[mapguide-commits] r1193 - in trunk/MgDev/Common: MdfModel MdfParser
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Mar 9 18:36:57 EST 2007
Author: ronnielouie
Date: 2007-03-09 18:36:56 -0500 (Fri, 09 Mar 2007)
New Revision: 1193
Added:
   trunk/MgDev/Common/MdfModel/Version.cpp
   trunk/MgDev/Common/MdfModel/Version.h
   trunk/MgDev/Common/MdfModel/Makefile.am
   trunk/MgDev/Common/MdfModel/MdfModel.vcproj
   trunk/MgDev/Common/MdfParser/IODrawingLayerDefinition.cpp
   trunk/MgDev/Common/MdfParser/IODrawingLayerDefinition.h
   trunk/MgDev/Common/MdfParser/IOGridLayerDefinition.cpp
   trunk/MgDev/Common/MdfParser/IOGridLayerDefinition.h
   trunk/MgDev/Common/MdfParser/IOVectorLayerDefinition.cpp
   trunk/MgDev/Common/MdfParser/IOVectorLayerDefinition.h
   trunk/MgDev/Common/MdfParser/SAX2Parser.cpp
   trunk/MgDev/Common/MdfParser/SAX2Parser.h
Add support for specifying a previous version when writing the layer definition.
Modified: trunk/MgDev/Common/MdfModel/Makefile.am
--- trunk/MgDev/Common/MdfModel/Makefile.am	2007-03-09 22:07:42 UTC (rev 1192)
+++ trunk/MgDev/Common/MdfModel/Makefile.am	2007-03-09 23:36:56 UTC (rev 1193)
@@ -79,6 +79,7 @@
   Vector.cpp \
   VectorLayerDefinition.cpp \
   VectorScaleRange.cpp \
+  Version.cpp \
   W2DSymbol.cpp
 noinst_HEADERS = \
@@ -164,6 +165,7 @@
   Vector.h \
   VectorLayerDefinition.h \
   VectorScaleRange.h \
+  Version.h \
   W2DSymbol.h \
   stdafx.h
Modified: trunk/MgDev/Common/MdfModel/MdfModel.vcproj
--- trunk/MgDev/Common/MdfModel/MdfModel.vcproj	2007-03-09 22:07:42 UTC (rev 1192)
+++ trunk/MgDev/Common/MdfModel/MdfModel.vcproj	2007-03-09 23:36:56 UTC (rev 1193)
@@ -874,6 +874,14 @@
 			RelativePath=".\UnicodeString.h"
 		</File>
+		<File
+			RelativePath=".\Version.cpp"
+		</File>
+		<File
+			RelativePath=".\Version.h"
+		</File>
 	</Files>
 	<Globals>
 	</Globals>
Added: trunk/MgDev/Common/MdfModel/Version.cpp
--- trunk/MgDev/Common/MdfModel/Version.cpp	                        (rev 0)
+++ trunk/MgDev/Common/MdfModel/Version.cpp	2007-03-09 23:36:56 UTC (rev 1193)
@@ -0,0 +1,148 @@
+//  Copyright (C) 2004-2007 by Autodesk, Inc.
+//  This library is free software; you can redistribute it and/or
+//  modify it under the terms of version 2.1 of the GNU Lesser
+//  General Public License as published by the Free Software Foundation.
+//  This library is distributed in the hope that it will be useful,
+//  but WITHOUT ANY WARRANTY; without even the implied warranty of
+//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+//  Lesser General Public License for more details.
+//  You should have received a copy of the GNU Lesser General Public
+//  License along with this library; if not, write to the Free Software
+//  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
+// DESCRIPTION:
+// Version Class implementation.
+#include "stdafx.h"
+#include "Version.h"
+#include <sstream>
+using namespace MDFMODEL_NAMESPACE;
+// PURPOSE: Initialize an instance of the Version class.
+Version::Version()
+    this->SetMajor(0);
+    this->SetMinor(0);
+    this->SetRevision(0);
+Version::Version(int nMajorNumber, int nMinorNumber, int nRevisionNumber)
+    this->SetMajor(nMajorNumber);
+    this->SetMinor(nMinorNumber);
+    this->SetRevision(nRevisionNumber);
+// PURPOSE: Destructor.
