[mapguide-commits] r1148 -
trunk/MgDev/Common/MapGuideCommon/Resources
svn_mapguide at osgeo.org
Fri Mar 2 14:52:32 EST 2007
Author: tonyfang
Date: 2007-03-02 14:52:32 -0500 (Fri, 02 Mar 2007)
New Revision: 1148
trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res
* put MgCoordinateSystemOverridden in alphabetical order
Modified: trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res
--- trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res 2007-03-02 10:18:26 UTC (rev 1147)
+++ trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res 2007-03-02 19:52:32 UTC (rev 1148)
@@ -266,6 +266,7 @@
[FeatureService]
MgBatchInsertNotSupported = Provider does not support batch insert. Only one Feature instance is allowed.
MgCommandNotSupported = Command is not supported by Provider.
+MgCoordinateSystemOverridden = This coordinate system has been overridden.
MgCustomFunctionNotSupported = Aggregate function specified not supported or invalid data type
MgGroupingNotSupported = Grouping is not supported by provider
MgInsertError = Error occurred while insert operation, no ID to retrieve
@@ -280,7 +281,6 @@
MgOnlyOnePropertyAllowed = Only one aggregate function of this kind is supported
MgOrderingOptionNotSupported = Ordering Option is not supported by provider
MgPropertyNotEnumerable = Property specified is not enumerable.
-MgCoordinateSystemOverridden = This coordinate system has been overridden.
# K M L S E R V I C E
More information about the mapguide-commits
