[mapguide-commits] r1150 - in trunk/MgDev:
Common/MapGuideCommon/Controller
Common/MapGuideCommon/Services Server/src/Services/Mapping
Server/src/Services/Rendering Web/src/HttpHandler
svn_mapguide at osgeo.org
Mon Mar 5 13:39:45 EST 2007
Author: brucedechant
Date: 2007-03-05 13:39:44 -0500 (Mon, 05 Mar 2007)
New Revision: 1150
trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp
trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.h
trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.cpp
trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.h
trunk/MgDev/Common/MapGuideCommon/Services/RenderingService.h
trunk/MgDev/Server/src/Services/Mapping/StylizationUtil.cpp
trunk/MgDev/Server/src/Services/Mapping/StylizationUtil.h
trunk/MgDev/Server/src/Services/Rendering/OpQueryFeatureProperties.cpp
trunk/MgDev/Server/src/Services/Rendering/OpQueryFeatures.cpp
trunk/MgDev/Server/src/Services/Rendering/OpRenderDynamicOverlay.cpp
trunk/MgDev/Server/src/Services/Rendering/OpRenderMap.cpp
trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.h
trunk/MgDev/Web/src/HttpHandler/HttpGetDynamicMapOverlayImage.cpp
trunk/MgDev/Web/src/HttpHandler/HttpGetDynamicMapOverlayImage.h
trunk/MgDev/Web/src/HttpHandler/HttpGetMapImage.cpp
trunk/MgDev/Web/src/HttpHandler/HttpGetMapImage.h
trunk/MgDev/Web/src/HttpHandler/HttpQueryMapFeatures.cpp
trunk/MgDev/Web/src/HttpHandler/HttpQueryMapFeatures.h
trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp
trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.h
Implement RFC 15.
Modified: trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp
--- trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp 2007-03-02 21:54:12 UTC (rev 1149)
+++ trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp 2007-03-05 18:39:44 UTC (rev 1150)
@@ -28,7 +28,7 @@
// Processes a GetDynamicMapOverlayImage request from the Viewer and returns an image of the specified map.
-MgByteReader* MgHtmlController::GetDynamicMapOverlayImage(CREFSTRING mapName, CREFSTRING format)
+MgByteReader* MgHtmlController::GetDynamicMapOverlayImage(CREFSTRING mapName, CREFSTRING format, bool bKeepSelection)
// Create a Resource Service instance
Ptr<MgResourceService> resourceService = (MgResourceService*)GetService(MgServiceType::ResourceService);
@@ -53,14 +53,14 @@
Ptr<MgRenderingService> service = (MgRenderingService*)(GetService(MgServiceType::RenderingService));
// Call the C++ API
- return service->RenderDynamicOverlay(map, selection, format);
+ return service->RenderDynamicOverlay(map, selection, format, bKeepSelection);
// Processes a GetMapImage request from the Viewer and returns an image of the specified map.
MgByteReader* MgHtmlController::GetMapImage(MgMap* map, MgSelection* selection,
- CREFSTRING format, MgPropertyCollection* mapViewCommands)
+ CREFSTRING format, MgPropertyCollection* mapViewCommands, bool bKeepSelection)
// Apply map view commands
ApplyMapViewCommands(map, mapViewCommands);
@@ -73,7 +73,7 @@
// Call the C++ API
- return service->RenderMap(map, selection, format);
+ return service->RenderMap(map, selection, format, bKeepSelection);
@@ -167,7 +167,8 @@
MgGeometry* selectionGeometry,
INT32 selectionVariant,
INT32 maxFeatures,
- bool persist)
+ bool persist,
+ bool bIgnoreScaleRange)
@@ -189,7 +190,7 @@
// Call the C++ API
Ptr<MgFeatureInformation> featureInfo = service->QueryFeatures(map, layerNames, selectionGeometry,
- selectionVariant, maxFeatures);
+ selectionVariant, maxFeatures, bIgnoreScaleRange);
if(persist)
Modified: trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.h
--- trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.h 2007-03-02 21:54:12 UTC (rev 1149)
+++ trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.h 2007-03-05 18:39:44 UTC (rev 1150)
@@ -54,13 +54,17 @@
/// Name of the map
/// \param format
/// Image format, from MgImageFormats
+ /// \param bKeepSelection
+ /// Input
+ /// true if you want to keep the selection
/// \return
/// A byte reader containing the map image
MgByteReader* GetDynamicMapOverlayImage(
CREFSTRING mapName,
- CREFSTRING format);
+ bool bKeepSelection);
/// \brief
@@ -74,6 +78,9 @@
/// \param mapViewCommands
/// Commands to be applied to the map before generation
+ /// Input
/// \return
@@ -82,7 +89,8 @@
MgMap* map,
CREFSTRING format,
- MgPropertyCollection* mapViewCommands);
+ MgPropertyCollection* mapViewCommands,
/// \brief
@@ -126,7 +134,8 @@
INT32 maxFeatures,
- bool persist);
+ bool persist,
+ bool bIgnoreScaleRange);
/// \brief
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.cpp 2007-03-02 21:54:12 UTC (rev 1149)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.cpp 2007-03-05 18:39:44 UTC (rev 1150)
@@ -131,16 +131,50 @@
CREFSTRING format)
+ // Call the updated RenderDynamicOverlay API
+ return RenderDynamicOverlay(map, selection, format, true);
+/// <summary>
+/// Renders all dynamic layers in the specified MgMap to a dynamic overlay image
+/// with a transparent background. The center, scale, size, and layers to be
+/// rendered are defined by the specified map instance. The format parameter
+/// must be set to an image format that supports transparency.
+/// </summary>
+/// <param name="map">Input
+/// map object containing current state of map.
