[mapguide-commits] r1227 - trunk/MgDev/Oem/CppUnit-1.9.14
svn_mapguide at osgeo.org
Wed Mar 14 14:34:32 EDT 2007
Author: trevorwekel
Date: 2007-03-14 14:34:32 -0400 (Wed, 14 Mar 2007)
New Revision: 1227
Removed:
trunk/MgDev/Oem/CppUnit-1.9.14/aclocal.m4
Remove aclocal.m4 from CppUnit. It should be generated by the build.
Deleted: trunk/MgDev/Oem/CppUnit-1.9.14/aclocal.m4
--- trunk/MgDev/Oem/CppUnit-1.9.14/aclocal.m4 2007-03-14 18:08:45 UTC (rev 1226)
+++ trunk/MgDev/Oem/CppUnit-1.9.14/aclocal.m4 2007-03-14 18:34:32 UTC (rev 1227)
@@ -1,7051 +0,0 @@
-# generated automatically by aclocal 1.7.5 -*- Autoconf -*-
-# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001, 2002
-# Free Software Foundation, Inc.
-# This file is free software; the Free Software Foundation
-# gives unlimited permission to copy and/or distribute it,
-# with or without modifications, as long as this notice is preserved.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY, to the extent permitted by law; without
-# even the implied warranty of MERCHANTABILITY or FITNESS FOR A
-# PARTICULAR PURPOSE.
-# Like AC_CONFIG_HEADER, but automatically create stamp file. -*- Autoconf -*-
-# Copyright 1996, 1997, 2000, 2001 Free Software Foundation, Inc.
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA
-# 02111-1307, USA.
-AC_PREREQ([2.52])
-# serial 6
-# AM_CONFIG_HEADER is obsolete. It has been replaced by AC_CONFIG_HEADERS.
-AU_DEFUN([AM_CONFIG_HEADER], [AC_CONFIG_HEADERS($@)])
-# Do all the work for Automake. -*- Autoconf -*-
-# This macro actually does too much some checks are only needed if
-# your package does certain things. But this isn't really a big deal.
-# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003
-# 02111-1307, USA.
-# serial 10
-AC_PREREQ([2.54])
-# Autoconf 2.50 wants to disallow AM_ names. We explicitly allow
-# the ones we care about.
-m4_pattern_allow([^AM_[A-Z]+FLAGS$])dnl
-# AM_INIT_AUTOMAKE(PACKAGE, VERSION, [NO-DEFINE])
-# AM_INIT_AUTOMAKE([OPTIONS])
-# The call with PACKAGE and VERSION arguments is the old style
-# call (pre autoconf-2.50), which is being phased out. PACKAGE
-# and VERSION should now be passed to AC_INIT and removed from
-# the call to AM_INIT_AUTOMAKE.
-# We support both call styles for the transition. After
-# the next Automake release, Autoconf can make the AC_INIT
-# arguments mandatory, and then we can depend on a new Autoconf
-# release and drop the old call support.
-AC_DEFUN([AM_INIT_AUTOMAKE],
-[AC_REQUIRE([AM_SET_CURRENT_AUTOMAKE_VERSION])dnl
- AC_REQUIRE([AC_PROG_INSTALL])dnl
-# test to see if srcdir already configured
-if test "`cd $srcdir && pwd`" != "`pwd`" &&
- test -f $srcdir/config.status; then
- AC_MSG_ERROR([source directory already configured; run "make distclean" there first])
-fi
-# test whether we have cygpath
-if test -z "$CYGPATH_W"; then
- if (cygpath --version) >/dev/null 2>/dev/null; then
- CYGPATH_W='cygpath -w'
- else
- CYGPATH_W=echo
- fi
-fi
-AC_SUBST([CYGPATH_W])
-# Define the identity of the package.
-dnl Distinguish between old-style and new-style calls.
-m4_ifval([$2],
-[m4_ifval([$3], [_AM_SET_OPTION([no-define])])dnl
- AC_SUBST([PACKAGE], [$1])dnl
- AC_SUBST([VERSION], [$2])],
-[_AM_SET_OPTIONS([$1])dnl
- AC_SUBST([PACKAGE], ['AC_PACKAGE_TARNAME'])dnl
- AC_SUBST([VERSION], ['AC_PACKAGE_VERSION'])])dnl
-_AM_IF_OPTION([no-define],,
-[AC_DEFINE_UNQUOTED(PACKAGE, "$PACKAGE", [Name of package])
- AC_DEFINE_UNQUOTED(VERSION, "$VERSION", [Version number of package])])dnl
-# Some tools Automake needs.
-AC_REQUIRE([AM_SANITY_CHECK])dnl
-AC_REQUIRE([AC_ARG_PROGRAM])dnl
-AM_MISSING_PROG(ACLOCAL, aclocal-${am__api_version})
-AM_MISSING_PROG(AUTOCONF, autoconf)
-AM_MISSING_PROG(AUTOMAKE, automake-${am__api_version})
-AM_MISSING_PROG(AUTOHEADER, autoheader)
-AM_MISSING_PROG(MAKEINFO, makeinfo)
-AM_MISSING_PROG(AMTAR, tar)
-AM_PROG_INSTALL_SH
-AM_PROG_INSTALL_STRIP
-# We need awk for the "check" target. The system "awk" is bad on
-# some platforms.
-AC_REQUIRE([AC_PROG_AWK])dnl
-AC_REQUIRE([AC_PROG_MAKE_SET])dnl
-AC_REQUIRE([AM_SET_LEADING_DOT])dnl
-_AM_IF_OPTION([no-dependencies],,
-[AC_PROVIDE_IFELSE([AC_PROG_CC],
- [_AM_DEPENDENCIES(CC)],
- [define([AC_PROG_CC],
- defn([AC_PROG_CC])[_AM_DEPENDENCIES(CC)])])dnl
-AC_PROVIDE_IFELSE([AC_PROG_CXX],
- [_AM_DEPENDENCIES(CXX)],
- [define([AC_PROG_CXX],
- defn([AC_PROG_CXX])[_AM_DEPENDENCIES(CXX)])])dnl
-# When config.status generates a header, we must update the stamp-h file.
-# This file resides in the same directory as the config header
-# that is generated. The stamp files are numbered to have different names.
-# Autoconf calls _AC_AM_CONFIG_HEADER_HOOK (when defined) in the
-# loop where config.status creates the headers, so we can generate
-# our stamp files there.
-AC_DEFUN([_AC_AM_CONFIG_HEADER_HOOK],
-[# Compute $1's index in $config_headers.
-_am_stamp_count=1
-for _am_header in $config_headers :; do
- case $_am_header in
- $1 | $1:* )
- break ;;
- _am_stamp_count=`expr $_am_stamp_count + 1` ;;
- esac
-done
-echo "timestamp for $1" >`AS_DIRNAME([$1])`/stamp-h[]$_am_stamp_count])
-# Copyright 2002 Free Software Foundation, Inc.
-# AM_AUTOMAKE_VERSION(VERSION)
-# Automake X.Y traces this macro to ensure aclocal.m4 has been
-# generated from the m4 files accompanying Automake X.Y.
-AC_DEFUN([AM_AUTOMAKE_VERSION],[am__api_version="1.7"])
-# AM_SET_CURRENT_AUTOMAKE_VERSION
-# Call AM_AUTOMAKE_VERSION so it can be traced.
-# This function is AC_REQUIREd by AC_INIT_AUTOMAKE.
-AC_DEFUN([AM_SET_CURRENT_AUTOMAKE_VERSION],
- [AM_AUTOMAKE_VERSION([1.7.5])])
-# Helper functions for option handling. -*- Autoconf -*-
-# Copyright 2001, 2002 Free Software Foundation, Inc.
-# 02111-1307, USA.
-# serial 2
-# _AM_MANGLE_OPTION(NAME)
-AC_DEFUN([_AM_MANGLE_OPTION],
-[[_AM_OPTION_]m4_bpatsubst($1, [[^a-zA-Z0-9_]], [_])])
-# _AM_SET_OPTION(NAME)
-# Set option NAME. Presently that only means defining a flag for this option.
-AC_DEFUN([_AM_SET_OPTION],
-[m4_define(_AM_MANGLE_OPTION([$1]), 1)])
-# _AM_SET_OPTIONS(OPTIONS)
-# OPTIONS is a space-separated list of Automake options.
-AC_DEFUN([_AM_SET_OPTIONS],
-[AC_FOREACH([_AM_Option], [$1], [_AM_SET_OPTION(_AM_Option)])])
-# _AM_IF_OPTION(OPTION, IF-SET, [IF-NOT-SET])
-# Execute IF-SET if OPTION is set, IF-NOT-SET otherwise.
-AC_DEFUN([_AM_IF_OPTION],
-[m4_ifset(_AM_MANGLE_OPTION([$1]), [$2], [$3])])
-# Check to make sure that the build environment is sane.
-# 02111-1307, USA.
-# serial 3
-# AM_SANITY_CHECK
-AC_DEFUN([AM_SANITY_CHECK],
-[AC_MSG_CHECKING([whether build environment is sane])
-# Just in case
-sleep 1
-echo timestamp > conftest.file
-# Do `set' in a subshell so we don't clobber the current shell's
-# arguments. Must try -L first in case configure is actually a
-# symlink; some systems play weird games with the mod time of symlinks
-# (eg FreeBSD returns the mod time of the symlink's containing
-# directory).
-if (
- set X `ls -Lt $srcdir/configure conftest.file 2> /dev/null`
- if test "$[*]" = "X"; then
- # -L didn't work.
- set X `ls -t $srcdir/configure conftest.file`
- fi
- rm -f conftest.file
- if test "$[*]" != "X $srcdir/configure conftest.file" \
- && test "$[*]" != "X conftest.file $srcdir/configure"; then
- # If neither matched, then we have a broken ls. This can happen
- # if, for instance, CONFIG_SHELL is bash and it inherits a
- # broken ls alias from the environment. This has actually
- # happened. Such a system could not be considered "sane".
- AC_MSG_ERROR([ls -t appears to fail. Make sure there is not a broken
-alias in your environment])
- fi
- test "$[2]" = conftest.file
-then
- # Ok.
-else
- AC_MSG_ERROR([newly created file is older than distributed files!
-Check your system clock])
-fi
-AC_MSG_RESULT(yes)])
-# -*- Autoconf -*-
-# Copyright 1997, 1999, 2000, 2001 Free Software Foundation, Inc.
-# 02111-1307, USA.
-# serial 3
-# AM_MISSING_PROG(NAME, PROGRAM)
-AC_DEFUN([AM_MISSING_PROG],
-[AC_REQUIRE([AM_MISSING_HAS_RUN])
-$1=${$1-"${am_missing_run}$2"}
-AC_SUBST($1)])
-# AM_MISSING_HAS_RUN
-# Define MISSING if not defined so far and test if it supports --run.
-# If it does, set am_missing_run to use it, otherwise, to nothing.
-AC_DEFUN([AM_MISSING_HAS_RUN],
-[AC_REQUIRE([AM_AUX_DIR_EXPAND])dnl
-test x"${MISSING+set}" = xset || MISSING="\${SHELL} $am_aux_dir/missing"
-# Use eval to expand $SHELL
-if eval "$MISSING --run true"; then
- am_missing_run="$MISSING --run "
-else
- am_missing_run=
- AC_MSG_WARN([`missing' script is too old or missing])
-fi
-# AM_AUX_DIR_EXPAND
-# Copyright 2001 Free Software Foundation, Inc.
-# 02111-1307, USA.
-# For projects using AC_CONFIG_AUX_DIR([foo]), Autoconf sets
-# $ac_aux_dir to `$srcdir/foo'. In other projects, it is set to
-# `$srcdir', `$srcdir/..', or `$srcdir/../..'.
-# Of course, Automake must honor this variable whenever it calls a
-# tool from the auxiliary directory. The problem is that $srcdir (and
-# therefore $ac_aux_dir as well) can be either absolute or relative,
-# depending on how configure is run. This is pretty annoying, since
-# it makes $ac_aux_dir quite unusable in subdirectories: in the top
-# source directory, any form will work fine, but in subdirectories a
-# relative path needs to be adjusted first.
-# $ac_aux_dir/missing
-# fails when called from a subdirectory if $ac_aux_dir is relative
-# $top_srcdir/$ac_aux_dir/missing
-# fails if $ac_aux_dir is absolute,
-# fails when called from a subdirectory in a VPATH build with
-# a relative $ac_aux_dir
-# The reason of the latter failure is that $top_srcdir and $ac_aux_dir
-# are both prefixed by $srcdir. In an in-source build this is usually
-# harmless because $srcdir is `.', but things will broke when you
-# start a VPATH build or use an absolute $srcdir.
-# So we could use something similar to $top_srcdir/$ac_aux_dir/missing,
-# iff we strip the leading $srcdir from $ac_aux_dir. That would be:
-# am_aux_dir='\$(top_srcdir)/'`expr "$ac_aux_dir" : "$srcdir//*\(.*\)"`
-# and then we would define $MISSING as
-# MISSING="\${SHELL} $am_aux_dir/missing"
-# This will work as long as MISSING is not called from configure, because
-# unfortunately $(top_srcdir) has no meaning in configure.
-# However there are other variables, like CC, which are often used in
-# configure, and could therefore not use this "fixed" $ac_aux_dir.
-# Another solution, used here, is to always expand $ac_aux_dir to an
-# absolute PATH. The drawback is that using absolute paths prevent a
-# configured tree to be moved without reconfiguration.
-# Rely on autoconf to set up CDPATH properly.
-AC_PREREQ([2.50])
-AC_DEFUN([AM_AUX_DIR_EXPAND], [
-# expand $ac_aux_dir to an absolute path
-am_aux_dir=`cd $ac_aux_dir && pwd`
-# AM_PROG_INSTALL_SH
-# Define $install_sh.
-# 02111-1307, USA.
-AC_DEFUN([AM_PROG_INSTALL_SH],
-install_sh=${install_sh-"$am_aux_dir/install-sh"}
-AC_SUBST(install_sh)])
-# AM_PROG_INSTALL_STRIP
-# 02111-1307, USA.
-# One issue with vendor `install' (even GNU) is that you can't
-# specify the program used to strip binaries. This is especially
-# annoying in cross-compiling environments, where the build's strip
-# is unlikely to handle the host's binaries.
-# Fortunately install-sh will honor a STRIPPROG variable, so we
-# always use install-sh in `make install-strip', and initialize
-# STRIPPROG with the value of the STRIP variable (set by the user).
-AC_DEFUN([AM_PROG_INSTALL_STRIP],
-[AC_REQUIRE([AM_PROG_INSTALL_SH])dnl
-# Installed binaries are usually stripped using `strip' when the user
-# run `make install-strip'. However `strip' might not be the right
-# tool to use in cross-compilation environments, therefore Automake
-# will honor the `STRIP' environment variable to overrule this program.
-dnl Don't test for $cross_compiling = yes, because it might be `maybe'.
-if test "$cross_compiling" != no; then
- AC_CHECK_TOOL([STRIP], [strip], :)
-fi
-INSTALL_STRIP_PROGRAM="\${SHELL} \$(install_sh) -c -s"
-AC_SUBST([INSTALL_STRIP_PROGRAM])])
-# -*- Autoconf -*-
-# Copyright (C) 2003 Free Software Foundation, Inc.
-# 02111-1307, USA.
-# serial 1
-# Check whether the underlying file-system supports filenames
-# with a leading dot. For instance MS-DOS doesn't.
-AC_DEFUN([AM_SET_LEADING_DOT],
-[rm -rf .tst 2>/dev/null
-mkdir .tst 2>/dev/null
-if test -d .tst; then
- am__leading_dot=.
-else
- am__leading_dot=_
-fi
-rmdir .tst 2>/dev/null
-AC_SUBST([am__leading_dot])])
-# serial 5 -*- Autoconf -*-
-# Copyright (C) 1999, 2000, 2001, 2002, 2003 Free Software Foundation, Inc.
-# 02111-1307, USA.
-# There are a few dirty hacks below to avoid letting `AC_PROG_CC' be
-# written in clear, in which case automake, when reading aclocal.m4,
-# will think it sees a *use*, and therefore will trigger all it's
-# C support machinery. Also note that it means that autoscan, seeing
-# CC etc. in the Makefile, will ask for an AC_PROG_CC use...
-# _AM_DEPENDENCIES(NAME)
-# See how the compiler implements dependency checking.
-# NAME is "CC", "CXX", "GCJ", or "OBJC".
-# We try a few techniques and use that to set a single cache variable.
-# We don't AC_REQUIRE the corresponding AC_PROG_CC since the latter was
-# modified to invoke _AM_DEPENDENCIES(CC); we would have a circular
-# dependency, and given that the user is not expected to run this macro,
-# just rely on AC_PROG_CC.
-AC_DEFUN([_AM_DEPENDENCIES],
-[AC_REQUIRE([AM_SET_DEPDIR])dnl
-AC_REQUIRE([AM_OUTPUT_DEPENDENCY_COMMANDS])dnl
-AC_REQUIRE([AM_MAKE_INCLUDE])dnl
-AC_REQUIRE([AM_DEP_TRACK])dnl
-ifelse([$1], CC, [depcc="$CC" am_compiler_list=],
- [$1], CXX, [depcc="$CXX" am_compiler_list=],
- [$1], OBJC, [depcc="$OBJC" am_compiler_list='gcc3 gcc'],
- [$1], GCJ, [depcc="$GCJ" am_compiler_list='gcc3 gcc'],
- [depcc="$$1" am_compiler_list=])
-AC_CACHE_CHECK([dependency style of $depcc],
- [am_cv_$1_dependencies_compiler_type],
-[if test -z "$AMDEP_TRUE" && test -f "$am_depcomp"; then
- # We make a subdir and do the tests there. Otherwise we can end up
- # making bogus files that we don't know about and never remove. For
- # instance it was reported that on HP-UX the gcc test will end up
- # making a dummy file named `D' -- because `-MD' means `put the output
- # in D'.
- mkdir conftest.dir
- # Copy depcomp to subdir because otherwise we won't find it if we're
- # using a relative directory.
- cp "$am_depcomp" conftest.dir
- cd conftest.dir
- am_cv_$1_dependencies_compiler_type=none
- if test "$am_compiler_list" = ""; then
- am_compiler_list=`sed -n ['s/^#*\([a-zA-Z0-9]*\))$/\1/p'] < ./depcomp`
- fi
- for depmode in $am_compiler_list; do
- # We need to recreate these files for each test, as the compiler may
- # overwrite some of them when testing with obscure command lines.
- # This happens at least with the AIX C compiler.
- echo '#include "conftest.h"' > conftest.c
- echo 'int i;' > conftest.h
- echo "${am__include} ${am__quote}conftest.Po${am__quote}" > confmf
- case $depmode in
- nosideeffect)
- # after this tag, mechanisms are not by side-effect, so they'll
- # only be used when explicitly requested
- if test "x$enable_dependency_tracking" = xyes; then
- continue
- else
- break
- fi
- none) break ;;
- esac
- # We check with `-c' and `-o' for the sake of the "dashmstdout"
- # mode. It turns out that the SunPro C++ compiler does not properly
- # handle `-M -o', and we need to detect this.
- if depmode=$depmode \
- source=conftest.c object=conftest.o \
- depfile=conftest.Po tmpdepfile=conftest.TPo \
- $SHELL ./depcomp $depcc -c -o conftest.o conftest.c \
- >/dev/null 2>conftest.err &&
- grep conftest.h conftest.Po > /dev/null 2>&1 &&
- ${MAKE-make} -s -f confmf > /dev/null 2>&1; then
- # icc doesn't choke on unknown options, it will just issue warnings
- # (even with -Werror). So we grep stderr for any message
- # that says an option was ignored.
- if grep 'ignoring option' conftest.err >/dev/null 2>&1; then :; else
- am_cv_$1_dependencies_compiler_type=$depmode
- break
- fi
- fi
- done
- cd ..
- rm -rf conftest.dir
-else
-fi
-AC_SUBST([$1DEPMODE], [depmode=$am_cv_$1_dependencies_compiler_type])
-AM_CONDITIONAL([am__fastdep$1], [
- test "x$enable_dependency_tracking" != xno \
- && test "$am_cv_$1_dependencies_compiler_type" = gcc3])
-# AM_SET_DEPDIR
-# Choose a directory name for dependency files.
-# This macro is AC_REQUIREd in _AM_DEPENDENCIES
-AC_DEFUN([AM_SET_DEPDIR],
-[AC_REQUIRE([AM_SET_LEADING_DOT])dnl
-AC_SUBST([DEPDIR], ["${am__leading_dot}deps"])dnl
-# AM_DEP_TRACK
-AC_DEFUN([AM_DEP_TRACK],
-[AC_ARG_ENABLE(dependency-tracking,
-[ --disable-dependency-tracking Speeds up one-time builds
- --enable-dependency-tracking Do not reject slow dependency extractors])
-if test "x$enable_dependency_tracking" != xno; then
- am_depcomp="$ac_aux_dir/depcomp"
- AMDEPBACKSLASH='\'
-fi
-AM_CONDITIONAL([AMDEP], [test "x$enable_dependency_tracking" != xno])
-AC_SUBST([AMDEPBACKSLASH])
-# Generate code to set up dependency tracking. -*- Autoconf -*-
-# Copyright 1999, 2000, 2001, 2002 Free Software Foundation, Inc.
-# 02111-1307, USA.
-#serial 2
-# _AM_OUTPUT_DEPENDENCY_COMMANDS
-AC_DEFUN([_AM_OUTPUT_DEPENDENCY_COMMANDS],
-[for mf in $CONFIG_FILES; do
- # Strip MF so we end up with the name of the file.
- mf=`echo "$mf" | sed -e 's/:.*$//'`
- # Check whether this is an Automake generated Makefile or not.
- # We used to match only the files named `Makefile.in', but
- # some people rename them; so instead we look at the file content.
- # Grep'ing the first line is not enough: some people post-process
- # each Makefile.in and add a new line on top of each file to say so.
- # So let's grep whole file.
- if grep '^#.*generated by automake' $mf > /dev/null 2>&1; then
- dirpart=`AS_DIRNAME("$mf")`
- else
- continue
- fi
- grep '^DEP_FILES *= *[[^ @%:@]]' < "$mf" > /dev/null || continue
- # Extract the definition of DEP_FILES from the Makefile without
- # running `make'.
- DEPDIR=`sed -n -e '/^DEPDIR = / s///p' < "$mf"`
- test -z "$DEPDIR" && continue
- # When using ansi2knr, U may be empty or an underscore; expand it
- U=`sed -n -e '/^U = / s///p' < "$mf"`
- test -d "$dirpart/$DEPDIR" || mkdir "$dirpart/$DEPDIR"
- # We invoke sed twice because it is the simplest approach to
- # changing $(DEPDIR) to its actual value in the expansion.
- for file in `sed -n -e '
- /^DEP_FILES = .*\\\\$/ {
- s/^DEP_FILES = //
- :loop
- s/\\\\$//
- p
- n
- /\\\\$/ b loop
- p
- /^DEP_FILES = / s/^DEP_FILES = //p' < "$mf" | \
- sed -e 's/\$(DEPDIR)/'"$DEPDIR"'/g' -e 's/\$U/'"$U"'/g'`; do
- # Make sure the directory exists.
- test -f "$dirpart/$file" && continue
- fdir=`AS_DIRNAME(["$file"])`
- AS_MKDIR_P([$dirpart/$fdir])
- # echo "creating $dirpart/$file"
- echo '# dummy' > "$dirpart/$file"
- done
-done
-])# _AM_OUTPUT_DEPENDENCY_COMMANDS
-# AM_OUTPUT_DEPENDENCY_COMMANDS
-# This macro should only be invoked once -- use via AC_REQUIRE.
-# This code is only required when automatic dependency tracking
-# is enabled. FIXME. This creates each `.P' file that we will
-# need in order to bootstrap the dependency handling code.
-AC_DEFUN([AM_OUTPUT_DEPENDENCY_COMMANDS],
-[AC_CONFIG_COMMANDS([depfiles],
- [test x"$AMDEP_TRUE" != x"" || _AM_OUTPUT_DEPENDENCY_COMMANDS],
- [AMDEP_TRUE="$AMDEP_TRUE" ac_aux_dir="$ac_aux_dir"])
-# Check to see how 'make' treats includes. -*- Autoconf -*-
-# Copyright (C) 2001, 2002, 2003 Free Software Foundation, Inc.
-# 02111-1307, USA.
-# serial 2
-# AM_MAKE_INCLUDE()
-# Check to see how make treats includes.
