[mapguide-commits] r1175 - trunk/MgDev/Server/src/UnitTesting
svn_mapguide at osgeo.org
Wed Mar 7 21:08:55 EST 2007
Author: waltweltonlair
Date: 2007-03-07 21:08:55 -0500 (Wed, 07 Mar 2007)
New Revision: 1175
trunk/MgDev/Server/src/UnitTesting/TestRenderingService.cpp
trunk/MgDev/Server/src/UnitTesting/TestRenderingService.h
The rendering service unit test needed some work. At some point someone changed
the test map from World to Sheboygan, but they didn't bother updating things like
the map center and scale. Consequently all tests were using a meaningless view.
I fixed the input parameters so the tests now give useful results. I also updated
the RenderMap, RenderDynamicOverlay, and QueryFeatures tests to call the APIs at
two scales. Furthermore, all rendered images are now written to disk so they can
easily be inspected.
Modified: trunk/MgDev/Server/src/UnitTesting/TestRenderingService.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestRenderingService.cpp 2007-03-07 22:52:26 UTC (rev 1174)
+++ trunk/MgDev/Server/src/UnitTesting/TestRenderingService.cpp 2007-03-08 02:08:55 UTC (rev 1175)
@@ -143,7 +143,6 @@
Ptr<MgByteReader> datardr = datasrc->GetReader();
m_svcResource->SetResourceData(slres1, L"symbols.dwf", L"File", datardr);
// publish symbology stuff
@@ -378,21 +377,16 @@
Ptr<MgSiteConnection> conn = new MgSiteConnection();
// make a runtime map
- Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan.MapDefinition");
- Ptr<MgMap> map = new MgMap();
- map->Create(m_svcResource, mdfres, L"UnitTestSheboygan");
+ Ptr<MgMap> map = CreateTestMap();
- map->SetViewScale(73745078.0);
+ // call the API using scales of 75000 and 12000
+ map->SetViewScale(75000.0);
+ Ptr<MgByteReader> rdr1 = m_svcRendering->RenderDynamicOverlay(map, NULL, L"PNG");
+ rdr1->ToFile(L"../UnitTestFiles/RenderDynamicOverlay75k.png");
- Ptr<MgCoordinate> coordNewCenter = new MgCoordinateXY(0.0, 0.0);
- Ptr<MgPoint> ptNewCenter = new MgPoint(coordNewCenter);
- map->SetViewCenter(ptNewCenter);
- map->SetDisplayDpi(96);
- map->SetDisplayWidth(1024);
- map->SetDisplayHeight(1024);
- // call the API
- Ptr<MgByteReader> rdr = m_svcRendering->RenderDynamicOverlay(map, NULL, L"PNG");
+ map->SetViewScale(12000.0);
+ Ptr<MgByteReader> rdr2 = m_svcRendering->RenderDynamicOverlay(map, NULL, L"PNG");
+ rdr2->ToFile(L"../UnitTestFiles/RenderDynamicOverlay12k.png");
catch (MgException* e)
@@ -415,31 +409,50 @@
- INT32 pixels = 512;
+ Ptr<MgByteReader> rdr1 = m_svcRendering->RenderMap(map, NULL, L"PNG");
+ rdr1->ToFile(L"../UnitTestFiles/RenderMap75k.png");
- map->SetDisplayWidth(pixels*2);
- map->SetDisplayHeight(pixels);
+ Ptr<MgByteReader> rdr2 = m_svcRendering->RenderMap(map, NULL, L"PNG");
+ rdr2->ToFile(L"../UnitTestFiles/RenderMap12k.png");
+ catch (MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+ catch (...)
