[mapguide-commits] r1169 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Mar 7 13:17:29 EST 2007
Author: traianstanev
Date: 2007-03-07 13:17:29 -0500 (Wed, 07 Mar 2007)
New Revision: 1169
   trunk/MgDev/Common/Stylization/GDRenderer.cpp
   trunk/MgDev/Common/Stylization/GDRenderer.h
   trunk/MgDev/Common/Stylization/LabelRenderer.cpp
   trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp
   trunk/MgDev/Common/Stylization/SE_Renderer.cpp
   trunk/MgDev/Common/Stylization/SE_Renderer.h
   trunk/MgDev/Common/Stylization/StylizationEngine.cpp
   trunk/MgDev/Common/Stylization/StylizationEngine.h
   trunk/MgDev/Common/Stylization/complex_polygon_gd.cpp
This submission adds exclusion region maintenance code for new point symbols and line styles.
Also improved positioning of default point labels -- the 8 possible positions now take into
account the size of the symbol that they are attached to. This makes new SymbolDefinitions
basically support the current point labeling behavior.
Also fixed a bug in the new polygon rasterizer. In certain cases it was drawing one more pixel
than necessary on the first scanline of the polygon. It was very obvious in rotated polygons,
not sure why nobody complained.
Modified: trunk/MgDev/Common/Stylization/GDRenderer.cpp
--- trunk/MgDev/Common/Stylization/GDRenderer.cpp	2007-03-07 18:17:11 UTC (rev 1168)
+++ trunk/MgDev/Common/Stylization/GDRenderer.cpp	2007-03-07 18:17:29 UTC (rev 1169)
@@ -1064,7 +1064,12 @@
     m_labeler->ProcessLabelGroup(labels, nlabels, text, type, exclude, path);
+void GDRenderer::AddExclusionRegion(RS_F_Point* fpts, int npts)
+    m_labeler->AddExclusionRegion(fpts, npts);
 void GDRenderer::SetSymbolManager(RS_SymbolManager* manager)
     m_symbolManager = manager;
Modified: trunk/MgDev/Common/Stylization/GDRenderer.h
--- trunk/MgDev/Common/Stylization/GDRenderer.h	2007-03-07 18:17:11 UTC (rev 1168)
+++ trunk/MgDev/Common/Stylization/GDRenderer.h	2007-03-07 18:17:29 UTC (rev 1169)
@@ -183,6 +183,8 @@
                        RS_F_Point*      res,
                        float*           offsets);
+    virtual void AddExclusionRegion(RS_F_Point* fpts, int npts);
 private:
     double _MeterToMapSize(RS_Units unit, double number);
     double _PixelToMapSize(Renderer* renderer, int pixels);
Modified: trunk/MgDev/Common/Stylization/LabelRenderer.cpp
--- trunk/MgDev/Common/Stylization/LabelRenderer.cpp	2007-03-07 18:17:11 UTC (rev 1168)
+++ trunk/MgDev/Common/Stylization/LabelRenderer.cpp	2007-03-07 18:17:29 UTC (rev 1169)
@@ -300,11 +300,8 @@
                                             group.m_type != RS_OverpostType_All);
             // only in the case of a simple label do we check the overpost type
-            if (group.m_algo == laSimple)
-                if (res && (group.m_type == RS_OverpostType_FirstFit))
-                    break;
+            if (res && (group.m_type == RS_OverpostType_FirstFit))
+                break;
Modified: trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp
--- trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp	2007-03-07 18:17:11 UTC (rev 1168)
+++ trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp	2007-03-07 18:17:29 UTC (rev 1169)
@@ -4,8 +4,11 @@
 #include "SE_PositioningAlgorithms.h"
 #include "SE_Renderer.h"
 #include "SE_Bounds.h"
+#include "RS_FontEngine.h"
+#include <algorithm>
+#include <functional>
+#include "SE_ConvexHull.h"