-AC_DEFUN([AM_MAKE_INCLUDE],
-[am_make=${MAKE-make}
-cat > confinc << 'END'
-am__doit:
- @echo done
-.PHONY: am__doit
-END
-# If we don't find an include directive, just comment out the code.
-AC_MSG_CHECKING([for style of include used by $am_make])
-am__include="#"
-am__quote=
-_am_result=none
-# First try GNU make style include.
-echo "include confinc" > confmf
-# We grep out `Entering directory' and `Leaving directory'
-# messages which can occur if `w' ends up in MAKEFLAGS.
-# In particular we don't look at `^make:' because GNU make might
-# be invoked under some other name (usually "gmake"), in which
-# case it prints its new name instead of `make'.
-if test "`$am_make -s -f confmf 2> /dev/null | grep -v 'ing directory'`" = "done"; then
- am__include=include
- am__quote=
- _am_result=GNU
-fi
-# Now try BSD make style include.
-if test "$am__include" = "#"; then
- echo '.include "confinc"' > confmf
- if test "`$am_make -s -f confmf 2> /dev/null`" = "done"; then
- am__include=.include
- am__quote="\""
- _am_result=BSD
- fi
-fi
-AC_SUBST([am__include])
-AC_SUBST([am__quote])
-AC_MSG_RESULT([$_am_result])
-rm -f confinc confmf
-# AM_CONDITIONAL -*- Autoconf -*-
-# Copyright 1997, 2000, 2001 Free Software Foundation, Inc.
-# 02111-1307, USA.
-# serial 5
-AC_PREREQ(2.52)
-# AM_CONDITIONAL(NAME, SHELL-CONDITION)
-# Define a conditional.
-AC_DEFUN([AM_CONDITIONAL],
-[ifelse([$1], [TRUE], [AC_FATAL([$0: invalid condition: $1])],
- [$1], [FALSE], [AC_FATAL([$0: invalid condition: $1])])dnl
-AC_SUBST([$1_TRUE])
-AC_SUBST([$1_FALSE])
-if $2; then
- $1_TRUE=
- $1_FALSE='#'
-else
- $1_TRUE='#'
- $1_FALSE=
-fi
-AC_CONFIG_COMMANDS_PRE(
-[if test -z "${$1_TRUE}" && test -z "${$1_FALSE}"; then
- AC_MSG_ERROR([conditional "$1" was never defined.
-Usually this means the macro was only invoked conditionally.])
-fi])])
-# libtool.m4 - Configure libtool for the host system. -*-Autoconf-*-
-# serial 47 AC_PROG_LIBTOOL
-# AC_PROVIDE_IFELSE(MACRO-NAME, IF-PROVIDED, IF-NOT-PROVIDED)
-# If this macro is not defined by Autoconf, define it here.
-m4_ifdef([AC_PROVIDE_IFELSE],
- [m4_define([AC_PROVIDE_IFELSE],
- [m4_ifdef([AC_PROVIDE_$1],
- [$2], [$3])])])
-# AC_PROG_LIBTOOL
-AC_DEFUN([AC_PROG_LIBTOOL],
-[AC_REQUIRE([_AC_PROG_LIBTOOL])dnl
-dnl If AC_PROG_CXX has already been expanded, run AC_LIBTOOL_CXX
-dnl immediately, otherwise, hook it in at the end of AC_PROG_CXX.
- AC_PROVIDE_IFELSE([AC_PROG_CXX],
- [AC_LIBTOOL_CXX],
- [define([AC_PROG_CXX], defn([AC_PROG_CXX])[AC_LIBTOOL_CXX
-dnl And a similar setup for Fortran 77 support
- AC_PROVIDE_IFELSE([AC_PROG_F77],
- [AC_LIBTOOL_F77],
- [define([AC_PROG_F77], defn([AC_PROG_F77])[AC_LIBTOOL_F77
-dnl Quote A][M_PROG_GCJ so that aclocal doesn't bring it in needlessly.
-dnl If either AC_PROG_GCJ or A][M_PROG_GCJ have already been expanded, run
-dnl AC_LIBTOOL_GCJ immediately, otherwise, hook it in at the end of both.
- AC_PROVIDE_IFELSE([AC_PROG_GCJ],
- [AC_LIBTOOL_GCJ],
- [AC_PROVIDE_IFELSE([A][M_PROG_GCJ],
- [AC_LIBTOOL_GCJ],
- [AC_PROVIDE_IFELSE([LT_AC_PROG_GCJ],
- [AC_LIBTOOL_GCJ],
- [ifdef([AC_PROG_GCJ],
- [define([AC_PROG_GCJ], defn([AC_PROG_GCJ])[AC_LIBTOOL_GCJ])])
- ifdef([A][M_PROG_GCJ],
- [define([A][M_PROG_GCJ], defn([A][M_PROG_GCJ])[AC_LIBTOOL_GCJ])])
- ifdef([LT_AC_PROG_GCJ],
- [define([LT_AC_PROG_GCJ],
- defn([LT_AC_PROG_GCJ])[AC_LIBTOOL_GCJ])])])])
-])])# AC_PROG_LIBTOOL
-# _AC_PROG_LIBTOOL
-AC_DEFUN([_AC_PROG_LIBTOOL],
-[AC_REQUIRE([AC_LIBTOOL_SETUP])dnl
-AC_BEFORE([$0],[AC_LIBTOOL_CXX])dnl
-AC_BEFORE([$0],[AC_LIBTOOL_F77])dnl
-AC_BEFORE([$0],[AC_LIBTOOL_GCJ])dnl
-# This can be used to rebuild libtool when needed
-LIBTOOL_DEPS="$ac_aux_dir/ltmain.sh"
-# Always use our own libtool.
-LIBTOOL='$(SHELL) $(top_builddir)/libtool'
-AC_SUBST(LIBTOOL)dnl
-# Prevent multiple expansion
-define([AC_PROG_LIBTOOL], [])
-])# _AC_PROG_LIBTOOL
-# AC_LIBTOOL_SETUP
-AC_DEFUN([AC_LIBTOOL_SETUP],
-[AC_PREREQ(2.50)dnl
-AC_REQUIRE([AC_ENABLE_SHARED])dnl
-AC_REQUIRE([AC_ENABLE_STATIC])dnl
-AC_REQUIRE([AC_ENABLE_FAST_INSTALL])dnl
-AC_REQUIRE([AC_CANONICAL_HOST])dnl
-AC_REQUIRE([AC_CANONICAL_BUILD])dnl
-AC_REQUIRE([AC_PROG_CC])dnl
-AC_REQUIRE([AC_PROG_LD])dnl
-AC_REQUIRE([AC_PROG_LD_RELOAD_FLAG])dnl
-AC_REQUIRE([AC_PROG_NM])dnl
-AC_REQUIRE([AC_PROG_LN_S])dnl
-AC_REQUIRE([AC_DEPLIBS_CHECK_METHOD])dnl
-# Autoconf 2.13's AC_OBJEXT and AC_EXEEXT macros only works for C compilers!
-AC_REQUIRE([AC_OBJEXT])dnl
-AC_REQUIRE([AC_EXEEXT])dnl
-dnl
-AC_LIBTOOL_SYS_MAX_CMD_LEN
-AC_LIBTOOL_SYS_GLOBAL_SYMBOL_PIPE
-AC_LIBTOOL_OBJDIR
-AC_REQUIRE([_LT_AC_SYS_COMPILER])dnl
-_LT_AC_PROG_ECHO_BACKSLASH
-case $host_os in
-aix3*)
- # AIX sometimes has problems with the GCC collect2 program. For some
- # reason, if we set the COLLECT_NAMES environment variable, the problems
- # vanish in a puff of smoke.
- if test "X${COLLECT_NAMES+set}" != Xset; then
- COLLECT_NAMES=
- export COLLECT_NAMES
- fi
-esac
-# Sed substitution that helps us do robust quoting. It backslashifies
-# metacharacters that are still active within double-quoted strings.
-Xsed='sed -e s/^X//'
-[sed_quote_subst='s/\([\\"\\`$\\\\]\)/\\\1/g']
-# Same as above, but do not quote variable references.
-[double_quote_subst='s/\([\\"\\`\\\\]\)/\\\1/g']
-# Sed substitution to delay expansion of an escaped shell variable in a
-# double_quote_subst'ed string.
-delay_variable_subst='s/\\\\\\\\\\\$/\\\\\\$/g'
-# Sed substitution to avoid accidental globbing in evaled expressions
-no_glob_subst='s/\*/\\\*/g'
-# Constants:
-rm="rm -f"
-# Global variables:
-default_ofile=libtool
-can_build_shared=yes
-# All known linkers require a `.a' archive for static linking (except M$VC,
-# which needs '.lib').
-libext=a
-ltmain="$ac_aux_dir/ltmain.sh"
-ofile="$default_ofile"
-with_gnu_ld="$lt_cv_prog_gnu_ld"
-AC_CHECK_TOOL(AR, ar, false)
-AC_CHECK_TOOL(RANLIB, ranlib, :)
-AC_CHECK_TOOL(STRIP, strip, :)
-old_CC="$CC"
-old_CFLAGS="$CFLAGS"
-# Set sane defaults for various variables
-test -z "$AR" && AR=ar
-test -z "$AR_FLAGS" && AR_FLAGS=cru
-test -z "$AS" && AS=as
-test -z "$CC" && CC=cc
-test -z "$LTCC" && LTCC=$CC
-test -z "$DLLTOOL" && DLLTOOL=dlltool
-test -z "$LD" && LD=ld
-test -z "$LN_S" && LN_S="ln -s"
-test -z "$MAGIC_CMD" && MAGIC_CMD=file
-test -z "$NM" && NM=nm
-test -z "$SED" && SED=sed
-test -z "$OBJDUMP" && OBJDUMP=objdump
-test -z "$RANLIB" && RANLIB=:
-test -z "$STRIP" && STRIP=:
-test -z "$ac_objext" && ac_objext=o
-# Determine commands to create old-style static archives.
-old_archive_cmds='$AR $AR_FLAGS $oldlib$oldobjs$old_deplibs'
-old_postinstall_cmds='chmod 644 $oldlib'
-old_postuninstall_cmds=
-if test -n "$RANLIB"; then
- case $host_os in
- openbsd*)
- old_postinstall_cmds="\$RANLIB -t \$oldlib~$old_postinstall_cmds"
- old_postinstall_cmds="\$RANLIB \$oldlib~$old_postinstall_cmds"
- esac
- old_archive_cmds="$old_archive_cmds~\$RANLIB \$oldlib"
-fi
-# Only perform the check for file, if the check method requires it
-case $deplibs_check_method in
-file_magic*)
- if test "$file_magic_cmd" = '$MAGIC_CMD'; then
- AC_PATH_MAGIC
- fi
-esac
-AC_PROVIDE_IFELSE([AC_LIBTOOL_DLOPEN], enable_dlopen=yes, enable_dlopen=no)
-AC_PROVIDE_IFELSE([AC_LIBTOOL_WIN32_DLL],
-enable_win32_dll=yes, enable_win32_dll=no)
-AC_ARG_ENABLE([libtool-lock],
- [AC_HELP_STRING([--disable-libtool-lock],
- [avoid locking (might break parallel builds)])])
-test "x$enable_libtool_lock" != xno && enable_libtool_lock=yes
-AC_ARG_WITH([pic],
- [AC_HELP_STRING([--with-pic],
- [try to use only PIC/non-PIC objects @<:@default=use both@:>@])],
- [pic_mode="$withval"],
- [pic_mode=default])
-test -z "$pic_mode" && pic_mode=default
-# Use C for the default configuration in the libtool script
-tagname=
-AC_LIBTOOL_LANG_C_CONFIG
-_LT_AC_TAGCONFIG
-])# AC_LIBTOOL_SETUP
-# _LT_AC_SYS_COMPILER
-AC_DEFUN([_LT_AC_SYS_COMPILER],
-[AC_REQUIRE([AC_PROG_CC])dnl
-# If no C compiler was specified, use CC.
-LTCC=${LTCC-"$CC"}
-# Allow CC to be a program name with arguments.
-compiler=$CC
-])# _LT_AC_SYS_COMPILER
-# _LT_AC_SYS_LIBPATH_AIX
-# Links a minimal program and checks the executable
-# for the system default hardcoded library path. In most cases,
-# this is /usr/lib:/lib, but when the MPI compilers are used
-# the location of the communication and MPI libs are included too.
-# If we don't find anything, use the default library path according
-# to the aix ld manual.
-AC_DEFUN([_LT_AC_SYS_LIBPATH_AIX],
-[AC_LINK_IFELSE(AC_LANG_PROGRAM,[
-aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
-# Check for a 64-bit object if we didn't find anything.
-if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
-}'`; fi],[])
-if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
-])# _LT_AC_SYS_LIBPATH_AIX
-# _LT_AC_SHELL_INIT(ARG)
-AC_DEFUN([_LT_AC_SHELL_INIT],
-[ifdef([AC_DIVERSION_NOTICE],
- [AC_DIVERT_PUSH(AC_DIVERSION_NOTICE)],
- [AC_DIVERT_PUSH(NOTICE)])
-$1
-AC_DIVERT_POP
-])# _LT_AC_SHELL_INIT
-# _LT_AC_PROG_ECHO_BACKSLASH
-# Add some code to the start of the generated configure script which
-# will find an echo command which doesn't interpret backslashes.
-AC_DEFUN([_LT_AC_PROG_ECHO_BACKSLASH],
-[_LT_AC_SHELL_INIT([
-# Check that we are running under the correct shell.
-SHELL=${CONFIG_SHELL-/bin/sh}
-case X$ECHO in
-X*--fallback-echo)
- # Remove one level of quotation (which was required for Make).
- ECHO=`echo "$ECHO" | sed 's,\\\\\[$]\\[$]0,'[$]0','`
-esac
-echo=${ECHO-echo}
-if test "X[$]1" = X--no-reexec; then
- # Discard the --no-reexec flag, and continue.
- shift
-elif test "X[$]1" = X--fallback-echo; then
- # Avoid inline document here, it may be left over
-elif test "X`($echo '\t') 2>/dev/null`" = 'X\t' ; then
- # Yippee, $echo works!
-else
- # Restart under the correct shell.
- exec $SHELL "[$]0" --no-reexec ${1+"[$]@"}
-fi
-if test "X[$]1" = X--fallback-echo; then
- # used as fallback echo
- shift
- cat <<EOF
-EOF
- exit 0
-fi
-# The HP-UX ksh and POSIX shell print the target directory to stdout
-# if CDPATH is set.
-if test "X${CDPATH+set}" = Xset; then CDPATH=:; export CDPATH; fi
-if test -z "$ECHO"; then
-if test "X${echo_test_string+set}" != Xset; then
-# find a string as large as possible, as long as the shell can cope with it
- for cmd in 'sed 50q "[$]0"' 'sed 20q "[$]0"' 'sed 10q "[$]0"' 'sed 2q "[$]0"' 'echo test'; do
- # expected sizes: less than 2Kb, 1Kb, 512 bytes, 16 bytes, ...
- if (echo_test_string="`eval $cmd`") 2>/dev/null &&
- echo_test_string="`eval $cmd`" &&
- (test "X$echo_test_string" = "X$echo_test_string") 2>/dev/null
- then
- break
- fi
- done
-fi
-if test "X`($echo '\t') 2>/dev/null`" = 'X\t' &&
- echo_testing_string=`($echo "$echo_test_string") 2>/dev/null` &&
- test "X$echo_testing_string" = "X$echo_test_string"; then
-else
- # The Solaris, AIX, and Digital Unix default echo programs unquote
- # backslashes. This makes it impossible to quote backslashes using
- # echo "$something" | sed 's/\\/\\\\/g'
- # So, first we look for a working echo in the user's PATH.
- lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
- for dir in $PATH /usr/ucb; do
- IFS="$lt_save_ifs"
- if (test -f $dir/echo || test -f $dir/echo$ac_exeext) &&
- test "X`($dir/echo '\t') 2>/dev/null`" = 'X\t' &&
- echo_testing_string=`($dir/echo "$echo_test_string") 2>/dev/null` &&
- echo="$dir/echo"
- break
- fi
- done
- if test "X$echo" = Xecho; then
- # We didn't find a better echo, so look for alternatives.
- if test "X`(print -r '\t') 2>/dev/null`" = 'X\t' &&
- echo_testing_string=`(print -r "$echo_test_string") 2>/dev/null` &&
- # This shell has a builtin print -r that does the trick.
- echo='print -r'
- elif (test -f /bin/ksh || test -f /bin/ksh$ac_exeext) &&
- test "X$CONFIG_SHELL" != X/bin/ksh; then
- # If we have ksh, try running configure again with it.
- ORIGINAL_CONFIG_SHELL=${CONFIG_SHELL-/bin/sh}
- export ORIGINAL_CONFIG_SHELL
- CONFIG_SHELL=/bin/ksh
- export CONFIG_SHELL
- exec $CONFIG_SHELL "[$]0" --no-reexec ${1+"[$]@"}
- else
- # Try using printf.
- echo='printf %s\n'
- if test "X`($echo '\t') 2>/dev/null`" = 'X\t' &&
- # Cool, printf works
- elif echo_testing_string=`($ORIGINAL_CONFIG_SHELL "[$]0" --fallback-echo '\t') 2>/dev/null` &&
- test "X$echo_testing_string" = 'X\t' &&
- echo_testing_string=`($ORIGINAL_CONFIG_SHELL "[$]0" --fallback-echo "$echo_test_string") 2>/dev/null` &&
- CONFIG_SHELL=$ORIGINAL_CONFIG_SHELL
- SHELL="$CONFIG_SHELL"
- export SHELL
- echo="$CONFIG_SHELL [$]0 --fallback-echo"
- elif echo_testing_string=`($CONFIG_SHELL "[$]0" --fallback-echo '\t') 2>/dev/null` &&
- echo_testing_string=`($CONFIG_SHELL "[$]0" --fallback-echo "$echo_test_string") 2>/dev/null` &&
- else
- # maybe with a smaller string...
- prev=:
- for cmd in 'echo test' 'sed 2q "[$]0"' 'sed 10q "[$]0"' 'sed 20q "[$]0"' 'sed 50q "[$]0"'; do
- if (test "X$echo_test_string" = "X`eval $cmd`") 2>/dev/null
- then
- break
- fi
- prev="$cmd"
- done
- if test "$prev" != 'sed 50q "[$]0"'; then
- echo_test_string=`eval $prev`
- export echo_test_string
- exec ${ORIGINAL_CONFIG_SHELL-${CONFIG_SHELL-/bin/sh}} "[$]0" ${1+"[$]@"}
- else
- # Oops. We lost completely, so just stick with echo.
- echo=echo
- fi
- fi
- fi
- fi
-fi
-fi
-# Copy echo and quote the copy suitably for passing to libtool from
-# the Makefile, instead of quoting the original, which is used later.
-ECHO=$echo
-if test "X$ECHO" = "X$CONFIG_SHELL [$]0 --fallback-echo"; then
- ECHO="$CONFIG_SHELL \\\$\[$]0 --fallback-echo"
-fi
-AC_SUBST(ECHO)
-])])# _LT_AC_PROG_ECHO_BACKSLASH
-# _LT_AC_LOCK
-AC_DEFUN([_LT_AC_LOCK],
-[AC_ARG_ENABLE([libtool-lock],
-# Some flags need to be propagated to the compiler or linker for good
-# libtool support.
-case $host in
-ia64-*-hpux*)
- # Find out which ABI we are using.
- echo 'int i;' > conftest.$ac_ext
- if AC_TRY_EVAL(ac_compile); then
- case `/usr/bin/file conftest.$ac_objext` in
- *ELF-32*)
- HPUX_IA64_MODE="32"
- *ELF-64*)
- HPUX_IA64_MODE="64"
- esac
- fi
- rm -rf conftest*
-*-*-irix6*)
- echo '[#]line __oline__ "configure"' > conftest.$ac_ext
- if test "$lt_cv_prog_gnu_ld" = yes; then
- *32-bit*)
- LD="${LD-ld} -melf32bsmip"
- *N32*)
- LD="${LD-ld} -melf32bmipn32"
- *64-bit*)
- LD="${LD-ld} -melf64bmip"
- esac
- else
- *32-bit*)
- LD="${LD-ld} -32"
- *N32*)
- LD="${LD-ld} -n32"
- *64-bit*)
- LD="${LD-ld} -64"
- esac
- fi
- fi
- rm -rf conftest*
-x86_64-*linux*|ppc*-*linux*|powerpc*-*linux*|s390*-*linux*|sparc*-*linux*)
- case "`/usr/bin/file conftest.o`" in
- *32-bit*)
- case $host in
- x86_64-*linux*)
- LD="${LD-ld} -m elf_i386"
- ppc64-*linux*)
- LD="${LD-ld} -m elf32ppclinux"
- s390x-*linux*)
- LD="${LD-ld} -m elf_s390"
- sparc64-*linux*)
- LD="${LD-ld} -m elf32_sparc"
- esac
- *64-bit*)
- case $host in
- x86_64-*linux*)
- LD="${LD-ld} -m elf_x86_64"
- ppc*-*linux*|powerpc*-*linux*)
- LD="${LD-ld} -m elf64ppc"
- s390*-*linux*)
- LD="${LD-ld} -m elf64_s390"
- sparc*-*linux*)
- LD="${LD-ld} -m elf64_sparc"
- esac
- esac
- fi
- rm -rf conftest*
-*-*-sco3.2v5*)
- # On SCO OpenServer 5, we need -belf to get full-featured binaries.
- SAVE_CFLAGS="$CFLAGS"
- CFLAGS="$CFLAGS -belf"
- AC_CACHE_CHECK([whether the C compiler needs -belf], lt_cv_cc_needs_belf,
- [AC_LANG_PUSH(C)
- AC_TRY_LINK([],[],[lt_cv_cc_needs_belf=yes],[lt_cv_cc_needs_belf=no])
- AC_LANG_POP])
- if test x"$lt_cv_cc_needs_belf" != x"yes"; then
- # this is probably gcc 2.8.0, egcs 1.0 or newer; no need for -belf
- CFLAGS="$SAVE_CFLAGS"
- fi
-[*-*-cygwin* | *-*-mingw* | *-*-pw32*)
- AC_CHECK_TOOL(DLLTOOL, dlltool, false)
- AC_CHECK_TOOL(AS, as, false)
- AC_CHECK_TOOL(OBJDUMP, objdump, false)
-esac
-need_locks="$enable_libtool_lock"
-])# _LT_AC_LOCK
-# AC_LIBTOOL_COMPILER_OPTION(MESSAGE, VARIABLE-NAME, FLAGS,
-# [OUTPUT-FILE], [ACTION-SUCCESS], [ACTION-FAILURE])
-# Check whether the given compiler option works
-AC_DEFUN([AC_LIBTOOL_COMPILER_OPTION],
-[AC_CACHE_CHECK([$1], [$2],
- [$2=no
- ifelse([$4], , [ac_outfile=conftest.$ac_objext], [ac_outfile=$4])
- printf "$lt_simple_compile_test_code" > conftest.$ac_ext
- lt_compiler_flag="$3"
- # Insert the option either (1) after the last *FLAGS variable, or
- # (2) before a word containing "conftest.", or (3) at the end.
- # Note that $ac_compile itself does not contain backslashes and begins
- # with a dollar sign (not a hyphen), so the echo should work correctly.
- # The option is referenced via a variable to avoid confusing sed.
- lt_compile=`echo "$ac_compile" | $SED \
- -e 's:.*FLAGS}? :&$lt_compiler_flag :; t' \
- -e 's: [[^ ]]*conftest\.: $lt_compiler_flag&:; t' \
- -e 's:$: $lt_compiler_flag:'`
- (eval echo "\"\$as_me:__oline__: $lt_compile\"" >&AS_MESSAGE_LOG_FD)
- (eval "$lt_compile" 2>conftest.err)
- ac_status=$?
- cat conftest.err >&AS_MESSAGE_LOG_FD
- echo "$as_me:__oline__: \$? = $ac_status" >&AS_MESSAGE_LOG_FD
- if (exit $ac_status) && test -s "$ac_outfile"; then
- # The compiler can only warn and ignore the option if not recognized
- # So say no if there are warnings
- if test ! -s conftest.err; then
- $2=yes
- fi
- fi
- $rm conftest*
-if test x"[$]$2" = xyes; then
- ifelse([$5], , :, [$5])
-else
- ifelse([$6], , :, [$6])
-fi
-])# AC_LIBTOOL_COMPILER_OPTION
-# AC_LIBTOOL_LINKER_OPTION(MESSAGE, VARIABLE-NAME, FLAGS,
-# [ACTION-SUCCESS], [ACTION-FAILURE])
-AC_DEFUN([AC_LIBTOOL_LINKER_OPTION],
- [$2=no
- save_LDFLAGS="$LDFLAGS"
- LDFLAGS="$LDFLAGS $3"
- printf "$lt_simple_link_test_code" > conftest.$ac_ext
- if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
- if test -s conftest.err; then
- # Append any errors to the config.log.
