[mapguide-commits] r1208 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Tue Mar 13 13:50:54 EDT 2007
Author: jasonnogar
Date: 2007-03-13 13:50:50 -0400 (Tue, 13 Mar 2007)
New Revision: 1208
trunk/MgDev/Common/Stylization/SE_Bounds.cpp
trunk/MgDev/Common/Stylization/SE_Bounds.h
trunk/MgDev/Common/Stylization/SE_ExpressionBase.cpp
trunk/MgDev/Common/Stylization/SE_Include.h
trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp
trunk/MgDev/Common/Stylization/StylizationEngine.cpp
Symbology:
* Add support for Path::WeightScalable
* Added SE_Bounds fix to avoid infinite loop on invalid input
* Added whitespace trimming for all expressions to SE_ExpressionBase (improves detection of constant expressions, e.g. " true " instead of "true").
KNOWN ISSUE: I noticed that when one uses an invalid, unknown, or non-TTF font for a Text graphic element, the first font, which is not TTF, will be used, causing divides by zero in text metrics and elsewhere.
Modified: trunk/MgDev/Common/Stylization/SE_Bounds.cpp
--- trunk/MgDev/Common/Stylization/SE_Bounds.cpp 2007-03-13 14:06:09 UTC (rev 1207)
+++ trunk/MgDev/Common/Stylization/SE_Bounds.cpp 2007-03-13 17:50:50 UTC (rev 1208)
@@ -167,6 +167,11 @@
+bool SE_Bounds::Contained(double minx, double miny, double maxx, double maxy)
+ return (minx < min[0]) && (miny < min[1]) && (maxx > max[0]) && (maxy > max[1]);
SE_Bounds* SE_Bounds::Union(SE_Bounds* bounds)
/* Andrew Convex Hull again, but this time in linear time (the points of the
@@ -206,6 +211,18 @@
ly = *(start[i]+1);
index = i;
+ _ASSERT(index != -1);
+ if (index == -1)
+ /* For some reason, one of the bounds we are combining is has invalid points,
+ which can only be caused by an error somewhere else in the code.
+ Rather than loop infinitely, we will return NULL */
+ if (usize > 4096)
+ delete[] vec;
+ return NULL;
if (index & 1) // U array
start[index] -= 2;
else // L array
Modified: trunk/MgDev/Common/Stylization/SE_Bounds.h
--- trunk/MgDev/Common/Stylization/SE_Bounds.h 2007-03-13 14:06:09 UTC (rev 1207)
+++ trunk/MgDev/Common/Stylization/SE_Bounds.h 2007-03-13 17:50:50 UTC (rev 1208)
@@ -43,6 +43,7 @@
STYLIZATION_API void Add(double x, double y);
STYLIZATION_API void Transform(const SE_Matrix& xform);
STYLIZATION_API void Transform(const SE_Matrix& xform, SE_Bounds* src);
+ STYLIZATION_API bool Contained(double minx, double miny, double maxx, double maxy);
STYLIZATION_API void Contained(double minx, double miny, double maxx, double maxy, double &growx, double &growy);
STYLIZATION_API void Free();
STYLIZATION_API SE_Bounds* Clone();
Modified: trunk/MgDev/Common/Stylization/SE_ExpressionBase.cpp
--- trunk/MgDev/Common/Stylization/SE_ExpressionBase.cpp 2007-03-13 14:06:09 UTC (rev 1207)
+++ trunk/MgDev/Common/Stylization/SE_ExpressionBase.cpp 2007-03-13 17:50:50 UTC (rev 1208)
@@ -60,9 +60,14 @@
MdfString::size_type startIdx, endIdx, count;
MdfString::iterator beginIter;
- const wchar_t *name, *value;
+ const wchar_t *name, *value, *trim;
- m_buffer.assign(exprstr);
+ /* Trim whitespace from the beginning */
+ trim = exprstr.c_str();
+ while (iswspace(*trim))
+ trim++;
+ m_buffer.assign(trim);
startIdx = endIdx = 0;
for(;;)
@@ -75,24 +80,11 @@
if (endIdx == MdfString::npos)
break;
+ /* We have found matched % characters--it must be a parameter */
count = endIdx - startIdx - 1;
m_param.assign(m_buffer, startIdx + 1, count);
name = m_param.c_str();
- /* If there is a space in the parameter name, this is not a parameter. This way,
- * if we add a modulus operator or something, parsing will not be completely screwed up,
- * although we should probably check for a few more illegal characters as well (checking
- * for legal characters doesn't seem viable in the face of localization) */
- bool notParam = false;
- for (size_t i = 0; i < count; i++)
- if (iswspace(name[i]))
- notParam = true;
- if (notParam)
- startIdx = endIdx;
- continue;
ParameterMap::const_iterator paramIter = m_parameters.find(ParamId(m_symbol, name));
if (paramIter == m_parameters.end())
@@ -110,6 +102,13 @@
m_buffer.replace(beginIter + startIdx, beginIter + endIdx + 1, value);
startIdx += wcslen(value);
+ /* Trim whitespace from the end */
+ size_t len = m_buffer.size();
+ trim = m_buffer.c_str() + len - 1;
+ while (iswspace(*trim--))
+ len--;
+ m_buffer.resize(len);
void SE_ExpressionBase::ParseDoubleExpression(const MdfModel::MdfString& exprstr, SE_Double& val)
@@ -122,7 +121,7 @@
if (len == 0)
- val.value = 0;
+ val = 0;
return;
@@ -144,11 +143,11 @@
if (len == 0)
- val.value = 0;
+ val = 0;
return;
- int ret = swscanf(cstr, L"%d%n", &val.value, &chars);
+ int ret = swscanf(cstr, L"%d%n", &val, &chars);
if (ret == 1 && chars == len)
return;
@@ -165,18 +164,18 @@
if (len == 0)
- val.value = false;
+ val = false;
return;
- if (_wcsnicmp(cstr, L"true", 5) == 0)
+ if (wcsicmp(cstr, L"true") == 0)
- val.value = true;
+ val = true;
return;
- else if (_wcsnicmp(cstr, L"false", 6) == 0)
+ else if (wcsicmp(cstr, L"false") == 0)
+ val = false;
return;
@@ -187,9 +186,6 @@
ReplaceParameters(exprstr, L"");
- //TODO: we need to add Parse functions that know what the string they are parsing represents.