+/// </param>
+/// <param name="selection">Input
+/// map feature selection. Specifies the selected features on the map
+/// </param>
+/// <param name="format">Input
+/// image format. Defines the format of the resulting image
+/// </param>
+/// <param name="bKeepSelection">Input
+/// true if you want to keep the selection
+/// </param>
+/// <returns>
+/// A byte reader containing the rendered image
+/// </returns>
+MgByteReader* MgProxyRenderingService::RenderDynamicOverlay(
+ MgMap* map,
+ MgSelection* selection,
MgCommand cmd;
cmd.ExecuteCommand(m_connProp, // Connection
MgCommand::knObject, // Return type expected
MgRenderingServiceOpId::RenderDynamicOverlay, // Command Code
- 3, // No of arguments
+ 4, // No of arguments
Rendering_Service, // Service Id
1, // Operation version
MgCommand::knObject, map, // Argument#1
MgCommand::knObject, selection, // Argument#2
MgCommand::knString, &format, // Argument#3
+ MgCommand::knInt32, bKeepSelection, // Argument#4
MgCommand::knNone); // End of arguments
SetWarning(cmd.GetWarningObject());
@@ -170,16 +204,47 @@
CREFSTRING format)
+ // Call the updated RenderMap API
+ return RenderMap(map, selection, format, true);
+/// <summary>
+/// Renders the specified MgMap to the requested image format.
+/// </summary>
+/// </param>
+/// </param>
+/// </param>
+/// </param>
+/// <returns>
+/// </returns>
+MgByteReader* MgProxyRenderingService::RenderMap(
+ MgMap* map,
MgCommand cmd;
MgRenderingServiceOpId::RenderMap1, // Command Code
@@ -225,11 +290,57 @@
MgColor* backgroundColor,
CREFSTRING format)
+ return RenderMap(map, selection, extents, width, height, backgroundColor, format, true);
+/// <summary>
+/// </summary>
+/// </param>
+/// </param>
+/// <param name="extents">Input
+/// map extents. Specifies the extents for the map
+/// </param>
+/// <param name="width">Input
+/// image width. Specifies the image width in pixels
+/// </param>
+/// <param name="height">Input
+/// image height. Specifies the image height in pixels
+/// </param>
+/// <param name="backgroundColor">Input
+/// background color. Specifies the map background color
+/// </param>
+/// </param>
+/// </param>
+/// <returns>
+/// </returns>
+ MgMap* map,
+ MgEnvelope* extents,
+ INT32 width,
+ INT32 height,
+ MgColor* backgroundColor,
MgCommand cmd;
MgRenderingServiceOpId::RenderMap2, // Command Code
- 7, // No of arguments
+ 8, // No of arguments
@@ -239,6 +350,7 @@
MgCommand::knInt32, height, // Argument#5
MgCommand::knObject, backgroundColor, // Argument#6
MgCommand::knString, &format, // Argument#7
+ MgCommand::knInt32, bKeepSelection, // Argument#8
@@ -246,7 +358,6 @@
return (MgByteReader*)cmd.GetReturnValue().val.m_obj;
/// <summary>
@@ -288,11 +399,60 @@
CREFSTRING format)
+ return RenderMap(map, selection, center, scale, width, height, backgroundColor, format, true);
+/// <summary>
+/// </summary>
+/// </param>
+/// </param>
+/// <param name="center">Input
+/// map center point. Specifies the center point for the map
+/// </param>
+/// <param name="scale">Input
+/// map scale. Specifies the scale for the map
+/// </param>
+/// </param>
+/// </param>
+/// </param>
+/// </param>
+/// </param>
+/// <returns>
+/// </returns>
+ MgMap* map,
+ MgCoordinate* center,
+ double scale,
+ INT32 width,
+ INT32 height,
MgCommand cmd;
MgRenderingServiceOpId::RenderMap3, // Command Code
- 8, // No of arguments
+ 9, // No of arguments
@@ -303,6 +463,7 @@
MgCommand::knInt32, height, // Argument#6
MgCommand::knObject, backgroundColor, // Argument#7
MgCommand::knString, &format, // Argument#8
+ MgCommand::knInt32, bKeepSelection, // Argument#9
@@ -310,7 +471,6 @@
/// <summary>
/// Renders the legend for the specified MgMap to the requested size and format
@@ -394,11 +554,53 @@
INT32 selectionVariant, // Within, Touching, Topmost
INT32 maxFeatures)
+ // Call the updated QueryFeatures API
+ return QueryFeatures(map, layerNames, geometry, selectionVariant, maxFeatures, false);
+/// <summary>
+/// The QueryFeatures operation identifies those features that
+/// meet the specified spatial selection criteria. This operation
+/// is used to implement server-side selection. In addition to
+/// a selection set, this operation returns attribute information
+/// in case only one feature is selected
+/// </summary>
+/// </param>
+/// <param name="layerName">Input
+/// Active layer name for which to query features
+/// </param>
+/// <param name="geometry">Input
+/// geometry object specifying the selection area
+/// </param>
+/// <param name="selectionVariant">Input
+/// selection criterion - 0=Within, 1=Touching, 2=Topmost
+/// </param>
+/// <param name="maxFeatures">Input
+/// the maximum number of features to return
+/// </param>
+/// <param name="bIgnoreScaleRange">Input
+/// true if you want to ignore scale ranges when querying features
+/// </param>
+/// <returns>
+/// An MgSelection instance identifying the features that meet the
+/// selection criteria. Returns null if no features are identified.
