[mapguide-commits] r1163 - in trunk/MgDev/Common: MdfModel
MdfParser Stylization
svn_mapguide at osgeo.org
Wed Mar 7 00:23:04 EST 2007
Author: jasonnogar
Date: 2007-03-07 00:23:02 -0500 (Wed, 07 Mar 2007)
New Revision: 1163
Added:
trunk/MgDev/Common/MdfModel/Usage.cpp
trunk/MgDev/Common/MdfModel/AreaUsage.cpp
trunk/MgDev/Common/MdfModel/AreaUsage.h
trunk/MgDev/Common/MdfModel/LineUsage.cpp
trunk/MgDev/Common/MdfModel/LineUsage.h
trunk/MgDev/Common/MdfModel/MdfModel.vcproj
trunk/MgDev/Common/MdfModel/PointUsage.cpp
trunk/MgDev/Common/MdfModel/PointUsage.h
trunk/MgDev/Common/MdfModel/Usage.h
trunk/MgDev/Common/MdfParser/IOAreaUsage.cpp
trunk/MgDev/Common/MdfParser/IOLineUsage.cpp
trunk/MgDev/Common/MdfParser/IOPointUsage.cpp
trunk/MgDev/Common/Stylization/SE_Bounds.cpp
trunk/MgDev/Common/Stylization/SE_Bounds.h
trunk/MgDev/Common/Stylization/SE_ExpressionBase.cpp
trunk/MgDev/Common/Stylization/SE_Include.h
trunk/MgDev/Common/Stylization/SE_LineBuffer.cpp
trunk/MgDev/Common/Stylization/SE_LineBuffer.h
trunk/MgDev/Common/Stylization/SE_Renderer.cpp
trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp
trunk/MgDev/Common/Stylization/StylizationEngine.cpp
MdfModel: Changed Usage enumerations to string properties (expressions).
MdfParser: Changed Usage enumerations to string properties
Stylization:
* Updated StylizationEngine to use expressions for the enumerations in the Usage classes.
* Fixed arc tessellation in SE_LineBuffer (including the issue with the previous implementation where a circle would have a line through the center).
* Fixed ResizeBox computation.
Modified: trunk/MgDev/Common/MdfModel/AreaUsage.cpp
--- trunk/MgDev/Common/MdfModel/AreaUsage.cpp 2007-03-07 04:47:30 UTC (rev 1162)
+++ trunk/MgDev/Common/MdfModel/AreaUsage.cpp 2007-03-07 05:23:02 UTC (rev 1163)
@@ -31,9 +31,6 @@
// NOTE: if you change any defaults then you must also update
// IOAreaUsage::Write to use the correct default values.
- this->m_eOriginControl = Global;
- this->m_eAngleControl = FromAngle;
- this->m_eClippingControl = Clip;
@@ -48,60 +45,42 @@
// PURPOSE:
// PARAMETERS:
-AreaUsage::OriginControl AreaUsage::GetOriginControl() const
+const MdfString& AreaUsage::GetOriginControl() const
- return this->m_eOriginControl;
+ return this->m_sOriginControl;
// PURPOSE:
// PARAMETERS:
-void AreaUsage::SetOriginControl(const OriginControl originControl)
+void AreaUsage::SetOriginControl(const MdfString& originControl)
- this->m_eOriginControl = originControl;
+ this->m_sOriginControl = originControl;
// PURPOSE:
// PARAMETERS:
-Usage::AngleControl AreaUsage::GetAngleControl() const
+const MdfString& AreaUsage::GetClippingControl() const
- return this->m_eAngleControl;
+ return this->m_sClippingControl;
// PURPOSE:
// PARAMETERS:
-void AreaUsage::SetAngleControl(AngleControl angleControl)
+void AreaUsage::SetClippingControl(const MdfString& clippingControl)
- this->m_eAngleControl = angleControl;
+ this->m_sClippingControl = clippingControl;
// PURPOSE:
// PARAMETERS:
-AreaUsage::ClippingControl AreaUsage::GetClippingControl() const
- return this->m_eClippingControl;
-// PURPOSE:
-// PARAMETERS:
-void AreaUsage::SetClippingControl(const ClippingControl clippingControl)
- this->m_eClippingControl = clippingControl;
-// PURPOSE:
-// PARAMETERS:
const MdfString& AreaUsage::GetOriginX() const
return this->m_sOriginX;
Modified: trunk/MgDev/Common/MdfModel/AreaUsage.h
--- trunk/MgDev/Common/MdfModel/AreaUsage.h 2007-03-07 04:47:30 UTC (rev 1162)
+++ trunk/MgDev/Common/MdfModel/AreaUsage.h 2007-03-07 05:23:02 UTC (rev 1163)
@@ -29,33 +29,16 @@
class MDFMODEL_API AreaUsage : public Usage
public:
- enum OriginControl
- Global,
- Local,
- Centroid
- enum ClippingControl
- Clip,
- Inside,
- Overlap
// Construction, destruction, initialization
AreaUsage();
virtual ~AreaUsage();
- OriginControl GetOriginControl() const;
- void SetOriginControl(OriginControl originControl);
+ const MdfString& GetOriginControl() const;
+ void SetOriginControl(const MdfString& originControl);
- AngleControl GetAngleControl() const;
- void SetAngleControl(AngleControl angleControl);
+ const MdfString& GetClippingControl() const;
+ void SetClippingControl(const MdfString& clippingControl);
- ClippingControl GetClippingControl() const;
- void SetClippingControl(ClippingControl clippingControl);
const MdfString& GetOriginX() const;
void SetOriginX(const MdfString& originX);
@@ -82,10 +65,8 @@
AreaUsage& operator=(const AreaUsage&);
// Data members
- OriginControl m_eOriginControl;
- AngleControl m_eAngleControl;
- ClippingControl m_eClippingControl;
+ MdfString m_sOriginControl;
+ MdfString m_sClippingControl;
MdfString m_sOriginX;
MdfString m_sOriginY;
MdfString m_sAngle;
Modified: trunk/MgDev/Common/MdfModel/LineUsage.cpp
--- trunk/MgDev/Common/MdfModel/LineUsage.cpp 2007-03-07 04:47:30 UTC (rev 1162)
+++ trunk/MgDev/Common/MdfModel/LineUsage.cpp 2007-03-07 05:23:02 UTC (rev 1163)
@@ -32,9 +32,6 @@
// IOLineUsage::Write to use the correct default values.