 SE_RenderPointStyle* DeepClonePointStyle(SE_RenderPointStyle* st)
     SE_RenderPointStyle* ret = new SE_RenderPointStyle(); //LEAK
@@ -18,6 +21,58 @@
     return ret;
+//recomputes the bounds of an SE_RenderPointStyle that contains a text
+//whose alignment we have messed with
+void UpdateStyleBounds(SE_RenderPointStyle* st, double cx, double cy, SE_Renderer* renderer)
+    SE_RenderText* txt = ((SE_RenderText*)st->symbol[0]);
+    RS_TextMetrics tm;
+    SE_Matrix txf;
+    renderer->GetFontEngine()->GetTextMetrics(txt->text, txt->tdef, tm, false);
+    RS_F_Point fpts[4];
+    //radian CCW rotation
+    double rotation = txt->tdef.rotation() * M_PI / 180.0;
+    double cos_a = cos(rotation);
+    double sin_a = sin(rotation);
+    RS_Bounds rotatedBounds(+DBL_MAX, +DBL_MAX, -DBL_MAX, -DBL_MAX);
+    RS_Bounds unrotatedBounds(+DBL_MAX, +DBL_MAX, -DBL_MAX, -DBL_MAX);
+    for (size_t k=0; k<tm.line_pos.size(); ++k)
+        //convert the unrotated measured bounds for the current line to a local point array
+        memcpy(fpts, tm.line_pos[k].ext, sizeof(fpts));
+        // process the extent points
+        for (int j=0; j<4; ++j)
+            // update the overall unrotated bounds
+            unrotatedBounds.add_point(fpts[j]);
+            // rotate and translate to the insertion point
+            double tmpX = fpts[j].x;
+            double tmpY = fpts[j].y;
+            fpts[j].x = tmpX * cos_a + tmpY * sin_a;
+            fpts[j].y = tmpX * sin_a + tmpY * cos_a;
+            // update the overall rotated bounds
+            rotatedBounds.add_point(fpts[j]);
+    txt->bounds->min[0] = rotatedBounds.minx;
+    txt->bounds->min[1] = rotatedBounds.miny;
+    txt->bounds->max[0] = rotatedBounds.maxx;
+    txt->bounds->max[1] = rotatedBounds.maxy;
+    st->bounds->min[0] = rotatedBounds.minx;
+    st->bounds->min[1] = rotatedBounds.miny;
+    st->bounds->max[0] = rotatedBounds.maxx;
+    st->bounds->max[1] = rotatedBounds.maxy;
 void SE_PositioningAlgorithms::EightBall(SE_Renderer*    renderer,
                           SE_LineBuffer*  geometry,
                           SE_Matrix&      xform,
@@ -60,17 +115,40 @@
-    //also need to get the bounds of the last drawn point symbol, so that we know how much to offset the label
-    //TODO:
-    RS_Bounds symbol_bounds(1,1,0,0); //init to invalid
-    double symbol_width = 0.001 * 32.0 / renderer->GetPixelsPerMillimeterScreen(); //symbol width in meters
-    double symbol_height = 0.001 * 32.0 / renderer->GetPixelsPerMillimeterScreen(); //symbol height in meters
-    double symbol_rot_deg = 0.0;
+    //get the bounds of the last drawn point symbol, so that we know how much to offset the label
+    //This call assumes the symbol draw right before the label and the symbol added its bounds
+    //as an exclusion region
+    const RS_F_Point* cfpts = renderer->GetLastExclusionRegion();
+    memcpy(fpts, cfpts, 4 * sizeof(RS_F_Point));
+    double dx = fpts[1].x - fpts[0].x;
+    double dy = fpts[1].y - fpts[0].y;
+    double box_angle_rad = atan2(dy, dx);
+    SE_Matrix ixform;
+    ixform.setIdentity();
+    ixform.translate(-cx, -cy); //factor out point position
+    ixform.rotate(-box_angle_rad); //factor out rotation
+    //double pixelToMeter = 0.001 / renderer->GetPixelsPerMillimeterScreen();
+    //ixform.scale(pixelToMeter,  pixelToMeter); //convert from pixels to meters for labeling