+/// </returns>
+MgFeatureInformation* MgProxyRenderingService::QueryFeatures(
+ MgMap* map,
+ MgStringCollection* layerNames,
+ MgGeometry* geometry,
+ INT32 selectionVariant, // Within, Touching, Topmost
+ INT32 maxFeatures,
MgCommand cmd;
MgRenderingServiceOpId::QueryFeatures, // Command Code
- 5, // No of arguments
+ 6, // No of arguments
@@ -406,6 +608,7 @@
MgCommand::knObject, geometry, // Argument#3
MgCommand::knInt32, selectionVariant, // Argument#4
MgCommand::knInt32, maxFeatures, // Argument#5
+ MgCommand::knInt32, bIgnoreScaleRange, // Argument#6
@@ -447,11 +650,54 @@
INT32 maxFeatures)
+ // Call the updated QueryFeatureProperties API
+ return QueryFeatureProperties(map, layerNames, geometry, selectionVariant, maxFeatures, false);
+/// <summary>
+/// The QueryFeatureProeprties operation identifies those features that
+/// is used to implement WMS feature info and returns property values
+/// for all features which match the spatial query
+/// </summary>
+/// </param>
+/// </param>
+/// </param>
+/// </param>
+/// </param>
+/// properties
+/// </param>
+/// <returns>
+/// </returns>
+MgBatchPropertyCollection* MgProxyRenderingService::QueryFeatureProperties(
+ MgMap* map,
MgCommand cmd;
MgRenderingServiceOpId::QueryFeatureProperties, // Command Code
@@ -459,6 +705,7 @@
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.h
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.h 2007-03-02 21:54:12 UTC (rev 1149)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.h 2007-03-05 18:39:44 UTC (rev 1150)
@@ -83,6 +83,35 @@
/// \brief
+ /// Renders all dynamic layers in the specified MgMap to a dynamic overlay image
+ /// with a transparent background. The center, scale, size, and layers to be
+ /// rendered are defined by the specified map instance. The format parameter
+ /// must be set to an image format that supports transparency.
+ /// \param map
+ /// Input
+ /// map object containing current state of map.
+ /// \param selection
+ /// Input
+ /// map feature selection. Specifies the selected features on the map
+ /// \param format
+ /// Input
+ /// image format. Defines the format of the resulting image
+ /// Input
+ /// \return
+ /// A byte reader containing the rendered image
+ virtual MgByteReader* RenderDynamicOverlay(
+ MgMap* map,
+ /// \brief
/// \param map
@@ -113,6 +142,32 @@
/// Input
+ /// \param format
+ /// Input
+ /// Input
+ /// \return
+ virtual MgByteReader* RenderMap(
+ MgMap* map,
+ /// \brief
+ /// Renders the specified MgMap to the requested image format.
+ /// \param map
+ /// Input
+ /// Input
/// \param extents
/// Input
@@ -151,6 +206,48 @@
/// Input
+ /// \param extents
+ /// Input
+ /// map extents. Specifies the extents for the map
+ /// \param width
+ /// Input
+ /// image width. Specifies the image width in pixels
+ /// \param height
+ /// Input
+ /// image height. Specifies the image height in pixels
+ /// \param backgroundColor
+ /// Input
+ /// background color. Specifies the map background color
+ /// \param format
+ /// Input
+ /// Input
+ /// \return
+ MgMap* map,
+ INT32 width,
+ INT32 height,
+ /// \brief
+ /// \param map
+ /// Input
+ /// Input
/// \param center
/// Input
@@ -185,6 +282,52 @@
/// \brief
+ /// \param map
+ /// Input
+ /// Input
+ /// \param center
+ /// Input
+ /// map center point. Specifies the center point for the map
+ /// \param scale
+ /// Input
+ /// map scale. Specifies the scale for the map
+ /// \param width
+ /// Input
+ /// \param height
+ /// Input
+ /// Input
+ /// \param format
+ /// Input
+ /// Input
+ /// \return
+ MgMap* map,
+ double scale,
+ INT32 width,
+ INT32 height,
+ /// \brief
/// \param map
@@ -251,6 +394,45 @@
/// \brief
+ /// The QueryFeatures operation identifies those features that
+ /// meet the specified spatial selection criteria. This operation
+ /// is used to implement server-side selection. In addition to
+ /// a selection set, this operation returns attribute information
+ /// in case only one feature is selected
+ /// \param map
+ /// Input
+ /// \param layerName
+ /// Input
+ /// Active layer name for which to query features
+ /// \param geometry
+ /// Input
+ /// geometry object specifying the selection area
+ /// \param selectionVariant
+ /// Input
+ /// selection criterion - 0=Within, 1=Touching, 2=Topmost
+ /// \param maxFeatures
+ /// Input
+ /// the maximum number of features to return
+ /// \param bIgnoreScaleRange
+ /// Input
+ /// true if you want to ignore scale ranges when querying features
+ /// \return
+ /// An MgSelection instance identifying the features that meet the
+ /// selection criteria. Returns null if no features are identified.
+ virtual MgFeatureInformation* QueryFeatures(
+ MgMap* map,
+ /// \brief
@@ -283,6 +465,44 @@
INT32 maxFeatures);
+ /// \brief
+ /// The QueryFeatureProeprties operation identifies those features that
+ /// is used to implement WMS feature info and returns property values
+ /// for all features which match the spatial query
+ /// \param map
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// properties
