[mapguide-commits] r1203 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Mon Mar 12 19:51:11 EDT 2007
Author: waltweltonlair
Date: 2007-03-12 19:51:11 -0400 (Mon, 12 Mar 2007)
New Revision: 1203
trunk/MgDev/Common/Stylization/DefaultStylizer.cpp
trunk/MgDev/Common/Stylization/DefaultStylizer.h
trunk/MgDev/Common/Stylization/SE_SymbolManager.h
trunk/MgDev/Common/Stylization/StylizationEngine.cpp
trunk/MgDev/Common/Stylization/Stylizer.h
Some cleanup of the Stylizer interface
- removed the Initialize method
- Renderer parameter is now passed to all StylizeLayer() methods
- renamed StylizeFeatures to StylizeVectorLayer for consistency
Modified: trunk/MgDev/Common/Stylization/DefaultStylizer.cpp
--- trunk/MgDev/Common/Stylization/DefaultStylizer.cpp 2007-03-12 20:02:07 UTC (rev 1202)
+++ trunk/MgDev/Common/Stylization/DefaultStylizer.cpp 2007-03-12 23:51:11 UTC (rev 1203)
@@ -32,12 +32,11 @@
const RS_String s_Empty(L"");
-DefaultStylizer::DefaultStylizer()
+DefaultStylizer::DefaultStylizer(SE_SymbolManager* sman)
- m_lbPool = new LineBufferPool;
m_pRasterAdapter = NULL;
- m_renderer = NULL;
- m_styleEngine = NULL;
+ m_styleEngine = new StylizationEngine(sman);
+ m_lbPool = new LineBufferPool;
DefaultStylizer::~DefaultStylizer()
@@ -47,35 +46,20 @@
//of stylization
ClearAdapters();
- delete m_lbPool;
delete m_styleEngine;
+ delete m_lbPool;
-// Initializes the Stylizer with a given graphics renderer
-// Input: A pointer to a Renderer implementation instance
-void DefaultStylizer::Initialize(Renderer* renderer, SE_SymbolManager* sman)
- m_renderer = renderer;
- if (m_styleEngine)
- delete m_styleEngine;
- m_styleEngine = new StylizationEngine(sman);
///<summary>
/// Stylizes given features with a specified layer and map scale.
///<summary>
-void DefaultStylizer::StylizeFeatures(const MdfModel::VectorLayerDefinition* layer,
- RS_FeatureReader* features,
- CSysTransformer* xformer, //can be NULL
- CancelStylization cancel,
- void* userData
+void DefaultStylizer::StylizeVectorLayer(const MdfModel::VectorLayerDefinition* layer,
+ Renderer* renderer,
+ RS_FeatureReader* features,
+ CSysTransformer* xformer, //can be NULL
+ CancelStylization cancel,
+ void* userData)
//gets rid of const in pointer -- some functions we call aren't const
MdfModel::VectorLayerDefinition* fl = (MdfModel::VectorLayerDefinition*)layer;
@@ -86,7 +70,7 @@
// the first one that contains the given scale will be used
MdfModel::VectorScaleRangeCollection* ranges = fl->GetScaleRanges();
- MdfModel::VectorScaleRange* range = Stylizer::FindScaleRange(*ranges, m_renderer->GetMapScale());
+ MdfModel::VectorScaleRange* range = Stylizer::FindScaleRange(*ranges, renderer->GetMapScale());
// no range -- do not stylize
if (NULL == range) return;
@@ -106,9 +90,9 @@
RS_FilterExecutor* exec = RS_FilterExecutor::Create(features);
// configure the filter with the current map/layer info
- RS_MapUIInfo* mapInfo = m_renderer->GetMapInfo();
- RS_LayerUIInfo* layerInfo = m_renderer->GetLayerInfo();
- RS_FeatureClassInfo* featInfo = m_renderer->GetFeatureClassInfo();
+ RS_MapUIInfo* mapInfo = renderer->GetMapInfo();
+ RS_LayerUIInfo* layerInfo = renderer->GetLayerInfo();
+ RS_FeatureClassInfo* featInfo = renderer->GetFeatureClassInfo();
const RS_String& session = (mapInfo != NULL)? mapInfo->session() : s_Empty;
const RS_String& mapName = (mapInfo != NULL)? mapInfo->name() : s_Empty;
@@ -126,7 +110,7 @@
if (FeatureTypeStyleVisitor::DetermineFeatureTypeStyle(ftsc->GetAt(0)) == FeatureTypeStyleVisitor::ftsComposite)
use_style_engine = true;
- se_renderer = dynamic_cast<SE_Renderer*>(m_renderer);
+ se_renderer = dynamic_cast<SE_Renderer*>(renderer);
//extract hyperlink and tooltip info
@@ -152,7 +136,7 @@
//but is so horribly slow that in all other cases it needs to be optimized away
//FdoPtr<FdoClassDefinition> concreteClass = features->GetClassDefinition();
- bool bClip = m_renderer->RequiresClipping();
+ bool bClip = renderer->RequiresClipping();
#ifdef _DEBUG
int nFeatures = 0;
@@ -176,7 +160,7 @@
//clip geometry to given map request extents
//TODO: is this the right place to do so?