+Version::~Version()
+// PURPOSE: Accessor method for the Major number.
+// RETURNS: the Major number .
+int Version::GetMajor()const
+    return this->m_nMajorNumber;
+// PARAMETERS:
+//      Input:
+//          nMajorNumber - the Major number.
+void Version::SetMajor(const int& nMajorNumber)
+    this->m_nMajorNumber= nMajorNumber;
+// PURPOSE: Accessor method for the Minor number.
+// RETURNS: the Minor number .
+int Version::GetMinor()const
+    return this->m_nMinorNumber;
+// PARAMETERS:
+//      Input:
+//          nMinorNumber - the Minor number.
+void Version::SetMinor(const int& nMinorNumber)
+    this->m_nMinorNumber= nMinorNumber;
+// PURPOSE: Accessor method for the Revision number.
+// RETURNS: the Revision number .
+int Version::GetRevision()const
+    return this->m_nRevisionNumber;
+// PARAMETERS:
+//      Input:
+//          nRevisionNumber - the Revision number.
+void Version::SetRevision(const int& nRevisionNumber)
+    this->m_nRevisionNumber= nRevisionNumber;
+// PURPOSE: Return a string representation of the version.  The format
+//                 is Major.Minor.Revision (ie 1.0.2).
+// RETURNS: the string representation of of the version.
+MdfString Version::ToString()
+    MdfString strVersion;
+    std::wstringstream ss;
+    MdfString strMajor;
+    MdfString strMinor;
+    MdfString strRevision;
+    MdfString strDot = L"."; // NOXLATE
+    ss << this->m_nMajorNumber;
+    ss >> strMajor;
+    ss.clear();
+    ss << this->m_nMinorNumber;
+    ss >> strMinor;
+    ss.clear();
+    ss << this->m_nRevisionNumber;
+    ss >> strRevision;
+    strVersion = strMajor + strDot + strMinor + strDot + strRevision;
+    return strVersion;
Added: trunk/MgDev/Common/MdfModel/Version.h
--- trunk/MgDev/Common/MdfModel/Version.h	                        (rev 0)
+++ trunk/MgDev/Common/MdfModel/Version.h	2007-03-09 23:36:56 UTC (rev 1193)
@@ -0,0 +1,69 @@
+#ifndef VERSION_H_
+#define VERSION_H_
+#include "MdfModel.h"
+#include "MdfRootObject.h"
+BEGIN_NAMESPACE_MDFMODEL
+    // DESCRIPTION:
+    // Represents a version object.
+    // The format of the version is Major.Minor.Revision.
+    // For example version 1.0.2,
+    // the Major number is 1, Minor number is 0, Revision number is 2.
+    class MDFMODEL_API Version : public MdfRootObject
+    public:
+        // Construction, destruction, initialization
+        Version();
+        Version(int nMajorNumber, int nMinorNumber, int nRevisionNumber);
+        virtual ~Version();
+        // Operations
+        // Property : Major
+        int GetMajor()const;
+        void SetMajor( const int& nMajorNumber);
+        // Property : Minor
+        int GetMinor()const;
+        void SetMinor( const int& nMinorNumber);
+        // Property : Revision
+        int GetRevision()const;
+        void SetRevision( const int& nRevisionNumber);
+        MdfString ToString();
+    private:
+        // Data members
+        // The major number in the version
+        int m_nMajorNumber;
+        // The minor number in the version
+        int m_nMinorNumber;
+        // The revision number in the version
+        int m_nRevisionNumber;
+END_NAMESPACE_MDFMODEL
+#endif //VERSION_H_
Modified: trunk/MgDev/Common/MdfParser/IODrawingLayerDefinition.cpp
