[mapguide-commits] r1166 - trunk/MgDev/Common/MdfModel
svn_mapguide at osgeo.org
Wed Mar 7 11:26:50 EST 2007
Author: traianstanev
Date: 2007-03-07 11:26:50 -0500 (Wed, 07 Mar 2007)
New Revision: 1166
trunk/MgDev/Common/MdfModel/ConvertUTF.h
int is 32 bits. long is not. This is a 64 bit compatibility issue.
Modified: trunk/MgDev/Common/MdfModel/ConvertUTF.h
--- trunk/MgDev/Common/MdfModel/ConvertUTF.h 2007-03-07 14:06:01 UTC (rev 1165)
+++ trunk/MgDev/Common/MdfModel/ConvertUTF.h 2007-03-07 16:26:50 UTC (rev 1166)
@@ -90,7 +90,7 @@
#ifndef CONVERT_UTF_H_
#define CONVERT_UTF_H_
-typedef unsigned long UTF32; /* at least 32 bits */
+typedef unsigned int UTF32; /* at least 32 bits */
typedef unsigned short UTF16; /* at least 16 bits */
typedef unsigned char UTF8; /* typically 8 bits */
typedef unsigned char Boolean; /* 0 or 1 */
More information about the mapguide-commits
