[mapguide-commits] r1201 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Mon Mar 12 13:53:22 EDT 2007
Author: waltweltonlair
Date: 2007-03-12 13:53:22 -0400 (Mon, 12 Mar 2007)
New Revision: 1201
trunk/MgDev/Common/Stylization/GDRenderer.cpp
trunk/MgDev/Common/Stylization/GDRenderer.h
trunk/MgDev/Common/Stylization/SE_Renderer.cpp
trunk/MgDev/Common/Stylization/SE_Renderer.h
Add selection support for the new symbolization. Selected features
using the new symbolization now draw highlighted.
Modified: trunk/MgDev/Common/Stylization/GDRenderer.cpp
--- trunk/MgDev/Common/Stylization/GDRenderer.cpp 2007-03-12 17:12:43 UTC (rev 1200)
+++ trunk/MgDev/Common/Stylization/GDRenderer.cpp 2007-03-12 17:53:22 UTC (rev 1201)
@@ -128,7 +128,6 @@
m_fcInfo(NULL),
m_bRequiresClipping(requiresClipping),
m_bLocalOverposting(localOverposting),
-m_bSelectionMode(false),
m_bIsSymbolW2D(false),
m_bHaveViewport(false),
m_imsym(NULL),
@@ -367,6 +366,9 @@
void GDRenderer::EndMap()
+ // turn off selection mode so the labels draw normal
+ SetRenderSelectionMode(false);
//finally draw all the labels
m_labeler->BlastLabels();
@@ -1491,7 +1493,7 @@
void GDRenderer::SetRenderSelectionMode(bool mode)
- m_bSelectionMode = mode;
+ SE_Renderer::SetRenderSelectionMode(mode);
//initialize the selection styles if needed
if (mode)
Modified: trunk/MgDev/Common/Stylization/GDRenderer.h
--- trunk/MgDev/Common/Stylization/GDRenderer.h 2007-03-12 17:12:43 UTC (rev 1200)
+++ trunk/MgDev/Common/Stylization/GDRenderer.h 2007-03-12 17:53:22 UTC (rev 1201)
@@ -237,7 +237,6 @@
void* m_imsym;
int m_lineColor;
- bool m_bSelectionMode;
RS_FillStyle m_selFill;
LabelRendererBase* m_labeler;
Modified: trunk/MgDev/Common/Stylization/SE_Renderer.cpp
--- trunk/MgDev/Common/Stylization/SE_Renderer.cpp 2007-03-12 17:12:43 UTC (rev 1200)
+++ trunk/MgDev/Common/Stylization/SE_Renderer.cpp 2007-03-12 17:53:22 UTC (rev 1201)
@@ -23,11 +23,40 @@
using namespace MDFMODEL_NAMESPACE;
+SE_Renderer::SE_Renderer()
+: m_bSelectionMode(false)
+, m_selWeight(0.0)
+, m_selColor(0)
+, m_selFill(0)
+, m_textForeColor(0)
+, m_textBackColor(0)
+SE_Renderer::~SE_Renderer()
void SE_Renderer::SetLineBufferPool(SE_LineBufferPool* pool)
m_lbp = pool;
+void SE_Renderer::SetRenderSelectionMode(bool mode)
+ m_bSelectionMode = mode;
+ if (mode)
+ // set the default selection style - 1mm line weight, partially transparent blue
+ m_selWeight = 3.0; // should be 1 to give 1mm, but the renderer is way off
+ m_selColor = RS_Color(0, 0, 255, 200).argb();
+ m_selFill = RS_Color(0, 0, 255, 160).argb();
+ m_textForeColor = RS_Color(0, 0, 255, 200);
+ m_textBackColor = RS_Color(0, 0, 255, 255);
void SE_Renderer::ProcessPoint(LineBuffer* geometry, SE_RenderPointStyle* style)
SE_Matrix xform;
@@ -150,10 +179,20 @@
LineBuffer* geometry = pl->geometry->TransformInstance(posxform);
- if (primitive->type == SE_PolygonPrimitive)