- this->m_eUnitsControl = Absolute;
- this->m_eVertexControl = OverlapWrap;
this->m_pDefaultPath = NULL;
@@ -52,60 +49,42 @@
// PURPOSE:
// PARAMETERS:
-Usage::AngleControl LineUsage::GetAngleControl() const
+const MdfString& LineUsage::GetUnitsControl() const
+ return this->m_sUnitsControl;
// PURPOSE:
// PARAMETERS:
-void LineUsage::SetAngleControl(AngleControl angleControl)
+void LineUsage::SetUnitsControl(const MdfString& unitsControl)
+ this->m_sUnitsControl = unitsControl;
// PURPOSE:
// PARAMETERS:
-LineUsage::UnitsControl LineUsage::GetUnitsControl() const
+const MdfString& LineUsage::GetVertexControl() const
- return this->m_eUnitsControl;
+ return this->m_sVertexControl;
// PURPOSE:
// PARAMETERS:
-void LineUsage::SetUnitsControl(UnitsControl unitsControl)
+void LineUsage::SetVertexControl(const MdfString& vertexControl)
- this->m_eUnitsControl = unitsControl;
+ this->m_sVertexControl = vertexControl;
// PURPOSE:
// PARAMETERS:
-LineUsage::VertexControl LineUsage::GetVertexControl() const
- return this->m_eVertexControl;
-// PURPOSE:
-// PARAMETERS:
-void LineUsage::SetVertexControl(VertexControl vertexControl)
- this->m_eVertexControl = vertexControl;
-// PURPOSE:
-// PARAMETERS:
const MdfString& LineUsage::GetAngle() const
return this->m_sAngle;
Modified: trunk/MgDev/Common/MdfModel/LineUsage.h
--- trunk/MgDev/Common/MdfModel/LineUsage.h 2007-03-07 04:47:30 UTC (rev 1162)
+++ trunk/MgDev/Common/MdfModel/LineUsage.h 2007-03-07 05:23:02 UTC (rev 1163)
@@ -30,33 +30,17 @@
class MDFMODEL_API LineUsage : public Usage
public:
- enum UnitsControl
- Absolute,
- Parametric
- enum VertexControl
- NoOverlap,
- OverlapDirect,
- OverlapNoWrap,
- OverlapWrap
LineUsage();
virtual ~LineUsage();
+ const MdfString& GetUnitsControl() const;
+ void SetUnitsControl(const MdfString& unitsControl);
- UnitsControl GetUnitsControl() const;
- void SetUnitsControl(UnitsControl unitsControl);
+ const MdfString& GetVertexControl() const;
+ void SetVertexControl(const MdfString& vertexControl);
- VertexControl GetVertexControl() const;
- void SetVertexControl(VertexControl vertexControl);
const MdfString& GetAngle() const;
void SetAngle(const MdfString& angle);
@@ -84,10 +68,8 @@
LineUsage& operator=(const LineUsage&);
// Data members
- UnitsControl m_eUnitsControl;
- VertexControl m_eVertexControl;
+ MdfString m_sUnitsControl;
+ MdfString m_sVertexControl;
MdfString m_sAngle;
MdfString m_sStartOffset;
MdfString m_sEndOffset;
Modified: trunk/MgDev/Common/MdfModel/MdfModel.vcproj
--- trunk/MgDev/Common/MdfModel/MdfModel.vcproj 2007-03-07 04:47:30 UTC (rev 1162)
+++ trunk/MgDev/Common/MdfModel/MdfModel.vcproj 2007-03-07 05:23:02 UTC (rev 1163)
@@ -327,6 +327,10 @@
</File>
<File
+ RelativePath=".\Usage.cpp"
+ </File>
+ <File
RelativePath=".\Usage.h"
</File>
Modified: trunk/MgDev/Common/MdfModel/PointUsage.cpp
--- trunk/MgDev/Common/MdfModel/PointUsage.cpp 2007-03-07 04:47:30 UTC (rev 1162)
+++ trunk/MgDev/Common/MdfModel/PointUsage.cpp 2007-03-07 05:23:02 UTC (rev 1163)
@@ -31,7 +31,6 @@
// IOPointUsage::Write to use the correct default values.
@@ -46,24 +45,6 @@
// PURPOSE:
// PARAMETERS:
-Usage::AngleControl PointUsage::GetAngleControl() const
-// PURPOSE:
-// PARAMETERS:
-void PointUsage::SetAngleControl(AngleControl angleControl)
-// PURPOSE:
-// PARAMETERS:
const MdfString& PointUsage::GetAngle() const
Modified: trunk/MgDev/Common/MdfModel/PointUsage.h
--- trunk/MgDev/Common/MdfModel/PointUsage.h 2007-03-07 04:47:30 UTC (rev 1162)
+++ trunk/MgDev/Common/MdfModel/PointUsage.h 2007-03-07 05:23:02 UTC (rev 1163)
@@ -33,9 +33,6 @@
PointUsage();
virtual ~PointUsage();
@@ -53,7 +50,6 @@
PointUsage& operator=(const PointUsage&);
// Data members
MdfString m_sAngle;
MdfString m_sOriginOffsetX;
MdfString m_sOriginOffsetY;
Added: trunk/MgDev/Common/MdfModel/Usage.cpp
--- trunk/MgDev/Common/MdfModel/Usage.cpp (rev 0)
+++ trunk/MgDev/Common/MdfModel/Usage.cpp 2007-03-07 05:23:02 UTC (rev 1163)
@@ -0,0 +1,54 @@
+// Copyright (C) 2007 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#include "Usage.h"
+using namespace MDFMODEL_NAMESPACE;
+// PURPOSE:
+// PARAMETERS:
+Usage::Usage()
+// PURPOSE:
+// PARAMETERS:
+Usage::~Usage()
+// PURPOSE:
+// PARAMETERS:
+const MdfString& Usage::GetAngleControl() const
+ return m_sAngleControl;
+// PURPOSE:
+// PARAMETERS:
+void Usage::SetAngleControl(const MdfString& sControl)
+ m_sAngleControl = sControl;
Modified: trunk/MgDev/Common/MdfModel/Usage.h
--- trunk/MgDev/Common/MdfModel/Usage.h 2007-03-07 04:47:30 UTC (rev 1162)
+++ trunk/MgDev/Common/MdfModel/Usage.h 2007-03-07 05:23:02 UTC (rev 1163)
@@ -30,26 +30,21 @@
class MDFMODEL_API Usage : public MdfRootObject
public:
- enum AngleControl
- FromAngle,
- FromGeometry
// Destruction
- virtual ~Usage()
+ virtual ~Usage();
+ const MdfString& GetAngleControl() const;
+ void SetAngleControl(const MdfString& sControl);
// Visitor Pattern method defined in Usage.