--- trunk/MgDev/Common/MdfParser/IODrawingLayerDefinition.cpp	2007-03-09 22:07:42 UTC (rev 1192)
+++ trunk/MgDev/Common/MdfParser/IODrawingLayerDefinition.cpp	2007-03-09 23:36:56 UTC (rev 1193)
@@ -96,9 +96,17 @@
-void IODrawingLayerDefinition::Write(MdfStream &fd, DrawingLayerDefinition *drawingLayer)
+void IODrawingLayerDefinition::Write(MdfStream &fd, DrawingLayerDefinition *drawingLayer, Version *version)
-    fd << tab() << "<LayerDefinition xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xmlns:xsd=\"http://www.w3.org/2001/XMLSchema\" xsi:noNamespaceSchemaLocation=\"LayerDefinition-1.1.0.xsd\" version=\"1.1.0\">" << std::endl; // NOXLATE
+    if (version)
+        MdfString strVersion = version->ToString();
+        fd << tab() << "<LayerDefinition xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xmlns:xsd=\"http://www.w3.org/2001/XMLSchema\" xsi:noNamespaceSchemaLocation=\"LayerDefinition-" << EncodeString(strVersion) << ".xsd\" version=\"" << EncodeString(strVersion) << "\">" << std::endl; // NOXLATE
+    else
+        fd << tab() << "<LayerDefinition xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xmlns:xsd=\"http://www.w3.org/2001/XMLSchema\" xsi:noNamespaceSchemaLocation=\"LayerDefinition-1.1.0.xsd\" version=\"1.1.0\">" << std::endl; // NOXLATE
     inctab();
     fd << tab() << "<DrawingLayerDefinition>" << std::endl; // NOXLATE
Modified: trunk/MgDev/Common/MdfParser/IODrawingLayerDefinition.h
--- trunk/MgDev/Common/MdfParser/IODrawingLayerDefinition.h	2007-03-09 22:07:42 UTC (rev 1192)
+++ trunk/MgDev/Common/MdfParser/IODrawingLayerDefinition.h	2007-03-09 23:36:56 UTC (rev 1193)
@@ -20,6 +20,7 @@
 #include "SAX2ElementHandler.h"
 #include "DrawingLayerDefinition.h"
 using namespace XERCES_CPP_NAMESPACE;
@@ -35,7 +36,7 @@
         IODrawingLayerDefinition();
         IODrawingLayerDefinition(DrawingLayerDefinition * layer);
         ~IODrawingLayerDefinition();
-        void Write(MdfStream &fd, DrawingLayerDefinition *drawingLayer);
+        void Write(MdfStream &fd, DrawingLayerDefinition *drawingLayer, Version *version = NULL);
         virtual void StartElement(const wchar_t *name, HandlerStack *handlerStack);
         virtual void ElementChars(const wchar_t *ch);
Modified: trunk/MgDev/Common/MdfParser/IOGridLayerDefinition.cpp
--- trunk/MgDev/Common/MdfParser/IOGridLayerDefinition.cpp	2007-03-09 22:07:42 UTC (rev 1192)
+++ trunk/MgDev/Common/MdfParser/IOGridLayerDefinition.cpp	2007-03-09 23:36:56 UTC (rev 1193)
@@ -100,9 +100,17 @@
-void IOGridLayerDefinition::Write(MdfStream &fd, GridLayerDefinition *gridLayer)
+void IOGridLayerDefinition::Write(MdfStream &fd, GridLayerDefinition *gridLayer, Version *version)
+    if (version)
+    else
     inctab();
     fd << tab() << "<GridLayerDefinition>" << std::endl; // NOXLATE
Modified: trunk/MgDev/Common/MdfParser/IOGridLayerDefinition.h
--- trunk/MgDev/Common/MdfParser/IOGridLayerDefinition.h	2007-03-09 22:07:42 UTC (rev 1192)
+++ trunk/MgDev/Common/MdfParser/IOGridLayerDefinition.h	2007-03-09 23:36:56 UTC (rev 1193)
@@ -20,6 +20,7 @@
 #include "GridLayerDefinition.h"
@@ -35,7 +36,7 @@
         IOGridLayerDefinition();
         IOGridLayerDefinition(GridLayerDefinition * layer);
         ~IOGridLayerDefinition();
-        void Write(MdfStream &fd,  GridLayerDefinition *gridLayer);