+    //factor out geometry position
+    for (int i=0; i<4; i++)
+        ixform.transform(fpts[i].x, fpts[i].y);
+    //unrotated bounds
+    RS_Bounds symbol_bounds(fpts[0].x, fpts[0].y, fpts[2].x, fpts[2].y);
+    double symbol_width = fpts[1].x - fpts[0].x; //symbol width in meters
+    double symbol_height = fpts[2].y - fpts[1].y; //symbol height in meters
+    double symbol_rot_deg = box_angle_rad * (180.0 / M_PI);
     double op_pts[16];
     // calculate a 2 pixel offset to allow for label ghosting
-    double offset = 0.001 * 2.0 / renderer->GetPixelsPerMillimeterScreen(); //2 pixels (in meters)
+    double offset = 2.0 ;
     //compute how far label needs to be offset from
     //center point of symbol
@@ -160,35 +238,43 @@
     SE_RenderPointStyle* st0 = DeepClonePointStyle(rstyle2);
     ((SE_RenderText*)st0->symbol[0])->tdef.halign() = RS_HAlignment_Left;
     ((SE_RenderText*)st0->symbol[0])->tdef.valign() = RS_VAlignment_Half;
-    candidates[0] = SE_LabelInfo(cx, cy, op_pts[0], op_pts[1], RS_Units_Device, 0.0, st0);
+    UpdateStyleBounds(st0, cx + op_pts[0], cy + op_pts[1], renderer);
+    candidates[0] = SE_LabelInfo(cx + op_pts[0], cy + op_pts[1], 0, 0, RS_Units_Device, 0.0, st0);
     SE_RenderPointStyle* st1 = DeepClonePointStyle(st0);
     ((SE_RenderText*)st1->symbol[0])->tdef.valign() = RS_VAlignment_Descent;
-    candidates[1] = SE_LabelInfo(cx, cy, op_pts[2], op_pts[3], RS_Units_Device, 0.0, st1);
+    UpdateStyleBounds(st1, cx + op_pts[2], cy + op_pts[3], renderer);
+    candidates[1] = SE_LabelInfo(cx + op_pts[2], cy + op_pts[3], 0, 0, RS_Units_Device, 0.0, st1);
     SE_RenderPointStyle* st2 = DeepClonePointStyle(st1);
     ((SE_RenderText*)st2->symbol[0])->tdef.halign() = RS_HAlignment_Center;
-    candidates[2] = SE_LabelInfo(cx, cy, op_pts[4], op_pts[5], RS_Units_Device, 0.0, st2);
+    UpdateStyleBounds(st2, cx + op_pts[4], cy + op_pts[5], renderer);
+    candidates[2] = SE_LabelInfo(cx + op_pts[4], cy + op_pts[5], 0, 0, RS_Units_Device, 0.0, st2);
     SE_RenderPointStyle* st3 = DeepClonePointStyle(st2);
     ((SE_RenderText*)st3->symbol[0])->tdef.halign() = RS_HAlignment_Right;
-    candidates[3] = SE_LabelInfo(cx, cy, op_pts[6], op_pts[7], RS_Units_Device, 0.0, st3);
+    UpdateStyleBounds(st3, cx + op_pts[6], cy + op_pts[7], renderer);
+    candidates[3] = SE_LabelInfo(cx + op_pts[6], cy + op_pts[7], 0, 0, RS_Units_Device, 0.0, st3);
     SE_RenderPointStyle* st4 = DeepClonePointStyle(st3);
     ((SE_RenderText*)st4->symbol[0])->tdef.valign() = RS_VAlignment_Half;
-    candidates[4] = SE_LabelInfo(cx, cy, op_pts[8], op_pts[9], RS_Units_Device, 0.0, st4);
+    UpdateStyleBounds(st4, cx + op_pts[8], cy + op_pts[9], renderer);
+    candidates[4] = SE_LabelInfo(cx + op_pts[8], cy + op_pts[9], 0, 0, RS_Units_Device, 0.0, st4);
     SE_RenderPointStyle* st5 = DeepClonePointStyle(st4);
     ((SE_RenderText*)st5->symbol[0])->tdef.valign() = RS_VAlignment_Ascent;
-    candidates[5] = SE_LabelInfo(cx, cy, op_pts[10], op_pts[11], RS_Units_Device, 0.0, st5);
+    UpdateStyleBounds(st5, cx + op_pts[10], cy + op_pts[11], renderer);
+    candidates[5] = SE_LabelInfo(cx + op_pts[10], cy + op_pts[11], 0, 0, RS_Units_Device, 0.0, st5);
     SE_RenderPointStyle* st6 = DeepClonePointStyle(st5);
     ((SE_RenderText*)st6->symbol[0])->tdef.halign() = RS_HAlignment_Center;
-    candidates[6] = SE_LabelInfo(cx, cy, op_pts[12], op_pts[13], RS_Units_Device, 0.0, st6);