- cat conftest.err 1>&AS_MESSAGE_LOG_FD
- else
- $2=yes
- fi
- fi
- $rm conftest*
- LDFLAGS="$save_LDFLAGS"
- ifelse([$4], , :, [$4])
-else
-fi
-])# AC_LIBTOOL_LINKER_OPTION
-# AC_LIBTOOL_SYS_MAX_CMD_LEN
-AC_DEFUN([AC_LIBTOOL_SYS_MAX_CMD_LEN],
-[# find the maximum length of command line arguments
-AC_MSG_CHECKING([the maximum length of command line arguments])
-AC_CACHE_VAL([lt_cv_sys_max_cmd_len], [dnl
- i=0
- testring="ABCD"
- case $build_os in
- msdosdjgpp*)
- # On DJGPP, this test can blow up pretty badly due to problems in libc
- # (any single argument exceeding 2000 bytes causes a buffer overrun
- # during glob expansion). Even if it were fixed, the result of this
- # check would be larger than it should be.
- lt_cv_sys_max_cmd_len=12288; # 12K is about right
- gnu*)
- # Under GNU Hurd, this test is not required because there is
- # no limit to the length of command line arguments.
- # Libtool will interpret -1 as no limit whatsoever
- lt_cv_sys_max_cmd_len=-1;
- cygwin* | mingw*)
- # On Win9x/ME, this test blows up -- it succeeds, but takes
- # about 5 minutes as the teststring grows exponentially.
- # Worse, since 9x/ME are not pre-emptively multitasking,
- # you end up with a "frozen" computer, even though with patience
- # the test eventually succeeds (with a max line length of 256k).
- # Instead, let's just punt: use the minimum linelength reported by
- # all of the supported platforms: 8192 (on NT/2K/XP).
- lt_cv_sys_max_cmd_len=8192;
- # If test is not a shell built-in, we'll probably end up computing a
- # maximum length that is only half of the actual maximum length, but
- # we can't tell.
- while (test "X"`$CONFIG_SHELL [$]0 --fallback-echo "X$testring" 2>/dev/null` \
- = "XX$testring") >/dev/null 2>&1 &&
- new_result=`expr "X$testring" : ".*" 2>&1` &&
- lt_cv_sys_max_cmd_len=$new_result &&
- test $i != 17 # 1/2 MB should be enough
- do
- i=`expr $i + 1`
- testring=$testring$testring
- done
- testring=
- # Add a significant safety factor because C++ compilers can tack on massive
- # amounts of additional arguments before passing them to the linker.
- # It appears as though 1/2 is a usable value.
- lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \/ 2`
- esac
-if test -n $lt_cv_sys_max_cmd_len ; then
- AC_MSG_RESULT($lt_cv_sys_max_cmd_len)
-else
- AC_MSG_RESULT(none)
-fi
-])# AC_LIBTOOL_SYS_MAX_CMD_LEN
-# _LT_AC_CHECK_DLFCN
-AC_DEFUN([_LT_AC_CHECK_DLFCN],
-[AC_CHECK_HEADERS(dlfcn.h)dnl
-])# _LT_AC_CHECK_DLFCN
-# _LT_AC_TRY_DLOPEN_SELF (ACTION-IF-TRUE, ACTION-IF-TRUE-W-USCORE,
-# ACTION-IF-FALSE, ACTION-IF-CROSS-COMPILING)
-AC_DEFUN([_LT_AC_TRY_DLOPEN_SELF],
-[AC_REQUIRE([_LT_AC_CHECK_DLFCN])dnl
-if test "$cross_compiling" = yes; then :
- [$4]
-else
- lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
- lt_status=$lt_dlunknown
- cat > conftest.$ac_ext <<EOF
-[#line __oline__ "configure"
-#include "confdefs.h"
-#if HAVE_DLFCN_H
-#include <dlfcn.h>
-#endif
-#include <stdio.h>
-#ifdef RTLD_GLOBAL
-# define LT_DLGLOBAL RTLD_GLOBAL
-#else
-# ifdef DL_GLOBAL
-# define LT_DLGLOBAL DL_GLOBAL
-# else
-# define LT_DLGLOBAL 0
-# endif
-#endif
-/* We may have to define LT_DLLAZY_OR_NOW in the command line if we
- find out it does not work in some platform. */
-#ifndef LT_DLLAZY_OR_NOW
-# ifdef RTLD_LAZY
-# define LT_DLLAZY_OR_NOW RTLD_LAZY
-# else
-# ifdef DL_LAZY
-# define LT_DLLAZY_OR_NOW DL_LAZY
-# else
-# ifdef RTLD_NOW
-# define LT_DLLAZY_OR_NOW RTLD_NOW
-# else
-# ifdef DL_NOW
-# define LT_DLLAZY_OR_NOW DL_NOW
-# else
-# define LT_DLLAZY_OR_NOW 0
-# endif
-# endif
-# endif
-# endif
-#endif
-#ifdef __cplusplus
-extern "C" void exit (int);
-#endif
-void fnord() { int i=42;}
-int main ()
- void *self = dlopen (0, LT_DLGLOBAL|LT_DLLAZY_OR_NOW);
- int status = $lt_dlunknown;
- if (self)
- if (dlsym (self,"fnord")) status = $lt_dlno_uscore;
- else if (dlsym( self,"_fnord")) status = $lt_dlneed_uscore;
- /* dlclose (self); */
- exit (status);
-EOF
- if AC_TRY_EVAL(ac_link) && test -s conftest${ac_exeext} 2>/dev/null; then
- (./conftest; exit; ) 2>/dev/null
- lt_status=$?
- case x$lt_status in
- x$lt_dlno_uscore) $1 ;;
- x$lt_dlneed_uscore) $2 ;;
- x$lt_unknown|x*) $3 ;;
- esac
- else :
- # compilation failed
- $3
- fi
-fi
-rm -fr conftest*
-])# _LT_AC_TRY_DLOPEN_SELF
-# AC_LIBTOOL_DLOPEN_SELF
-AC_DEFUN([AC_LIBTOOL_DLOPEN_SELF],
-if test "x$enable_dlopen" != xyes; then
- enable_dlopen=unknown
- enable_dlopen_self=unknown
- enable_dlopen_self_static=unknown
-else
- lt_cv_dlopen=no
- lt_cv_dlopen_libs=
- case $host_os in
- beos*)
- lt_cv_dlopen="load_add_on"
- lt_cv_dlopen_self=yes
- mingw* | pw32*)
- lt_cv_dlopen="LoadLibrary"
- cygwin*)
- lt_cv_dlopen="dlopen"
- darwin*)
- # if libdl is installed we need to link against it
- AC_CHECK_LIB([dl], [dlopen],
- [lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-ldl"],[
- lt_cv_dlopen="dyld"
- AC_CHECK_FUNC([shl_load],
- [lt_cv_dlopen="shl_load"],
- [AC_CHECK_LIB([dld], [shl_load],
- [lt_cv_dlopen="shl_load" lt_cv_dlopen_libs="-dld"],
- [AC_CHECK_FUNC([dlopen],
- [lt_cv_dlopen="dlopen"],
- [AC_CHECK_LIB([dl], [dlopen],
- [AC_CHECK_LIB([svld], [dlopen],
- [lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-lsvld"],
- [AC_CHECK_LIB([dld], [dld_link],
- [lt_cv_dlopen="dld_link" lt_cv_dlopen_libs="-dld"])
- esac
- if test "x$lt_cv_dlopen" != xno; then
- enable_dlopen=yes
- else
- enable_dlopen=no
- fi
- case $lt_cv_dlopen in
- dlopen)
- save_CPPFLAGS="$CPPFLAGS"
- test "x$ac_cv_header_dlfcn_h" = xyes && CPPFLAGS="$CPPFLAGS -DHAVE_DLFCN_H"
- eval LDFLAGS=\"\$LDFLAGS $export_dynamic_flag_spec\"
- save_LIBS="$LIBS"
- LIBS="$lt_cv_dlopen_libs $LIBS"
- AC_CACHE_CHECK([whether a program can dlopen itself],
- lt_cv_dlopen_self, [dnl
- _LT_AC_TRY_DLOPEN_SELF(
- lt_cv_dlopen_self=yes, lt_cv_dlopen_self=yes,
- lt_cv_dlopen_self=no, lt_cv_dlopen_self=cross)
- if test "x$lt_cv_dlopen_self" = xyes; then
- LDFLAGS="$LDFLAGS $link_static_flag"
- AC_CACHE_CHECK([whether a statically linked program can dlopen itself],
- lt_cv_dlopen_self_static, [dnl
- lt_cv_dlopen_self_static=yes, lt_cv_dlopen_self_static=yes,
- lt_cv_dlopen_self_static=no, lt_cv_dlopen_self_static=cross)
- fi
- CPPFLAGS="$save_CPPFLAGS"
- LIBS="$save_LIBS"
- esac
- case $lt_cv_dlopen_self in
- yes|no) enable_dlopen_self=$lt_cv_dlopen_self ;;
- *) enable_dlopen_self=unknown ;;
- esac
- case $lt_cv_dlopen_self_static in
- yes|no) enable_dlopen_self_static=$lt_cv_dlopen_self_static ;;
- *) enable_dlopen_self_static=unknown ;;
- esac
-fi
-])# AC_LIBTOOL_DLOPEN_SELF
-# AC_LIBTOOL_PROG_CC_C_O([TAGNAME])
-# Check to see if options -c and -o are simultaneously supported by compiler
-AC_DEFUN([AC_LIBTOOL_PROG_CC_C_O],
-[AC_REQUIRE([_LT_AC_SYS_COMPILER])dnl
-AC_CACHE_CHECK([if $compiler supports -c -o file.$ac_objext],
- [_LT_AC_TAGVAR(lt_cv_prog_compiler_c_o, $1)],
- [_LT_AC_TAGVAR(lt_cv_prog_compiler_c_o, $1)=no
- $rm -r conftest 2>/dev/null
- mkdir conftest
- cd conftest
- mkdir out
- # According to Tom Tromey, Ian Lance Taylor reported there are C compilers
- # that will create temporary files in the current directory regardless of
- # the output directory. Thus, making CWD read-only will cause this test
- # to fail, enabling locking or at least warning the user not to do parallel
- # builds.
- chmod -w .
- lt_compiler_flag="-o out/conftest2.$ac_objext"
- (eval "$lt_compile" 2>out/conftest.err)
- ac_status=$?
- cat out/conftest.err >&AS_MESSAGE_LOG_FD
- if (exit $ac_status) && test -s out/conftest2.$ac_objext
- then
- if test ! -s out/conftest.err; then
- _LT_AC_TAGVAR(lt_cv_prog_compiler_c_o, $1)=yes
- fi
- fi
- chmod u+w .
- $rm conftest* out/*
- rmdir out
- cd ..
- rmdir conftest
- $rm conftest*
-])# AC_LIBTOOL_PROG_CC_C_O
-# AC_LIBTOOL_SYS_HARD_LINK_LOCKS([TAGNAME])
-# Check to see if we can do hard links to lock some files if needed
-AC_DEFUN([AC_LIBTOOL_SYS_HARD_LINK_LOCKS],
-[AC_REQUIRE([_LT_AC_LOCK])dnl
-hard_links="nottested"
-if test "$_LT_AC_TAGVAR(lt_cv_prog_compiler_c_o, $1)" = no && test "$need_locks" != no; then
- # do not overwrite the value of need_locks provided by the user
- AC_MSG_CHECKING([if we can lock with hard links])
- hard_links=yes
- $rm conftest*
- ln conftest.a conftest.b 2>/dev/null && hard_links=no
- touch conftest.a
- ln conftest.a conftest.b 2>&5 || hard_links=no
- AC_MSG_RESULT([$hard_links])
- if test "$hard_links" = no; then
- AC_MSG_WARN([`$CC' does not support `-c -o', so `make -j' may be unsafe])
- need_locks=warn
- fi
-else
- need_locks=no
-fi
-])# AC_LIBTOOL_SYS_HARD_LINK_LOCKS
-# AC_LIBTOOL_OBJDIR
-AC_DEFUN([AC_LIBTOOL_OBJDIR],
-[AC_CACHE_CHECK([for objdir], [lt_cv_objdir],
-[rm -f .libs 2>/dev/null
-mkdir .libs 2>/dev/null
-if test -d .libs; then
- lt_cv_objdir=.libs
-else
- # MS-DOS does not allow filenames that begin with a dot.
- lt_cv_objdir=_libs
-fi
-rmdir .libs 2>/dev/null])
-objdir=$lt_cv_objdir
-])# AC_LIBTOOL_OBJDIR
-# AC_LIBTOOL_PROG_LD_HARDCODE_LIBPATH([TAGNAME])
-# Check hardcoding attributes.
-AC_DEFUN([AC_LIBTOOL_PROG_LD_HARDCODE_LIBPATH],
-[AC_MSG_CHECKING([how to hardcode library paths into programs])
-_LT_AC_TAGVAR(hardcode_action, $1)=
-if test -n "$_LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)" || \
- test -n "$_LT_AC_TAGVAR(runpath_var $1)" || \
- test "X$_LT_AC_TAGVAR(hardcode_automatic, $1)"="Xyes" ; then
- # We can hardcode non-existant directories.
- if test "$_LT_AC_TAGVAR(hardcode_direct, $1)" != no &&
- # If the only mechanism to avoid hardcoding is shlibpath_var, we
- # have to relink, otherwise we might link with an installed library
- # when we should be linking with a yet-to-be-installed one
- ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, $1)" != no &&
- test "$_LT_AC_TAGVAR(hardcode_minus_L, $1)" != no; then
- # Linking always hardcodes the temporary library directory.
- _LT_AC_TAGVAR(hardcode_action, $1)=relink
- else
- # We can link without hardcoding, and we can hardcode nonexisting dirs.
- _LT_AC_TAGVAR(hardcode_action, $1)=immediate
- fi
-else
- # We cannot hardcode anything, or else we can only hardcode existing
- # directories.
- _LT_AC_TAGVAR(hardcode_action, $1)=unsupported
-fi
-AC_MSG_RESULT([$_LT_AC_TAGVAR(hardcode_action, $1)])
-if test "$_LT_AC_TAGVAR(hardcode_action, $1)" = relink; then
- # Fast installation is not supported
- enable_fast_install=no
-elif test "$shlibpath_overrides_runpath" = yes ||
- test "$enable_shared" = no; then
- # Fast installation is not necessary
- enable_fast_install=needless
-fi
-])# AC_LIBTOOL_PROG_LD_HARDCODE_LIBPATH
-# AC_LIBTOOL_SYS_LIB_STRIP
-AC_DEFUN([AC_LIBTOOL_SYS_LIB_STRIP],
-[striplib=
-old_striplib=
-AC_MSG_CHECKING([whether stripping libraries is possible])
-if test -n "$STRIP" && $STRIP -V 2>&1 | grep "GNU strip" >/dev/null; then
- test -z "$old_striplib" && old_striplib="$STRIP --strip-debug"
- test -z "$striplib" && striplib="$STRIP --strip-unneeded"
- AC_MSG_RESULT([yes])
-else
-# FIXME - insert some real tests, host_os isn't really good enough
- case $host_os in
- darwin*)
- if test -n "$STRIP" ; then
- striplib="$STRIP -x"
- else
- AC_MSG_RESULT([no])
-fi
- esac
-fi
-])# AC_LIBTOOL_SYS_LIB_STRIP
-# AC_LIBTOOL_SYS_DYNAMIC_LINKER
-# PORTME Fill in your ld.so characteristics
-AC_DEFUN([AC_LIBTOOL_SYS_DYNAMIC_LINKER],
-[AC_MSG_CHECKING([dynamic linker characteristics])
-library_names_spec=
-libname_spec='lib$name'
-soname_spec=
-shrext=".so"
-postinstall_cmds=
-postuninstall_cmds=
-finish_cmds=
-finish_eval=
-shlibpath_var=
-shlibpath_overrides_runpath=unknown
-version_type=none
-dynamic_linker="$host_os ld.so"
-sys_lib_dlsearch_path_spec="/lib /usr/lib"
-if test "$GCC" = yes; then
- sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
- if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
- # if the path contains ";" then we assume it to be the separator
- # otherwise default to the standard path separator (i.e. ":") - it is
- # assumed that no part of a normal pathname contains ";" but that should
- # okay in the real world where ";" in dirpaths is itself problematic.
- sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
- else
- sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
- fi
-else
- sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
-fi
-need_lib_prefix=unknown
-hardcode_into_libs=no
-# when you set need_version to no, make sure it does not cause -set_version
-# flags to be left without arguments
-need_version=unknown
-case $host_os in
-aix3*)
- version_type=linux
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
- shlibpath_var=LIBPATH
- # AIX 3 has no versioning support, so we append a major version to the name.
- soname_spec='${libname}${release}${shared_ext}$major'
-aix4* | aix5*)
- need_lib_prefix=no
- need_version=no
- hardcode_into_libs=yes
- if test "$host_cpu" = ia64; then
- # AIX 5 supports IA64
- library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
- shlibpath_var=LD_LIBRARY_PATH
- else
- # With GCC up to 2.95.x, collect2 would create an import file
- # for dependence libraries. The import file would start with
- # the line `#! .'. This would cause the generated library to
- # depend on `.', always an invalid library. This was fixed in
- # development snapshots of GCC prior to 3.0.
- case $host_os in
- aix4 | aix4.[[01]] | aix4.[[01]].*)
- if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
- echo ' yes '
- echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
- else
- can_build_shared=no
- fi
- esac
- # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
- # soname into executable. Probably we can add versioning support to
- # collect2, so additional links can be useful in future.
- if test "$aix_use_runtimelinking" = yes; then
- # If using run time linking (on AIX 4.2 or later) use lib<name>.so
- # instead of lib<name>.a to let people know that these are not
- # typical AIX shared libraries.
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
- else
- # We preserve .a as extension for shared libraries through AIX4.2
- # and later when we are not doing run time linking.
- library_names_spec='${libname}${release}.a $libname.a'
- fi
- fi
-amigaos*)
- library_names_spec='$libname.ixlibrary $libname.a'
- # Create ${libname}_ixlibrary.a entries in /sys/libs.
- finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([[^/]]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "(cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a)"; (cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a) || exit 1; done'
-beos*)
- library_names_spec='${libname}${shared_ext}'
- dynamic_linker="$host_os ld.so"
- shlibpath_var=LIBRARY_PATH
-bsdi4*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
- sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
- sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
- # the default ld.so.conf also contains /usr/contrib/lib and
- # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
- # libtool to hard-code these into programs
-cygwin* | mingw* | pw32*)
- version_type=windows
- shrext=".dll"
- need_version=no
- case $GCC,$host_os in
- yes,cygwin* | yes,mingw* | yes,pw32*)
- library_names_spec='$libname.dll.a'
- # DLL is installed to $(libdir)/../bin by postinstall_cmds
- postinstall_cmds='base_file=`basename \${file}`~
- dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
- dldir=$destdir/`dirname \$dlpath`~
- test -d \$dldir || mkdir -p \$dldir~
- $install_prog $dir/$dlname \$dldir/$dlname'
- postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
- dlpath=$dir/\$dldll~
- $rm \$dlpath'
- shlibpath_overrides_runpath=yes
- case $host_os in
- cygwin*)
- # Cygwin DLLs use 'cyg' prefix rather than 'lib'
- soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[[.]]/-/g'`${versuffix}${shared_ext}'
- sys_lib_search_path_spec="/lib /lib/w32api /usr/lib /usr/local/lib"
- mingw*)
- # MinGW DLLs use traditional 'lib' prefix
- soname_spec='${libname}`echo ${release} | $SED -e 's/[[.]]/-/g'`${versuffix}${shared_ext}'
- if echo "$sys_lib_search_path_spec" | [grep ';[c-zC-Z]:/' >/dev/null]; then
- # It is most probably a Windows format PATH printed by
- # mingw gcc, but we are running on Cygwin. Gcc prints its search
- # path with ; separators, and with drive letters. We can handle the
- # drive letters (cygwin fileutils understands them), so leave them,
- # especially as we might pass files found there to a mingw objdump,
- # which wouldn't understand a cygwinified path. Ahh.
- else
- fi
- pw32*)
- # pw32 DLLs use 'pw' prefix rather than 'lib'
- library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- esac
- library_names_spec='${libname}`echo ${release} | $SED -e 's/[[.]]/-/g'`${versuffix}${shared_ext} $libname.lib'
- esac
- dynamic_linker='Win32 ld.exe'
- # FIXME: first we should search . and the directory the executable is in
- shlibpath_var=PATH
-darwin* | rhapsody*)
- dynamic_linker="$host_os dyld"
- version_type=darwin
- need_version=no
- # FIXME: Relying on posixy $() will cause problems for
- # cross-compilation, but unfortunately the echo tests do not
- # yet detect zsh echo's removal of \ escapes.
- library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
- soname_spec='${libname}${release}${major}$shared_ext'
- shlibpath_var=DYLD_LIBRARY_PATH
- shrext='$(test .$module = .yes && echo .so || echo .dylib)'
- # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
- if $CC -v 2>&1 | grep 'Apple' >/dev/null ; then
- sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
- fi
- sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
-dgux*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
-freebsd1*)
- dynamic_linker=no
-freebsd*)
- objformat=`test -x /usr/bin/objformat && /usr/bin/objformat || echo aout`
- version_type=freebsd-$objformat
- case $version_type in
- freebsd-elf*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
- need_version=no
- freebsd-*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
- need_version=yes
- esac
- case $host_os in
- freebsd2*)
- freebsd3.[01]* | freebsdelf3.[01]*)
- *) # from 3.2 on
- shlibpath_overrides_runpath=no
- esac
-gnu*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
-hpux9* | hpux10* | hpux11*)
- # Give a soname corresponding to the major version so that dld.sl refuses to
- # link against other versions.
- version_type=sunos
- need_version=no
- case "$host_cpu" in
- ia64*)
- shrext='.so'
- dynamic_linker="$host_os dld.so"
- shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
- if test "X$HPUX_IA64_MODE" = X32; then
- sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
- else
- sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
- fi
- sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
- hppa*64*)
- shrext='.sl'
- dynamic_linker="$host_os dld.sl"
- shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
- sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
- shrext='.sl'
- shlibpath_var=SHLIB_PATH
- shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
- esac
- # HP-UX runs *really* slowly unless shared libraries are mode 555.
- postinstall_cmds='chmod 555 $lib'
-irix5* | irix6* | nonstopux*)
- case $host_os in
- nonstopux*) version_type=nonstopux ;;
- else
- version_type=irix
- fi ;;
- esac
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
- case $host_os in
- irix5* | nonstopux*)
- libsuff= shlibsuff=
- case $LD in # libtool.m4 will add one of these switches to LD
- *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
- libsuff= shlibsuff= libmagic=32-bit;;
- *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
- libsuff=32 shlibsuff=N32 libmagic=N32;;
- *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
- libsuff=64 shlibsuff=64 libmagic=64-bit;;
- *) libsuff= shlibsuff= libmagic=never-match;;
- esac
- esac
- shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
- sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
- sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
-# No shared lib support for Linux oldld, aout, or coff.
-linux*oldld* | linux*aout* | linux*coff*)
- dynamic_linker=no
-# This must be Linux ELF.
-linux*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
- # This implies no fast_install, which is unacceptable.
- # Some rework will be needed to allow for fast_install
- # before this can be enabled.
- # We used to test for /lib/ld.so.1 and disable shared libraries on
- # powerpc, because MkLinux only supported shared libraries with the
- # GNU dynamic linker. Since this was broken with cross compilers,
- # most powerpc-linux boxes support dynamic linking these days and
- # people can always --disable-shared, the test was removed, and we
- # assume the GNU/Linux dynamic linker is in use.