+        void Write(MdfStream &fd,  GridLayerDefinition *gridLayer, Version *version = NULL);
Modified: trunk/MgDev/Common/MdfParser/IOVectorLayerDefinition.cpp
--- trunk/MgDev/Common/MdfParser/IOVectorLayerDefinition.cpp	2007-03-09 22:07:42 UTC (rev 1192)
+++ trunk/MgDev/Common/MdfParser/IOVectorLayerDefinition.cpp	2007-03-09 23:36:56 UTC (rev 1193)
@@ -145,9 +145,17 @@
-void IOVectorLayerDefinition::Write(MdfStream &fd, VectorLayerDefinition *featureLayer)
+void IOVectorLayerDefinition::Write(MdfStream &fd, VectorLayerDefinition *featureLayer, Version *version)
+    if (version)
+    else
     inctab();
     fd << tab() << startStr(sVectorLayerDefinition) << std::endl;
Modified: trunk/MgDev/Common/MdfParser/IOVectorLayerDefinition.h
--- trunk/MgDev/Common/MdfParser/IOVectorLayerDefinition.h	2007-03-09 22:07:42 UTC (rev 1192)
+++ trunk/MgDev/Common/MdfParser/IOVectorLayerDefinition.h	2007-03-09 23:36:56 UTC (rev 1193)
@@ -20,6 +20,7 @@
 #include "VectorLayerDefinition.h"
@@ -35,7 +36,7 @@
         IOVectorLayerDefinition();
         IOVectorLayerDefinition(VectorLayerDefinition * layer);
         ~IOVectorLayerDefinition();
-        void Write(MdfStream &fd, VectorLayerDefinition *featureLayer);
+        void Write(MdfStream &fd, VectorLayerDefinition *featureLayer, Version *version = NULL);
Modified: trunk/MgDev/Common/MdfParser/SAX2Parser.cpp
--- trunk/MgDev/Common/MdfParser/SAX2Parser.cpp	2007-03-09 22:07:42 UTC (rev 1192)
+++ trunk/MgDev/Common/MdfParser/SAX2Parser.cpp	2007-03-09 23:36:56 UTC (rev 1193)
@@ -320,9 +320,13 @@
     return fd.str();
 std::string SAX2Parser::SerializeToXML(LayerDefinition *pLayer)
+    return SerializeToXML(pLayer, NULL);
+std::string SAX2Parser::SerializeToXML(LayerDefinition *pLayer, Version *version)
     MdfStringStream fd;
     VectorLayerDefinition *pVectorLayer = dynamic_cast<VectorLayerDefinition*>(pLayer);
@@ -332,17 +336,17 @@
     if (NULL != pVectorLayer)
         std::auto_ptr<IOVectorLayerDefinition> spIO(new IOVectorLayerDefinition());
-        spIO->Write(fd, pVectorLayer);
+        spIO->Write(fd, pVectorLayer, version);
     else if (NULL != pDrawingLayer)
         std::auto_ptr<IODrawingLayerDefinition> spIO(new IODrawingLayerDefinition());
-        spIO->Write(fd, pDrawingLayer);
+        spIO->Write(fd, pDrawingLayer, version);
     else if (NULL != pGridLayer)
         std::auto_ptr<IOGridLayerDefinition> spIO(new IOGridLayerDefinition());
-        spIO->Write(fd, pGridLayer);
+        spIO->Write(fd, pGridLayer, version);
     return fd.str();
Modified: trunk/MgDev/Common/MdfParser/SAX2Parser.h
--- trunk/MgDev/Common/MdfParser/SAX2Parser.h	2007-03-09 22:07:42 UTC (rev 1192)
+++ trunk/MgDev/Common/MdfParser/SAX2Parser.h	2007-03-09 23:36:56 UTC (rev 1193)
@@ -34,6 +34,7 @@
 #include <xercesc/framework/MemBufInputSource.hpp>
 #include "IOUtil.h"
@@ -108,6 +109,7 @@
         std::string SerializeToXML(MapDefinition *pMap);
         std::string SerializeToXML(LayerDefinition *pLayer);
+        std::string SerializeToXML(LayerDefinition *pLayer, MdfModel::Version *version);
         std::string SerializeToXML(SymbolDefinition *pSymbol);
         // there are two modes for retrieving objects created by parsing:
More information about the mapguide-commits mailing list
