleDescriptionAuthor = Author role
+MgRoleDescriptionViewer = Viewer role
+MgUserDescriptionAdministrator = Built-in account for administering the site
+MgUserDescriptionAnonymous = Built-in account for guests with Viewer role
+MgUserDescriptionAuthor = Built-in account for users with Author role
+MgUserDescriptionWfsUser = Built-in account for WFS users with Viewer role
+MgUserDescriptionWmsUser = Built-in account for WMS users with Viewer role
+MgUserFullNameAdministrator = Site Administrator
+MgUserFullNameAnonymous = Anonymous User
+MgUserFullNameAuthor = Map Author
+MgUserFullNameWfsUser = WFS User
+MgUserFullNameWmsUser = WMS User
+# T I L E S E R V I C E
+[TileService]
Property changes on: trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res
___________________________________________________________________
+ native
Modified: trunk/MgDev/Server/src/Core/Makefile.am
--- trunk/MgDev/Server/src/Core/Makefile.am 2007-01-31 18:33:44 UTC (rev 1082)
+++ trunk/MgDev/Server/src/Core/Makefile.am 2007-01-31 21:21:41 UTC (rev 1083)
@@ -272,7 +272,7 @@
Resources :
@mkdir Resources
- @cp -f ../Resources/server_en.res Resources/server_en.res
+ @cp -f ../../../Common/MapGuideCommon/Resources/mapguide_en.res Resources/mapguide_en.res
Schema :
@mkdir Schema
@@ -314,7 +314,7 @@
test -d $(proj4naddir) || $(mkinstalldirs) $(proj4naddir)
test -d $(fdodir) || $(mkinstalldirs) $(fdodir)
test -d $(daemondir) || $(mkinstalldirs) $(daemondir)
- @cp -fp ../Resources/*.res $(resourcesdir)
+ @cp -fp ../../../Common/MapGuideCommon/Resources/*.res $(resourcesdir)
@cp -fp ../Wms/* $(wmsdir)
@cp -fp ../Wfs/* $(wfsdir)
test -d $(schemadir) || $(mkinstalldirs) $(schemadir)
Modified: trunk/MgDev/Server/src/Core/Server.cpp
--- trunk/MgDev/Server/src/Core/Server.cpp 2007-01-31 18:33:44 UTC (rev 1082)
+++ trunk/MgDev/Server/src/Core/Server.cpp 2007-01-31 21:21:41 UTC (rev 1083)
@@ -122,7 +122,6 @@
// If additional locales are needed they will be loaded/cached on demand.
ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::init() - Loading resources.\n")));
MgResources* pResources = MgResources::GetInstance();
- pResources->SetComponent(MgResources::ResourceComponentServer);
pResources->Initialize(resourcesPath);
// Try loading the specified locale resource. If it fails default to loading "en".
Modified: trunk/MgDev/Server/src/PostBuild/PostBuild.mak
--- trunk/MgDev/Server/src/PostBuild/PostBuild.mak 2007-01-31 18:33:44 UTC (rev 1082)
+++ trunk/MgDev/Server/src/PostBuild/PostBuild.mak 2007-01-31 21:21:41 UTC (rev 1083)
@@ -111,9 +111,9 @@
if NOT EXIST ..\..\bin\debug\Schema\nul mkdir ..\..\bin\debug\Schema
xcopy /r /y /d ..\..\..\Common\Schema\*.xsd ..\..\bin\debug\Schema
-CopyResourcesDebug : ..\..\src\Resources\server_en.res
+CopyResourcesDebug : ..\..\..\Common\MapGuideCommon\Resources\mapguide_en.res
if NOT EXIST ..\..\bin\debug\Resources\nul mkdir ..\..\bin\debug\Resources
- xcopy /r /d /y "..\..\src\Resources\server_en.res" ..\..\bin\debug\Resources\
+ xcopy /r /d /y "..\..\..\Common\MapGuideCommon\Resources\mapguide_en.res" ..\..\bin\debug\Resources\
CopyOgcFilesDebug : ..\..\src\wms\*.awd ..\..\src\wfs\*.awd
if NOT EXIST ..\..\bin\debug\wms\nul mkdir ..\..\bin\debug\wms
@@ -332,9 +332,9 @@
if NOT EXIST ..\..\bin\release\Schema\nul mkdir ..\..\bin\release\Schema
xcopy /r /y /d ..\..\..\Common\Schema\*.xsd ..\..\bin\release\Schema
-CopyResourcesRelease : ..\..\src\Resources\server_en.res
+CopyResourcesRelease : ..\..\..\Common\MapGuideCommon\Resources\mapguide_en.res
if NOT EXIST ..\..\bin\release\Resources\nul mkdir ..\..\bin\release\Resources
- xcopy /r /d /y "..\..\src\Resources\server_en.res" ..\..\bin\release\Resources\
+ xcopy /r /d /y "..\..\..\Common\MapGuideCommon\Resources\mapguide_en.res" ..\..\bin\release\Resources\
CopyOgcFilesRelease: ..\..\src\wms\*.awd ..\..\src\wfs\*.awd
if NOT EXIST ..\..\bin\release\wms\nul mkdir ..\..\bin\release\wms
More information about the mapguide-commits