virtual void AcceptVisitor(IUsageVisitor& iuVisitor) = 0;
protected:
// Construction, initialization
// Default constructor is protected to make this class abstract.
- Usage()
+ Usage();
+ MdfString m_sAngleControl;
END_NAMESPACE_MDFMODEL
Modified: trunk/MgDev/Common/MdfParser/IOAreaUsage.cpp
--- trunk/MgDev/Common/MdfParser/IOAreaUsage.cpp 2007-03-07 04:47:30 UTC (rev 1162)
+++ trunk/MgDev/Common/MdfParser/IOAreaUsage.cpp 2007-03-07 05:23:02 UTC (rev 1163)
@@ -40,9 +40,9 @@
void IOAreaUsage::ElementChars(const wchar_t *ch)
- IF_ENUM_2(m_currElemName, this->_areaUsage, AreaUsage, OriginControl, ch, Global, Centroid)
- else IF_ENUM_2(m_currElemName, this->_areaUsage, Usage, AngleControl, ch, FromAngle, FromGeometry)
- else IF_ENUM_2(m_currElemName, this->_areaUsage, AreaUsage, ClippingControl, ch, Clip, Overlap)
+ IF_STRING_PROPERTY(m_currElemName, this->_areaUsage, OriginControl, ch)
+ else IF_STRING_PROPERTY(m_currElemName, this->_areaUsage, AngleControl, ch)
+ else IF_STRING_PROPERTY(m_currElemName, this->_areaUsage, ClippingControl, ch)
else IF_STRING_PROPERTY(m_currElemName, this->_areaUsage, OriginX, ch)
else IF_STRING_PROPERTY(m_currElemName, this->_areaUsage, OriginY, ch)
else IF_STRING_PROPERTY(m_currElemName, this->_areaUsage, Angle, ch)
@@ -69,9 +69,9 @@
fd << tab() << "<AreaUsage>" << std::endl; // NOXLATE
inctab();
- EMIT_ENUM_2(fd, usage, AreaUsage, OriginControl, Global, Centroid, 1) // Global is default
- EMIT_ENUM_2(fd, usage, Usage, AngleControl, FromAngle, FromGeometry, 1) // FromAngle is default
- EMIT_ENUM_2(fd, usage, AreaUsage, ClippingControl, Clip, Overlap, 1) // Clip is default
+ EMIT_STRING_PROPERTY(fd, usage, OriginControl, true);
+ EMIT_STRING_PROPERTY(fd, usage, AngleControl, true);
+ EMIT_STRING_PROPERTY(fd, usage, ClippingControl, true);
EMIT_STRING_PROPERTY(fd, usage, OriginX, true)
EMIT_STRING_PROPERTY(fd, usage, OriginY, true)
EMIT_STRING_PROPERTY(fd, usage, Angle, true)
Modified: trunk/MgDev/Common/MdfParser/IOLineUsage.cpp
--- trunk/MgDev/Common/MdfParser/IOLineUsage.cpp 2007-03-07 04:47:30 UTC (rev 1162)
+++ trunk/MgDev/Common/MdfParser/IOLineUsage.cpp 2007-03-07 05:23:02 UTC (rev 1163)
@@ -49,9 +49,9 @@
void IOLineUsage::ElementChars(const wchar_t *ch)
- IF_ENUM_2(m_currElemName, this->_lineUsage, Usage, AngleControl, ch, FromAngle, FromGeometry)
- else IF_ENUM_2(m_currElemName, this->_lineUsage, LineUsage, UnitsControl, ch, Absolute, Parametric)
- else IF_ENUM_4(m_currElemName, this->_lineUsage, LineUsage, VertexControl, ch, NoOverlap, OverlapDirect, OverlapNoWrap, OverlapWrap)
+ IF_STRING_PROPERTY(m_currElemName, this->_lineUsage, AngleControl, ch)
+ else IF_STRING_PROPERTY(m_currElemName, this->_lineUsage, UnitsControl, ch)
+ else IF_STRING_PROPERTY(m_currElemName, this->_lineUsage, VertexControl, ch)
else IF_STRING_PROPERTY(m_currElemName, this->_lineUsage, Angle, ch)
else IF_STRING_PROPERTY(m_currElemName, this->_lineUsage, StartOffset, ch)
else IF_STRING_PROPERTY(m_currElemName, this->_lineUsage, EndOffset, ch)
@@ -77,9 +77,9 @@
fd << tab() << "<LineUsage>" << std::endl; // NOXLATE
inctab();
- EMIT_ENUM_2(fd, lineUsage, Usage, AngleControl, FromAngle, FromGeometry, 1) // FromAngle is default
- EMIT_ENUM_2(fd, lineUsage, LineUsage, UnitsControl, Absolute, Parametric, 1) // Absolute is default
- EMIT_ENUM_4(fd, lineUsage, LineUsage, VertexControl, NoOverlap, OverlapDirect, OverlapNoWrap, OverlapWrap, 4) // OverlapWrap is default
+ EMIT_STRING_PROPERTY(fd, lineUsage, AngleControl, true)
+ EMIT_STRING_PROPERTY(fd, lineUsage, UnitsControl, true)
+ EMIT_STRING_PROPERTY(fd, lineUsage, VertexControl, true)
EMIT_STRING_PROPERTY(fd, lineUsage, Angle, true)