- //for example ParseHorizontalAlignment. This way we can determine if the value is a constant
- //or an expression that needs to be evaluated all the time.
if (exprstr.empty())
val.expression = NULL;
@@ -197,31 +193,37 @@
else
- const wchar_t* str = m_buffer.c_str();
- while (iswspace(*str))
- str++;
+ const wchar_t* start = m_buffer.c_str();
+ const wchar_t* str = start;
+ /* Literal expression must start with a single quote (after trimming) */
if (*str++ != L'\'')
- val.expression = FdoExpression::Parse(m_buffer.c_str());
+ val.expression = FdoExpression::Parse(start);
return;
- const wchar_t* begin = str;
while(*str != L'\0' && *str != L'\'')
str++;
- if (*str == L'\0')
+ if (*str++ == L'\0')
return;
- size_t len = str - begin;
+ /* Last character of the literal expression should be a single quote as well */
+ if (*str != L'\0')
+ return;
+ size_t len = m_buffer.size() - 2;
wchar_t* copy = new wchar_t[len + 1];
- memcpy(copy, begin, sizeof(wchar_t)*len);
+ memcpy(copy, start + 1, sizeof(wchar_t)*len);
copy[len] = L'\0';
- val.value = copy;
+ val = copy;
Modified: trunk/MgDev/Common/Stylization/SE_Include.h
--- trunk/MgDev/Common/Stylization/SE_Include.h 2007-03-13 14:06:09 UTC (rev 1207)
+++ trunk/MgDev/Common/Stylization/SE_Include.h 2007-03-13 17:50:50 UTC (rev 1208)
@@ -284,6 +284,7 @@
SE_LineBuffer* geometry;
SE_Double weight;
SE_Color color;
+ SE_Boolean weightScalable;
SE_INLINE SE_Polyline() : weight(0.0) { type = SE_PolylinePrimitive; }
Modified: trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp
--- trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp 2007-03-13 14:06:09 UTC (rev 1207)
+++ trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp 2007-03-13 17:50:50 UTC (rev 1208)
@@ -389,12 +389,15 @@
ParseGeometry(geometry, *line->geometry);
ParseDoubleExpression(path.GetLineWeight(), line->weight);
ParseColorExpression(path.GetLineColor(), line->color);
+ ParseBooleanExpression(path.GetLineWeightScalable(), line->weightScalable);
/* If the color is transparent, there is no point in drawing this path,
* so we will change it to black. */
if (line->color.argb() == 0)
line->color.a = 255;
line->cacheable = !(line->weight.expression ||
- line->color.expression);
+ line->color.expression ||
+ line->weightScalable.expression);
else
@@ -405,9 +408,11 @@
ParseDoubleExpression(path.GetLineWeight(), polygon->weight);
polygon->fill = color;
ParseColorExpression(path.GetLineColor(), polygon->color);
- polygon->cacheable = !(polygon->weight.expression ||
- polygon->color.expression ||
- polygon->fill.expression);
+ ParseBooleanExpression(path.GetLineWeightScalable(), polygon->weightScalable);
+ polygon->cacheable = !(polygon->weight.expression ||
+ polygon->color.expression ||
+ polygon->fill.expression ||
+ polygon->weightScalable.expression);
Modified: trunk/MgDev/Common/Stylization/StylizationEngine.cpp
--- trunk/MgDev/Common/Stylization/StylizationEngine.cpp 2007-03-13 14:06:09 UTC (rev 1207)
+++ trunk/MgDev/Common/Stylization/StylizationEngine.cpp 2007-03-13 17:50:50 UTC (rev 1208)
@@ -147,7 +147,7 @@
SE_LineBuffer* xformGeom = m_pool->NewLineBuffer(geometry->point_count());
xformGeom->compute_bounds() = false;
xformGeom->Transform(geometry, w2s);
for (std::vector<SE_Symbolization*>::const_iterator iter = symbolization->begin(); iter != symbolization->end(); iter++)
@@ -166,7 +166,7 @@
SE_Style* style = *siter;
- SE_Matrix tmpxform = xform; //TODO: this is lame, but necessary since the xform can be modified
+ SE_Matrix tmpxform(xform); //TODO: this is lame, but necessary since the xform can be modified
//when we evalute the style, in the case of point style set on a
//non-point geometry
@@ -348,7 +348,10 @@
if (!rsym) rsym = new SE_RenderPolyline();
SE_Polyline* p = (SE_Polyline*) sym;
SE_RenderPolyline* rp = (SE_RenderPolyline*)rsym;
- rp->weight = p->weight.evaluate(m_exec)*mm2px;
+ double wx = p->weightScalable.evaluate(m_exec) ?
+ m_renderer->GetPixelsPerMillimeterWorld() :
+ m_renderer->GetPixelsPerMillimeterScreen();
+ rp->weight = p->weight.evaluate(m_exec)*wx;
rp->geometry = p->geometry;
rp->color = p->color.evaluate(m_exec);
/* Defer transformation */
More information about the mapguide-commits