- DrawScreenPolygon( geometry, ((SE_RenderPolygon*)primitive)->fill );
+ if (m_bSelectionMode)
+ if (primitive->type == SE_PolygonPrimitive)
+ DrawScreenPolygon( geometry, m_selFill);
+ DrawScreenPolyline( geometry, m_selColor, m_selWeight );
+ else
+ DrawScreenPolygon( geometry, ((SE_RenderPolygon*)primitive)->fill );
DrawScreenPolyline( geometry, pl->color, pl->weight );
else if (primitive->type == SE_TextPrimitive)
@@ -164,12 +203,21 @@
double x, y;
posxform.transform(tp->position[0], tp->position[1], x, y);
- if (anglerad != 0)
- RS_TextDef tdef2 = tp->tdef;
- tdef2.rotation() = anglerad * (180 / M_PI);
- DrawScreenText(tp->text, tdef2, x, y, NULL, 0, 0.0);
+ RS_TextDef tdef = tp->tdef;
+ tdef.color() = m_textForeColor;
+ tdef.bgcolor() = m_textBackColor;
+ if (anglerad != 0)
+ tdef.rotation() = anglerad * (180 / M_PI);
+ DrawScreenText(tp->text, tdef, x, y, NULL, 0, 0.0);
+ else if (anglerad != 0.0)
+ tdef.rotation() = anglerad * (180.0 / M_PI);
else
DrawScreenText(tp->text, tp->tdef, x, y, NULL, 0, 0.0);
Modified: trunk/MgDev/Common/Stylization/SE_Renderer.h
--- trunk/MgDev/Common/Stylization/SE_Renderer.h 2007-03-12 17:12:43 UTC (rev 1200)
+++ trunk/MgDev/Common/Stylization/SE_Renderer.h 2007-03-12 17:53:22 UTC (rev 1201)
@@ -25,6 +25,9 @@
class SE_Renderer
public:
+ STYLIZATION_API SE_Renderer();
+ STYLIZATION_API ~SE_Renderer();
void SetLineBufferPool(SE_LineBufferPool* pool);
/* SE_RenderSymbol, under associated xform, is in screen space, and geometry is in screen space */
STYLIZATION_API virtual void ProcessPoint(LineBuffer* geometry, SE_RenderPointStyle* style);
@@ -35,7 +38,7 @@
virtual void DrawScreenPolyline(LineBuffer* polyline, unsigned int color, double weight) = 0; // px
virtual void DrawScreenPolygon(LineBuffer* polygon, unsigned int fill) = 0;
- virtual void DrawScreenRaster(unsigned char* data, int length, RS_ImageFormat format, int native_width, int native_height,
+ virtual void DrawScreenRaster(unsigned char* data, int length, RS_ImageFormat format, int native_width, int native_height,
double x, double y, double w, double h, double angledeg) = 0;
virtual void DrawScreenText(const RS_String& txt, RS_TextDef& tdef, double insx, double insy, double* path, int npts, double param_position) = 0;
@@ -61,16 +64,25 @@
//sigh
const RS_F_Point* GetLastExclusionRegion() { return m_lastExclusionRegion; }
+protected:
+ void SetRenderSelectionMode(bool mode);
private:
void AddLabel(LineBuffer* geom, SE_RenderStyle* style, SE_Matrix& xform, double angle);
void AddExclusionRegion(SE_RenderStyle* rstyle, SE_Matrix& xform, double angle);
RS_F_Point m_lastExclusionRegion[4];
protected:
SE_LineBufferPool* m_lbp;
+ bool m_bSelectionMode;
+ double m_selWeight;
+ unsigned int m_selColor;
+ unsigned int m_selFill;
+ RS_Color m_textForeColor;
+ RS_Color m_textBackColor;
#endif // SE_RENDERER_H
More information about the mapguide-commits