EMIT_STRING_PROPERTY(fd, lineUsage, StartOffset, true)
EMIT_STRING_PROPERTY(fd, lineUsage, EndOffset, true)
Modified: trunk/MgDev/Common/MdfParser/IOPointUsage.cpp
--- trunk/MgDev/Common/MdfParser/IOPointUsage.cpp 2007-03-07 04:47:30 UTC (rev 1162)
+++ trunk/MgDev/Common/MdfParser/IOPointUsage.cpp 2007-03-07 05:23:02 UTC (rev 1163)
@@ -40,7 +40,7 @@
void IOPointUsage::ElementChars(const wchar_t *ch)
- IF_ENUM_2(m_currElemName, this->_pointUsage, Usage, AngleControl, ch, FromAngle, FromGeometry)
+ IF_STRING_PROPERTY(m_currElemName, this->_pointUsage, AngleControl, ch)
else IF_STRING_PROPERTY(m_currElemName, this->_pointUsage, Angle, ch)
else IF_STRING_PROPERTY(m_currElemName, this->_pointUsage, OriginOffsetX, ch)
else IF_STRING_PROPERTY(m_currElemName, this->_pointUsage, OriginOffsetY, ch)
@@ -64,7 +64,7 @@
fd << tab() << "<PointUsage>" << std::endl; // NOXLATE
inctab();
- EMIT_ENUM_2(fd, pointUsage, Usage, AngleControl, FromAngle, FromGeometry, 1) // FromAngle is default
+ EMIT_STRING_PROPERTY(fd, pointUsage, AngleControl, true)
EMIT_STRING_PROPERTY(fd, pointUsage, Angle, true)
EMIT_STRING_PROPERTY(fd, pointUsage, OriginOffsetX, true)
EMIT_STRING_PROPERTY(fd, pointUsage, OriginOffsetY, true)
Modified: trunk/MgDev/Common/Stylization/SE_Bounds.cpp
--- trunk/MgDev/Common/Stylization/SE_Bounds.cpp 2007-03-07 04:47:30 UTC (rev 1162)
+++ trunk/MgDev/Common/Stylization/SE_Bounds.cpp 2007-03-07 05:23:02 UTC (rev 1163)
@@ -1,5 +1,5 @@
-// Copyright (C) 2007 by Autodesk, Inc.
+// Copyright (C) 2007 Autodesk, Inc.
@@ -20,6 +20,14 @@
#include "SE_ConvexHull.h"
#include <float.h>
+SE_Bounds::SE_Bounds()
+SE_Bounds::~SE_Bounds()
void SE_Bounds::Add(double x, double y)
if (size >= capacity)
@@ -43,7 +51,7 @@
double *last = hull + 2*size;
double *cur = hull;
while (cur < last)
xform.transform(*cur++, *cur++);
@@ -93,25 +101,36 @@
void SE_Bounds::Contained(double minx, double miny, double maxx, double maxy, double &growx, double &growy)
double sx, sy;
- if (min[0] < minx)
+ double cx = (minx + maxx)/2.0;
+ double cy = (miny + maxy)/2.0;
+ minx -= cx;
+ maxx -= cx;
+ miny -= cy;
+ maxy -= cy;
+ double xfminx, xfminy, xfmaxx, xfmaxy;
+ xfminx = min[0] - cx;
+ xfminy = min[1] - cy;
+ xfmaxx = max[0] - cx;
+ xfmaxy = max[1] - cy;
+ if (xfminx < minx) // minx always negative
- sx = (minx - min[0])/(maxx - minx);
+ sx = xfminx/minx - 1.0;
growx = (growx > sx) ? growx : sx;
- if (max[0] > maxx)
+ if (xfmaxx > maxx) // maxx always positive
- sx = (max[0] - maxx)/(maxx - minx);
+ sx = xfmaxx/maxx - 1.0;
- if (min[1] < miny)
+ if (xfminy < miny)
- sy = (miny - min[1])/(maxy - miny);
+ sy = xfminy/miny - 1.0;
growy = (growy > sy) ? growy : sy;
- if (max[1] < maxy)
+ if (xfmaxy > maxy)
- sy = (max[1] - maxy)/(maxy - miny);
+ sy = xfmaxy/maxy - 1.0;
@@ -127,7 +146,7 @@
vec = new double[2*usize];
else
vec = (double*)alloca(sizeof(double)*2*usize);
double* start[4] = {hull, hull + 2*size - 2, bounds->hull, bounds->hull + 2*bounds->size - 2};
double* end[4] = {hull + 2*pivot, hull + 2*pivot - 2, bounds->hull + 2*bounds->pivot, bounds->hull + 2*bounds->pivot - 2};
@@ -169,10 +188,10 @@
double* last = vec + pnts - 2;
double* first = vec;
- SE_Bounds* ubounds = AndrewHull<SimplePoint*, SimplePointUtil>((SimplePoint*)first, (SimplePoint*)last, pnts/2, pool);
+ SE_Bounds* ubounds = AndrewHull<SimplePoint*, SimplePointUtil>((SimplePoint*)first, (SimplePoint*)last, pnts/2, pool);
if (usize > 4096)
delete[] vec;
return ubounds;
\ No newline at end of file
Modified: trunk/MgDev/Common/Stylization/SE_Bounds.h
--- trunk/MgDev/Common/Stylization/SE_Bounds.h 2007-03-07 04:47:30 UTC (rev 1162)