- dynamic_linker='GNU/Linux ld.so'
-netbsd*)
- need_version=no
- if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
- dynamic_linker='NetBSD (a.out) ld.so'
- else
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} ${libname}${shared_ext}'
- dynamic_linker='NetBSD ld.elf_so'
- fi
-newsos6)
-nto-qnx)
- need_version=no
-openbsd*)
- need_version=no
- if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- case $host_os in
- openbsd2.[[89]] | openbsd2.[[89]].*)
- esac
- else
- fi
-os2*)
- libname_spec='$name'
- shrext=".dll"
- library_names_spec='$libname${shared_ext} $libname.a'
- dynamic_linker='OS/2 ld.exe'
-osf3* | osf4* | osf5*)
- version_type=osf
- need_version=no
- sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
- sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
-sco3.2v5*)
- version_type=osf
-solaris*)
- need_version=no
- # ldd complains unless libraries are executable
- postinstall_cmds='chmod +x $lib'
-sunos4*)
- finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
- if test "$with_gnu_ld" = yes; then
- fi
- need_version=yes
-sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
- case $host_vendor in
- sni)
- export_dynamic_flag_spec='${wl}-Blargedynsym'
- runpath_var=LD_RUN_PATH
- siemens)
- motorola)
- need_version=no
- sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
- esac
-sysv4*MP*)
- if test -d /usr/nec ;then
- library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
- soname_spec='$libname${shared_ext}.$major'
- fi
-uts4*)
- dynamic_linker=no
-esac
-AC_MSG_RESULT([$dynamic_linker])
-test "$dynamic_linker" = no && can_build_shared=no
-])# AC_LIBTOOL_SYS_DYNAMIC_LINKER
-# _LT_AC_TAGCONFIG
-AC_DEFUN([_LT_AC_TAGCONFIG],
-[AC_ARG_WITH([tags],
- [AC_HELP_STRING([--with-tags@<:@=TAGS@:>@],
- [include additional configurations @<:@automatic@:>@])],
- [tagnames="$withval"])
-if test -f "$ltmain" && test -n "$tagnames"; then
- if test ! -f "${ofile}"; then
- AC_MSG_WARN([output file `$ofile' does not exist])
- fi
- if test -z "$LTCC"; then
- eval "`$SHELL ${ofile} --config | grep '^LTCC='`"
- AC_MSG_WARN([output file `$ofile' does not look like a libtool script])
- else
- AC_MSG_WARN([using `LTCC=$LTCC', extracted from `$ofile'])
- fi
- fi
- # Extract list of available tagged configurations in $ofile.
- # Note that this assumes the entire list is on one line.
- available_tags=`grep "^available_tags=" "${ofile}" | $SED -e 's/available_tags=\(.*$\)/\1/' -e 's/\"//g'`
- lt_save_ifs="$IFS"; IFS="${IFS}$PATH_SEPARATOR,"
- for tagname in $tagnames; do
- # Check whether tagname contains only valid characters
- case `$echo "X$tagname" | $Xsed -e 's:[[-_ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz1234567890,/]]::g'` in
- *) AC_MSG_ERROR([invalid tag name: $tagname])
- esac
- if grep "^# ### BEGIN LIBTOOL TAG CONFIG: $tagname$" < "${ofile}" > /dev/null
- then
- AC_MSG_ERROR([tag name \"$tagname\" already exists])
- fi
- # Update the list of available tags.
- if test -n "$tagname"; then
- echo appending configuration tag \"$tagname\" to $ofile
- case $tagname in
- CXX)
- if test -n "$CXX" && test "X$CXX" != "Xno"; then
- AC_LIBTOOL_LANG_CXX_CONFIG
- else
- tagname=""
- fi
- F77)
- if test -n "$F77" && test "X$F77" != "Xno"; then
- AC_LIBTOOL_LANG_F77_CONFIG
- else
- tagname=""
- fi
- GCJ)
- if test -n "$GCJ" && test "X$GCJ" != "Xno"; then
- AC_LIBTOOL_LANG_GCJ_CONFIG
- else
- tagname=""
- fi
- RC)
- AC_LIBTOOL_LANG_RC_CONFIG
- AC_MSG_ERROR([Unsupported tag name: $tagname])
- esac
- # Append the new tag name to the list of available tags.
- if test -n "$tagname" ; then
- available_tags="$available_tags $tagname"
- fi
- fi
- done
- # Now substitute the updated list of available tags.
- if eval "sed -e 's/^available_tags=.*\$/available_tags=\"$available_tags\"/' \"$ofile\" > \"${ofile}T\""; then
- mv "${ofile}T" "$ofile"
- chmod +x "$ofile"
- else
- rm -f "${ofile}T"
- AC_MSG_ERROR([unable to update list of available tagged configurations.])
- fi
-fi
-])# _LT_AC_TAGCONFIG
-# enable checks for dlopen support
-AC_DEFUN([AC_LIBTOOL_DLOPEN],
- [AC_BEFORE([$0],[AC_LIBTOOL_SETUP])
-# AC_LIBTOOL_WIN32_DLL
-# declare package support for building win32 dll's
-AC_DEFUN([AC_LIBTOOL_WIN32_DLL],
-[AC_BEFORE([$0], [AC_LIBTOOL_SETUP])
-])# AC_LIBTOOL_WIN32_DLL
-# AC_ENABLE_SHARED([DEFAULT])
-# implement the --enable-shared flag
-# DEFAULT is either `yes' or `no'. If omitted, it defaults to `yes'.
-AC_DEFUN([AC_ENABLE_SHARED],
-[define([AC_ENABLE_SHARED_DEFAULT], ifelse($1, no, no, yes))dnl
-AC_ARG_ENABLE([shared],
- [AC_HELP_STRING([--enable-shared@<:@=PKGS@:>@],
- [build shared libraries @<:@default=]AC_ENABLE_SHARED_DEFAULT[@:>@])],
- [p=${PACKAGE-default}
- case $enableval in
- yes) enable_shared=yes ;;
- no) enable_shared=no ;;
- enable_shared=no
- # Look at the argument we got. We use all the common list separators.
- for pkg in $enableval; do
- if test "X$pkg" = "X$p"; then
- enable_shared=yes
- fi
- done
- esac],
- [enable_shared=]AC_ENABLE_SHARED_DEFAULT)
-])# AC_ENABLE_SHARED
-# AC_DISABLE_SHARED
-#- set the default shared flag to --disable-shared
-AC_DEFUN([AC_DISABLE_SHARED],
-[AC_BEFORE([$0],[AC_LIBTOOL_SETUP])dnl
-AC_ENABLE_SHARED(no)
-])# AC_DISABLE_SHARED
-# AC_ENABLE_STATIC([DEFAULT])
-# implement the --enable-static flag
-AC_DEFUN([AC_ENABLE_STATIC],
-[define([AC_ENABLE_STATIC_DEFAULT], ifelse($1, no, no, yes))dnl
-AC_ARG_ENABLE([static],
- [AC_HELP_STRING([--enable-static@<:@=PKGS@:>@],
- [build static libraries @<:@default=]AC_ENABLE_STATIC_DEFAULT[@:>@])],
- yes) enable_static=yes ;;
- no) enable_static=no ;;
- enable_static=no
- enable_static=yes
- fi
- done
- esac],
- [enable_static=]AC_ENABLE_STATIC_DEFAULT)
-])# AC_ENABLE_STATIC
-# AC_DISABLE_STATIC
-# set the default static flag to --disable-static
-AC_DEFUN([AC_DISABLE_STATIC],
-AC_ENABLE_STATIC(no)
-])# AC_DISABLE_STATIC
-# AC_ENABLE_FAST_INSTALL([DEFAULT])
-# implement the --enable-fast-install flag
-AC_DEFUN([AC_ENABLE_FAST_INSTALL],
-[define([AC_ENABLE_FAST_INSTALL_DEFAULT], ifelse($1, no, no, yes))dnl
-AC_ARG_ENABLE([fast-install],
- [AC_HELP_STRING([--enable-fast-install@<:@=PKGS@:>@],
- [optimize for fast installation @<:@default=]AC_ENABLE_FAST_INSTALL_DEFAULT[@:>@])],
- yes) enable_fast_install=yes ;;
- no) enable_fast_install=no ;;
- enable_fast_install=yes
- fi
- done
- esac],
- [enable_fast_install=]AC_ENABLE_FAST_INSTALL_DEFAULT)
-])# AC_ENABLE_FAST_INSTALL
-# AC_DISABLE_FAST_INSTALL
-# set the default to --disable-fast-install
-AC_DEFUN([AC_DISABLE_FAST_INSTALL],
-AC_ENABLE_FAST_INSTALL(no)
-])# AC_DISABLE_FAST_INSTALL
-# AC_LIBTOOL_PICMODE([MODE])
-# implement the --with-pic flag
-# MODE is either `yes' or `no'. If omitted, it defaults to `both'.
-AC_DEFUN([AC_LIBTOOL_PICMODE],
-pic_mode=ifelse($#,1,$1,default)
-])# AC_LIBTOOL_PICMODE
-# AC_PROG_EGREP
-# This is predefined starting with Autoconf 2.54, so this conditional
-# definition can be removed once we require Autoconf 2.54 or later.
-m4_ifndef([AC_PROG_EGREP], [AC_DEFUN([AC_PROG_EGREP],
-[AC_CACHE_CHECK([for egrep], [ac_cv_prog_egrep],
- [if echo a | (grep -E '(a|b)') >/dev/null 2>&1
- then ac_cv_prog_egrep='grep -E'
- else ac_cv_prog_egrep='egrep'
- fi])
- EGREP=$ac_cv_prog_egrep
- AC_SUBST([EGREP])
-# AC_PATH_TOOL_PREFIX
-# find a file program which can recognise shared library
-AC_DEFUN([AC_PATH_TOOL_PREFIX],
-[AC_REQUIRE([AC_PROG_EGREP])dnl
-AC_MSG_CHECKING([for $1])
-AC_CACHE_VAL(lt_cv_path_MAGIC_CMD,
-[case $MAGIC_CMD in
- lt_cv_path_MAGIC_CMD="$MAGIC_CMD" # Let the user override the test with a path.
- lt_save_MAGIC_CMD="$MAGIC_CMD"
-dnl $ac_dummy forces splitting on constant user-supplied paths.
-dnl POSIX.2 word splitting is done only on the output of word expansions,
-dnl not every word. This closes a longstanding sh security hole.
- ac_dummy="ifelse([$2], , $PATH, [$2])"
- for ac_dir in $ac_dummy; do
- test -z "$ac_dir" && ac_dir=.
- if test -f $ac_dir/$1; then
- lt_cv_path_MAGIC_CMD="$ac_dir/$1"
- if test -n "$file_magic_test_file"; then
- case $deplibs_check_method in
- "file_magic "*)
- file_magic_regex="`expr \"$deplibs_check_method\" : \"file_magic \(.*\)\"`"
- MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
- if eval $file_magic_cmd \$file_magic_test_file 2> /dev/null |
- $EGREP "$file_magic_regex" > /dev/null; then
- else
- cat <<EOF 1>&2
-*** Warning: the command libtool uses to detect shared libraries,
-*** $file_magic_cmd, produces output that libtool cannot recognize.
-*** The result is that libtool may fail to recognize shared libraries
-*** as such. This will affect the creation of libtool libraries that
-*** depend on shared libraries, but programs linked with such libtool
-*** libraries will work regardless of this problem. Nevertheless, you
-*** may want to report the problem to your system manager and/or to
-*** bug-libtool at gnu.org
-EOF
- fi ;;
- esac
- fi
- break
- fi
- done
- MAGIC_CMD="$lt_save_MAGIC_CMD"
-esac])
-MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
-if test -n "$MAGIC_CMD"; then
- AC_MSG_RESULT($MAGIC_CMD)
-else
- AC_MSG_RESULT(no)
-fi
-])# AC_PATH_TOOL_PREFIX
-# AC_PATH_MAGIC
-# find a file program which can recognise a shared library
-AC_DEFUN([AC_PATH_MAGIC],
-[AC_PATH_TOOL_PREFIX(${ac_tool_prefix}file, /usr/bin$PATH_SEPARATOR$PATH)
-if test -z "$lt_cv_path_MAGIC_CMD"; then
- if test -n "$ac_tool_prefix"; then
- AC_PATH_TOOL_PREFIX(file, /usr/bin$PATH_SEPARATOR$PATH)
- else
- MAGIC_CMD=:
- fi
-fi
-])# AC_PATH_MAGIC
-# AC_PROG_LD
-# find the path to the GNU or non-GNU linker
-AC_DEFUN([AC_PROG_LD],
-[AC_ARG_WITH([gnu-ld],
- [AC_HELP_STRING([--with-gnu-ld],
- [assume the C compiler uses GNU ld @<:@default=no@:>@])],
- [test "$withval" = no || with_gnu_ld=yes],
- [with_gnu_ld=no])
-AC_REQUIRE([LT_AC_PROG_SED])dnl
-ac_prog=ld
- # Check if gcc -print-prog-name=ld gives a path.
- AC_MSG_CHECKING([for ld used by $CC])
- case $host in
- *-*-mingw*)
- # gcc leaves a trailing carriage return which upsets mingw
- ac_prog=`($CC -print-prog-name=ld) 2>&5 | tr -d '\015'` ;;
- ac_prog=`($CC -print-prog-name=ld) 2>&5` ;;
- esac
- case $ac_prog in
- # Accept absolute paths.
- re_direlt='/[[^/]][[^/]]*/\.\./'
- # Canonicalize the path of ld
- ac_prog=`echo $ac_prog| $SED 's%\\\\%/%g'`
- while echo $ac_prog | grep "$re_direlt" > /dev/null 2>&1; do
- ac_prog=`echo $ac_prog| $SED "s%$re_direlt%/%"`
- done
- test -z "$LD" && LD="$ac_prog"
- # If it fails, then pretend we aren't using GCC.
- ac_prog=ld
- # If it is relative, then search for the first ld in PATH.
- with_gnu_ld=unknown
- esac
-elif test "$with_gnu_ld" = yes; then
- AC_MSG_CHECKING([for GNU ld])
-else
- AC_MSG_CHECKING([for non-GNU ld])
-fi
-AC_CACHE_VAL(lt_cv_path_LD,
-[if test -z "$LD"; then
- for ac_dir in $PATH; do
- if test -f "$ac_dir/$ac_prog" || test -f "$ac_dir/$ac_prog$ac_exeext"; then
- lt_cv_path_LD="$ac_dir/$ac_prog"
- # Check to see if the program is GNU ld. I'd rather use --version,
- # but apparently some GNU ld's only accept -v.
- # Break only if it was the GNU/non-GNU ld that we prefer.
- case `"$lt_cv_path_LD" -v 2>&1 </dev/null` in
- *GNU* | *'with BFD'*)
- test "$with_gnu_ld" != no && break
- test "$with_gnu_ld" != yes && break
- esac
- fi
- done
-else
- lt_cv_path_LD="$LD" # Let the user override the test with a path.
-fi])
-LD="$lt_cv_path_LD"
-if test -n "$LD"; then
- AC_MSG_RESULT($LD)
-else
- AC_MSG_RESULT(no)
-fi
-test -z "$LD" && AC_MSG_ERROR([no acceptable ld found in \$PATH])
-AC_PROG_LD_GNU
-])# AC_PROG_LD
-# AC_PROG_LD_GNU
-AC_DEFUN([AC_PROG_LD_GNU],
-AC_CACHE_CHECK([if the linker ($LD) is GNU ld], lt_cv_prog_gnu_ld,
-[# I'd rather use --version here, but apparently some GNU ld's only accept -v.
-case `"$LD" -v 2>&1 </dev/null` in
-*GNU* | *'with BFD'*)
- lt_cv_prog_gnu_ld=yes
- lt_cv_prog_gnu_ld=no
-esac])
-with_gnu_ld=$lt_cv_prog_gnu_ld
-])# AC_PROG_LD_GNU
-# AC_PROG_LD_RELOAD_FLAG
-# find reload flag for linker
-# -- PORTME Some linkers may need a different reload flag.
-AC_DEFUN([AC_PROG_LD_RELOAD_FLAG],
-[AC_CACHE_CHECK([for $LD option to reload object files],
- lt_cv_ld_reload_flag,
- [lt_cv_ld_reload_flag='-r'])
-reload_flag=$lt_cv_ld_reload_flag
-case $reload_flag in
-*) reload_flag=" $reload_flag" ;;
-esac
-reload_cmds='$LD$reload_flag -o $output$reload_objs'
-])# AC_PROG_LD_RELOAD_FLAG
-# AC_DEPLIBS_CHECK_METHOD
-# how to check for library dependencies
-# -- PORTME fill in with the dynamic library characteristics
-AC_DEFUN([AC_DEPLIBS_CHECK_METHOD],
-[AC_CACHE_CHECK([how to recognise dependent libraries],
-lt_cv_deplibs_check_method,
-[lt_cv_file_magic_cmd='$MAGIC_CMD'
-lt_cv_file_magic_test_file=
-lt_cv_deplibs_check_method='unknown'
-# Need to set the preceding variable on all platforms that support
-# interlibrary dependencies.
-# 'none' -- dependencies not supported.
-# `unknown' -- same as none, but documents that we really don't know.
-# 'pass_all' -- all dependencies passed with no checks.
-# 'test_compile' -- check by making test program.
-# 'file_magic [[regex]]' -- check by looking for files in library path
-# which responds to the $file_magic_cmd with a given extended regex.
-# If you have `file' or equivalent on your system and you're not sure
-# whether `pass_all' will *always* work, you probably want this one.
-case $host_os in
-aix4* | aix5*)
- lt_cv_deplibs_check_method=pass_all
-beos*)
-bsdi4*)
- lt_cv_deplibs_check_method='file_magic ELF [[0-9]][[0-9]]*-bit [[ML]]SB (shared object|dynamic lib)'
- lt_cv_file_magic_cmd='/usr/bin/file -L'
- lt_cv_file_magic_test_file=/shlib/libc.so
- # win32_libid is a shell function defined in ltmain.sh
- lt_cv_deplibs_check_method='file_magic ^x86 archive import|^x86 DLL'
- lt_cv_file_magic_cmd='win32_libid'
- # this will be overwritten by pass_all, but leave it in just in case
- lt_cv_deplibs_check_method='file_magic Mach-O dynamically linked shared library'
- case "$host_os" in
- rhapsody* | darwin1.[[012]])
- lt_cv_file_magic_test_file=`/System/Library/Frameworks/System.framework/System`
- *) # Darwin 1.3 on
- lt_cv_file_magic_test_file='/usr/lib/libSystem.dylib'
- esac
-freebsd*)
- if echo __ELF__ | $CC -E - | grep __ELF__ > /dev/null; then
- case $host_cpu in
- i*86 )
- # Not sure whether the presence of OpenBSD here was a mistake.
- # Let's accept both of them until this is cleared up.
- lt_cv_deplibs_check_method='file_magic (FreeBSD|OpenBSD)/i[[3-9]]86 (compact )?demand paged shared library'
- lt_cv_file_magic_cmd=/usr/bin/file
- lt_cv_file_magic_test_file=`echo /usr/lib/libc.so.*`
- esac
- else
- fi
-gnu*)
-hpux10.20* | hpux11*)
- ia64*)
- lt_cv_deplibs_check_method='file_magic (s[[0-9]][[0-9]][[0-9]]|ELF-[[0-9]][[0-9]]) shared object file - IA64'
- lt_cv_file_magic_test_file=/usr/lib/hpux32/libc.so
- hppa*64*)
- [lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|ELF-[0-9][0-9]) shared object file - PA-RISC [0-9].[0-9]']
- lt_cv_file_magic_test_file=/usr/lib/pa20_64/libc.sl
- lt_cv_deplibs_check_method='file_magic (s[[0-9]][[0-9]][[0-9]]|PA-RISC[[0-9]].[[0-9]]) shared library'
- lt_cv_file_magic_test_file=/usr/lib/libc.sl
- esac
- case $host_os in
- # this will be overridden with pass_all, but let us keep it just in case
- lt_cv_deplibs_check_method="file_magic ELF 32-bit MSB dynamic lib MIPS - version 1"
- case $LD in
- *-32|*"-32 ") libmagic=32-bit;;
- *-n32|*"-n32 ") libmagic=N32;;
- *-64|*"-64 ") libmagic=64-bit;;
- *) libmagic=never-match;;
- esac
- lt_cv_deplibs_check_method="file_magic ELF ${libmagic} MSB mips-[[1234]] dynamic lib MIPS - version 1"
- esac
- lt_cv_file_magic_test_file=`echo /lib${libsuff}/libc.so*`
-linux*)
- case $host_cpu in
- alpha* | hppa* | i*86 | ia64* | m68* | mips | mipsel | powerpc* | sparc* | s390* | sh*)
- lt_cv_deplibs_check_method=pass_all ;;
- # glibc up to 2.1.1 does not perform some relocations on ARM
- lt_cv_deplibs_check_method='file_magic ELF [[0-9]][[0-9]]*-bit [[LM]]SB (shared object|dynamic lib )' ;;
- esac
- lt_cv_file_magic_test_file=`echo /lib/libc.so* /lib/libc-*.so`
-netbsd*)
- lt_cv_deplibs_check_method='match_pattern /lib[[^/]]+(\.so\.[[0-9]]+\.[[0-9]]+|_pic\.a)$'
- else
- lt_cv_deplibs_check_method='match_pattern /lib[[^/]]+(\.so|_pic\.a)$'
- fi
-newos6*)
- lt_cv_deplibs_check_method='file_magic ELF [[0-9]][[0-9]]*-bit [[ML]]SB (executable|dynamic lib)'
- lt_cv_file_magic_test_file=/usr/lib/libnls.so
-nto-qnx)
- lt_cv_deplibs_check_method=unknown
-openbsd*)
- lt_cv_deplibs_check_method='file_magic ELF [[0-9]][[0-9]]*-bit [[LM]]SB shared object'
- else
- lt_cv_deplibs_check_method='file_magic OpenBSD.* shared library'
- fi
- lt_cv_deplibs_check_method='file_magic COFF format alpha shared library'
-sco3.2v5*)
-solaris*)
- lt_cv_file_magic_test_file=/lib/libc.so
- motorola)
- lt_cv_deplibs_check_method='file_magic ELF [[0-9]][[0-9]]*-bit [[ML]]SB (shared object|dynamic lib) M[[0-9]][[0-9]]* Version [[0-9]]'
- lt_cv_file_magic_test_file=`echo /usr/lib/libc.so*`
- ncr)
- sequent)
- lt_cv_file_magic_cmd='/bin/file'
- sni)
- lt_cv_deplibs_check_method="file_magic ELF [[0-9]][[0-9]]*-bit [[LM]]SB dynamic lib"
- siemens)
- esac
-sysv5OpenUNIX8* | sysv5UnixWare7* | sysv5uw[[78]]* | unixware7* | sysv4*uw2*)
-esac
-file_magic_cmd=$lt_cv_file_magic_cmd
-deplibs_check_method=$lt_cv_deplibs_check_method
-test -z "$deplibs_check_method" && deplibs_check_method=unknown
-])# AC_DEPLIBS_CHECK_METHOD
-# AC_PROG_NM
-# find the path to a BSD-compatible name lister
-AC_DEFUN([AC_PROG_NM],
-[AC_CACHE_CHECK([for BSD-compatible nm], lt_cv_path_NM,
-[if test -n "$NM"; then
- # Let the user override the test.
- lt_cv_path_NM="$NM"
-else
- for ac_dir in $PATH /usr/ccs/bin /usr/ucb /bin; do
- tmp_nm="$ac_dir/${ac_tool_prefix}nm"
- if test -f "$tmp_nm" || test -f "$tmp_nm$ac_exeext" ; then
- # Check to see if the nm accepts a BSD-compat flag.
- # Adding the `sed 1q' prevents false positives on HP-UX, which says:
- # nm: unknown option "B" ignored
- # Tru64's nm complains that /dev/null is an invalid object file
- case `"$tmp_nm" -B /dev/null 2>&1 | sed '1q'` in
- */dev/null* | *'Invalid file or object type'*)
- lt_cv_path_NM="$tmp_nm -B"
- break
- case `"$tmp_nm" -p /dev/null 2>&1 | sed '1q'` in
- */dev/null*)
- lt_cv_path_NM="$tmp_nm -p"
- break
- lt_cv_path_NM=${lt_cv_path_NM="$tmp_nm"} # keep the first match, but
- continue # so that we can try to find one that supports BSD flags
- esac
- esac
- fi
- done
- test -z "$lt_cv_path_NM" && lt_cv_path_NM=nm
-fi])
-NM="$lt_cv_path_NM"
-])# AC_PROG_NM
-# AC_CHECK_LIBM
-# check for math library
-AC_DEFUN([AC_CHECK_LIBM],
-[AC_REQUIRE([AC_CANONICAL_HOST])dnl
-LIBM=
-case $host in
-*-*-beos* | *-*-cygwin* | *-*-pw32* | *-*-darwin*)
- # These system don't have libm, or don't need it
-*-ncr-sysv4.3*)
- AC_CHECK_LIB(mw, _mwvalidcheckl, LIBM="-lmw")
- AC_CHECK_LIB(m, cos, LIBM="$LIBM -lm")
- AC_CHECK_LIB(m, cos, LIBM="-lm")
-esac
-])# AC_CHECK_LIBM
-# AC_LIBLTDL_CONVENIENCE([DIRECTORY])
-# sets LIBLTDL to the link flags for the libltdl convenience library and
-# LTDLINCL to the include flags for the libltdl header and adds
-# --enable-ltdl-convenience to the configure arguments. Note that LIBLTDL
-# and LTDLINCL are not AC_SUBSTed, nor is AC_CONFIG_SUBDIRS called. If
-# DIRECTORY is not provided, it is assumed to be `libltdl'. LIBLTDL will
-# be prefixed with '${top_builddir}/' and LTDLINCL will be prefixed with
-# '${top_srcdir}/' (note the single quotes!). If your package is not
-# flat and you're not using automake, define top_builddir and
-# top_srcdir appropriately in the Makefiles.