+    UpdateStyleBounds(st6, cx + op_pts[12], cy + op_pts[13], renderer);
+    candidates[6] = SE_LabelInfo(cx + op_pts[12], cy + op_pts[13], 0, 0, RS_Units_Device, 0.0, st6);
     SE_RenderPointStyle* st7 = DeepClonePointStyle(st6);
     ((SE_RenderText*)st7->symbol[0])->tdef.halign() = RS_HAlignment_Left;
-    candidates[7] = SE_LabelInfo(cx, cy, op_pts[14], op_pts[15], RS_Units_Device, 0.0, st7);
+    UpdateStyleBounds(st7, cx + op_pts[14], cy + op_pts[15], renderer);
+    candidates[7] = SE_LabelInfo(cx + op_pts[14], cy + op_pts[15], 0, 0, RS_Units_Device, 0.0, st7);
     renderer->ProcessLabelGroup(candidates, 8, RS_OverpostType_FirstFit, true, NULL);
Modified: trunk/MgDev/Common/Stylization/SE_Renderer.cpp
--- trunk/MgDev/Common/Stylization/SE_Renderer.cpp	2007-03-07 18:17:11 UTC (rev 1168)
+++ trunk/MgDev/Common/Stylization/SE_Renderer.cpp	2007-03-07 18:17:29 UTC (rev 1169)
@@ -19,6 +19,7 @@
 #include "SE_LineBuffer.h"
+#include "SE_Bounds.h"
 using namespace MDFMODEL_NAMESPACE;
@@ -43,10 +44,17 @@
         xform.translate(geometry->xf_points()[2*i], geometry->xf_points()[2*i+1]);
         double pt[2] = {geometry->xf_points()[2*i], geometry->xf_points()[2*i+1]};
         geom.points = pt;
+        double angle = 0;//TODO: angle needs to be added to the RenderPointStyle
         if (style->drawLast)
-            AddLabel(&geom, style, xform, 0);
+            AddLabel(&geom, style, xform, angle);
         else
-            DrawSymbol(style->symbol, xform, 0);
+            DrawSymbol(style->symbol, xform, angle);
+            if (style->addToExclusionRegions)
+                AddExclusionRegion(style, xform, angle);
@@ -123,10 +131,15 @@
                 while (drawpos < len)
-                        AddLabel(&geom, style, symxf, symrot);
+                        AddLabel(&geom, style, xform, symrot);
                     else
-                        DrawSymbol(style->symbol, symxf, symrot);
+                        DrawSymbol(style->symbol, xform, symrot);
+                            AddExclusionRegion(style, xform, symrot);
                     xform.translate(dx_incr, dy_incr);
                     symxf.translate(dx_incr, dy_incr);
                     drawpos += increment;
@@ -202,5 +215,29 @@
     RS_OverpostType type = RS_OverpostType_AllFit;
-    ProcessLabelGroup(&info, 1, type, true /*style->addToExclusionRegions*/, geom);
+    ProcessLabelGroup(&info, 1, type, style->addToExclusionRegions, geom);
+void SE_Renderer::AddExclusionRegion(SE_RenderStyle* rstyle, SE_Matrix& xform, double angle)
+    SE_Matrix xform2;
+    xform2.setIdentity();
+    xform2.rotate(angle);
+    xform2.translate(xform.x2, xform.y2);
+    RS_F_Point* fpts = m_lastExclusionRegion;
+    fpts[0].x = rstyle->bounds->min[0];
+    fpts[0].y = rstyle->bounds->min[1];
+    fpts[1].x = rstyle->bounds->max[0];
+    fpts[1].y = rstyle->bounds->min[1];
+    fpts[2].x = rstyle->bounds->max[0];
+    fpts[2].y = rstyle->bounds->max[1];
+    fpts[3].x = rstyle->bounds->min[0];
+    fpts[3].y = rstyle->bounds->max[1];
+        xform2.transform(fpts[i].x, fpts[i].y);
+    AddExclusionRegion(fpts, 4);
Modified: trunk/MgDev/Common/Stylization/SE_Renderer.h
--- trunk/MgDev/Common/Stylization/SE_Renderer.h	2007-03-07 18:17:11 UTC (rev 1168)
+++ trunk/MgDev/Common/Stylization/SE_Renderer.h	2007-03-07 18:17:29 UTC (rev 1169)