+ /// \return
+ virtual MgBatchPropertyCollection* QueryFeatureProperties(
+ MgMap* map,
INTERNAL_API:
Modified: trunk/MgDev/Common/MapGuideCommon/Services/RenderingService.h
--- trunk/MgDev/Common/MapGuideCommon/Services/RenderingService.h 2007-03-02 21:54:12 UTC (rev 1149)
+++ trunk/MgDev/Common/MapGuideCommon/Services/RenderingService.h 2007-03-05 18:39:44 UTC (rev 1150)
@@ -86,6 +86,35 @@
/// \brief
+ /// \param map
+ /// Input
+ /// Input
+ /// \param format
+ /// Input
+ /// Input
+ /// \return
+ MgMap* map,
+ bool bKeepSelection) = 0;
+ /// \brief
/// \param map
@@ -116,6 +145,32 @@
/// Input
+ /// \param format
+ /// Input
+ /// Input
+ /// \return
+ MgMap* map,
+ /// \brief
+ /// \param map
+ /// Input
+ /// Input
/// \param extents
/// Input
@@ -154,6 +209,48 @@
/// Input
+ /// Input
+ /// \param width
+ /// Input
+ /// \param height
+ /// Input
+ /// Input
+ /// \param format
+ /// Input
+ /// Input
+ /// \return
+ MgMap* map,
+ INT32 width,
+ INT32 height,
+ /// \brief
+ /// \param map
+ /// Input
+ /// Input
/// \param center
/// Input
@@ -188,6 +285,52 @@
/// \brief
+ /// \param map
+ /// Input
+ /// Input
+ /// \param center
+ /// Input
+ /// \param scale
+ /// Input
+ /// \param width
+ /// Input
+ /// \param height
+ /// Input
+ /// Input
+ /// \param format
+ /// Input
+ /// Input
+ /// \return
+ MgMap* map,
+ double scale,
+ INT32 width,
+ INT32 height,
+ /// \brief
/// \param map
@@ -254,6 +397,45 @@
/// \brief
+ /// \param map
+ /// Input
+ /// \param layerNames
+ /// Input
+ /// Active layer names for which to query features
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// \return
+ MgMap* map,
+ bool bIgnoreScaleRange) = 0;
+ /// \brief
@@ -286,6 +468,44 @@
INT32 maxFeatures) = 0;
+ /// \brief
+ /// \param map
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// properties
+ /// \return
+ MgMap* map,
INTERNAL_API:
Modified: trunk/MgDev/Server/src/Services/Mapping/StylizationUtil.cpp
--- trunk/MgDev/Server/src/Services/Mapping/StylizationUtil.cpp 2007-03-02 21:54:12 UTC (rev 1149)
+++ trunk/MgDev/Server/src/Services/Mapping/StylizationUtil.cpp 2007-03-05 18:39:44 UTC (rev 1150)
@@ -442,11 +442,12 @@
MgCoordinateSystem* dstCs,
bool expandExtents,
bool checkRefreshFlag,
- double scale)
+ double scale,
+ bool selection)
#ifdef _DEBUG
long dwStart = GetTickCount();
- printf("\nStylizeLayers() **MAPSTART** Layers: %d\n", layers->GetCount());
+ printf("\nStylizeLayers() **MAPSTART** Layers:%d Scale:%f\n", layers->GetCount(), scale);
#endif
// Cache coordinate system transforms for the life of the
@@ -462,11 +463,11 @@
Ptr<MgLayerBase> mapLayer = layers->GetItem(i);
#ifdef _DEBUG
- printf(" StylizeLayers() **LAYERSTART** Layer: %d - %S\n", i, (mapLayer->GetName()).c_str());
+ printf(" StylizeLayers() **LAYERSTART** Name:%S VAS:%S\n", (mapLayer->GetName()).c_str(), mapLayer->IsVisibleAtScale(scale) ? L"True" : L"False");
#endif
//don't send data if layer is not currently visible
- if (!mapLayer->IsVisibleAtScale(scale))
+ if ((!selection) && (!mapLayer->IsVisible()))
continue;
//don't send data if the refresh flag is not set
@@ -520,11 +521,31 @@
long dwLayerStart = GetTickCount();
#endif
+ // Modify the layer scale range to also support infinite
+ // Need to apply default style as one will not be defined
+ if(selection)
+ MdfModel::VectorScaleRangeCollection* scaleRanges = vl->GetScaleRanges();
+ if(scaleRanges)
+ MdfModel::VectorScaleRange* scaleRange = scaleRanges->GetAt(0);
+ if(scaleRange)
+ scaleRange->SetMinScale(0.0);
+ scaleRange->SetMaxScale(MdfModel::VectorScaleRange::MAX_MAP_SCALE);
// make sure we have a valid scale range
MdfModel::VectorScaleRange* scaleRange = Stylizer::FindScaleRange(*vl->GetScaleRanges(), scale);
if (scaleRange)
+ #ifdef _DEBUG
+ printf(" StylizeLayers() **Stylizing** Name:%S\n", (mapLayer->GetName()).c_str());
+ #endif
// get feature source id
STRING sfeatResId = vl->GetResourceID();
Ptr<MgResourceIdentifier> featResId = new MgResourceIdentifier(sfeatResId);
@@ -820,10 +841,15 @@
+ else
+ #ifdef _DEBUG
+ printf(" StylizeLayers() **NOT Stylizing - NO SCALE RANGE** Name:%S\n", (mapLayer->GetName()).c_str());
+ #endif
#ifdef _DEBUG
- printf(" StylizeLayers() **LAYEREND** Vector layer time = %6.4f (s)\n\n", (GetTickCount()-dwLayerStart)/1000.0);
+ printf(" StylizeLayers() **LAYEREND** -Vector- Name:%S Time:%6.4f (s)\n\n", (mapLayer->GetName()).c_str(), (GetTickCount()-dwLayerStart)/1000.0);
#endif
else if (gl)
@@ -1012,7 +1038,7 @@
#ifdef _DEBUG
- printf(" StylizeLayers() **LAYEREND** Grid layer time = %6.4f (s)\n\n", (GetTickCount()-dwLayerStart)/1000.0);
+ printf(" StylizeLayers() **LAYEREND** -Grid- Name:%S Time:%6.4f (s)\n\n", (mapLayer->GetName()).c_str(), (GetTickCount()-dwLayerStart)/1000.0);
#endif
else if (dl) //drawing layer
@@ -1071,7 +1097,7 @@
#ifdef _DEBUG
- printf(" StylizeLayers() **LAYEREND** Drawing layer time = %6.4f (s)\n\n", (GetTickCount()-dwLayerStart)/1000.0);
+ printf(" StylizeLayers() **LAYEREND** -Drawing- Name:%S Time = %6.4f (s)\n\n", (mapLayer->GetName()).c_str(), (GetTickCount()-dwLayerStart)/1000.0);