+ throw;
- double mapHeight = 180.0;
- double scale = mapHeight * 111000.0 * 100.0 / 2.54 * 96.0 / (double)pixels;
- map->SetViewScale(scale);
+void TestRenderingService::TestCase_RenderLegend()
+ try
+ // get root
+ Ptr<MgSiteConnection> conn = new MgSiteConnection();
- // call the API
- Ptr<MgByteReader> rdr = m_svcRendering->RenderMap(map, NULL, L"PNG");
+ // make a runtime map
- Ptr<MgColor> bgc = new MgColor(255,255,255,255);
+ Ptr<MgColor> bgc = new MgColor(255, 255, 255, 255);
- //also test the map legend API
+ Ptr<MgByteReader> rdr1 = m_svcRendering->RenderMapLegend(map, 200, 400, bgc, L"PNG");
+ rdr1->ToFile(L"../UnitTestFiles/RenderLegend75k.png");
Ptr<MgByteReader> rdr2 = m_svcRendering->RenderMapLegend(map, 200, 400, bgc, L"PNG");
+ rdr2->ToFile(L"../UnitTestFiles/RenderLegend12k.png");
@@ -462,45 +475,25 @@
+ // call the API using a scale of 75000
+ Ptr<MgStringCollection> layerNames1 = new MgStringCollection();
+ layerNames1->Add(L"Rail");
+ layerNames1->Add(L"HydrographicPolygons");
+ Ptr<MgPolygon> poly1 = CreateSelectionPolygon(map, 0.3, 0.3);
+ Ptr<MgFeatureInformation> fi1 = m_svcRendering->QueryFeatures(map, layerNames1, poly1, MgFeatureSpatialOperations::Within, -1);
- // selection bounds in mapping space
- Ptr<MgCoordinate> ll = new MgCoordinateXY( 0.0, 0.0);
- Ptr<MgCoordinate> ur = new MgCoordinateXY(40.0, 60.0);
+ // call the API using a scale of 12000
- Ptr<MgCoordinateXY> c1 = new MgCoordinateXY(ll->GetX(), ll->GetY());
- Ptr<MgCoordinateXY> c2 = new MgCoordinateXY(ur->GetX(), ll->GetY());
- Ptr<MgCoordinateXY> c3 = new MgCoordinateXY(ur->GetX(), ur->GetY());
- Ptr<MgCoordinateXY> c4 = new MgCoordinateXY(ll->GetX(), ur->GetY());
- Ptr<MgCoordinateXY> c5 = new MgCoordinateXY(ll->GetX(), ll->GetY());
- Ptr<MgCoordinateCollection> cc = new MgCoordinateCollection();
- cc->Add(c1);
- cc->Add(c2);
- cc->Add(c3);
- cc->Add(c4);
- cc->Add(c5);
- Ptr<MgLinearRing> outer = new MgLinearRing(cc);
- Ptr<MgPolygon> poly = new MgPolygon(outer, NULL);
- Ptr<MgStringCollection> layerNames = new MgStringCollection();
- layerNames->Add(L"World Countries");
- layerNames->Add(L"World Cities");
- // call the API
- Ptr<MgFeatureInformation> fi = m_svcRendering->QueryFeatures(map, layerNames, poly, MgFeatureSpatialOperations::Within, -1);
+ Ptr<MgStringCollection> layerNames2 = new MgStringCollection();
+ layerNames2->Add(L"Rail");
+ layerNames2->Add(L"Parcels");
+ Ptr<MgPolygon> poly2 = CreateSelectionPolygon(map, 0.05, 0.05);
+ Ptr<MgFeatureInformation> fi2 = m_svcRendering->QueryFeatures(map, layerNames2, poly2, MgFeatureSpatialOperations::Within, -1);
@@ -515,6 +508,51 @@
+MgMap* TestRenderingService::CreateTestMap()
+ Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan.MapDefinition");
+ MgMap* map = new MgMap();
+ map->Create(m_svcResource, mdfres, L"UnitTestSheboygan");
+ Ptr<MgCoordinate> coordNewCenter = new MgCoordinateXY(-87.733253, 43.746199);
+ Ptr<MgPoint> ptNewCenter = new MgPoint(coordNewCenter);