-AC_DEFUN([AC_LIBLTDL_CONVENIENCE],
- case $enable_ltdl_convenience in
- no) AC_MSG_ERROR([this package needs a convenience libltdl]) ;;
- "") enable_ltdl_convenience=yes
- ac_configure_args="$ac_configure_args --enable-ltdl-convenience" ;;
- esac
- LIBLTDL='${top_builddir}/'ifelse($#,1,[$1],['libltdl'])/libltdlc.la
- LTDLINCL='-I${top_srcdir}/'ifelse($#,1,[$1],['libltdl'])
- # For backwards non-gettext consistent compatibility...
- INCLTDL="$LTDLINCL"
-])# AC_LIBLTDL_CONVENIENCE
-# AC_LIBLTDL_INSTALLABLE([DIRECTORY])
-# sets LIBLTDL to the link flags for the libltdl installable library and
-# --enable-ltdl-install to the configure arguments. Note that LIBLTDL
-# DIRECTORY is not provided and an installed libltdl is not found, it is
-# assumed to be `libltdl'. LIBLTDL will be prefixed with '${top_builddir}/'
-# and LTDLINCL will be prefixed with '${top_srcdir}/' (note the single
-# quotes!). If your package is not flat and you're not using automake,
-# define top_builddir and top_srcdir appropriately in the Makefiles.
-# In the future, this macro may have to be called after AC_PROG_LIBTOOL.
-AC_DEFUN([AC_LIBLTDL_INSTALLABLE],
- AC_CHECK_LIB(ltdl, lt_dlinit,
- [test x"$enable_ltdl_install" != xyes && enable_ltdl_install=no],
- [if test x"$enable_ltdl_install" = xno; then
- AC_MSG_WARN([libltdl not installed, but installation disabled])
- else
- enable_ltdl_install=yes
- fi
- if test x"$enable_ltdl_install" = x"yes"; then
- ac_configure_args="$ac_configure_args --enable-ltdl-install"
- LIBLTDL='${top_builddir}/'ifelse($#,1,[$1],['libltdl'])/libltdl.la
- else
- ac_configure_args="$ac_configure_args --enable-ltdl-install=no"
- LIBLTDL="-lltdl"
- LTDLINCL=
- fi
-])# AC_LIBLTDL_INSTALLABLE
-# AC_LIBTOOL_CXX
-# enable support for C++ libraries
-AC_DEFUN([AC_LIBTOOL_CXX],
-[AC_REQUIRE([_LT_AC_LANG_CXX])
-])# AC_LIBTOOL_CXX
-# _LT_AC_LANG_CXX
-AC_DEFUN([_LT_AC_LANG_CXX],
-[AC_REQUIRE([AC_PROG_CXX])
-AC_REQUIRE([AC_PROG_CXXCPP])
-_LT_AC_SHELL_INIT([tagnames=`echo "$tagnames,CXX" | sed 's/^,//'`])
-])# _LT_AC_LANG_CXX
-# AC_LIBTOOL_F77
-# enable support for Fortran 77 libraries
-AC_DEFUN([AC_LIBTOOL_F77],
-[AC_REQUIRE([_LT_AC_LANG_F77])
-])# AC_LIBTOOL_F77
-# _LT_AC_LANG_F77
-AC_DEFUN([_LT_AC_LANG_F77],
-[AC_REQUIRE([AC_PROG_F77])
-_LT_AC_SHELL_INIT([tagnames=`echo "$tagnames,F77" | sed 's/^,//'`])
-])# _LT_AC_LANG_F77
-# AC_LIBTOOL_GCJ
-# enable support for GCJ libraries
-AC_DEFUN([AC_LIBTOOL_GCJ],
-[AC_REQUIRE([_LT_AC_LANG_GCJ])
-])# AC_LIBTOOL_GCJ
-# _LT_AC_LANG_GCJ
-AC_DEFUN([_LT_AC_LANG_GCJ],
-[AC_PROVIDE_IFELSE([AC_PROG_GCJ],[],
- [AC_PROVIDE_IFELSE([A][M_PROG_GCJ],[],
- [AC_PROVIDE_IFELSE([LT_AC_PROG_GCJ],[],
- [ifdef([AC_PROG_GCJ],[AC_REQUIRE([AC_PROG_GCJ])],
- [ifdef([A][M_PROG_GCJ],[AC_REQUIRE([A][M_PROG_GCJ])],
- [AC_REQUIRE([A][C_PROG_GCJ_OR_A][M_PROG_GCJ])])])])])])
-_LT_AC_SHELL_INIT([tagnames=`echo "$tagnames,GCJ" | sed 's/^,//'`])
-])# _LT_AC_LANG_GCJ
-# AC_LIBTOOL_RC
-# enable support for Windows resource files
-AC_DEFUN([AC_LIBTOOL_RC],
-[AC_REQUIRE([LT_AC_PROG_RC])
-_LT_AC_SHELL_INIT([tagnames=`echo "$tagnames,RC" | sed 's/^,//'`])
-])# AC_LIBTOOL_RC
-# AC_LIBTOOL_LANG_C_CONFIG
-# Ensure that the configuration vars for the C compiler are
-# suitably defined. Those variables are subsequently used by
-# AC_LIBTOOL_CONFIG to write the compiler configuration to `libtool'.
-AC_DEFUN([AC_LIBTOOL_LANG_C_CONFIG], [_LT_AC_LANG_C_CONFIG])
-AC_DEFUN([_LT_AC_LANG_C_CONFIG],
-[lt_save_CC="$CC"
-AC_LANG_PUSH(C)
-# Source file extension for C test sources.
-ac_ext=c
-# Object file extension for compiled C test sources.
-objext=o
-_LT_AC_TAGVAR(objext, $1)=$objext
-# Code to be used in simple compile tests
-lt_simple_compile_test_code="int some_variable = 0;\n"
-# Code to be used in simple link tests
-lt_simple_link_test_code='int main(){return(0);}\n'
-_LT_AC_SYS_COMPILER
-# Check for any special shared library compilation flags.
-_LT_AC_TAGVAR(lt_prog_cc_shlib, $1)=
-if test "$GCC" = no; then
- case $host_os in
- sco3.2v5*)
- _LT_AC_TAGVAR(lt_prog_cc_shlib, $1)='-belf'
- esac
-fi
-if test -n "$_LT_AC_TAGVAR(lt_prog_cc_shlib, $1)"; then
- AC_MSG_WARN([`$CC' requires `$_LT_AC_TAGVAR(lt_prog_cc_shlib, $1)' to build shared libraries])
- if echo "$old_CC $old_CFLAGS " | grep "[[ ]]$]_LT_AC_TAGVAR(lt_prog_cc_shlib, $1)[[[ ]]" >/dev/null; then :
- else
- AC_MSG_WARN([add `$_LT_AC_TAGVAR(lt_prog_cc_shlib, $1)' to the CC or CFLAGS env variable and reconfigure])
- _LT_AC_TAGVAR(lt_cv_prog_cc_can_build_shared, $1)=no
- fi
-fi
-# Check to make sure the static flag actually works.
-AC_LIBTOOL_LINKER_OPTION([if $compiler static flag $_LT_AC_TAGVAR(lt_prog_compiler_static, $1) works],
- _LT_AC_TAGVAR(lt_prog_compiler_static_works, $1),
- $_LT_AC_TAGVAR(lt_prog_compiler_static, $1),
- [_LT_AC_TAGVAR(lt_prog_compiler_static, $1)=])
-AC_LIBTOOL_PROG_COMPILER_NO_RTTI($1)
-AC_LIBTOOL_PROG_COMPILER_PIC($1)
-AC_LIBTOOL_PROG_CC_C_O($1)
-AC_LIBTOOL_SYS_HARD_LINK_LOCKS($1)
-AC_LIBTOOL_PROG_LD_SHLIBS($1)
-AC_LIBTOOL_PROG_LD_HARDCODE_LIBPATH($1)
-AC_LIBTOOL_SYS_LIB_STRIP
-AC_LIBTOOL_SYS_DYNAMIC_LINKER($1)
-AC_LIBTOOL_DLOPEN_SELF($1)
-# Report which librarie types wil actually be built
-AC_MSG_CHECKING([if libtool supports shared libraries])
-AC_MSG_RESULT([$can_build_shared])
-AC_MSG_CHECKING([whether to build shared libraries])
-test "$can_build_shared" = "no" && enable_shared=no
-# On AIX, shared libraries and static libraries use the same namespace, and
-# are all built from PIC.
-case "$host_os" in
-aix3*)
- test "$enable_shared" = yes && enable_static=no
- if test -n "$RANLIB"; then
- archive_cmds="$archive_cmds~\$RANLIB \$lib"
- postinstall_cmds='$RANLIB $lib'
- fi
-aix4*)
- if test "$host_cpu" != ia64 && test "$aix_use_runtimelinking" = no ; then
- fi
- darwin* | rhapsody*)
- _LT_AC_TAGVAR(archive_cmds_need_lc, $1)=no
- _LT_AC_TAGVAR(allow_undefined_flag, $1)='-undefined suppress'
- test -z ${LD_TWOLEVEL_NAMESPACE} && _LT_AC_TAGVAR(allow_undefined_flag, $1)='-flat_namespace -undefined suppress'
- esac
- # yet detect zsh echo's removal of \ escapes. Also zsh mangles
- # `"' quotes if we put them in here... so don't!
- output_verbose_link_cmd='echo'
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs$compiler_flags -install_name $rpath/$soname $verstring'
- _LT_AC_TAGVAR(module_cmds, $1)='$CC -bundle $allow_undefined_flag -o $lib $libobjs $deplibs$compiler_flags'
- # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin ld's
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs$compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- _LT_AC_TAGVAR(module_expsym_cmds, $1)='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -bundle $allow_undefined_flag -o $lib $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- _LT_AC_TAGVAR(hardcode_direct, $1)=no
- _LT_AC_TAGVAR(hardcode_automatic, $1)=yes
- _LT_AC_TAGVAR(hardcode_shlibpath_var, $1)=unsupported
- _LT_AC_TAGVAR(whole_archive_flag_spec, $1)='-all_load $convenience'
- _LT_AC_TAGVAR(link_all_deplibs, $1)=yes
- fi
-esac
-AC_MSG_RESULT([$enable_shared])
-AC_MSG_CHECKING([whether to build static libraries])
-# Make sure either enable_shared or enable_static is yes.
-test "$enable_shared" = yes || enable_static=yes
-AC_MSG_RESULT([$enable_static])
-AC_LIBTOOL_CONFIG($1)
-AC_LANG_POP
-CC="$lt_save_CC"
-])# AC_LIBTOOL_LANG_C_CONFIG
-# AC_LIBTOOL_LANG_CXX_CONFIG
-AC_DEFUN([AC_LIBTOOL_LANG_CXX_CONFIG], [_LT_AC_LANG_CXX_CONFIG(CXX)])
-AC_DEFUN([_LT_AC_LANG_CXX_CONFIG],
-[AC_LANG_PUSH(C++)
-AC_REQUIRE([AC_PROG_CXX])
-_LT_AC_TAGVAR(archive_cmds_need_lc, $1)=no
-_LT_AC_TAGVAR(allow_undefined_flag, $1)=
-_LT_AC_TAGVAR(always_export_symbols, $1)=no
-_LT_AC_TAGVAR(archive_expsym_cmds, $1)=
-_LT_AC_TAGVAR(export_dynamic_flag_spec, $1)=
-_LT_AC_TAGVAR(hardcode_direct, $1)=no
-_LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)=
-_LT_AC_TAGVAR(hardcode_libdir_flag_spec_ld, $1)=
-_LT_AC_TAGVAR(hardcode_libdir_separator, $1)=
-_LT_AC_TAGVAR(hardcode_minus_L, $1)=no
-_LT_AC_TAGVAR(hardcode_automatic, $1)=no
-_LT_AC_TAGVAR(module_cmds, $1)=
-_LT_AC_TAGVAR(module_expsym_cmds, $1)=
-_LT_AC_TAGVAR(link_all_deplibs, $1)=unknown
-_LT_AC_TAGVAR(old_archive_cmds, $1)=$old_archive_cmds
-_LT_AC_TAGVAR(no_undefined_flag, $1)=
-_LT_AC_TAGVAR(whole_archive_flag_spec, $1)=
-_LT_AC_TAGVAR(enable_shared_with_static_runtimes, $1)=no
-# Dependencies to place before and after the object being linked:
-_LT_AC_TAGVAR(predep_objects, $1)=
-_LT_AC_TAGVAR(postdep_objects, $1)=
-_LT_AC_TAGVAR(predeps, $1)=
-_LT_AC_TAGVAR(postdeps, $1)=
-_LT_AC_TAGVAR(compiler_lib_search_path, $1)=
-# Source file extension for C++ test sources.
-ac_ext=cc
-# Object file extension for compiled C++ test sources.
-objext=o
-lt_simple_link_test_code='int main(int, char *[]) { return(0); }\n'
-# ltmain only uses $CC for tagged configurations so make sure $CC is set.
-# Allow CC to be a program name with arguments.
-lt_save_CC=$CC
-lt_save_LD=$LD
-lt_save_GCC=$GCC
-GCC=$GXX
-lt_save_with_gnu_ld=$with_gnu_ld
-lt_save_path_LD=$lt_cv_path_LD
-if test -n "${lt_cv_prog_gnu_ldcxx+set}"; then
- lt_cv_prog_gnu_ld=$lt_cv_prog_gnu_ldcxx
-else
- unset lt_cv_prog_gnu_ld
-fi
-if test -n "${lt_cv_path_LDCXX+set}"; then
- lt_cv_path_LD=$lt_cv_path_LDCXX
-else
- unset lt_cv_path_LD
-fi
-test -z "${LDCXX+set}" || LD=$LDCXX
-CC=${CXX-"c++"}
-compiler=$CC
-_LT_AC_TAGVAR(compiler, $1)=$CC
-cc_basename=`$echo X"$compiler" | $Xsed -e 's%^.*/%%'`
-# We don't want -fno-exception wen compiling C++ code, so set the
-# no_builtin_flag separately
-if test "$GXX" = yes; then
- _LT_AC_TAGVAR(lt_prog_compiler_no_builtin_flag, $1)=' -fno-builtin'
-else
-fi
- # Set up default GNU C++ configuration
- AC_PROG_LD
- # Check if GNU C++ uses GNU ld as the underlying linker, since the
- # archiving commands below assume that GNU ld is being used.
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}--rpath ${wl}$libdir'
- _LT_AC_TAGVAR(export_dynamic_flag_spec, $1)='${wl}--export-dynamic'
- # If archive_cmds runs LD, not CC, wlarc should be empty
- # XXX I think wlarc can be eliminated in ltcf-cxx, but I need to
- # investigate it a little bit more. (MM)
- wlarc='${wl}'
- # ancient GNU ld didn't support --whole-archive et. al.
- if eval "`$CC -print-prog-name=ld` --help 2>&1" | \
- grep 'no-whole-archive' > /dev/null; then
- _LT_AC_TAGVAR(whole_archive_flag_spec, $1)="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
- else
- fi
- else
- with_gnu_ld=no
- wlarc=
- # A generic and very simple default shared library creation
- # command for GNU C++ for the case where it uses the native
- # linker, instead of GNU ld. If possible, this setting should
- # overridden to take advantage of the native linker features on
- # the platform it is being used on.
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $lib'
- fi
- # Commands to make compiler produce verbose output that lists
- # what "hidden" libraries, object files and flags are used when
- # linking a shared library.
- output_verbose_link_cmd='$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "\-L"'
-else
- GXX=no
- with_gnu_ld=no
- wlarc=
-fi
-# PORTME: fill in a description of your system's C++ link characteristics
-AC_MSG_CHECKING([whether the $compiler linker ($LD) supports shared libraries])
-_LT_AC_TAGVAR(ld_shlibs, $1)=yes
-case $host_os in
- aix3*)
- # FIXME: insert proper C++ library support
- _LT_AC_TAGVAR(ld_shlibs, $1)=no
- aix4* | aix5*)
- # On IA64, the linker does run time linking by default, so we don't
- # have to do anything special.
- aix_use_runtimelinking=no
- exp_sym_flag='-Bexport'
- no_entry_flag=""
- else
- # Test if we are trying to use run time linking or normal
- # AIX style linking. If -brtl is somewhere in LDFLAGS, we
- # need to do runtime linking.
- case $host_os in aix4.[[23]]|aix4.[[23]].*|aix5*)
- for ld_flag in $LDFLAGS; do
- case $ld_flag in
- *-brtl*)
- aix_use_runtimelinking=yes
- break
- esac
- done
- esac
- exp_sym_flag='-bexport'
- no_entry_flag='-bnoentry'
- fi
- # When large executables or shared objects are built, AIX ld can
- # have problems creating the table of contents. If linking a library
- # or program results in "error TOC overflow" add -mminimal-toc to
- # CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
- # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
- _LT_AC_TAGVAR(archive_cmds, $1)=''
- _LT_AC_TAGVAR(hardcode_direct, $1)=yes
- _LT_AC_TAGVAR(hardcode_libdir_separator, $1)=':'
- if test "$GXX" = yes; then
- case $host_os in aix4.[012]|aix4.[012].*)
- # We only want to do this on AIX 4.2 and lower, the check
- # below for broken collect2 doesn't work under 4.3+
- collect2name=`${CC} -print-prog-name=collect2`
- if test -f "$collect2name" && \
- strings "$collect2name" | grep resolve_lib_name >/dev/null
- then
- # We have reworked collect2
- else
- # We have old collect2
- _LT_AC_TAGVAR(hardcode_direct, $1)=unsupported
- # It fails to find uninstalled libraries when the uninstalled
- # path is not listed in the libpath. Setting hardcode_minus_L
- # to unsupported forces relinking
- _LT_AC_TAGVAR(hardcode_minus_L, $1)=yes
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='-L$libdir'
- fi
- esac
- shared_flag='-shared'
- else
- # not using gcc
- # VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
- # chokes on -Wl,-G. The following line is correct:
- shared_flag='-G'
- else
- shared_flag='${wl}-G'
- else
- shared_flag='${wl}-bM:SRE'
- fi
- fi
- fi
- # It seems that -bexpall does not export symbols beginning with
- # underscore (_), so it is better to generate a list of symbols to export.
- _LT_AC_TAGVAR(always_export_symbols, $1)=yes
- # Warning - without using the other runtime loading flags (-brtl),
- # -berok will link without error, but may produce a broken library.
- _LT_AC_TAGVAR(allow_undefined_flag, $1)='-berok'
- # Determine the default libpath from the value encoded in an empty executable.
- _LT_AC_SYS_LIBPATH_AIX
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}-blibpath:$libdir:'"$aix_libpath"
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)="\$CC"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols $shared_flag"
- else
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}-R $libdir:/usr/lib:/lib'
- _LT_AC_TAGVAR(allow_undefined_flag, $1)="-z nodefs"
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols"
- else
- # Warning - without using the other run time loading flags,
- _LT_AC_TAGVAR(no_undefined_flag, $1)=' ${wl}-bernotok'
- _LT_AC_TAGVAR(allow_undefined_flag, $1)=' ${wl}-berok'
- # -bexpall does not export symbols beginning with underscore (_)
- # Exported symbols can be pulled into shared objects from archives
- _LT_AC_TAGVAR(whole_archive_flag_spec, $1)=' '
- _LT_AC_TAGVAR(archive_cmds_need_lc, $1)=yes
- # This is similar to how AIX traditionally builds it's shared libraries.
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}-bE:$export_symbols ${wl}-bnoentry${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
- fi
- fi
- chorus*)
- case $cc_basename in
- esac
- cygwin* | mingw* | pw32*)
- # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1) is actually meaningless,
- # as there is no search path for DLLs.
- _LT_AC_TAGVAR(allow_undefined_flag, $1)=unsupported
- _LT_AC_TAGVAR(always_export_symbols, $1)=no
- _LT_AC_TAGVAR(enable_shared_with_static_runtimes, $1)=yes
- if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
- # If the export-symbols file already is a .def file (1st line
- # is EXPORTS), use it as is; otherwise, prepend...
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
- cp $export_symbols $output_objdir/$soname.def;
- else
- echo EXPORTS > $output_objdir/$soname.def;
- cat $export_symbols >> $output_objdir/$soname.def;
- fi~
- $CC -shared -nostdlib $output_objdir/$soname.def $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
- else
- fi
- esac
- lt_int_apple_cc_single_mod=no
- if $CC -dumpspecs 2>&1 | grep 'single_module' >/dev/null ; then
- lt_int_apple_cc_single_mod=yes
- fi
- if test "X$lt_int_apple_cc_single_mod" = Xyes ; then
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
- else
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -r ${wl}-bind_at_load -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
- fi
- _LT_AC_TAGVAR(module_cmds, $1)='$CC -bundle ${wl}-bind_at_load $allow_undefined_flag -o $lib $libobjs $deplibs$compiler_flags'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- else
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -r ${wl}-bind_at_load -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- fi
- fi
- dgux*)
- ec++)
- ghcx)
- # Green Hills C++ Compiler
- esac
- freebsd[12]*)
- # C++ shared libraries reported to be fairly broken before switch to ELF
- freebsd-elf*)
- freebsd*)
- # FreeBSD 3 and later use GNU C++ and GNU ld with standard ELF
- # conventions
- _LT_AC_TAGVAR(ld_shlibs, $1)=yes
- gnu*)
- hpux9*)
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}+b ${wl}$libdir'
- _LT_AC_TAGVAR(hardcode_libdir_separator, $1)=:
- _LT_AC_TAGVAR(export_dynamic_flag_spec, $1)='${wl}-E'
- _LT_AC_TAGVAR(hardcode_minus_L, $1)=yes # Not in the search PATH,
- # but as the default
- # location of the library.
- CC)
- aCC)
- _LT_AC_TAGVAR(archive_cmds, $1)='$rm $output_objdir/$soname~$CC -b ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- # There doesn't appear to be a way to prevent this compiler from
- # explicitly linking system object files so we need to strip them
- # from the output so that they don't get included in the library
- # dependencies.
- output_verbose_link_cmd='templist=`($CC -b $CFLAGS -v conftest.$objext 2>&1) | egrep "\-L"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
- _LT_AC_TAGVAR(archive_cmds, $1)='$rm $output_objdir/$soname~$CC -shared -nostdlib -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- else
- fi
- esac
- hpux10*|hpux11*)
- if test $with_gnu_ld = no; then
- hppa*64*)
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec_ld, $1)='+b $libdir'
- ia64*)
- esac
- fi
- hppa*64*)
- _LT_AC_TAGVAR(hardcode_shlibpath_var, $1)=no
- ia64*)
- esac
- CC)
- aCC)
- hppa*64*|ia64*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -b +h $soname -o $lib $linker_flags $libobjs $deplibs'
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- esac
- # dependencies.
- output_verbose_link_cmd='templist=`($CC -b $CFLAGS -v conftest.$objext 2>&1) | grep "\-L"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
- ia64*|hppa*64*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- esac
- fi
- else
- fi
- esac
- irix5* | irix6*)
- CC)
- # SGI C++
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -all -multigot $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${objdir}/so_locations -o $lib'
- # Archives containing C++ object files must be created using
- # "CC -ar", where "CC" is the IRIX C++ compiler. This is
- # necessary to make sure instantiated templates are included
- # in the archive.