#endif
@@ -1120,7 +1146,7 @@
#ifdef _DEBUG
- printf("StylizeLayers() **MAPDONE** Layers: %d Total Time = %6.4f (s)\n\n", layers->GetCount(), (GetTickCount()-dwStart)/1000.0);
+ printf("StylizeLayers() **MAPDONE** Layers:%d Total Time:%6.4f (s)\n\n", layers->GetCount(), (GetTickCount()-dwStart)/1000.0);
#endif
TransformCacheMap::iterator iter = transformCache.begin();
Modified: trunk/MgDev/Server/src/Services/Mapping/StylizationUtil.h
--- trunk/MgDev/Server/src/Services/Mapping/StylizationUtil.h 2007-03-02 21:54:12 UTC (rev 1149)
+++ trunk/MgDev/Server/src/Services/Mapping/StylizationUtil.h 2007-03-05 18:39:44 UTC (rev 1150)
@@ -74,7 +74,8 @@
bool expandExtents,
- double scale);
+ double scale,
+ bool selection = false);
static MgFeatureReader * ExecuteFeatureQuery(MgFeatureService* svcFeature,
RS_Bounds& extent,
Modified: trunk/MgDev/Server/src/Services/Rendering/OpQueryFeatureProperties.cpp
--- trunk/MgDev/Server/src/Services/Rendering/OpQueryFeatureProperties.cpp 2007-03-02 21:54:12 UTC (rev 1149)
+++ trunk/MgDev/Server/src/Services/Rendering/OpQueryFeatureProperties.cpp 2007-03-05 18:39:44 UTC (rev 1150)
@@ -32,12 +32,7 @@
void MgOpQueryFeatureProperties::Execute()
ACE_DEBUG((LM_DEBUG, ACE_TEXT(" (%t) MgOpQueryFeatureProperties::Execute()\n")));
MG_LOG_OPERATION_MESSAGE(L"QueryFeatures");
MG_TRY()
@@ -46,7 +41,7 @@
ACE_ASSERT(m_stream != NULL);
- if (5 == m_packet.m_NumArguments)
+ if (6 == m_packet.m_NumArguments)
Ptr<MgMap> map = (MgMap*)m_stream->GetObject();
map->SetDelayedLoadResourceService(m_resourceService);
@@ -60,6 +55,9 @@
INT32 maxFeatures = 0;
m_stream->GetInt32(maxFeatures);
+ INT32 bIgnoreScale = 0;
+ m_stream->GetInt32(bIgnoreScale);
BeginExecution();
MG_LOG_OPERATION_MESSAGE_PARAMETERS_START();
@@ -69,17 +67,18 @@
MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"MgGeometry");
- MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"selectionVariant");
+ MG_LOG_OPERATION_MESSAGE_ADD_INT32(selectionVariant);
- MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"maxFeatures");
+ MG_LOG_OPERATION_MESSAGE_ADD_INT32(maxFeatures);
+ MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
+ MG_LOG_OPERATION_MESSAGE_ADD_BOOL(bIgnoreScale);
MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
Validate();
Ptr<MgBatchPropertyCollection> info =
- m_service->QueryFeatureProperties(map, layerNames, geom, selectionVariant, maxFeatures);
+ m_service->QueryFeatureProperties(map, layerNames, geom, selectionVariant, maxFeatures, bIgnoreScale);
EndExecution(info);
else
@@ -101,8 +100,6 @@
if (mgException != NULL)
// Failed operation
MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Failure.c_str());
Modified: trunk/MgDev/Server/src/Services/Rendering/OpQueryFeatures.cpp
--- trunk/MgDev/Server/src/Services/Rendering/OpQueryFeatures.cpp 2007-03-02 21:54:12 UTC (rev 1149)
+++ trunk/MgDev/Server/src/Services/Rendering/OpQueryFeatures.cpp 2007-03-05 18:39:44 UTC (rev 1150)
@@ -32,12 +32,7 @@
void MgOpQueryFeatures::Execute()
ACE_DEBUG((LM_DEBUG, ACE_TEXT(" (%t) MgOpQueryFeatures::Execute()\n")));
MG_TRY()
@@ -46,7 +41,7 @@
@@ -60,6 +55,9 @@
BeginExecution();
@@ -69,17 +67,18 @@
Validate();
Ptr<MgFeatureInformation> info =
- m_service->QueryFeatures(map, layerNames, geom, selectionVariant, maxFeatures);
+ m_service->QueryFeatures(map, layerNames, geom, selectionVariant, maxFeatures, bIgnoreScale);
EndExecution(info);
else
@@ -101,8 +100,6 @@
// Failed operation
Modified: trunk/MgDev/Server/src/Services/Rendering/OpRenderDynamicOverlay.cpp
--- trunk/MgDev/Server/src/Services/Rendering/OpRenderDynamicOverlay.cpp 2007-03-02 21:54:12 UTC (rev 1149)
+++ trunk/MgDev/Server/src/Services/Rendering/OpRenderDynamicOverlay.cpp 2007-03-05 18:39:44 UTC (rev 1150)
@@ -33,11 +33,6 @@
ACE_DEBUG((LM_DEBUG, ACE_TEXT(" (%t) MgOpRenderDynamicOverlay::Execute()\n")));
MG_LOG_OPERATION_MESSAGE(L"RenderDynamicOverlay");
MG_TRY()
@@ -46,7 +41,7 @@
- if (3 == m_packet.m_NumArguments)
+ if (4 == m_packet.m_NumArguments)
@@ -58,6 +53,9 @@
STRING format;
m_stream->GetString(format);
+ INT32 bKeepSelection = 0;
+ m_stream->GetInt32(bKeepSelection);
BeginExecution();
@@ -66,14 +64,15 @@
MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"MgSelection");
MG_LOG_OPERATION_MESSAGE_ADD_STRING(format.c_str());
+ MG_LOG_OPERATION_MESSAGE_ADD_BOOL(bKeepSelection);
Validate();
Ptr<MgByteReader> byteReader =
- m_service->RenderDynamicOverlay(map, selection, format);
+ m_service->RenderDynamicOverlay(map, selection, format, bKeepSelection);
EndExecution(byteReader);
else
@@ -95,8 +94,6 @@
// Failed operation
Modified: trunk/MgDev/Server/src/Services/Rendering/OpRenderMap.cpp
--- trunk/MgDev/Server/src/Services/Rendering/OpRenderMap.cpp 2007-03-02 21:54:12 UTC (rev 1149)
+++ trunk/MgDev/Server/src/Services/Rendering/OpRenderMap.cpp 2007-03-05 18:39:44 UTC (rev 1150)
@@ -33,11 +33,6 @@
ACE_DEBUG((LM_DEBUG, ACE_TEXT(" (%t) MgOpRenderMap::Execute()\n")));
MG_LOG_OPERATION_MESSAGE(L"RenderMap");
MG_TRY()
@@ -46,7 +41,7 @@