@@ -56,11 +56,21 @@
                                    bool             exclude,
                                    SE_Geometry*     path = NULL) = 0;
+    virtual void AddExclusionRegion(RS_F_Point* fpts, int npts) = 0;
+    //sigh
+    const RS_F_Point* GetLastExclusionRegion() { return m_lastExclusionRegion; }
 private:
     void AddLabel(SE_Geometry* geom, SE_RenderStyle* style, SE_Matrix& xform, double angle);
+    void AddExclusionRegion(SE_RenderStyle* rstyle, SE_Matrix& xform, double angle);
+    RS_F_Point m_lastExclusionRegion[4];
 protected:
     SE_LineBufferPool* m_lbp;
 #endif // SE_RENDERER_H
Modified: trunk/MgDev/Common/Stylization/StylizationEngine.cpp
--- trunk/MgDev/Common/Stylization/StylizationEngine.cpp	2007-03-07 18:17:11 UTC (rev 1168)
+++ trunk/MgDev/Common/Stylization/StylizationEngine.cpp	2007-03-07 18:17:29 UTC (rev 1169)
@@ -170,7 +170,7 @@
             if (!sym->positioningAlgorithm.empty() && sym->positioningAlgorithm != L"Default")
-                LayoutCustomLabel(xformGeom, tmpxform, style, rstyle, mm2px);
+                LayoutCustomLabel(sym->positioningAlgorithm, xformGeom, tmpxform, style, rstyle, mm2px);
             else
@@ -529,14 +529,13 @@
-void StylizationEngine::LayoutCustomLabel(SE_LineBuffer* geometry, SE_Matrix& xform, SE_Style* style, SE_RenderStyle* rstyle, double mm2px)
+void StylizationEngine::LayoutCustomLabel(const std::wstring& positioningAlgo, SE_LineBuffer* geometry, SE_Matrix& xform, SE_Style* style, SE_RenderStyle* rstyle, double mm2px)
     //here we decide which one to call based on the name of the positioning algorithm
-    //if (style->positioningAlgorithm == 8Candidates)
+    if (positioningAlgo == L"EightSurrounding")
         SE_PositioningAlgorithms::EightBall(m_renderer, geometry, xform, style, rstyle, mm2px);
     //else if (style->positioningAlgorithm == MultipleHighwayShields)
Modified: trunk/MgDev/Common/Stylization/StylizationEngine.h
--- trunk/MgDev/Common/Stylization/StylizationEngine.h	2007-03-07 18:17:11 UTC (rev 1168)
+++ trunk/MgDev/Common/Stylization/StylizationEngine.h	2007-03-07 18:17:29 UTC (rev 1169)
@@ -59,7 +59,7 @@
     SE_RenderAreaStyle* EvaluateAreaStyle(SE_Matrix& xform, SE_AreaStyle* style);
     SE_RenderLineStyle* EvaluateLineStyle(SE_Matrix& xform, SE_LineStyle* style);
-    void LayoutCustomLabel(SE_LineBuffer* geometry, SE_Matrix& xform, SE_Style* style, SE_RenderStyle* rstyle, double mm2px);
+    void LayoutCustomLabel(const std::wstring& positioningAlgo, SE_LineBuffer* geometry, SE_Matrix& xform, SE_Style* style, SE_RenderStyle* rstyle, double mm2px);
     void EvaluateSymbols(SE_Matrix& xform, SE_Style* style, SE_RenderStyle* renderStyle, double mm2px);
     SE_Renderer* m_renderer;
     RS_FilterExecutor* m_exec;
Modified: trunk/MgDev/Common/Stylization/complex_polygon_gd.cpp
--- trunk/MgDev/Common/Stylization/complex_polygon_gd.cpp	2007-03-07 18:17:11 UTC (rev 1168)
+++ trunk/MgDev/Common/Stylization/complex_polygon_gd.cpp	2007-03-07 18:17:29 UTC (rev 1169)
@@ -349,7 +349,8 @@
     while (CurrentEdge != NULL) {
         LeftX = CurrentEdge->X;
         CurrentEdge = CurrentEdge->NextEdge;
-        DrawHorizontalLineSeg(YToScan, LeftX, CurrentEdge->X-1, Color, target);
+        if (LeftX < CurrentEdge->X)
+            DrawHorizontalLineSeg(YToScan, LeftX, CurrentEdge->X-1, Color, target);
More information about the mapguide-commits mailing list