- _LT_AC_TAGVAR(old_archive_cmds, $1)='$CC -ar -WR,-u -o $oldlib $oldobjs'
- if test "$with_gnu_ld" = no; then
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${objdir}/so_locations -o $lib'
- else
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` -o $lib'
- fi
- fi
- esac
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}-rpath ${wl}$libdir'
- linux*)
- KCC)
- # Kuck and Associates, Inc. (KAI) C++ Compiler
- # KCC will only create a shared library if the output file
- # ends with ".so" (or ".sl" for HP-UX), so rename the library
- # to its proper name (with version) after linking.
- _LT_AC_TAGVAR(archive_cmds, $1)='tempext=`echo $shared_ext | $SED -e '\''s/\([[^()0-9A-Za-z{}]]\)/\\\\\1/g'\''`; templib=`echo $lib | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib; mv \$templib $lib'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='tempext=`echo $shared_ext | $SED -e '\''s/\([[^()0-9A-Za-z{}]]\)/\\\\\1/g'\''`; templib=`echo $lib | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib ${wl}-retain-symbols-file,$export_symbols; mv \$templib $lib'
- # dependencies.
- output_verbose_link_cmd='templist=`$CC $CFLAGS -v conftest.$objext -o libconftest$shared_ext 2>&1 | grep "ld"`; rm -f libconftest$shared_ext; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}--rpath,$libdir'
- # "CC -Bstatic", where "CC" is the KAI C++ compiler.
- _LT_AC_TAGVAR(old_archive_cmds, $1)='$CC -Bstatic -o $oldlib $oldobjs'
- icpc)
- # Intel C++
- with_gnu_ld=yes
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}-rpath,$libdir'
- _LT_AC_TAGVAR(whole_archive_flag_spec, $1)='${wl}--whole-archive$convenience ${wl}--no-whole-archive'
- cxx)
- # Compaq C++
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib ${wl}-retain-symbols-file $wl$export_symbols'
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='-rpath $libdir'
- # dependencies.
- output_verbose_link_cmd='templist=`$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "ld"`; templist=`echo $templist | $SED "s/\(^.*ld.*\)\( .*ld .*$\)/\1/"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
- esac
- lynxos*)
- m88k*)
- mvs*)
- cxx)
- esac
- netbsd*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -Bshareable -o $lib $predep_objects $libobjs $deplibs $postdep_objects $linker_flags'
- wlarc=
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='-R$libdir'
- fi
- # Workaround some broken pre-1.5 toolchains
- output_verbose_link_cmd='$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep conftest.$objext | $SED -e "s:-lgcc -lc -lgcc::"'
- osf3*)
- KCC)
- RCC)
- # Rational C++ 2.4.1
- cxx)
- _LT_AC_TAGVAR(allow_undefined_flag, $1)=' ${wl}-expect_unresolved ${wl}\*'
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $soname `test -n "$verstring" && echo ${wl}-set_version $verstring` -update_registry ${objdir}/so_locations -o $lib'
- # dependencies.
- output_verbose_link_cmd='templist=`$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "ld" | grep -v "ld:"`; templist=`echo $templist | $SED "s/\(^.*ld.*\)\( .*ld.*$\)/\1/"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
- if test "$GXX" = yes && test "$with_gnu_ld" = no; then
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib ${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${objdir}/so_locations -o $lib'
- else
- fi
- esac
- osf4* | osf5*)
- KCC)
- # the KAI C++ compiler.
- _LT_AC_TAGVAR(old_archive_cmds, $1)='$CC -o $oldlib $oldobjs'
- RCC)
- cxx)
- _LT_AC_TAGVAR(allow_undefined_flag, $1)=' -expect_unresolved \*'
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${objdir}/so_locations -o $lib'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done~
- echo "-hidden">> $lib.exp~
- $CC -shared$allow_undefined_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -msym -soname $soname -Wl,-input -Wl,$lib.exp `test -n "$verstring" && echo -set_version $verstring` -update_registry $objdir/so_locations -o $lib~
- $rm $lib.exp'
- # dependencies.
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib ${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${objdir}/so_locations -o $lib'
- else
- fi
- esac
- psos*)
- sco*)
- CC)
- esac
- sunos4*)
- CC)
- # Sun C++ 4.x
- lcc)
- # Lucid
- esac
- solaris*)
- CC)
- # Sun C++ 4.2, 5.x and Centerline C++
- _LT_AC_TAGVAR(no_undefined_flag, $1)=' -zdefs'
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -G${allow_undefined_flag} -nolib -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
- $CC -G${allow_undefined_flag} -nolib ${wl}-M ${wl}$lib.exp -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
- case $host_os in
- solaris2.[0-5] | solaris2.[0-5].*) ;;
- # The C++ compiler is used as linker so we must use $wl
- # flag to pass the commands to the underlying system
- # linker.
- # Supported since Solaris 2.6 (maybe 2.5.1?)
- _LT_AC_TAGVAR(whole_archive_flag_spec, $1)='${wl}-z ${wl}allextract$convenience ${wl}-z ${wl}defaultextract'
- esac
- # dependencies.
- output_verbose_link_cmd='templist=`$CC -G $CFLAGS -v conftest.$objext 2>&1 | grep "\-[[LR]]"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
- # "CC -xar", where "CC" is the Sun C++ compiler. This is
- # in the archive.
- _LT_AC_TAGVAR(old_archive_cmds, $1)='$CC -xar -o $oldlib $oldobjs'
- gcx)
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
- # The C++ compiler must be used to create the archive.
- _LT_AC_TAGVAR(old_archive_cmds, $1)='$CC $LDFLAGS -archive -o $oldlib $oldobjs'
- # GNU C++ compiler with Solaris linker
- _LT_AC_TAGVAR(no_undefined_flag, $1)=' ${wl}-z ${wl}defs'
- if $CC --version | grep -v '^2\.7' > /dev/null; then
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib $LDFLAGS $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
- $CC -shared -nostdlib ${wl}-M $wl$lib.exp -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
- output_verbose_link_cmd="$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep \"\-L\""
- else
- # g++ 2.7 appears to require `-G' NOT `-shared' on this
- # platform.
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -G -nostdlib $LDFLAGS $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
- $CC -G -nostdlib ${wl}-M $wl$lib.exp -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
- output_verbose_link_cmd="$CC -G $CFLAGS -v conftest.$objext 2>&1 | grep \"\-L\""
- fi
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}-R $wl$libdir'
- fi
- esac
- sysv5OpenUNIX8* | sysv5UnixWare7* | sysv5uw[[78]]* | unixware7*)
- tandem*)
- NCC)
- # NonStop-UX NCC 3.20
- esac
- vxworks*)
-esac
-AC_MSG_RESULT([$_LT_AC_TAGVAR(ld_shlibs, $1)])
-test "$_LT_AC_TAGVAR(ld_shlibs, $1)" = no && can_build_shared=no
-_LT_AC_TAGVAR(GCC, $1)="$GXX"
-_LT_AC_TAGVAR(LD, $1)="$LD"
-AC_LIBTOOL_POSTDEP_PREDEP($1)
-AC_LANG_POP
-CC=$lt_save_CC
-LDCXX=$LD
-LD=$lt_save_LD
-GCC=$lt_save_GCC
-with_gnu_ldcxx=$with_gnu_ld
-with_gnu_ld=$lt_save_with_gnu_ld
-lt_cv_path_LDCXX=$lt_cv_path_LD
-lt_cv_path_LD=$lt_save_path_LD
-lt_cv_prog_gnu_ldcxx=$lt_cv_prog_gnu_ld
-lt_cv_prog_gnu_ld=$lt_save_with_gnu_ld
-])# AC_LIBTOOL_LANG_CXX_CONFIG
-# AC_LIBTOOL_POSTDEP_PREDEP([TAGNAME])
-# Figure out "hidden" library dependencies from verbose
-# compiler output when linking a shared library.
-# Parse the compiler output and extract the necessary
-# objects, libraries and library flags.
-AC_DEFUN([AC_LIBTOOL_POSTDEP_PREDEP],[
-dnl we can't use the lt_simple_compile_test_code here,
-dnl because it contains code intended for an executable,
-dnl not a library. It's possible we should let each
-dnl tag define a new lt_????_link_test_code variable,
-dnl but it's only used here...
-ifelse([$1],[],[cat > conftest.$ac_ext <<EOF
-int a;
-void foo (void) { a = 0; }
-EOF
-],[$1],[CXX],[cat > conftest.$ac_ext <<EOF
-class Foo
-public:
- Foo (void) { a = 0; }
-private:
- int a;
-EOF
-],[$1],[F77],[cat > conftest.$ac_ext <<EOF
- subroutine foo
- implicit none
- integer*4 a
- a=0
- return
- end
-EOF
-],[$1],[GCJ],[cat > conftest.$ac_ext <<EOF
-public class foo {
- private int a;
- public void bar (void) {
- a = 0;
-EOF
-dnl Parse the compiler output and extract the necessary
-dnl objects, libraries and library flags.
-if AC_TRY_EVAL(ac_compile); then
- # Parse the compiler output and extract the necessary
- # objects, libraries and library flags.
- # Sentinel used to keep track of whether or not we are before
- # the conftest object file.
- pre_test_object_deps_done=no
- # The `*' in the case matches for architectures that use `case' in
- # $output_verbose_cmd can trigger glob expansion during the loop
- # eval without this substitution.
- output_verbose_link_cmd="`$echo \"X$output_verbose_link_cmd\" | $Xsed -e \"$no_glob_subst\"`"
- for p in `eval $output_verbose_link_cmd`; do
- case $p in
- -L* | -R* | -l*)
- # Some compilers place space between "-{L,R}" and the path.
- # Remove the space.
- if test $p = "-L" \
- || test $p = "-R"; then
- prev=$p
- continue
- else
- prev=
- fi
- if test "$pre_test_object_deps_done" = no; then
- case $p in
- -L* | -R*)
- # Internal compiler library paths should come after those
- # provided the user. The postdeps already come after the
- # user supplied libs so there is no need to process them.
- if test -z "$_LT_AC_TAGVAR(compiler_lib_search_path, $1)"; then
- _LT_AC_TAGVAR(compiler_lib_search_path, $1)="${prev}${p}"
- else
- _LT_AC_TAGVAR(compiler_lib_search_path, $1)="${_LT_AC_TAGVAR(compiler_lib_search_path, $1)} ${prev}${p}"
- fi
- # The "-l" case would never come before the object being
- # linked, so don't bother handling this case.
- esac
- else
- if test -z "$_LT_AC_TAGVAR(postdeps, $1)"; then
- _LT_AC_TAGVAR(postdeps, $1)="${prev}${p}"
- else
- _LT_AC_TAGVAR(postdeps, $1)="${_LT_AC_TAGVAR(postdeps, $1)} ${prev}${p}"
- fi
- fi
- *.$objext)
- # This assumes that the test object file only shows up
- # once in the compiler output.
- if test "$p" = "conftest.$objext"; then
- pre_test_object_deps_done=yes
- continue
- fi
- if test -z "$_LT_AC_TAGVAR(predep_objects, $1)"; then
- _LT_AC_TAGVAR(predep_objects, $1)="$p"
- else
- _LT_AC_TAGVAR(predep_objects, $1)="$_LT_AC_TAGVAR(predep_objects, $1) $p"
- fi
- else
- if test -z "$_LT_AC_TAGVAR(postdep_objects, $1)"; then
- _LT_AC_TAGVAR(postdep_objects, $1)="$p"
- else
- _LT_AC_TAGVAR(postdep_objects, $1)="$_LT_AC_TAGVAR(postdep_objects, $1) $p"
- fi
- fi
- *) ;; # Ignore the rest.
- esac
- done
- # Clean up.
- rm -f a.out a.exe
-else
- echo "libtool.m4: error: problem compiling $1 test program"
-fi
-$rm -f confest.$objext
-case " $_LT_AC_TAGVAR(postdeps, $1) " in
-*" -lc "*) _LT_AC_TAGVAR(archive_cmds_need_lc, $1)=no ;;
-esac
-])# AC_LIBTOOL_POSTDEP_PREDEP
-# AC_LIBTOOL_LANG_F77_CONFIG
-AC_DEFUN([AC_LIBTOOL_LANG_F77_CONFIG], [_LT_AC_LANG_F77_CONFIG(F77)])
-AC_DEFUN([_LT_AC_LANG_F77_CONFIG],
-AC_LANG_PUSH(Fortran 77)
-# Source file extension for f77 test sources.
-ac_ext=f
-# Object file extension for compiled f77 test sources.
-objext=o
-lt_simple_compile_test_code=" subroutine t\n return\n end\n"
-lt_simple_link_test_code=" program t\n end\n"
-lt_save_CC="$CC"
-CC=${F77-"f77"}
-compiler=$CC
-case "$host_os" in
-aix3*)
- fi
-aix4*)
-esac
-_LT_AC_TAGVAR(GCC, $1)="$G77"
-AC_LANG_POP
-CC="$lt_save_CC"
-])# AC_LIBTOOL_LANG_F77_CONFIG
-# AC_LIBTOOL_LANG_GCJ_CONFIG
-AC_DEFUN([AC_LIBTOOL_LANG_GCJ_CONFIG], [_LT_AC_LANG_GCJ_CONFIG(GCJ)])
-AC_DEFUN([_LT_AC_LANG_GCJ_CONFIG],
-[AC_LANG_SAVE
-# Source file extension for Java test sources.
-ac_ext=java
-# Object file extension for compiled Java test sources.
-objext=o
-lt_simple_compile_test_code="class foo {}\n"
-lt_simple_link_test_code='public class conftest { public static void main(String[] argv) {}; }\n'
-lt_save_CC="$CC"
-CC=${GCJ-"gcj"}
-compiler=$CC
-# GCJ did not exist at the time GCC didn't implicitly link libc in.
-AC_LANG_RESTORE
-CC="$lt_save_CC"
-])# AC_LIBTOOL_LANG_GCJ_CONFIG
-# AC_LIBTOOL_LANG_RC_CONFIG
-# Ensure that the configuration vars for the Windows resource compiler are
-AC_DEFUN([AC_LIBTOOL_LANG_RC_CONFIG], [_LT_AC_LANG_RC_CONFIG(RC)])
-AC_DEFUN([_LT_AC_LANG_RC_CONFIG],
-[AC_LANG_SAVE
-# Source file extension for RC test sources.
-ac_ext=rc
-# Object file extension for compiled RC test sources.
-objext=o
-lt_simple_compile_test_code='sample MENU { MENUITEM "&Soup", 100, CHECKED }\n'
-lt_simple_link_test_code="$lt_simple_compile_test_code"
-lt_save_CC="$CC"
-CC=${RC-"windres"}
-compiler=$CC
-_LT_AC_TAGVAR(lt_cv_prog_compiler_c_o, $1)=yes
-AC_LANG_RESTORE
-CC="$lt_save_CC"
-])# AC_LIBTOOL_LANG_RC_CONFIG
-# AC_LIBTOOL_CONFIG([TAGNAME])
-# If TAGNAME is not passed, then create an initial libtool script
-# with a default configuration from the untagged config vars. Otherwise
-# add code to config.status for appending the configuration named by
-# TAGNAME from the matching tagged config vars.
-AC_DEFUN([AC_LIBTOOL_CONFIG],
-[# The else clause should only fire when bootstrapping the
-# libtool distribution, otherwise you forgot to ship ltmain.sh
-# with your package, and you will get complaints that there are
-# no rules to generate ltmain.sh.
-if test -f "$ltmain"; then
- # See if we are running on zsh, and set the options which allow our commands through
- # without removal of \ escapes.
- if test -n "${ZSH_VERSION+set}" ; then
- setopt NO_GLOB_SUBST
- fi
- # Now quote all the things that may contain metacharacters while being
- # careful not to overquote the AC_SUBSTed values. We take copies of the
- # variables and quote the copies for generation of the libtool script.
- for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC NM SED SHELL \
- libname_spec library_names_spec soname_spec extract_expsyms_cmds \
- old_striplib striplib file_magic_cmd finish_cmds finish_eval \
- deplibs_check_method reload_flag reload_cmds need_locks \
- lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
- lt_cv_sys_global_symbol_to_c_name_address \
- sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
- old_postinstall_cmds old_postuninstall_cmds \
- _LT_AC_TAGVAR(compiler, $1) \
- _LT_AC_TAGVAR(CC, $1) \
- _LT_AC_TAGVAR(LD, $1) \
- _LT_AC_TAGVAR(lt_prog_compiler_wl, $1) \
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1) \
- _LT_AC_TAGVAR(lt_prog_compiler_static, $1) \
- _LT_AC_TAGVAR(lt_prog_compiler_no_builtin_flag, $1) \
- _LT_AC_TAGVAR(export_dynamic_flag_spec, $1) \
- _LT_AC_TAGVAR(thread_safe_flag_spec, $1) \
- _LT_AC_TAGVAR(whole_archive_flag_spec, $1) \
- _LT_AC_TAGVAR(enable_shared_with_static_runtimes, $1) \
- _LT_AC_TAGVAR(old_archive_cmds, $1) \
- _LT_AC_TAGVAR(old_archive_from_new_cmds, $1) \
- _LT_AC_TAGVAR(predep_objects, $1) \
- _LT_AC_TAGVAR(postdep_objects, $1) \
- _LT_AC_TAGVAR(predeps, $1) \
- _LT_AC_TAGVAR(postdeps, $1) \
- _LT_AC_TAGVAR(compiler_lib_search_path, $1) \
- _LT_AC_TAGVAR(archive_cmds, $1) \
- _LT_AC_TAGVAR(archive_expsym_cmds, $1) \
- _LT_AC_TAGVAR(postinstall_cmds, $1) \
- _LT_AC_TAGVAR(postuninstall_cmds, $1) \
- _LT_AC_TAGVAR(old_archive_from_expsyms_cmds, $1) \
- _LT_AC_TAGVAR(allow_undefined_flag, $1) \
- _LT_AC_TAGVAR(no_undefined_flag, $1) \
- _LT_AC_TAGVAR(export_symbols_cmds, $1) \
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1) \
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec_ld, $1) \
- _LT_AC_TAGVAR(hardcode_libdir_separator, $1) \
- _LT_AC_TAGVAR(hardcode_automatic, $1) \
- _LT_AC_TAGVAR(module_cmds, $1) \
- _LT_AC_TAGVAR(module_expsym_cmds, $1) \
- _LT_AC_TAGVAR(lt_cv_prog_compiler_c_o, $1) \
- _LT_AC_TAGVAR(exclude_expsyms, $1) \
- _LT_AC_TAGVAR(include_expsyms, $1); do
- case $var in
- _LT_AC_TAGVAR(old_archive_cmds, $1) | \
- _LT_AC_TAGVAR(old_archive_from_new_cmds, $1) | \
- _LT_AC_TAGVAR(archive_cmds, $1) | \
- _LT_AC_TAGVAR(archive_expsym_cmds, $1) | \
- _LT_AC_TAGVAR(module_cmds, $1) | \
- _LT_AC_TAGVAR(module_expsym_cmds, $1) | \
- _LT_AC_TAGVAR(old_archive_from_expsyms_cmds, $1) | \
- _LT_AC_TAGVAR(export_symbols_cmds, $1) | \
- extract_expsyms_cmds | reload_cmds | finish_cmds | \
- postinstall_cmds | postuninstall_cmds | \
- old_postinstall_cmds | old_postuninstall_cmds | \
- sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
- # Double-quote double-evaled strings.
- eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
- eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
- esac
- done
- case $lt_echo in
- *'\[$]0 --fallback-echo"')
- lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\[$]0 --fallback-echo"[$]/[$]0 --fallback-echo"/'`
- esac
-ifelse([$1], [],
- [cfgfile="${ofile}T"
- trap "$rm \"$cfgfile\"; exit 1" 1 2 15
- $rm -f "$cfgfile"
- AC_MSG_NOTICE([creating $ofile])],
- [cfgfile="$ofile"])
- cat <<__EOF__ >> "$cfgfile"
-ifelse([$1], [],
-[#! $SHELL
-# `$echo "$cfgfile" | sed 's%^.*/%%'` - Provide generalized library-building support services.
-# Generated automatically by $PROGRAM (GNU $PACKAGE $VERSION$TIMESTAMP)
-# NOTE: Changes made to this file will be lost: look at ltmain.sh.
-# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001
-# Free Software Foundation, Inc.
-# This file is part of GNU Libtool:
-# Originally by Gordon Matzigkeit <gord at gnu.ai.mit.edu>, 1996
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2 of the License, or
-# (at your option) any later version.
-# This program is distributed in the hope that it will be useful, but
-# WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-# General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-# As a special exception to the GNU General Public License, if you
-# distribute this file as part of a program that contains a
-# configuration script generated by Autoconf, you may include it under
-# the same distribution terms that you use for the rest of that program.
-# A sed program that does not truncate output.
-SED=$lt_SED
-# Sed that helps us avoid accidentally triggering echo(1) options like -n.
-Xsed="$SED -e s/^X//"
-# The HP-UX ksh and POSIX shell print the target directory to stdout
-# if CDPATH is set.
-if test "X\${CDPATH+set}" = Xset; then CDPATH=:; export CDPATH; fi
-# The names of the tagged configurations supported by this script.
-available_tags=
-# ### BEGIN LIBTOOL CONFIG],
-[# ### BEGIN LIBTOOL TAG CONFIG: $tagname])
-# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
-# Shell to use when invoking shell scripts.
-SHELL=$lt_SHELL
-# Whether or not to build shared libraries.
-build_libtool_libs=$enable_shared
-# Whether or not to build static libraries.
-build_old_libs=$enable_static
-# Whether or not to add -lc for building shared libraries.
-build_libtool_need_lc=$_LT_AC_TAGVAR(archive_cmds_need_lc, $1)
-# Whether or not to disallow shared libs when runtime libs are static
-allow_libtool_libs_with_static_runtimes=$_LT_AC_TAGVAR(enable_shared_with_static_runtimes, $1)
-# Whether or not to optimize for fast installation.
-fast_install=$enable_fast_install
-# The host system.
-host_alias=$host_alias
-host=$host
-# An echo program that does not interpret backslashes.
-echo=$lt_echo
-# The archiver.
-AR=$lt_AR
-AR_FLAGS=$lt_AR_FLAGS
-# A C compiler.
-LTCC=$lt_LTCC
-# A language-specific compiler.
-CC=$lt_[]_LT_AC_TAGVAR(compiler, $1)
-# Is the compiler the GNU C compiler?
-with_gcc=$_LT_AC_TAGVAR(GCC, $1)
-# An ERE matcher.
-EGREP=$lt_EGREP
-# The linker used to build libraries.
-LD=$lt_[]_LT_AC_TAGVAR(LD, $1)
-# Whether we need hard or soft links.
-LN_S=$lt_LN_S
-# A BSD-compatible nm program.
-NM=$lt_NM
-# A symbol stripping program
-STRIP=$STRIP
-# Used to examine libraries when file_magic_cmd begins "file"
-MAGIC_CMD=$MAGIC_CMD
-# Used on cygwin: DLL creation program.
-DLLTOOL="$DLLTOOL"
-# Used on cygwin: object dumper.
-OBJDUMP="$OBJDUMP"
-# Used on cygwin: assembler.
-AS="$AS"
-# The name of the directory that contains temporary libtool files.
-objdir=$objdir
-# How to create reloadable object files.
-reload_flag=$lt_reload_flag
-reload_cmds=$lt_reload_cmds
-# How to pass a linker flag through the compiler.
-wl=$lt_[]_LT_AC_TAGVAR(lt_prog_compiler_wl, $1)
-# Object file suffix (normally "o").
-objext="$ac_objext"
-# Old archive suffix (normally "a").
-libext="$libext"
-# Shared library suffix (normally ".so").
-shrext='$shrext'
-# Executable file suffix (normally "").
-exeext="$exeext"
-# Additional compiler flags for building library objects.
-pic_flag=$lt_[]_LT_AC_TAGVAR(lt_prog_compiler_pic, $1)
-pic_mode=$pic_mode
-# What is the maximum length of a command?
-max_cmd_len=$lt_cv_sys_max_cmd_len
-# Does compiler simultaneously support -c and -o options?
-compiler_c_o=$lt_[]_LT_AC_TAGVAR(lt_cv_prog_compiler_c_o, $1)
-# Must we lock files when doing compilation ?
-need_locks=$lt_need_locks
-# Do we need the lib prefix for modules?
-need_lib_prefix=$need_lib_prefix
-# Do we need a version for libraries?
-need_version=$need_version
-# Whether dlopen is supported.
-dlopen_support=$enable_dlopen
-# Whether dlopen of programs is supported.
-dlopen_self=$enable_dlopen_self
-# Whether dlopen of statically linked programs is supported.
-dlopen_self_static=$enable_dlopen_self_static
-# Compiler flag to prevent dynamic linking.