+++ trunk/MgDev/Common/Stylization/SE_Bounds.h 2007-03-07 05:23:02 UTC (rev 1163)
@@ -1,5 +1,5 @@
@@ -27,6 +27,7 @@
friend class SE_LineBufferPool;
private:
SE_Bounds();
+ ~SE_Bounds();
int capacity;
SE_LineBufferPool* pool;
@@ -46,4 +47,4 @@
STYLIZATION_API SE_Bounds* Union(SE_Bounds* bounds);
-#endif // SE_BOUNDS_H
+#endif // SE_BOUNDS_H
Modified: trunk/MgDev/Common/Stylization/SE_ExpressionBase.cpp
--- trunk/MgDev/Common/Stylization/SE_ExpressionBase.cpp 2007-03-07 04:47:30 UTC (rev 1162)
+++ trunk/MgDev/Common/Stylization/SE_ExpressionBase.cpp 2007-03-07 05:23:02 UTC (rev 1163)
@@ -196,7 +196,33 @@
val.value = L"";
else
- val.expression = FdoExpression::Parse(m_buffer.c_str());
+ const wchar_t* str = m_buffer.c_str();
+ while (isspace(*str))
+ str++;
+ if (*str++ != '\'')
+ val.expression = FdoExpression::Parse(m_buffer.c_str());
+ return;
+ const wchar_t* begin = str;
+ while(*str != NULL && *str != '\'')
+ str++;
+ if (*str == NULL)
+ return;
+ size_t len = str - begin;
+ wchar_t* copy = new wchar_t[len + 1];
+ memcpy(copy, begin, sizeof(wchar_t)*len);
+ copy[len] = L'\0';
+ val.value = copy;
void SE_ExpressionBase::ParseColorExpression(const MdfModel::MdfString& exprstr, SE_Color& val)
Modified: trunk/MgDev/Common/Stylization/SE_Include.h
--- trunk/MgDev/Common/Stylization/SE_Include.h 2007-03-07 04:47:30 UTC (rev 1162)
+++ trunk/MgDev/Common/Stylization/SE_Include.h 2007-03-07 05:23:02 UTC (rev 1163)
@@ -60,7 +60,7 @@
expression->Process(processor);
*((unsigned int*)this) = (unsigned int)processor->GetInt64Result();
return *((unsigned int*)this);
@@ -145,12 +145,20 @@
SE_INLINE SE_String() : expression(NULL), value(NULL) { }
SE_INLINE SE_String(const wchar_t* s) : value(s), expression(NULL) { }
- ~SE_String() { if (expression) expression->Release(); }
+ ~SE_String()
+ if (value)
+ delete[] value;
+ if (expression)
+ expression->Release();
SE_INLINE const wchar_t* evaluate(RS_FilterExecutor* processor)
if (expression)
+ if (value)
+ delete[] value;
value = processor->GetStringResult();
@@ -187,7 +195,7 @@
SE_Color fill;
- SE_INLINE SE_Polygon() { type = SE_PolygonPrimitive; weight = 0.0; }
+ SE_INLINE SE_Polygon() { type = SE_PolygonPrimitive; weight = 0.0; }
/* Font/properties caching is left to the implementor of SE_Renderer */
@@ -223,6 +231,7 @@
SE_INLINE SE_Raster() { type = SE_RasterPrimitive; }
// SE_RenderPrimitives
@@ -307,7 +316,7 @@
SE_INLINE SE_PointStyle() : SE_Style(SE_PointStyleType) { }
- Usage::AngleControl orientation;
+ SE_String orientation;
SE_Double angle;
SE_Double offset[2];
@@ -316,10 +325,10 @@
SE_INLINE SE_LineStyle() : SE_Style(SE_LineStyleType) { }
- LineUsage::UnitsControl units;
- LineUsage::VertexControl overlap;
- Path::LineJoin join;
+ SE_String units;
+ SE_String overlap;
+ SE_String join;
SE_Double startOffset;
SE_Double endOffset;
@@ -332,9 +341,9 @@
SE_INLINE SE_AreaStyle() : SE_Style(SE_AreaStyleType) { }
- AreaUsage::OriginControl origincontrol;
- AreaUsage::ClippingControl clipping;
+ SE_String origincontrol;
+ SE_String clipping;
SE_Double origin[2];
SE_Double repeat[2];
@@ -350,7 +359,7 @@
struct SE_RenderStyle
- SE_INLINE SE_RenderStyle(SE_StyleType stype)
+ SE_INLINE SE_RenderStyle(SE_StyleType stype)
: type(stype),
drawLast(false),
checkExclusionRegions(false),
@@ -384,10 +393,10 @@
SE_INLINE SE_RenderLineStyle() : SE_RenderStyle(SE_LineStyleType) { }
+ const wchar_t* orientation;
+ const wchar_t* units;
+ const wchar_t* overlap;
+ const wchar_t* join;
double startOffset;
double endOffset;
@@ -400,9 +409,9 @@
SE_INLINE SE_RenderAreaStyle() : SE_RenderStyle(SE_AreaStyleType) { }
- AreaUsage::AngleControl orientation;
+ const wchar_t* origincontrol;
