[mapguide-commits] r1212 - trunk/MgDev/Common/Foundation/System
svn_mapguide at osgeo.org
Tue Mar 13 16:05:54 EDT 2007
Author: brucedechant
Date: 2007-03-13 16:05:53 -0400 (Tue, 13 Mar 2007)
New Revision: 1212
trunk/MgDev/Common/Foundation/System/Util.cpp
trunk/MgDev/Common/Foundation/System/Util.h
Updated ValuesEqual method to display failure details for both release and debug builds if needed via an optional parameter.
Note: This method is only used by the unit tests.
Modified: trunk/MgDev/Common/Foundation/System/Util.cpp
--- trunk/MgDev/Common/Foundation/System/Util.cpp 2007-03-13 19:28:04 UTC (rev 1211)
+++ trunk/MgDev/Common/Foundation/System/Util.cpp 2007-03-13 20:05:53 UTC (rev 1212)
@@ -942,7 +942,7 @@
str = &buf[0];
-bool MgUtil::ValuesEqual(double value1, double value2, double tolerance)
+bool MgUtil::ValuesEqual(double value1, double value2, double tolerance, bool output)
bool valuesEqual = true;
double difference = value1 - value2;
@@ -956,7 +956,10 @@
if (::fabs(error) > ::fabs(tolerance))
// If the values don't match and don't fall within the tolerance, then output them.
- ACE_DEBUG((LM_DEBUG, ACE_TEXT("\nMgUtil.ValuesEqual() failed!\nOriginal: \"%.17g\"\nCalculated: \"%.17g\"\n"), value1, value2));
+ if(output)
+ ACE_DEBUG((LM_INFO, ACE_TEXT("\nMgUtil.ValuesEqual() failed!\nOriginal: \"%.17g\"\nCalculated: \"%.17g\"\n"), value1, value2));
valuesEqual = false;
Modified: trunk/MgDev/Common/Foundation/System/Util.h
--- trunk/MgDev/Common/Foundation/System/Util.h 2007-03-13 19:28:04 UTC (rev 1211)
+++ trunk/MgDev/Common/Foundation/System/Util.h 2007-03-13 20:05:53 UTC (rev 1212)
@@ -502,7 +502,8 @@
static void DoubleToString(double val, STRING& str);
static bool ValuesEqual(double value1, double value2,
- double tolerance = MgUtil::DefaultCompareTolerance);
+ double tolerance = MgUtil::DefaultCompareTolerance,
+ bool output = true);
static void TrimEndingZeros(string& str);
static void TrimEndingZeros(STRING& str);
More information about the mapguide-commits