- LineBuffer* lbc = lb->Clip(m_renderer->GetBounds(), LineBuffer::ctAGF, m_lbPool);
+ LineBuffer* lbc = lb->Clip(renderer->GetBounds(), LineBuffer::ctAGF, m_lbPool);
//did geom require clipping?
//free original line buffer
@@ -244,7 +228,7 @@
MdfModel::LengthConverter::UnitToMeters(modelElevSettings->GetUnit(), 1.0),
elevType);
- adapter->Stylize(m_renderer, features, exec, lb, fts, lrTip, lrUrl, elevSettings);
+ adapter->Stylize(renderer, features, exec, lb, fts, lrTip, lrUrl, elevSettings);
delete elevSettings;
elevSettings = NULL;
@@ -259,7 +243,7 @@
#ifdef _DEBUG
- printf(" DefaultStylizer::StylizeFeatures() Layer: %S Features: %d\n", layer->GetFeatureName().c_str(), nFeatures);
+ printf(" DefaultStylizer::StylizeVectorLayer() Layer: %S Features: %d\n", layer->GetFeatureName().c_str(), nFeatures);
#endif
//need the cast due to multiple inheritance resulting in two Disposables
@@ -273,12 +257,12 @@
-void DefaultStylizer::StylizeGridLayer( const MdfModel::GridLayerDefinition* layer,
- CSysTransformer* /*xformer*/,
- void* userData
+void DefaultStylizer::StylizeGridLayer(const MdfModel::GridLayerDefinition* layer,
+ CSysTransformer* /*xformer*/,
+ void* userData)
MdfModel::GridLayerDefinition* gl = (MdfModel::GridLayerDefinition*)layer;
@@ -289,7 +273,7 @@
MdfModel::GridScaleRangeCollection* ranges = gl->GetScaleRanges();
- MdfModel::GridScaleRange* range = Stylizer::FindScaleRange(*ranges, m_renderer->GetMapScale());
+ MdfModel::GridScaleRange* range = Stylizer::FindScaleRange(*ranges, renderer->GetMapScale());
@@ -330,7 +314,7 @@
exec->Reset();
if (m_pRasterAdapter)
- m_pRasterAdapter->Stylize(m_renderer, features, exec, raster, gcs, NULL, NULL);
+ m_pRasterAdapter->Stylize(renderer, features, exec, raster, gcs, NULL, NULL);
if (raster)
delete raster; //need to free returned raster
@@ -348,44 +332,43 @@
-void DefaultStylizer::StylizeDrawingLayer( const MdfModel::DrawingLayerDefinition* layer,
- RS_LayerUIInfo* legendInfo,
- RS_InputStream* dwfin,
- const RS_String& layerFilter,
+void DefaultStylizer::StylizeDrawingLayer(const MdfModel::DrawingLayerDefinition* layer,
+ RS_LayerUIInfo* legendInfo,
+ RS_InputStream* dwfin,
+ const RS_String& layerFilter,
+ CSysTransformer* xformer)
- double mapScale = m_renderer->GetMapScale();
+ double mapScale = renderer->GetMapScale();
//check if we are in scale range
if (mapScale >= layer->GetMinScale() && mapScale < layer->GetMaxScale())
- m_renderer->StartLayer(legendInfo, NULL);
+ renderer->StartLayer(legendInfo, NULL);
//TODO: dwf password
- m_renderer->AddDWFContent(dwfin, xformer, L"", L"", layerFilter);
+ renderer->AddDWFContent(dwfin, xformer, L"", L"", layerFilter);
- m_renderer->EndLayer();
+ renderer->EndLayer();
//WARNING: given pointer to the new stylizer will be destroyed
//by the stylizer (in its destructor)
-void DefaultStylizer::SetGeometryAdapter( FdoGeometryType type, GeometryAdapter* sg)