+ const wchar_t* clipping;
unsigned int background;
double origin[2];
@@ -421,8 +430,8 @@
double dx;
double dy;
double anglerad;
- RS_Units dunits;
+ RS_Units dunits;
SE_INLINE SE_LabelInfo() :
x(0.0),
y(0.0),
@@ -463,7 +472,7 @@
std::vector<SE_Symbolization*> symbolization;
FdoFilter* filter;
~SE_Rule()
if (filter) filter->Release();
@@ -475,4 +484,5 @@
#endif // SE_INCLUDE_H
Modified: trunk/MgDev/Common/Stylization/SE_LineBuffer.cpp
--- trunk/MgDev/Common/Stylization/SE_LineBuffer.cpp 2007-03-07 04:47:30 UTC (rev 1162)
+++ trunk/MgDev/Common/Stylization/SE_LineBuffer.cpp 2007-03-07 05:23:02 UTC (rev 1163)
@@ -1,5 +1,5 @@
@@ -27,7 +27,7 @@
#define ENSURE_POINT_BUFFER(points) \
if ((m_npts + (points)) > m_max_pts) \
- ResizeBuffer((void**)&m_pts, 2*sizeof(double), (points), m_npts, m_max_pts);
+ ResizeBuffer((void**)&m_pts, sizeof(double), (points), m_npts, m_max_pts);
#define ENSURE_XF_POINT_BUFFER(points) \
if ((m_xf_npts + (points)) > m_max_xf_pts) \
@@ -165,7 +165,7 @@
however, appear to be using round joins at the moment. */
m_ch_ptbuf.insert(std::pair<double,double>(x + vx, y + vy));
m_ch_ptbuf.insert(std::pair<double,double>(x - vx, y - vy));
- m_ch_ptbuf.insert(std::pair<double,double>(lx + vx, ly + vy));
+ m_ch_ptbuf.insert(std::pair<double,double>(lx + vx, ly + vy));
m_ch_ptbuf.insert(std::pair<double,double>(lx - vx, ly - vy));
while(cur < last)
@@ -211,7 +211,7 @@
m_max_inst_pts(size),
m_max_xf_cntrs(size),
m_max_inst_cntrs(size),
- m_max_pts(size),
+ m_max_pts(2*size),
m_max_segs(size),
m_xf_tol(-1.0),
m_xf_weight(-1.0),
@@ -239,28 +239,33 @@
void SE_LineBuffer::MoveTo(double x, double y)
- ENSURE_POINT_BUFFER(1);
+ ENSURE_POINT_BUFFER(2);
ENSURE_SEG_BUFFER(1);
- double* cur_pt = m_pts + 2*m_npts++;
+ double* cur_pt = m_pts + m_npts;
*cur_pt++ = x;
*cur_pt = y;
- m_start[0] = x;
- m_start[1] = y;
+ m_start[0] = m_last[0] = x;
+ m_start[1] = m_last[1] = y;
+ m_npts += 2;
m_segs[m_nsegs++] = SegType_MoveTo;
void SE_LineBuffer::LineTo(double x, double y)
*cur_pt++ = x;
*cur_pt = y;
+ m_last[0] = x;
+ m_last[1] = y;
+ m_npts += 2;
m_segs[m_nsegs++] = SegType_LineTo;
@@ -269,7 +274,47 @@
ENSURE_POINT_BUFFER(7);
- double* cur_pt = m_pts + 2*m_npts;
+ double sx, sy, ex, ey, dsx, dsy, dex, dey;
+ sx = cx + rx*cos(sAng);
+ sy = cy + ry*sin(sAng);
+ ex = cx + rx*cos(eAng);
+ ey = cy + ry*sin(eAng);
+ if (rotation != 0)
+ double rs = sin(rotation);
+ double rc = cos(rotation);
+ double tx, ty;
+ tx = sx; ty = sy;
+ sx = rc*sx + rs*sy;
+ sy = rc*sy - rs*sx;
+ tx = ex; ty = ey;
+ ex = rc*ex + rs*ey;
+ ey = rc*ey - rs*ex;
+ dsx = m_last[0] - sx;
+ dsy = m_last[1] - sy;
+ dex = m_last[0] - ex;
+ dey = m_last[1] - ey;
+ /* End angle is actually the current line position */
+ if (dsx*dsx + dsy*dsy > dex*dex + dey*dey)
+ double t = sAng;
+ sAng = eAng;
+ eAng = t;
+ m_last[0] = sx;
+ m_last[1] = sy;
+ else
+ m_last[0] = ex;
+ m_last[1] = ey;
*cur_pt++ = cx;
*cur_pt++ = cy;
*cur_pt++ = rx;
@@ -310,7 +355,7 @@
int max_newpts = (int)(max_pts*GROWTH_FACTOR) + 1;
if (max_newpts - max_pts < mininc)
max_newpts += mininc;
void* newbuf = new char[unitsize*max_newpts];
memcpy(newbuf, *buffer, cur_pts*unitsize);
delete[] *buffer;
@@ -368,14 +413,15 @@
double eAng = m_pts[src_idx++];
double rot = m_pts[src_idx++];
- /* TODO: change the # of segments based on the tolerance?...up to 4 for now */
- int nsegs = (int)(4.0*(eAng - sAng)/(2*M_PI)) + 1; // eAng - sAng is (0, 2pi), so this is {1,2,3,4}.
+ /* TODO: change the # of segments based on the tolerance?...up to 6 for now */
+ int nsegs = (int)(4.0*fabs(eAng - sAng)/(2*M_PI)) + 1; // eAng - sAng is (0, 2pi), so this is {1,2,3,4}.