+ map->SetViewCenter(ptNewCenter);
+ map->SetDisplayDpi(96);
+ map->SetDisplayWidth(1024);
+ map->SetDisplayHeight(1024);
+ return map;
+// creates a selection bounds in mapping space
+MgPolygon* TestRenderingService::CreateSelectionPolygon(MgMap* map, double width, double height)
+ Ptr<MgPoint> centerPt = map->GetViewCenter();
+ Ptr<MgCoordinate> center = centerPt->GetCoordinate();
+ double xMin = center->GetX() - 0.5*width;
+ double yMin = center->GetY() - 0.5*height;
+ double xMax = center->GetX() + 0.5*width;
+ double yMax = center->GetY() + 0.5*height;
+ Ptr<MgCoordinateXY> c1 = new MgCoordinateXY(xMin, yMin);
+ Ptr<MgCoordinateXY> c2 = new MgCoordinateXY(xMax, yMin);
+ Ptr<MgCoordinateXY> c3 = new MgCoordinateXY(xMax, yMax);
+ Ptr<MgCoordinateXY> c4 = new MgCoordinateXY(xMin, yMax);
+ Ptr<MgCoordinateXY> c5 = new MgCoordinateXY(xMin, yMin);
+ Ptr<MgCoordinateCollection> cc = new MgCoordinateCollection();
+ cc->Add(c1);
+ cc->Add(c2);
+ cc->Add(c3);
+ cc->Add(c4);
+ cc->Add(c5);
+ Ptr<MgLinearRing> outer = new MgLinearRing(cc);
+ return new MgPolygon(outer, NULL);
void TestRenderingService::TestCase_SymbologyMdfModel()
try
@@ -686,7 +724,7 @@
+ map->SetDisplayWidth(2*pixels);
// the map is a little silly -- it's in degrees but thinks it's in meters --
@@ -697,7 +735,6 @@
// call the API
rdr->ToFile(L"../UnitTestFiles/SymbologyPoints.png");
@@ -727,7 +764,7 @@
@@ -738,7 +775,6 @@
// call the API
rdr->ToFile(L"../UnitTestFiles/SymbologyPointsParam.png");
@@ -773,13 +809,12 @@
// hence the 111000 is commented out
- double mapHeight = 8;
- double scale = mapHeight /*111000.0 **/ * 100.0 / 2.54 * 96.0 / (double)pixels;
+ double mapHeight = 8.0;
+ double scale = mapHeight * /*111000.0 **/ 100.0 / 2.54 * 96.0 / (double)pixels;
// call the API
rdr->ToFile(L"../UnitTestFiles/SymbologyLines.png");
@@ -812,14 +847,13 @@
double scale = mapHeight /** 111000.0*/ * 100.0 / 2.54 * 96.0 / (double)pixels;
// call the API
rdr->ToFile(L"../UnitTestFiles/SymbologyLinesCrossTick.png");
Modified: trunk/MgDev/Server/src/UnitTesting/TestRenderingService.h
--- trunk/MgDev/Server/src/UnitTesting/TestRenderingService.h 2007-03-07 22:52:26 UTC (rev 1174)
+++ trunk/MgDev/Server/src/UnitTesting/TestRenderingService.h 2007-03-08 02:08:55 UTC (rev 1175)
@@ -33,6 +33,7 @@
CPPUNIT_TEST(TestCase_RenderDynamicOverlay);
CPPUNIT_TEST(TestCase_RenderMap);
+ CPPUNIT_TEST(TestCase_RenderLegend);
CPPUNIT_TEST(TestCase_QueryFeatures);
CPPUNIT_TEST(TestEnd); // This must be the very last unit test
@@ -49,6 +50,7 @@
void TestCase_RenderDynamicOverlay();
void TestCase_RenderMap();
+ void TestCase_RenderLegend();
void TestCase_QueryFeatures();
void TestCase_SymbologyMdfModel();
@@ -58,6 +60,10 @@
void TestCase_SymbologyLinesCrossTick();
private:
+ MgMap* CreateTestMap();
+ MgPolygon* CreateSelectionPolygon(MgMap* map, double width, double height);
+private:
Ptr<MgResourceService> m_svcResource;
Ptr<MgRenderingService> m_svcRendering;
More information about the mapguide-commits