-link_static_flag=$lt_[]_LT_AC_TAGVAR(lt_prog_compiler_static, $1)
-# Compiler flag to turn off builtin functions.
-no_builtin_flag=$lt_[]_LT_AC_TAGVAR(lt_prog_compiler_no_builtin_flag, $1)
-# Compiler flag to allow reflexive dlopens.
-export_dynamic_flag_spec=$lt_[]_LT_AC_TAGVAR(export_dynamic_flag_spec, $1)
-# Compiler flag to generate shared objects directly from archives.
-whole_archive_flag_spec=$lt_[]_LT_AC_TAGVAR(whole_archive_flag_spec, $1)
-# Compiler flag to generate thread-safe objects.
-thread_safe_flag_spec=$lt_[]_LT_AC_TAGVAR(thread_safe_flag_spec, $1)
-# Library versioning type.
-version_type=$version_type
-# Format of library name prefix.
-libname_spec=$lt_libname_spec
-# List of archive names. First name is the real one, the rest are links.
-# The last name is the one that the linker finds with -lNAME.
-library_names_spec=$lt_library_names_spec
-# The coded name of the library, if different from the real name.
-soname_spec=$lt_soname_spec
-# Commands used to build and install an old-style archive.
-RANLIB=$lt_RANLIB
-old_archive_cmds=$lt_[]_LT_AC_TAGVAR(old_archive_cmds, $1)
-old_postinstall_cmds=$lt_old_postinstall_cmds
-old_postuninstall_cmds=$lt_old_postuninstall_cmds
-# Create an old-style archive from a shared archive.
-old_archive_from_new_cmds=$lt_[]_LT_AC_TAGVAR(old_archive_from_new_cmds, $1)
-# Create a temporary old-style archive to link instead of a shared archive.
-old_archive_from_expsyms_cmds=$lt_[]_LT_AC_TAGVAR(old_archive_from_expsyms_cmds, $1)
-# Commands used to build and install a shared archive.
-archive_cmds=$lt_[]_LT_AC_TAGVAR(archive_cmds, $1)
-archive_expsym_cmds=$lt_[]_LT_AC_TAGVAR(archive_expsym_cmds, $1)
-postinstall_cmds=$lt_postinstall_cmds
-postuninstall_cmds=$lt_postuninstall_cmds
-# Commands used to build a loadable module (assumed same as above if empty)
-module_cmds=$lt_[]_LT_AC_TAGVAR(module_cmds, $1)
-module_expsym_cmds=$lt_[]_LT_AC_TAGVAR(module_expsym_cmds, $1)
-# Commands to strip libraries.
-old_striplib=$lt_old_striplib
-striplib=$lt_striplib
-# Dependencies to place before the objects being linked to create a
-# shared library.
-predep_objects=$lt_[]_LT_AC_TAGVAR(predep_objects, $1)
-# Dependencies to place after the objects being linked to create a
-# shared library.
-postdep_objects=$lt_[]_LT_AC_TAGVAR(postdep_objects, $1)
-# shared library.
-predeps=$lt_[]_LT_AC_TAGVAR(predeps, $1)
-# shared library.
-postdeps=$lt_[]_LT_AC_TAGVAR(postdeps, $1)
-# The library search path used internally by the compiler when linking
-# a shared library.
-compiler_lib_search_path=$lt_[]_LT_AC_TAGVAR(compiler_lib_search_path, $1)
-# Method to check whether dependent libraries are shared objects.
-deplibs_check_method=$lt_deplibs_check_method
-# Command to use when deplibs_check_method == file_magic.
-file_magic_cmd=$lt_file_magic_cmd
-# Flag that allows shared libraries with undefined symbols to be built.
-allow_undefined_flag=$lt_[]_LT_AC_TAGVAR(allow_undefined_flag, $1)
-# Flag that forces no undefined symbols.
-no_undefined_flag=$lt_[]_LT_AC_TAGVAR(no_undefined_flag, $1)
-# Commands used to finish a libtool library installation in a directory.
-finish_cmds=$lt_finish_cmds
-# Same as above, but a single script fragment to be evaled but not shown.
-finish_eval=$lt_finish_eval
-# Take the output of nm and produce a listing of raw symbols and C names.
-global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
-# Transform the output of nm in a proper C declaration
-global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
-# Transform the output of nm in a C name address pair
-global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
-# This is the shared library runtime path variable.
-runpath_var=$runpath_var
-# This is the shared library path variable.
-shlibpath_var=$shlibpath_var
-# Is shlibpath searched before the hard-coded library search path?
-shlibpath_overrides_runpath=$shlibpath_overrides_runpath
-# How to hardcode a shared library path into an executable.
-hardcode_action=$_LT_AC_TAGVAR(hardcode_action, $1)
-# Whether we should hardcode library paths into libraries.
-hardcode_into_libs=$hardcode_into_libs
-# Flag to hardcode \$libdir into a binary during linking.
-# This must work even if \$libdir does not exist.
-hardcode_libdir_flag_spec=$lt_[]_LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)
-# If ld is used when linking, flag to hardcode \$libdir into
-# a binary during linking. This must work even if \$libdir does
-# not exist.
-hardcode_libdir_flag_spec_ld=$lt_[]_LT_AC_TAGVAR(hardcode_libdir_flag_spec_ld, $1)
-# Whether we need a single -rpath flag with a separated argument.
-hardcode_libdir_separator=$lt_[]_LT_AC_TAGVAR(hardcode_libdir_separator, $1)
-# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
-# resulting binary.
-hardcode_direct=$_LT_AC_TAGVAR(hardcode_direct, $1)
-# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
-hardcode_minus_L=$_LT_AC_TAGVAR(hardcode_minus_L, $1)
-# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
-# the resulting binary.
-hardcode_shlibpath_var=$_LT_AC_TAGVAR(hardcode_shlibpath_var, $1)
-# Set to yes if building a shared library automatically hardcodes DIR into the library
-# and all subsequent libraries and executables linked against it.
-hardcode_automatic=$_LT_AC_TAGVAR(hardcode_automatic, $1)
-# Variables whose values should be saved in libtool wrapper scripts and
-# restored at relink time.
-variables_saved_for_relink="$variables_saved_for_relink"
-# Whether libtool must link a program against all its dependency libraries.
-link_all_deplibs=$_LT_AC_TAGVAR(link_all_deplibs, $1)
-# Compile-time system search path for libraries
-sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
-# Run-time system search path for libraries
-sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
-# Fix the shell variable \$srcfile for the compiler.
-fix_srcfile_path="$_LT_AC_TAGVAR(fix_srcfile_path, $1)"
-# Set to yes if exported symbols are required.
-always_export_symbols=$_LT_AC_TAGVAR(always_export_symbols, $1)
-# The commands to list exported symbols.
-export_symbols_cmds=$lt_[]_LT_AC_TAGVAR(export_symbols_cmds, $1)
-# The commands to extract the exported symbol list from a shared archive.
-extract_expsyms_cmds=$lt_extract_expsyms_cmds
-# Symbols that should not be listed in the preloaded symbols.
-exclude_expsyms=$lt_[]_LT_AC_TAGVAR(exclude_expsyms, $1)
-# Symbols that must always be exported.
-include_expsyms=$lt_[]_LT_AC_TAGVAR(include_expsyms, $1)
-ifelse([$1],[],
-[# ### END LIBTOOL CONFIG],
-[# ### END LIBTOOL TAG CONFIG: $tagname])
-__EOF__
-ifelse([$1],[], [
- case $host_os in
- aix3*)
- cat <<\EOF >> "$cfgfile"
-# AIX sometimes has problems with the GCC collect2 program. For some
-# reason, if we set the COLLECT_NAMES environment variable, the problems
-# vanish in a puff of smoke.
-if test "X${COLLECT_NAMES+set}" != Xset; then
- COLLECT_NAMES=
- export COLLECT_NAMES
-fi
-EOF
- esac
- # We use sed instead of cat because bash on DJGPP gets confused if
- # if finds mixed CR/LF and LF-only lines. Since sed operates in
- # text mode, it properly converts lines to CR/LF. This bash problem
- # is reportedly fixed, but why not run on old versions too?
- sed '$q' "$ltmain" >> "$cfgfile" || (rm -f "$cfgfile"; exit 1)
- mv -f "$cfgfile" "$ofile" || \
- (rm -f "$ofile" && cp "$cfgfile" "$ofile" && rm -f "$cfgfile")
- chmod +x "$ofile"
-else
- # If there is no Makefile yet, we rely on a make rule to execute
- # `config.status --recheck' to rerun these tests and create the
- # libtool script then.
- test -f Makefile && make "$ltmain"
-fi
-])# AC_LIBTOOL_CONFIG
-# AC_LIBTOOL_PROG_COMPILER_NO_RTTI([TAGNAME])
-AC_DEFUN([AC_LIBTOOL_PROG_COMPILER_NO_RTTI],
-[AC_REQUIRE([_LT_AC_SYS_COMPILER])dnl
-_LT_AC_TAGVAR(lt_prog_compiler_no_builtin_flag, $1)=
-if test "$GCC" = yes; then
- AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -fno-rtti -fno-exceptions],
- lt_cv_prog_compiler_rtti_exceptions,
- [-fno-rtti -fno-exceptions], [],
- [_LT_AC_TAGVAR(lt_prog_compiler_no_builtin_flag, $1)="$_LT_AC_TAGVAR(lt_prog_compiler_no_builtin_flag, $1) -fno-rtti -fno-exceptions"])
-fi
-])# AC_LIBTOOL_PROG_COMPILER_NO_RTTI
-# AC_LIBTOOL_SYS_GLOBAL_SYMBOL_PIPE
-AC_DEFUN([AC_LIBTOOL_SYS_GLOBAL_SYMBOL_PIPE],
-AC_REQUIRE([AC_PROG_NM])
-AC_REQUIRE([AC_OBJEXT])
-# Check for command to grab the raw symbol name followed by C symbol from nm.
-AC_MSG_CHECKING([command to parse $NM output from $compiler object])
-AC_CACHE_VAL([lt_cv_sys_global_symbol_pipe],
-# These are sane defaults that work on at least a few old systems.
-# [They come from Ultrix. What could be older than Ultrix?!! ;)]
-# Character class describing NM global symbol codes.
-symcode='[[BCDEGRST]]'
-# Regexp to match symbols that can be accessed directly from C.
-sympat='\([[_A-Za-z]][[_A-Za-z0-9]]*\)'
-# Transform the above into a raw symbol and a C symbol.
-symxfrm='\1 \2\3 \3'
-# Transform an extracted symbol line into a proper C declaration
-lt_cv_sys_global_symbol_to_cdecl="sed -n -e 's/^. .* \(.*\)$/extern int \1;/p'"
-# Transform an extracted symbol line into symbol name and symbol address
-lt_cv_sys_global_symbol_to_c_name_address="sed -n -e 's/^: \([[^ ]]*\) $/ {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode \([[^ ]]*\) \([[^ ]]*\)$/ {\"\2\", (lt_ptr) \&\2},/p'"
-# Define system-specific variables.
-case $host_os in
-aix*)
- symcode='[[BCDT]]'
-cygwin* | mingw* | pw32*)
- symcode='[[ABCDGISTW]]'
-hpux*) # Its linker distinguishes data from code symbols
- if test "$host_cpu" = ia64; then
- symcode='[[ABCDEGRST]]'
- fi
- lt_cv_sys_global_symbol_to_cdecl="sed -n -e 's/^T .* \(.*\)$/extern int \1();/p' -e 's/^$symcode* .* \(.*\)$/extern char \1;/p'"
- lt_cv_sys_global_symbol_to_c_name_address="sed -n -e 's/^: \([[^ ]]*\) $/ {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode* \([[^ ]]*\) \([[^ ]]*\)$/ {\"\2\", (lt_ptr) \&\2},/p'"
-irix* | nonstopux*)
- symcode='[[BCDEGRST]]'
-osf*)
- symcode='[[BCDEGQRST]]'
-solaris* | sysv5*)
- symcode='[[BDT]]'
-sysv4)
- symcode='[[DFNSTU]]'
-esac
-# Handle CRLF in mingw tool chain
-opt_cr=
-case $build_os in
-mingw*)
- opt_cr=`echo 'x\{0,1\}' | tr x '\015'` # option cr in regexp
-esac
-# If we're using GNU nm, then use its standard symbol codes.
-case `$NM -V 2>&1` in
-*GNU* | *'with BFD'*)
- symcode='[[ABCDGISTW]]' ;;
-esac
-# Try without a prefix undercore, then with it.
-for ac_symprfx in "" "_"; do
- # Write the raw and C identifiers.
- lt_cv_sys_global_symbol_pipe="sed -n -e 's/^.*[[ ]]\($symcode$symcode*\)[[ ]][[ ]]*\($ac_symprfx\)$sympat$opt_cr$/$symxfrm/p'"
- # Check to see that the pipe works correctly.
- pipe_works=no
- rm -f conftest*
- cat > conftest.$ac_ext <<EOF
-#ifdef __cplusplus
-extern "C" {
-#endif
-char nm_test_var;
-void nm_test_func(){}
-#ifdef __cplusplus
-#endif
-int main(){nm_test_var='a';nm_test_func();return(0);}
-EOF
- if AC_TRY_EVAL(ac_compile); then
- # Now try to grab the symbols.
- nlist=conftest.nm
- if AC_TRY_EVAL(NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist) && test -s "$nlist"; then
- # Try sorting and uniquifying the output.
- if sort "$nlist" | uniq > "$nlist"T; then
- mv -f "$nlist"T "$nlist"
- else
- rm -f "$nlist"T
- fi
- # Make sure that we snagged all the symbols we need.
- if grep ' nm_test_var$' "$nlist" >/dev/null; then
- if grep ' nm_test_func$' "$nlist" >/dev/null; then
- cat <<EOF > conftest.$ac_ext
-#ifdef __cplusplus
-extern "C" {
-#endif
-EOF
- # Now generate the symbol file.
- eval "$lt_cv_sys_global_symbol_to_cdecl"' < "$nlist" | grep -v main >> conftest.$ac_ext'
- cat <<EOF >> conftest.$ac_ext
-#if defined (__STDC__) && __STDC__
-# define lt_ptr_t void *
-#else
-# define lt_ptr_t char *
-# define const
-#endif
-/* The mapping between symbol names and symbols. */
-const struct {
- const char *name;
- lt_ptr_t address;
-lt_preloaded_symbols[[]] =
-EOF
- $SED "s/^$symcode$symcode* \(.*\) \(.*\)$/ {\"\2\", (lt_ptr_t) \&\2},/" < "$nlist" | grep -v main >> conftest.$ac_ext
- cat <<\EOF >> conftest.$ac_ext
- {0, (lt_ptr_t) 0}
-#ifdef __cplusplus
-#endif
-EOF
- # Now try linking the two files.
- mv conftest.$ac_objext conftstm.$ac_objext
- lt_save_LIBS="$LIBS"
- lt_save_CFLAGS="$CFLAGS"
- LIBS="conftstm.$ac_objext"
- CFLAGS="$CFLAGS$_LT_AC_TAGVAR(lt_prog_compiler_no_builtin_flag, $1)"
- if AC_TRY_EVAL(ac_link) && test -s conftest${ac_exeext}; then
- pipe_works=yes
- fi
- LIBS="$lt_save_LIBS"
- CFLAGS="$lt_save_CFLAGS"
- else
- echo "cannot find nm_test_func in $nlist" >&AS_MESSAGE_LOG_FD
- fi
- else
- echo "cannot find nm_test_var in $nlist" >&AS_MESSAGE_LOG_FD
- fi
- else
- echo "cannot run $lt_cv_sys_global_symbol_pipe" >&AS_MESSAGE_LOG_FD
- fi
- else
- echo "$progname: failed program was:" >&AS_MESSAGE_LOG_FD
- cat conftest.$ac_ext >&5
- fi
- rm -f conftest* conftst*
- # Do not use the global_symbol_pipe unless it works.
- if test "$pipe_works" = yes; then
- break
- else
- fi
-done
-if test -z "$lt_cv_sys_global_symbol_pipe"; then
-fi
-if test -z "$lt_cv_sys_global_symbol_pipe$lt_cv_sys_global_symbol_to_cdecl"; then
- AC_MSG_RESULT(failed)
-else
- AC_MSG_RESULT(ok)
-fi
-]) # AC_LIBTOOL_SYS_GLOBAL_SYMBOL_PIPE
-# AC_LIBTOOL_PROG_COMPILER_PIC([TAGNAME])
-AC_DEFUN([AC_LIBTOOL_PROG_COMPILER_PIC],
-[_LT_AC_TAGVAR(lt_prog_compiler_wl, $1)=
-_LT_AC_TAGVAR(lt_prog_compiler_pic, $1)=
-_LT_AC_TAGVAR(lt_prog_compiler_static, $1)=
-AC_MSG_CHECKING([for $compiler option to produce PIC])
- ifelse([$1],[CXX],[
- # C++ specific cases for pic, static, wl, etc.
- _LT_AC_TAGVAR(lt_prog_compiler_wl, $1)='-Wl,'
- _LT_AC_TAGVAR(lt_prog_compiler_static, $1)='-static'
- case $host_os in
- aix*)
- # All AIX code is PIC.
- # AIX 5 now supports IA64 processor
- _LT_AC_TAGVAR(lt_prog_compiler_static, $1)='-Bstatic'
- fi
- amigaos*)
- # FIXME: we need at least 68020 code to build shared libraries, but
- # adding the `-m68020' flag to GCC prevents building anything better,
- # like `-m68040'.
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)='-m68020 -resident32 -malways-restore-a4'
- beos* | cygwin* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
- # PIC is the default for these OSes.
- mingw* | os2* | pw32*)
- # This hack is so that the source file can tell whether it is being
- # built for inclusion in a dll (and should export symbols for example).
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)='-DDLL_EXPORT'
- # PIC is the default on this platform
- # Common symbols not allowed in MH_DYLIB files
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)='-fno-common'
- *djgpp*)
- # DJGPP does not support shared libraries at all
- sysv4*MP*)
- if test -d /usr/nec; then
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)=-Kconform_pic
- fi
- hpux*)
- # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
- # not for PA HP-UX.
- case "$host_cpu" in
- hppa*64*|ia64*)
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)='-fPIC'
- esac
- esac
- else
- case $host_os in
- aix4* | aix5*)
- else
- _LT_AC_TAGVAR(lt_prog_compiler_static, $1)='-bnso -bI:/lib/syscalls.exp'
- fi
- chorus*)
- cxch68)
- # _LT_AC_TAGVAR(lt_prog_compiler_static, $1)="--no_auto_instantiation -u __main -u __premain -u _abort -r $COOL_DIR/lib/libOrb.a $MVME_DIR/lib/CC/libC.a $MVME_DIR/lib/classix/libcx.s.a"
- esac
- dgux*)
- ec++)
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)='-KPIC'
- ghcx)
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)='-pic'
- esac
- freebsd*)
- # FreeBSD uses GNU C++
- hpux9* | hpux10* | hpux11*)
- CC)
- _LT_AC_TAGVAR(lt_prog_compiler_static, $1)="${ac_cv_prog_cc_wl}-a ${ac_cv_prog_cc_wl}archive"
- if test "$host_cpu" != ia64; then
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)='+Z'
- fi
- aCC)
- hppa*64*|ia64*)
- # +Z the default
- esac
- esac
- irix5* | irix6* | nonstopux*)
- CC)
- _LT_AC_TAGVAR(lt_prog_compiler_static, $1)='-non_shared'
- # CC pic flag -KPIC is the default.
- esac
- linux*)
- KCC)
- # KAI C++ Compiler
- _LT_AC_TAGVAR(lt_prog_compiler_wl, $1)='--backend -Wl,'
- icpc)
- # Intel C++
- cxx)
- # Compaq C++
- # Make sure the PIC flag is empty. It appears that all Alpha
- # Linux and Compaq Tru64 Unix objects are PIC.
- esac
- lynxos*)
- m88k*)
- mvs*)
- cxx)
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)='-W c,exportall'
- esac
- netbsd*)
- osf3* | osf4* | osf5*)
- KCC)
- RCC)
- cxx)
- # Digital/Compaq C++
- esac
- psos*)
- sco*)
- CC)
- esac
- solaris*)
- CC)
- _LT_AC_TAGVAR(lt_prog_compiler_wl, $1)='-Qoption ld '
- gcx)
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)='-PIC'
- esac
- sunos4*)
- CC)
- # Sun C++ 4.x
- lcc)
- # Lucid
- esac
- tandem*)
- NCC)
- esac
- unixware*)
- vxworks*)
- _LT_AC_TAGVAR(lt_prog_compiler_can_build_shared, $1)=no
- esac
- fi
- if test "$GCC" = yes; then
- case $host_os in
- aix*)
- fi
- amigaos*)
- # like `-m68040'.
- mingw* | pw32* | os2*)
- msdosdjgpp*)
- # Just because we use GCC doesn't mean we suddenly get shared libraries
- # on systems that don't support them.
- enable_shared=no
- sysv4*MP*)
- fi
- hpux*)
- hppa*64*|ia64*)
- # +Z the default
- esac
- esac
- else
- # PORTME Check for flag to pass linker flags through the system compiler.
- case $host_os in
- aix*)
- else
- fi
- hppa*64*|ia64*)
- # +Z the default
- esac
- # Is there a better lt_prog_compiler_static that works with the bundled CC?
- _LT_AC_TAGVAR(lt_prog_compiler_static, $1)='${wl}-a ${wl}archive'
- # PIC (with -KPIC) is the default.
- newsos6)
- linux*)
- case $CC in
- icc|ecc)
- ccc)
- # All Alpha code is PIC.
- esac
- # All OSF/1 code is PIC.
- sco3.2v5*)
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)='-Kpic'
- _LT_AC_TAGVAR(lt_prog_compiler_static, $1)='-dn'
- solaris*)
- sunos4*)
- sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
- sysv4*MP*)
- if test -d /usr/nec ;then
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)='-Kconform_pic'
- fi
- uts4*)
- esac
- fi
-AC_MSG_RESULT([$_LT_AC_TAGVAR(lt_prog_compiler_pic, $1)])
-# Check to make sure the PIC flag actually works.
-if test -n "$_LT_AC_TAGVAR(lt_prog_compiler_pic, $1)"; then
- AC_LIBTOOL_COMPILER_OPTION([if $compiler PIC flag $_LT_AC_TAGVAR(lt_prog_compiler_pic, $1) works],
- _LT_AC_TAGVAR(lt_prog_compiler_pic_works, $1),
- [$_LT_AC_TAGVAR(lt_prog_compiler_pic, $1)ifelse([$1],[],[ -DPIC],[ifelse([$1],[CXX],[ -DPIC],[])])], [],
- [case $_LT_AC_TAGVAR(lt_prog_compiler_pic, $1) in
- *) _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)=" $_LT_AC_TAGVAR(lt_prog_compiler_pic, $1)" ;;
- esac],
- [_LT_AC_TAGVAR(lt_prog_compiler_pic, $1)=
- _LT_AC_TAGVAR(lt_prog_compiler_can_build_shared, $1)=no])
-fi
-case "$host_os" in
- # For platforms which do not support PIC, -DPIC is meaningless:
- *djgpp*)
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)="$_LT_AC_TAGVAR(lt_prog_compiler_pic, $1)ifelse([$1],[],[ -DPIC],[ifelse([$1],[CXX],[ -DPIC],[])])"
-esac
-# AC_LIBTOOL_PROG_LD_SHLIBS([TAGNAME])
-# See if the linker supports building shared libraries.
-AC_DEFUN([AC_LIBTOOL_PROG_LD_SHLIBS],
-[AC_MSG_CHECKING([whether the $compiler linker ($LD) supports shared libraries])
-ifelse([$1],[CXX],[
- _LT_AC_TAGVAR(export_symbols_cmds, $1)='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
- case $host_os in
- aix4* | aix5*)
- # If we're using GNU nm, then we don't want the "-C" option.