@@ -58,6 +53,9 @@
STRING format;
BeginExecution();
@@ -66,17 +64,18 @@
Validate();
- m_service->RenderMap(map, selection, format);
+ m_service->RenderMap(map, selection, format, bKeepSelection);
- else if (7 == m_packet.m_NumArguments)
+ else if (8 == m_packet.m_NumArguments)
@@ -98,6 +97,9 @@
STRING format;
BeginExecution();
@@ -107,24 +109,25 @@
MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"MgEnvelope");
- MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"width");
+ MG_LOG_OPERATION_MESSAGE_ADD_INT32(width);
- MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"height");
+ MG_LOG_OPERATION_MESSAGE_ADD_INT32(height);
MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"MgColor");
Validate();
- m_service->RenderMap(map, selection, extents, width, height, color, format);
+ m_service->RenderMap(map, selection, extents, width, height, color, format, bKeepSelection);
- else if (8 == m_packet.m_NumArguments)
+ else if (9 == m_packet.m_NumArguments)
@@ -149,6 +152,9 @@
STRING format;
BeginExecution();
@@ -158,23 +164,24 @@
MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"MgCoordinate");
- MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"scale");
+ MG_LOG_OPERATION_MESSAGE_ADD_DOUBLE(scale);
Validate();
- m_service->RenderMap(map, selection, center, scale, width, height, color, format);
+ m_service->RenderMap(map, selection, center, scale, width, height, color, format, bKeepSelection);
else
@@ -196,8 +203,6 @@
// Failed operation
Modified: trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
--- trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2007-03-02 21:54:12 UTC (rev 1149)
+++ trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2007-03-05 18:39:44 UTC (rev 1150)
@@ -201,7 +201,7 @@
baseGroup->SetVisible(true);
// call the internal helper API to do all the stylization overhead work
- ret = RenderMapInternal(map, NULL, roLayers, &dr, width, height, format, scale, extent, true);
+ ret = RenderMapInternal(map, NULL, roLayers, &dr, width, height, format, scale, extent, true, true);
// restore the base group's visibility
baseGroup->SetVisible(groupVisible);
@@ -216,6 +216,15 @@
CREFSTRING format)
+ // Call updated RenderDynamicOverlay API
+MgByteReader* MgServerRenderingService::RenderDynamicOverlay(MgMap* map,
Ptr<MgByteReader> ret;
MG_TRY()
@@ -268,7 +277,7 @@
- ret = RenderMapInternal(map, selection, roLayers, &dr, width, height, format, scale, extent, false);
+ ret = RenderMapInternal(map, selection, roLayers, &dr, width, height, format, scale, extent, false, bKeepSelection);
MG_CATCH_AND_THROW(L"MgServerRenderingService.RenderDynamicOverlay")
@@ -280,6 +289,15 @@
CREFSTRING format)
+ // Call updated RenderMap API
+MgByteReader* MgServerRenderingService::RenderMap(MgMap* map,
MG_TRY()
@@ -297,7 +315,7 @@
Ptr<MgColor> bgColor = new MgColor(col.red(), col.green(), col.blue(), col.alpha());
// punt to more specific RenderMap API
- ret = RenderMap(map, selection, center, scale, map->GetDisplayWidth(), map->GetDisplayHeight(), bgColor, format);
+ ret = RenderMap(map, selection, center, scale, map->GetDisplayWidth(), map->GetDisplayHeight(), bgColor, format, bKeepSelection);
MG_CATCH_AND_THROW(L"MgServerRenderingService.RenderMap")
@@ -313,6 +331,19 @@
CREFSTRING format)
+ INT32 width,
+ INT32 height,
MG_TRY()
@@ -390,7 +421,7 @@
GDRenderer dr(drawWidth, drawHeight, bgcolor, false);
- ret = RenderMapInternal(map, selection, NULL, &dr, width, height, format, scale, b, false);
+ ret = RenderMapInternal(map, selection, NULL, &dr, width, height, format, scale, b, false, bKeepSelection);
@@ -407,6 +438,20 @@
CREFSTRING format)
+ double scale,
+ INT32 width,
+ INT32 height,
MG_TRY()
@@ -444,7 +489,7 @@
GDRenderer dr(width, height, bgcolor, false);
@@ -459,6 +504,18 @@
INT32 maxFeatures)
+ // Call updated QueryFeatures API
+MgFeatureInformation* MgServerRenderingService::QueryFeatures(MgMap* map,
Ptr<MgFeatureInformation> ret;
MG_TRY()
@@ -472,7 +529,7 @@
Ptr<MgSelection> sel = new MgSelection(map);
FeatureInfoRenderer fir(sel, maxFeatures, map->GetViewScale());
- RenderForSelection(map, layerNames, geometry, selectionVariant, maxFeatures, &fir);
+ RenderForSelection(map, layerNames, geometry, selectionVariant, maxFeatures, &fir, bIgnoreScaleRange);
//fill out the output object with the info we collected
//in the FeatureInfoRenderer for the first feature we hit
@@ -486,6 +543,11 @@
ret->SetSelection(sel);
+ #ifdef _DEBUG
+ Ptr<MgReadOnlyLayerCollection> selLayers = sel->GetLayers();
+ ACE_DEBUG((LM_ERROR, ACE_TEXT("MgServerRenderingService::QueryFeatures() Selection Size:%d\n"), selLayers.p ? selLayers->GetCount() : 0));
+ #endif
MG_CATCH_AND_THROW(L"MgServerRenderingService.QueryFeatures")
return ret.Detach();
@@ -498,6 +560,18 @@
INT32 maxFeatures)
+ // Call updated QueryFeatureProperties API
+MgBatchPropertyCollection* MgServerRenderingService::QueryFeatureProperties( MgMap* map,
Ptr<MgBatchPropertyCollection> ret;
MG_TRY()
@@ -509,7 +583,7 @@
Ptr<MgSelection> sel = NULL;//TODO: do we need this for this API? new MgSelection(map);