double span = (eAng - sAng)/(double)nsegs;
- double sec = 1.0/cos(span/2.0);
- double alpha = sin(span)*(sqrt(1.0 + 3.0/sec/sec) - 1)/3.0;
+ double aspan = fabs(span);
+ double sec = 1.0/cos(aspan/2.0);
+ double alpha = sin(aspan)*(sqrt(1.0 + 3.0/sec/sec) - 1)/3.0;
double rcos = cos(rot), rsin = sin(rot);
double ex, ey, sx, sy;
double scos, ssin, ecos, esin;
double sa, ea;
@@ -386,6 +432,8 @@
ey = ry*esin;
ea = sAng;
+ double cw = sAng > eAng ? -1.0 : 1.0;
for (int i = 0; i < nsegs; i++)
sa = ea;
@@ -401,11 +449,13 @@
ex = rx*ecos;
ey = ry*esin;
- double c1x = sx - alpha*rx*ssin;
- double c1y = sy + alpha*ry*scos;
- double c2x = ex + alpha*rx*esin;
- double c2y = ey - alpha*ry*ecos;
+ double c1x, c1y, c2x, c2y;
+ c1x = sx - cw*alpha*rx*ssin;
+ c1y = sy + cw*alpha*ry*scos;
+ c2x = ex + cw*alpha*rx*esin;
+ c2y = ey - cw*alpha*ry*ecos;
/* Here, we fine the maximum 2nd derivative over the interval in question, and
calculate the number of segments, assuming a deviation of the segment length *
the second derivative must be within the tolerance */
@@ -413,7 +463,7 @@
SineCosineMax(sa, ssin, scos, ea, esin, ecos, my, mx);
mx *= rx;
my *= ry;
- int steps = (int)((span/tolerance)*sqrt(mx*mx + my*my)) + 1;
+ int steps = (int)((aspan/tolerance)*sqrt(mx*mx + my*my)) + 1;
ENSURE_XF_POINT_BUFFER(steps + 1);
m_xf_cntrs[m_xf_ncntrs-1] += steps + 1;
m_xf_npts += steps + 1;
@@ -433,15 +483,13 @@
tx = mx, ty = my;
- ex += cx;
- ey += cy;
c1x += cx;
c1y += cy;
c2x += cx;
c2y += cy;
- TessellateCubicTo(m_xf_pts + dst_idx, c1x, c1y, c2x, c2y, ex, ey, steps);
- dst_idx += steps + 1;
+ TessellateCubicTo(m_xf_pts + dst_idx, c1x, c1y, c2x, c2y, ex + cx, ey + cy, steps);
+ dst_idx += 2*steps + 2;
break;
@@ -504,6 +552,10 @@
double px1 = pts[-2];
double py1 = pts[-1];
+ m_xf.transform(px2, py2);
+ m_xf.transform(px3, py3);
+ m_xf.transform(px4, py4);
double dt = 1.0/(double)steps;
double dt3 = dt * dt * dt;
@@ -537,8 +589,8 @@
ddfy += dddfy;
ddfx += dddfx;
- m_xf.transform(fx, fy, pts[0], pts[1]);
- pts += 2;
+ *pts++ = fx;
+ *pts++ = fy;
*pts++ = px4;
@@ -614,7 +666,7 @@
m_xf_ncntrs = lb->cntr_count();
memcpy(m_xf_cntrs, lb->cntrs(), sizeof(int)*m_xf_ncntrs);
m_xf_npts = lb->point_count();
double *srcpts = lb->points();
@@ -679,4 +731,4 @@
void SE_LineBufferPool::FreeBounds(SE_Bounds* bounds)
m_bnd_pool.push(bounds);
Modified: trunk/MgDev/Common/Stylization/SE_LineBuffer.h
--- trunk/MgDev/Common/Stylization/SE_LineBuffer.h 2007-03-07 04:47:30 UTC (rev 1162)
+++ trunk/MgDev/Common/Stylization/SE_LineBuffer.h 2007-03-07 05:23:02 UTC (rev 1163)
@@ -1,5 +1,5 @@
@@ -33,6 +33,23 @@
struct SE_Geometry
+ SE_INLINE SE_Geometry() :
+ points(NULL),
+ n_pts(0),
+ contours(NULL),
+ n_cntrs(0),
+ geom_type(0)
+ SE_INLINE SE_Geometry(LineBuffer* srclb)
+ points = srclb->points();
+ n_pts = srclb->point_count();
+ contours = srclb->cntrs();
+ n_cntrs = srclb->cntr_count();
+ geom_type = srclb->geom_type();
double* points;
int n_pts;
int* contours;
@@ -41,7 +58,6 @@
struct SE_Bounds;
-class SE_LineBufferPool;
class SE_LineBuffer
@@ -55,8 +71,8 @@
SegType_MoveTo,
SegType_LineTo,
SegType_EllipticalArc
STYLIZATION_API void SetToTransform(LineBuffer* lb, const SE_Matrix& xform);
STYLIZATION_API void MoveTo(double x, double y);
@@ -81,7 +97,7 @@
void ResizeBuffer(void** buffer, int unitsize, int mininc, int cur_pts, int& max_pts);
void TessellateCubicTo(double* pts, double px2, double py2, double px3, double py3, double px4, double py4, int steps);
SE_Bounds* ComputeConvexHull(double* pnts, int* cntrs, int ncntrs, double weight);
SE_LineBufferPool* m_pool;
LineBuffer* m_src_lb;
@@ -100,8 +116,9 @@
SE_Bounds* m_inst_bounds;
double m_xf_tol;
double m_xf_weight;
double m_start[2];
+ double m_last[2];
int m_npts;
int m_xf_npts;
@@ -132,4 +149,4 @@
DataValueStack<SE_Bounds> m_bnd_pool;
-#endif // SE_LINEBUFFER_H
+#endif // SE_LINEBUFFER_H
Modified: trunk/MgDev/Common/Stylization/SE_Renderer.cpp
--- trunk/MgDev/Common/Stylization/SE_Renderer.cpp 2007-03-07 04:47:30 UTC (rev 1162)
+++ trunk/MgDev/Common/Stylization/SE_Renderer.cpp 2007-03-07 05:23:02 UTC (rev 1163)
@@ -53,6 +53,7 @@
void SE_Renderer::ProcessLine(SE_LineBuffer* geometry, SE_RenderLineStyle* style)
SE_Matrix xform;
+ SE_Matrix symxf;
SE_Geometry geom;
geom.points = geometry->xf_points();
geom.n_pts = geometry->xf_point_cnt();
@@ -60,7 +61,7 @@
geom.n_cntrs = geometry->xf_cntr_cnt();
geom.geom_type = geometry->xf_geom_type();
- bool yUp = GetFontEngine()->_Yup();
+ double yUp = GetFontEngine()->_Yup() ? 1.0 : -1.0;
int ptindex = 0;
@@ -83,6 +84,7 @@
while (cur_seg < ptcount - 1)
xform.setIdentity();
+ symxf.setIdentity();
//current line segment
double* seg = pts + cur_seg * 2;
@@ -106,8 +108,13 @@
dx_incr = cos(slope);
dy_incr = sin(slope);
- xform.rotate(yUp ? slope : -slope); // negative for y-inversion
- xform.translate(seg[0] + dx_incr * drawpos, seg[1] + dy_incr * drawpos);