+void DefaultStylizer::SetGeometryAdapter(FdoGeometryType type, GeometryAdapter* stylizer)
GeometryAdapter* old = (GeometryAdapter*)m_hGeomStylizers[type];
if (old) delete old;
- m_hGeomStylizers[type] = sg;
+ m_hGeomStylizers[type] = stylizer;
-void DefaultStylizer::SetStylizeFeature( FdoClassDefinition* /*classDef*/, GeometryAdapter* /*sg*/)
+void DefaultStylizer::SetStylizeFeature(FdoClassDefinition* /*classDef*/, GeometryAdapter* /*stylizer*/)
- //TODO
- //not impl.
+ //TODO: implemented
@@ -437,6 +420,7 @@
return m_hGeomStylizers[geomType];
void DefaultStylizer::ClearAdapters()
std::map<int, GeometryAdapter*>::iterator sgiter = m_hGeomStylizers.begin();
Modified: trunk/MgDev/Common/Stylization/DefaultStylizer.h
--- trunk/MgDev/Common/Stylization/DefaultStylizer.h 2007-03-12 20:02:07 UTC (rev 1202)
+++ trunk/MgDev/Common/Stylization/DefaultStylizer.h 2007-03-12 23:51:11 UTC (rev 1203)
@@ -28,39 +28,34 @@
class DefaultStylizer : public Stylizer
public:
- STYLIZATION_API DefaultStylizer();
+ STYLIZATION_API DefaultStylizer(SE_SymbolManager* sman);
STYLIZATION_API virtual ~DefaultStylizer();
- STYLIZATION_API virtual void Initialize(Renderer* renderer, SE_SymbolManager* sman = NULL);
+ STYLIZATION_API virtual void StylizeVectorLayer(const MdfModel::VectorLayerDefinition* layer,
+ void* userData);
- STYLIZATION_API virtual void StylizeFeatures( const MdfModel::VectorLayerDefinition* layer,
- void* userData
+ STYLIZATION_API virtual void StylizeGridLayer(const MdfModel::GridLayerDefinition* layer,
+ void* userData);
- STYLIZATION_API virtual void StylizeGridLayer(
- const MdfModel::GridLayerDefinition* layer,
- void* userData
+ STYLIZATION_API virtual void StylizeDrawingLayer(const MdfModel::DrawingLayerDefinition* layer,
+ CSysTransformer* xformer);
- STYLIZATION_API virtual void StylizeDrawingLayer( const MdfModel::DrawingLayerDefinition* layer,
+ STYLIZATION_API virtual void SetGeometryAdapter(FdoGeometryType type, GeometryAdapter* stylizer);
- STYLIZATION_API virtual void SetGeometryAdapter( FdoGeometryType type,
- GeometryAdapter* sg);
+ STYLIZATION_API virtual void SetStylizeFeature(FdoClassDefinition* classDef, GeometryAdapter* stylizer);
- STYLIZATION_API virtual void SetStylizeFeature( FdoClassDefinition* classDef,
private:
GeometryAdapter* FindGeomAdapter(int geomType);
void ClearAdapters();
@@ -76,7 +71,5 @@
//TODO feature class stylizers
- Renderer* m_renderer;
LineBufferPool* m_lbPool;
Modified: trunk/MgDev/Common/Stylization/SE_SymbolManager.h
--- trunk/MgDev/Common/Stylization/SE_SymbolManager.h 2007-03-12 20:02:07 UTC (rev 1202)
+++ trunk/MgDev/Common/Stylization/SE_SymbolManager.h 2007-03-12 23:51:11 UTC (rev 1203)
@@ -26,7 +26,7 @@
class SE_SymbolManager
public:
- virtual MdfModel::SymbolDefinition* GetSymbolDefinition(const wchar_t* resource) = 0;