FeaturePropRenderer fpr(sel, maxFeatures, map->GetViewScale());
- RenderForSelection(map, layerNames, geometry, selectionVariant, maxFeatures, &fpr);
+ RenderForSelection(map, layerNames, geometry, selectionVariant, maxFeatures, &fpr, bIgnoreScaleRange);
ret = fpr.GetProperties();
//ret->SetSelection(sel);
@@ -530,7 +604,8 @@
CREFSTRING format,
double scale,
RS_Bounds& b,
- bool expandExtents)
+ bool expandExtents,
// convert the map coordinate system from srs wkt to a mentor cs structure
STRING srs = map->GetMapSRS();
@@ -591,6 +666,11 @@
if (selection)
Ptr<MgReadOnlyLayerCollection> selLayers = selection->GetLayers();
+ #ifdef _DEBUG
+ printf("MgServerRenderingService::RenderMapInternal() - Layers:%d Selection Layers:%d\n", tempLayers.p ? tempLayers->GetCount() : 0, selLayers.p ? selLayers->GetCount() : 0);
+ #endif
if (selLayers.p && selLayers->GetCount() > 0)
// tell the renderer to override draw styles with the ones
@@ -612,7 +692,7 @@
MgStylizationUtil::StylizeLayers(m_svcResource, m_svcFeature, m_svcDrawing, m_pCSFactory, map,
- modLayers, overrideFilters, &ds, dr, dstCs, false, false, scale);
+ modLayers, overrideFilters, &ds, dr, dstCs, false, false, scale, bKeepSelection);
@@ -756,8 +836,10 @@
INT32 maxFeatures,
- FeatureInfoRenderer* selRenderer)
+ FeatureInfoRenderer* selRenderer,
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("RenderForSelection(): ** START **\n")));
if (NULL == map || NULL == geometry)
throw new MgNullArgumentException(L"MgServerRenderingService.RenderForSelection", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -804,14 +886,24 @@
//find the layer we need to select features from
Ptr<MgLayerBase> layer = layers->GetItem(p);
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("RenderForSelection(): Layer: %W Selectable:%W Visible: %W\n"), layer->GetName().c_str(), layer->GetSelectable() ? L"True" : L"False", layer->IsVisibleAtScale(map->GetViewScale()) ? L"True" : L"False"));
//do we want to select on this layer -- if caller
//gave us a layer name collection, check if the layer
//is in there
if (layerNames && layerNames->GetCount() > 0 && layerNames->IndexOf(layer->GetName()) == -1)
continue;
- if (!layer->GetSelectable() || !layer->IsVisibleAtScale(map->GetViewScale()))
- continue;
+ if(bIgnoreScaleRange)
+ if (!layer->GetSelectable())
+ continue;
+ else
+ if (!layer->GetSelectable() || !layer->IsVisibleAtScale(map->GetViewScale()))
+ continue;
//have we processed enough features already?
if (maxFeatures <= 0)
@@ -822,9 +914,26 @@
auto_ptr<MdfModel::LayerDefinition> ldf(MgStylizationUtil::GetLayerDefinition(m_svcResource, layerResId));
MdfModel::VectorLayerDefinition* vl = dynamic_cast<MdfModel::VectorLayerDefinition*>(ldf.get());
- //we can only do geometric query selectionb for vector layers
+ //we can only do geometric query selection for vector layers
if (vl)
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("RenderForSelection(): Layer: %W Vector Layer\n"), layer->GetName().c_str()));
+ // Modify the layer scale range only for layers that are passed in
+ if(scaleRanges)
+ if(scaleRange)
Ptr<MgResourceIdentifier> featResId = new MgResourceIdentifier(layer->GetFeatureSourceId());
//get the coordinate system of the layer --> we need this
@@ -1009,6 +1118,7 @@
selRenderer->EndMap();
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("RenderForSelection(): ** END **\n")));
void MgServerRenderingService::SetConnectionProperties(MgConnectionProperties*)
Modified: trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.h
--- trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.h 2007-03-02 21:54:12 UTC (rev 1149)
+++ trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.h 2007-03-05 18:39:44 UTC (rev 1150)
@@ -45,12 +45,22 @@
CREFSTRING format);
+ virtual MgByteReader* RenderDynamicOverlay(MgMap* map,
virtual MgByteReader* RenderMap(MgMap* map,
CREFSTRING format);
+ virtual MgByteReader* RenderMap(MgMap* map,
INT32 width,
INT32 height,
@@ -59,6 +69,15 @@
+ INT32 width,
+ INT32 height,
double scale,
INT32 width,
@@ -66,6 +85,16 @@
CREFSTRING format);
+ double scale,
+ INT32 width,
+ INT32 height,
virtual MgByteReader* RenderMapLegend(MgMap* map,
INT32 width,
INT32 height,
@@ -78,12 +107,26 @@
INT32 maxFeatures);
+ virtual MgFeatureInformation* QueryFeatures( MgMap* map,
virtual MgBatchPropertyCollection* QueryFeatureProperties( MgMap* map,
INT32 maxFeatures);
+ virtual MgBatchPropertyCollection* QueryFeatureProperties( MgMap* map,
private:
// used for tile generation
@@ -109,14 +152,16 @@
CREFSTRING format,
double scale,
RS_Bounds& b,
- bool expandExtents);
void RenderForSelection(MgMap* map,
INT32 maxFeatures,
- FeatureInfoRenderer* selRenderer);
// member data
Ptr<MgFeatureService> m_svcFeature;
Modified: trunk/MgDev/Web/src/HttpHandler/HttpGetDynamicMapOverlayImage.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpGetDynamicMapOverlayImage.cpp 2007-03-02 21:54:12 UTC (rev 1149)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGetDynamicMapOverlayImage.cpp 2007-03-05 18:39:44 UTC (rev 1150)