+ double symrot = wcscmp(L"FromAngle", style->orientation) == 0 ? style->angle : slope*yUp;
+ xform.rotate(slope*yUp); // negative for y-inversion
+ symxf.rotate(symrot);
+ double tx = seg[0] + dx_incr * drawpos;
+ double ty = seg[1] + dy_incr * drawpos;
+ xform.translate(tx, ty);
+ symxf.translate(tx, ty);
dx_incr *= increment;
dy_incr *= increment;
@@ -116,11 +123,12 @@
while (drawpos < len)
if (style->drawLast)
- AddLabel(&geom, style, xform, style->orientation == LineUsage::FromGeometry ? slope : style->angle);
+ AddLabel(&geom, style, symxf, symrot);
else
- DrawSymbol(style->symbol, xform, style->orientation == LineUsage::FromGeometry ? slope : style->angle);
+ DrawSymbol(style->symbol, symxf, symrot);
xform.translate(dx_incr, dy_incr);
+ symxf.translate(dx_incr, dy_incr);
drawpos += increment;
Modified: trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp
--- trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp 2007-03-07 04:47:30 UTC (rev 1162)
+++ trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp 2007-03-07 05:23:02 UTC (rev 1163)
@@ -41,7 +41,6 @@
double cx, cy;
double startAng, endAng;
- double rotation;
bool ParseArc(ArcDefinition& def, ArcData& data);
@@ -60,7 +59,7 @@
ParseDoubleExpression(pntRpt.GetAngle(), style->angle);
ParseDoubleExpression(pntRpt.GetOriginOffsetX(), style->offset[0]);
ParseDoubleExpression(pntRpt.GetOriginOffsetY(), style->offset[1]);
- style->orientation = pntRpt.GetAngleControl();
+ ParseStringExpression(pntRpt.GetAngleControl(), style->orientation);
void SE_StyleVisitor::VisitLineUsage(LineUsage& lnRpt)
@@ -72,6 +71,10 @@
ParseDoubleExpression(lnRpt.GetRepeat(), style->repeat);
ParseDoubleExpression(lnRpt.GetAngle(), style->angle);
ParseDoubleExpression(lnRpt.GetVertexAngleLimit(), style->angleLimit);
+ ParseStringExpression(lnRpt.GetUnitsControl(), style->units);
+ ParseStringExpression(lnRpt.GetAngleControl(), style->orientation);
+ ParseStringExpression(lnRpt.GetVertexControl(), style->overlap);
+ //ParseStringExpression(lnRpt.GetLineJoin(), style->join);
void SE_StyleVisitor::VisitAreaUsage(AreaUsage& areaRpt)
@@ -84,6 +87,9 @@
ParseDoubleExpression(areaRpt.GetRepeatX(), style->repeat[0]);
ParseDoubleExpression(areaRpt.GetRepeatY(), style->repeat[1]);
ParseDoubleExpression(areaRpt.GetBufferWidth(), style->bufferWidth);
+ ParseStringExpression(areaRpt.GetAngleControl(), style->orientation);
+ ParseStringExpression(areaRpt.GetClippingControl(), style->clipping);
+ ParseStringExpression(areaRpt.GetOriginControl(), style->origincontrol);
bool SE_StyleVisitor::ParseDouble(const wchar_t*& str, double& val)
@@ -219,7 +225,7 @@
if (!ParseArc(arcdef, arcdata))
return false;
- lb->EllipticalArcTo(arcdata.cx, arcdata.cy, arcdef.rx, arcdef.ry, arcdata.startAng, arcdata.endAng, arcdata.rotation);
+ lb->EllipticalArcTo(arcdata.cx, arcdata.cy, arcdef.rx, arcdef.ry, arcdata.startAng, arcdata.endAng, arcdef.rotation);
break;
case L'z': // Line segment to start point of figure
case L'Z':
Modified: trunk/MgDev/Common/Stylization/StylizationEngine.cpp
--- trunk/MgDev/Common/Stylization/StylizationEngine.cpp 2007-03-07 04:47:30 UTC (rev 1162)
+++ trunk/MgDev/Common/Stylization/StylizationEngine.cpp 2007-03-07 05:23:02 UTC (rev 1163)
@@ -224,7 +224,8 @@
break;
- if (style->orientation == PointUsage::FromGeometry)
+ const wchar_t* orientation = style->orientation.evaluate(m_exec);
+ if (wcscmp(L"FromGeometry", orientation) == 0)
if (type == LineBuffer::ctLine || type == LineBuffer::ctArea)
@@ -262,10 +263,9 @@
render->repeat = style->repeat.evaluate(m_exec)*xform.x0;
render->startOffset = style->startOffset.evaluate(m_exec)*xform.x0;
- render->units = style->units;
- render->orientation = style->orientation;
- render->overlap = style->overlap;
- render->join = style->join;
+ render->units = style->units.evaluate(m_exec);
+ render->orientation = style->orientation.evaluate(m_exec);
+ render->overlap = style->overlap.evaluate(m_exec);
return render;
@@ -274,9 +274,9 @@
SE_RenderAreaStyle* render = new SE_RenderAreaStyle();
- render->clipping = style->clipping;
- render->origincontrol = style->origincontrol;
+ render->clipping = style->clipping.evaluate(m_exec);
+ render->origincontrol = style->origincontrol.evaluate(m_exec);
return render;
@@ -452,17 +452,16 @@
if (renderStyle->bounds)
SE_Bounds* bounds = renderStyle->bounds;
- renderStyle->bounds = renderStyle->bounds->Union(rsym->bounds);
- if (style->useBox && sym->resize == GraphicElement::AddToResizeBox)
- bounds->Contained(minx, miny, maxx, maxy, growx, growy);
+ renderStyle->bounds = bounds->Union(rsym->bounds);
bounds->Free();
else
renderStyle->bounds = rsym->bounds->Clone();
rsym->resize = sym->resize == GraphicElement::AdjustToResizeBox;
renderStyle->symbol.push_back(rsym);
+ if (style->useBox && sym->resize == GraphicElement::AddToResizeBox)
+ rsym->bounds->Contained(minx, miny, maxx, maxy, growx, growy);
More information about the mapguide-commits