+ virtual SymbolDefinition* GetSymbolDefinition(const wchar_t* resource) = 0;
virtual unsigned char* GetImageData(const wchar_t* resource, int& length) = 0;
Modified: trunk/MgDev/Common/Stylization/StylizationEngine.cpp
--- trunk/MgDev/Common/Stylization/StylizationEngine.cpp 2007-03-12 20:02:07 UTC (rev 1202)
+++ trunk/MgDev/Common/Stylization/StylizationEngine.cpp 2007-03-12 23:51:11 UTC (rev 1203)
@@ -298,7 +298,7 @@
return render;
-SE_RenderAreaStyle* StylizationEngine::EvaluateAreaStyle(SE_Matrix& xform, SE_AreaStyle* style)
+SE_RenderAreaStyle* StylizationEngine::EvaluateAreaStyle(SE_Matrix& /*xform*/, SE_AreaStyle* style)
SE_RenderAreaStyle* render = new SE_RenderAreaStyle();
Modified: trunk/MgDev/Common/Stylization/Stylizer.h
--- trunk/MgDev/Common/Stylization/Stylizer.h 2007-03-12 20:02:07 UTC (rev 1202)
+++ trunk/MgDev/Common/Stylization/Stylizer.h 2007-03-12 23:51:11 UTC (rev 1203)
@@ -42,53 +42,47 @@
public:
///<summary>
- ///Sets the Renderer object for this Stylizer
+ /// Stylizes a feature/vector (FDO-based) layer.
///</summary>
- virtual void Initialize(Renderer* renderer, SE_SymbolManager* sman = NULL) = 0;
+ virtual void StylizeVectorLayer(const MdfModel::VectorLayerDefinition* layer,
+ void* userData
+ ) = 0;
///<summary>
- /// Stylizes a feature (FDO based) layer.
- ///</summary>
- virtual void StylizeFeatures( const MdfModel::VectorLayerDefinition* layer,
- void* userData
- ) = 0;
- ///<summary>
/// Stylizes a grid/raster layer.
///</summary>
- virtual void StylizeGridLayer( const MdfModel::GridLayerDefinition* layer,
- void* userData
- ) = 0;
+ virtual void StylizeGridLayer(const MdfModel::GridLayerDefinition* layer,
+ void* userData
+ ) = 0;
///<summary>
- /// Stylizes a drawing (DWF based) layer.
+ /// Stylizes a drawing (DWF-based) layer.
///</summary>
- virtual void StylizeDrawingLayer( const MdfModel::DrawingLayerDefinition* layer,
- ) = 0;
+ virtual void StylizeDrawingLayer(const MdfModel::DrawingLayerDefinition* layer,
+ ) = 0;
///<summary>
- ///allows user to set a custom stylization object for certain
- ///geometry types
+ /// Allows a user to set a custom stylization object for certain geometry types.
///</summary>
- virtual void SetGeometryAdapter( FdoGeometryType type,
- GeometryAdapter* sg) = 0;
+ virtual void SetGeometryAdapter(FdoGeometryType type, GeometryAdapter* stylizer) = 0;
///<summary>
- ///allows user to set a custom stylization object for a
- ///given feature class
+ /// Allows a user to set a custom stylization object for a given feature class.
///</summary>
- virtual void SetStylizeFeature( FdoClassDefinition* classDef,
+ virtual void SetStylizeFeature(FdoClassDefinition* classDef, GeometryAdapter* stylizer) = 0;
STYLIZATION_API static MdfModel::VectorScaleRange* FindScaleRange(MdfModel::VectorScaleRangeCollection& src,
double mapScale);
More information about the mapguide-commits