@@ -41,6 +41,14 @@
// Get the requested image format
m_mapFormat = params->GetParameterValue(MgHttpResourceStrings::reqRenderingFormat);
+ // Get the keep selection flag
+ m_bKeepSelection = true; // default
+ STRING keepSelection = params->GetParameterValue(MgHttpResourceStrings::reqRenderingKeepSelection);
+ if(!keepSelection.empty())
+ m_bKeepSelection = (keepSelection.c_str() == L"1");
/// <summary>
@@ -61,7 +69,7 @@
// Call the HTML controller to render the map image
MgHtmlController controller(m_siteConn);
- Ptr<MgByteReader> map = controller.GetDynamicMapOverlayImage(m_mapName, m_mapFormat);
+ Ptr<MgByteReader> map = controller.GetDynamicMapOverlayImage(m_mapName, m_mapFormat, m_bKeepSelection);
// Set the result
hResult->SetResultObject(map, map->GetMimeType());
Modified: trunk/MgDev/Web/src/HttpHandler/HttpGetDynamicMapOverlayImage.h
--- trunk/MgDev/Web/src/HttpHandler/HttpGetDynamicMapOverlayImage.h 2007-03-02 21:54:12 UTC (rev 1149)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGetDynamicMapOverlayImage.h 2007-03-05 18:39:44 UTC (rev 1150)
@@ -54,6 +54,7 @@
private:
STRING m_mapName;
STRING m_mapFormat;
+ bool m_bKeepSelection;
#endif // _FS_GET_DYNAMIC_MAP_OVERLAY_IMAGE_H
Modified: trunk/MgDev/Web/src/HttpHandler/HttpGetMapImage.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpGetMapImage.cpp 2007-03-02 21:54:12 UTC (rev 1149)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGetMapImage.cpp 2007-03-05 18:39:44 UTC (rev 1150)
@@ -44,6 +44,14 @@
/// <summary>
@@ -95,7 +103,7 @@
- Ptr<MgByteReader> reader = controller.GetMapImage(map, selection, m_mapFormat, commands);
+ Ptr<MgByteReader> reader = controller.GetMapImage(map, selection, m_mapFormat, commands, m_bKeepSelection);
// If we opened the map from the repository then save it back to ensure
// any track changes are removed from the persisted version, since these
Modified: trunk/MgDev/Web/src/HttpHandler/HttpGetMapImage.h
--- trunk/MgDev/Web/src/HttpHandler/HttpGetMapImage.h 2007-03-02 21:54:12 UTC (rev 1149)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGetMapImage.h 2007-03-05 18:39:44 UTC (rev 1150)
@@ -55,6 +55,7 @@
STRING m_mapName;
STRING m_mapDefinition;
STRING m_mapFormat;
#endif // _FS_GET_MAP_IMAGE_H
Modified: trunk/MgDev/Web/src/HttpHandler/HttpQueryMapFeatures.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpQueryMapFeatures.cpp 2007-03-02 21:54:12 UTC (rev 1149)
+++ trunk/MgDev/Web/src/HttpHandler/HttpQueryMapFeatures.cpp 2007-03-05 18:39:44 UTC (rev 1150)
@@ -57,6 +57,9 @@
// Flag indicated if the selection should be stored in the session repository
m_persist = params->GetParameterValue(MgHttpResourceStrings::reqRenderingPersist) == L"1";
+ // Get the ignore scale flag
+ m_bIgnoreScale = params->GetParameterValue(MgHttpResourceStrings::reqRenderingIgnoreScale) == L"1";
/// <summary>
@@ -106,7 +109,7 @@
// Call the HTML controller to process the request
Ptr<MgByteReader> featureDescriptionInfo = controller.QueryMapFeatures(
- m_mapName, layerNames, geometry, selectionVariant, m_maxFeatures, m_persist);
+ m_mapName, layerNames, geometry, selectionVariant, m_maxFeatures, m_persist, m_bIgnoreScale);
// Set the result
hResult->SetResultObject(featureDescriptionInfo, featureDescriptionInfo->GetMimeType());
Modified: trunk/MgDev/Web/src/HttpHandler/HttpQueryMapFeatures.h
--- trunk/MgDev/Web/src/HttpHandler/HttpQueryMapFeatures.h 2007-03-02 21:54:12 UTC (rev 1149)
+++ trunk/MgDev/Web/src/HttpHandler/HttpQueryMapFeatures.h 2007-03-05 18:39:44 UTC (rev 1150)
@@ -58,6 +58,7 @@
STRING m_selectionVariant;
INT32 m_maxFeatures;
bool m_persist;
+ bool m_bIgnoreScale;
#endif // _FS_DESCRIBE_MAP_FEATURES_H
Modified: trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp 2007-03-02 21:54:12 UTC (rev 1149)
+++ trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp 2007-03-05 18:39:44 UTC (rev 1150)
@@ -228,6 +228,8 @@
const STRING MgHttpResourceStrings::reqRenderingTileRow = L"TILEROW";
const STRING MgHttpResourceStrings::reqRenderingPersist = L"PERSIST";
const STRING MgHttpResourceStrings::reqRenderingScaleIndex = L"SCALEINDEX";
+const STRING MgHttpResourceStrings::reqRenderingIgnoreScale = L"IGNORESCALE";
+const STRING MgHttpResourceStrings::reqRenderingKeepSelection = L"KEEPSELECTION";
// Rendering Service Operation Requests
const STRING MgHttpResourceStrings::opGetDynamicMapOverlayImage = L"GETDYNAMICMAPOVERLAYIMAGE";
Modified: trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.h
--- trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.h 2007-03-02 21:54:12 UTC (rev 1149)
+++ trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.h 2007-03-05 18:39:44 UTC (rev 1150)
@@ -167,6 +167,8 @@
static const STRING reqRenderingTileRow;
static const STRING reqRenderingPersist;
static const STRING reqRenderingScaleIndex;
+ static const STRING reqRenderingIgnoreScale;
+ static const STRING reqRenderingKeepSelection;
// PREDEFINED TILE REQUEST PARAMETERS
static const STRING reqTileMapDefinition;
More information about the mapguide-commits