- # -C means demangle to AIX nm, but means don't demangle with GNU nm
- if $NM -V 2>&1 | grep 'GNU' > /dev/null; then
- _LT_AC_TAGVAR(export_symbols_cmds, $1)='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\[$]2 == "T") || (\[$]2 == "D") || (\[$]2 == "B")) && ([substr](\[$]3,1,1) != ".")) { print \[$]3 } }'\'' | sort -u > $export_symbols'
- else
- _LT_AC_TAGVAR(export_symbols_cmds, $1)='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\[$]2 == "T") || (\[$]2 == "D") || (\[$]2 == "B")) && ([substr](\[$]3,1,1) != ".")) { print \[$]3 } }'\'' | sort -u > $export_symbols'
- fi
- pw32*)
- _LT_AC_TAGVAR(export_symbols_cmds, $1)="$ltdll_cmds"
- cygwin* | mingw*)
- _LT_AC_TAGVAR(export_symbols_cmds, $1)='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[[BCDGS]] /s/.* \([[^ ]]*\)/\1 DATA/'\'' | $SED -e '\''/^[[AITW]] /s/.* //'\'' | sort | uniq > $export_symbols'
- esac
- runpath_var=
- _LT_AC_TAGVAR(enable_shared_with_static_runtimes, $1)=no
- _LT_AC_TAGVAR(old_archive_From_new_cmds, $1)=
- _LT_AC_TAGVAR(old_archive_from_expsyms_cmds, $1)=
- _LT_AC_TAGVAR(thread_safe_flag_spec, $1)=
- _LT_AC_TAGVAR(hardcode_minus_L, $1)=no
- _LT_AC_TAGVAR(link_all_deplibs, $1)=unknown
- _LT_AC_TAGVAR(hardcode_automatic, $1)=no
- # include_expsyms should be a list of space-separated symbols to be *always*
- # included in the symbol list
- _LT_AC_TAGVAR(include_expsyms, $1)=
- # exclude_expsyms can be an extended regexp of symbols to exclude
- # it will be wrapped by ` (' and `)$', so one must not match beginning or
- # end of line. Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
- # as well as any symbol that contains `d'.
- _LT_AC_TAGVAR(exclude_expsyms, $1)="_GLOBAL_OFFSET_TABLE_"
- # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
- # platforms (ab)use it in PIC code, but their linkers get confused if
- # the symbol is explicitly referenced. Since portable code cannot
- # rely on this symbol name, it's probably fine to never include it in
- # preloaded symbol tables.
- extract_expsyms_cmds=
- case $host_os in
- # FIXME: the MSVC++ port hasn't been tested in a loooong time
- # When not using gcc, we currently assume that we are using
- # Microsoft Visual C++.
- if test "$GCC" != yes; then
- with_gnu_ld=no
- fi
- openbsd*)
- with_gnu_ld=no
- esac
- if test "$with_gnu_ld" = yes; then
- wlarc='${wl}'
- # See if GNU ld supports shared libraries.
- case $host_os in
- aix3* | aix4* | aix5*)
- # On AIX/PPC, the GNU linker is very broken
- cat <<EOF 1>&2
-*** Warning: the GNU linker, at least up to release 2.9.1, is reported
-*** to be unable to reliably create shared libraries on AIX.
-*** Therefore, libtool is disabling shared libraries support. If you
-*** really care for shared libraries, you may want to modify your PATH
-*** so that a non-GNU linker is found, and then restart.
-EOF
- fi
- amigaos*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
- # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
- # that the semantics of dynamic libraries on AmigaOS, at least up
- # to version 4, is to share data among multiple programs linked
- # with the same dynamic library. Since this doesn't match the
- # behavior of shared libraries on other platforms, we can't use
- # them.
- beos*)
- if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
- # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
- # support --undefined. This deserves some investigation. FIXME
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- else
- fi
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
- else
- fi~
- $CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
- else
- ld_shlibs=no
- fi
- netbsd*)
- if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
- wlarc=
- else
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- fi
- solaris* | sysv5*)
- if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
- cat <<EOF 1>&2
-*** Warning: The releases 2.8.* of the GNU linker cannot reliably
-*** create shared libraries on Solaris systems. Therefore, libtool
-*** is disabling shared libraries support. We urge you to upgrade GNU
-*** binutils to release 2.9.1 or newer. Another option is to modify
-*** your PATH or compiler configuration so that the native linker is
-*** used, and then restart.
-EOF
- elif $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
- else
- fi
- sunos4*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- wlarc=
- else
- fi
- esac
- if test "$_LT_AC_TAGVAR(ld_shlibs, $1)" = yes; then
- runpath_var=LD_RUN_PATH
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}--rpath ${wl}$libdir'
- _LT_AC_TAGVAR(export_dynamic_flag_spec, $1)='${wl}--export-dynamic'
- if $LD --help 2>&1 | grep 'no-whole-archive' > /dev/null; then
- else
- fi
- fi
- else
- # PORTME fill in a description of your system's linker (not GNU ld)
- case $host_os in
- aix3*)
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
- # Note: this linker hardcodes the directories in LIBPATH if there
- # are no directories specified by -L.
- if test "$GCC" = yes && test -z "$link_static_flag"; then
- # Neither direct hardcoding nor static linking is supported with a
- # broken collect2.
- fi
- aix4* | aix5*)
- no_entry_flag=""
- else
- else
- fi
- if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
- break
- fi
- done
- esac
- fi
- _LT_AC_TAGVAR(link_all_deplibs, $1)=yes
- then
- else
- fi
- esac
- else
- # not using gcc
- shared_flag='-G'
- else
- if test "$aix_use_runtimelinking" = yes; then
- else
- fi
- fi
- fi
- else
- else
- fi
- fi
- amigaos*)
- # see comment about different semantics on the GNU ld section
- bsdi4*)
- _LT_AC_TAGVAR(export_dynamic_flag_spec, $1)=-rdynamic
- # hardcode_libdir_flag_spec is actually meaningless, as there is
- # no search path for DLLs.
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)=' '
- # Tell ltmain to make .lib files, not .a files.
- libext=lib
- # Tell ltmain to make .dll files, not .so files.
- shrext=".dll"
- # FIXME: Setting linknames here is a bad hack.
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | $SED -e '\''s/ -lc$//'\''` -link -dll~linknames='
- # The linker will automatically build a .lib file if we build a DLL.
- _LT_AC_TAGVAR(old_archive_From_new_cmds, $1)='true'
- # FIXME: Should let the user specify the lib program.
- _LT_AC_TAGVAR(old_archive_cmds, $1)='lib /OUT:$oldlib$oldobjs$old_deplibs'
- fix_srcfile_path='`cygpath -w "$srcfile"`'
- darwin* | rhapsody*)
- if $CC -v 2>&1 | grep 'Apple' >/dev/null ; then
- _LT_AC_TAGVAR(archive_cmds_need_lc, $1)=no
- case "$host_os" in
- rhapsody* | darwin1.[[012]])
- _LT_AC_TAGVAR(allow_undefined_flag, $1)='-undefined suppress'
- *) # Darwin 1.3 on
- test -z ${LD_TWOLEVEL_NAMESPACE} && _LT_AC_TAGVAR(allow_undefined_flag, $1)='-flat_namespace -undefined suppress'
- esac
- # FIXME: Relying on posixy $() will cause problems for
- # cross-compilation, but unfortunately the echo tests do not
- # yet detect zsh echo's removal of \ escapes. Also zsh mangles
- # `"' quotes if we put them in here... so don't!
- output_verbose_link_cmd='echo'
- fi
- else
- fi
- # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin ld's
- else
- fi
- _LT_AC_TAGVAR(module_expsym_cmds, $1)='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -bundle $allow_undefined_flag -o $lib $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- _LT_AC_TAGVAR(hardcode_direct, $1)=no
- _LT_AC_TAGVAR(hardcode_automatic, $1)=yes
- _LT_AC_TAGVAR(hardcode_shlibpath_var, $1)=unsupported
- _LT_AC_TAGVAR(whole_archive_flag_spec, $1)='-all_load $convenience'
- fi
- dgux*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='-L$libdir'
- freebsd1*)
- _LT_AC_TAGVAR(ld_shlibs, $1)=no
- # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
- # support. Future versions do this automatically, but an explicit c++rt0.o
- # does not break anything, and helps significantly (at the cost of a little
- # extra space).
- freebsd2.2*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
- _LT_AC_TAGVAR(hardcode_direct, $1)=yes
- # Unfortunately, older versions of FreeBSD 2 do not have this feature.
- freebsd2*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
- freebsd*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
- hpux9*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$rm $output_objdir/$soname~$CC -shared -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- else
- _LT_AC_TAGVAR(archive_cmds, $1)='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- fi
- # hardcode_minus_L: Not really in the search PATH,
- # but as the default location of the library.
- hpux10* | hpux11*)
- if test "$GCC" = yes -a "$with_gnu_ld" = no; then
- hppa*64*|ia64*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
- esac
- else
- hppa*64*|ia64*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -b +h $soname -o $lib $libobjs $deplibs $linker_flags'
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
- esac
- fi
- hppa*64*)
- ia64*)
- esac
- fi
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec_ld, $1)='-rpath $libdir'
- fi
- netbsd*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags' # a.out
- else
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -shared -o $lib $libobjs $deplibs $linker_flags' # ELF
- fi
- newsos6)
- openbsd*)
- if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
- else
- case $host_os in
- openbsd[[01]].* | openbsd2.[[0-7]] | openbsd2.[[0-7]].*)
- esac
- fi
- os2*)
- _LT_AC_TAGVAR(allow_undefined_flag, $1)=unsupported
- _LT_AC_TAGVAR(archive_cmds, $1)='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
- _LT_AC_TAGVAR(old_archive_From_new_cmds, $1)='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
- osf3*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- fi
- osf4* | osf5*) # as osf3* with the addition of -msym flag
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
- $LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${objdir}/so_locations -o $lib~$rm $lib.exp'
- # Both c and cxx compiler support -rpath directly
- fi
- _LT_AC_TAGVAR(hardcode_libdir_separator, $1)=:
- sco3.2v5*)
- _LT_AC_TAGVAR(export_dynamic_flag_spec, $1)='${wl}-Bexport'
- hardcode_runpath_var=yes
- solaris*)
- _LT_AC_TAGVAR(no_undefined_flag, $1)=' -z text'
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- $CC -shared ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$rm $lib.exp'
- else
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
- $LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
- fi
- case $host_os in
- solaris2.[[0-5]] | solaris2.[[0-5]].*) ;;
- *) # Supported since Solaris 2.6 (maybe 2.5.1?)
- _LT_AC_TAGVAR(whole_archive_flag_spec, $1)='-z allextract$convenience -z defaultextract' ;;
- esac
- sunos4*)
- if test "x$host_vendor" = xsequent; then
- # Use $CC to link under sequent, because it throws in some extra .o
- # files that make .init and .fini sections work.
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
- fi
- _LT_AC_TAGVAR(hardcode_minus_L, $1)=yes
- sysv4)
- case $host_vendor in
- sni)
- _LT_AC_TAGVAR(hardcode_direct, $1)=yes # is this really true???
- siemens)
- ## LD is ld it makes a PLAMLIB
- ## CC just makes a GrossModule.
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -G -o $lib $libobjs $deplibs $linker_flags'
- _LT_AC_TAGVAR(reload_cmds, $1)='$CC -r -o $output$reload_objs'
- motorola)
- _LT_AC_TAGVAR(hardcode_direct, $1)=no #Motorola manual says yes, but my tests say they lie
- esac
- runpath_var='LD_RUN_PATH'
- _LT_AC_TAGVAR(hardcode_shlibpath_var, $1)=no
- sysv4.3*)
- _LT_AC_TAGVAR(export_dynamic_flag_spec, $1)='-Bexport'
- sysv4*MP*)
- _LT_AC_TAGVAR(ld_shlibs, $1)=yes
- fi
- sysv4.2uw2*)
- _LT_AC_TAGVAR(no_undefined_flag, $1)='${wl}-z ${wl}text'
- else
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -G ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- fi
- sysv5*)
- # $CC -shared without GNU ld will not create a library from C++
- # object files and a static libstdc++, better avoid it by now
- uts4*)
- esac
- fi
-variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
- variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
-fi
-# Do we need to explicitly link libc?
-case "x$_LT_AC_TAGVAR(archive_cmds_need_lc, $1)" in
-x|xyes)
- # Assume -lc should be added
- _LT_AC_TAGVAR(archive_cmds_need_lc, $1)=yes
- if test "$enable_shared" = yes && test "$GCC" = yes; then
- case $_LT_AC_TAGVAR(archive_cmds, $1) in
- # FIXME: we may have to deal with multi-command sequences.
- '$CC '*)
- # Test whether the compiler implicitly links with -lc since on some
- # systems, -lgcc has to come before -lc. If gcc already passes -lc
- # to ld, don't add -lc before -lgcc.
- AC_MSG_CHECKING([whether -lc should be explicitly linked in])
- $rm conftest*
- printf "$lt_simple_compile_test_code" > conftest.$ac_ext
- if AC_TRY_EVAL(ac_compile) 2>conftest.err; then
- soname=conftest
- lib=conftest
- libobjs=conftest.$ac_objext
- deplibs=
- wl=$_LT_AC_TAGVAR(lt_prog_compiler_wl, $1)
- compiler_flags=-v
- linker_flags=-v
- verstring=
- output_objdir=.
- libname=conftest
- lt_save_allow_undefined_flag=$_LT_AC_TAGVAR(allow_undefined_flag, $1)
- if AC_TRY_EVAL(_LT_AC_TAGVAR(archive_cmds, $1) 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1)
- then
- else
- fi
- _LT_AC_TAGVAR(allow_undefined_flag, $1)=$lt_save_allow_undefined_flag
- else
- cat conftest.err 1>&5
- fi
- $rm conftest*
- AC_MSG_RESULT([$_LT_AC_TAGVAR(archive_cmds_need_lc, $1)])
- esac
- fi
-esac
-])# AC_LIBTOOL_PROG_LD_SHLIBS
-# _LT_AC_FILE_LTDLL_C
-# Be careful that the start marker always follows a newline.
-AC_DEFUN([_LT_AC_FILE_LTDLL_C], [
-# /* ltdll.c starts here */
-# #define WIN32_LEAN_AND_MEAN
-# #include <windows.h>
-# #undef WIN32_LEAN_AND_MEAN
-# #include <stdio.h>
-# #ifndef __CYGWIN__
-# # ifdef __CYGWIN32__
-# # define __CYGWIN__ __CYGWIN32__
-# # endif
-# #endif
-# #ifdef __cplusplus
-# extern "C" {
-# #endif
-# BOOL APIENTRY DllMain (HINSTANCE hInst, DWORD reason, LPVOID reserved);
-# #endif
-# #ifdef __CYGWIN__
-# #include <cygwin/cygwin_dll.h>
-# DECLARE_CYGWIN_DLL( DllMain );
-# #endif
-# HINSTANCE __hDllInstance_base;
-# BOOL APIENTRY
-# DllMain (HINSTANCE hInst, DWORD reason, LPVOID reserved)
-# __hDllInstance_base = hInst;
-# return TRUE;
-# /* ltdll.c ends here */
-])# _LT_AC_FILE_LTDLL_C
-# _LT_AC_TAGVAR(VARNAME, [TAGNAME])
-AC_DEFUN([_LT_AC_TAGVAR], [ifelse([$2], [], [$1], [$1_$2])])
-# old names
-AC_DEFUN([AM_PROG_LIBTOOL], [AC_PROG_LIBTOOL])
-AC_DEFUN([AM_ENABLE_SHARED], [AC_ENABLE_SHARED($@)])
-AC_DEFUN([AM_ENABLE_STATIC], [AC_ENABLE_STATIC($@)])
-AC_DEFUN([AM_DISABLE_SHARED], [AC_DISABLE_SHARED($@)])
-AC_DEFUN([AM_DISABLE_STATIC], [AC_DISABLE_STATIC($@)])
-AC_DEFUN([AM_PROG_LD], [AC_PROG_LD])
-AC_DEFUN([AM_PROG_NM], [AC_PROG_NM])
-# This is just to silence aclocal about the macro not being used
-ifelse([AC_DISABLE_FAST_INSTALL])
-AC_DEFUN([LT_AC_PROG_GCJ],
-[AC_CHECK_TOOL(GCJ, gcj, no)
- test "x${GCJFLAGS+set}" = xset || GCJFLAGS="-g -O2"
- AC_SUBST(GCJFLAGS)
-AC_DEFUN([LT_AC_PROG_RC],
-[AC_CHECK_TOOL(RC, windres, no)
-# NOTE: This macro has been submitted for inclusion into #
-# GNU Autoconf as AC_PROG_SED. When it is available in #
-# a released version of Autoconf we should remove this #
-# macro and use it instead. #
-# LT_AC_PROG_SED
-# Check for a fully-functional sed program, that truncates
-# as few characters as possible. Prefer GNU sed if found.
-AC_DEFUN([LT_AC_PROG_SED],
-[AC_MSG_CHECKING([for a sed that does not truncate output])
-AC_CACHE_VAL(lt_cv_path_SED,
-[# Loop through the user's path and test for sed and gsed.
-# Then use that list of sed's as ones to test for truncation.
-as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-for as_dir in $PATH
-do
- IFS=$as_save_IFS
- test -z "$as_dir" && as_dir=.
- for lt_ac_prog in sed gsed; do
- for ac_exec_ext in '' $ac_executable_extensions; do
- if $as_executable_p "$as_dir/$lt_ac_prog$ac_exec_ext"; then
- lt_ac_sed_list="$lt_ac_sed_list $as_dir/$lt_ac_prog$ac_exec_ext"
- fi
- done
- done
-done
-lt_ac_max=0
-lt_ac_count=0
-# Add /usr/xpg4/bin/sed as it is typically found on Solaris
-# along with /bin/sed that truncates output.
-for lt_ac_sed in $lt_ac_sed_list /usr/xpg4/bin/sed; do
- test ! -f $lt_ac_sed && break
- cat /dev/null > conftest.in
- lt_ac_count=0
- echo $ECHO_N "0123456789$ECHO_C" >conftest.in
- # Check for GNU sed and select it if it is found.
- if "$lt_ac_sed" --version 2>&1 < /dev/null | grep 'GNU' > /dev/null; then
- lt_cv_path_SED=$lt_ac_sed
- break
- fi
- while true; do
- cat conftest.in conftest.in >conftest.tmp
- mv conftest.tmp conftest.in
- cp conftest.in conftest.nl
- echo >>conftest.nl
- $lt_ac_sed -e 's/a$//' < conftest.nl >conftest.out || break
- cmp -s conftest.out conftest.nl || break
- # 10000 chars as input seems more than enough
- test $lt_ac_count -gt 10 && break
- lt_ac_count=`expr $lt_ac_count + 1`
- if test $lt_ac_count -gt $lt_ac_max; then
- lt_ac_max=$lt_ac_count
- fi
- done
-done
-SED=$lt_cv_path_SED
-AC_MSG_RESULT([$SED])
-# AC_LTDL_DLLIB
-AC_DEFUN([AC_LTDL_DLLIB],
-[LIBADD_DL=
-AC_SUBST(LIBADD_DL)
-AC_CHECK_FUNC([shl_load],
- [AC_DEFINE([HAVE_SHL_LOAD], [1],
- [Define if you have the shl_load function.])],
- [AC_CHECK_LIB([dld], [shl_load],
- LIBADD_DL="$LIBADD_DL -ldld"],
- [AC_CHECK_LIB([dl], [dlopen],
- [AC_DEFINE([HAVE_LIBDL], [1],
- [Define if you have the libdl library or equivalent.])
- LIBADD_DL="-ldl"],
- [AC_TRY_LINK([#if HAVE_DLFCN_H
-# include <dlfcn.h>
-#endif
- [dlopen(0, 0);],
- [Define if you have the libdl library or equivalent.])],
- [AC_CHECK_LIB([svld], [dlopen],
- LIBADD_DL="-lsvld"],
- [AC_CHECK_LIB([dld], [dld_link],
- [AC_DEFINE([HAVE_DLD], [1],
- [Define if you have the GNU dld library.])
-if test "x$ac_cv_func_dlopen" = xyes || test "x$ac_cv_lib_dl_dlopen" = xyes; then
- LIBS_SAVE="$LIBS"
- LIBS="$LIBS $LIBADD_DL"
- AC_CHECK_FUNCS(dlerror)
- LIBS="$LIBS_SAVE"
-fi
-])# AC_LTDL_DLLIB
-AC_DEFUN(BB_ENABLE_DOXYGEN,
-AC_ARG_ENABLE(doxygen, [ --enable-doxygen enable documentation generation with doxygen (auto)])
-AC_ARG_ENABLE(dot, [ --enable-dot use 'dot' to generate graphs in doxygen (auto)])
-AC_ARG_ENABLE(html-docs, [ --enable-html-docs enable HTML generation with doxygen (yes)], [], [ enable_html_docs=yes])
-AC_ARG_ENABLE(latex-docs, [ --enable-latex-docs enable LaTeX documentation generation with doxygen (no)], [], [ enable_latex_docs=no])
-if test "x$enable_doxygen" = xno; then
- enable_doc=no
-else
- AC_PATH_PROG(DOXYGEN, doxygen, , $PATH)
- if test "x$DOXYGEN" = x; then
- if test "x$enable_doxygen" = xyes; then
- AC_MSG_ERROR([could not find doxygen])
- fi
- enable_doc=no
- else
- enable_doc=yes
- AC_PATH_PROG(DOT, dot, , $PATH)
- fi
-fi
-AM_CONDITIONAL(DOC, test x$enable_doc = xyes)
-if test x$DOT = x; then
- if test "x$enable_dot" = xyes; then
- AC_MSG_ERROR([could not find dot])
- fi
- enable_dot=no
-else
- enable_dot=yes
-fi
-AC_SUBST(enable_dot)
-AC_SUBST(enable_html_docs)
-AC_SUBST(enable_latex_docs)
-dnl @synopsis AC_CXX_RTTI
-dnl
-dnl If the compiler supports Run-Time Type Identification (typeinfo
-dnl header and typeid keyword), define HAVE_RTTI.
-dnl
-dnl @version $Id: ac_cxx_rtti.m4,v 1.1 2001/06/02 22:29:52 smr99 Exp $
-dnl @author Luc Maisonobe
-dnl
-AC_DEFUN([AC_CXX_RTTI],
-[AC_CACHE_CHECK(whether the compiler supports Run-Time Type Identification,
-ac_cv_cxx_rtti,
-[AC_LANG_SAVE
- AC_LANG_CPLUSPLUS
- AC_TRY_COMPILE([#include <typeinfo>
-class Base { public :
- Base () {}
- virtual int f () { return 0; }
-class Derived : public Base { public :
- Derived () {}
- virtual int f () { return 1; }
-],[Derived d;
-Base *ptr = &d;
-return typeid (*ptr) == typeid (Derived);
- ac_cv_cxx_rtti=yes, ac_cv_cxx_rtti=no)
- AC_LANG_RESTORE
-if test "$ac_cv_cxx_rtti" = yes; then
- AC_DEFINE(HAVE_RTTI,1,
- [define if the compiler supports Run-Time Type Identification])
-fi
-dnl @synopsis AX_CXX_GCC_ABI_DEMANGLE
-dnl
-dnl If the compiler supports GCC C++ ABI name demangling (has header cxxabi.h
-dnl and abi::__cxa_demangle() function), define HAVE_GCC_ABI_DEMANGLE
-dnl
-dnl Adapted from AC_CXX_RTTI by Luc Maisonobe
-dnl
-dnl @version $Id: ax_cxx_gcc_abi_demangle.m4,v 1.1 2004/02/18 20:45:36 blep Exp $
-dnl @author Neil Ferguson <nferguso at eso.org>
-dnl
-AC_DEFUN([AX_CXX_GCC_ABI_DEMANGLE],
-[AC_CACHE_CHECK(whether the compiler supports GCC C++ ABI name demangling,
-ac_cv_cxx_gcc_abi_demangle,
-[AC_LANG_SAVE
- AC_LANG_CPLUSPLUS
-#include <cxxabi.h>
-#include <string>
-template<typename TYPE>
-class A {};
-],[A<int> instance;
-int status = 0;
-char* c_name = 0;
-c_name = abi::__cxa_demangle(typeid(instance).name(), 0, 0, &status);
-std::string name(c_name);
-free(c_name);
-return name == "A<int>";
- ac_cv_cxx_gcc_abi_demangle=yes, ac_cv_cxx_gcc_abi_demangle=no)
- AC_LANG_RESTORE
-if test "$ac_cv_cxx_gcc_abi_demangle" = yes; then
- AC_DEFINE(HAVE_GCC_ABI_DEMANGLE,1,
- [define if the compiler supports GCC C++ ABI name demangling])
-fi
-dnl @synopsis AC_CXX_STRING_COMPARE_STRING_FIRST
-dnl
-dnl If the standard library string::compare() function takes the
-dnl string as its first argument, define FUNC_STRING_COMPARE_STRING_FIRST to 1.
-dnl
-dnl @author Steven Robbins
-dnl
-AC_DEFUN([AC_CXX_STRING_COMPARE_STRING_FIRST],
-[AC_CACHE_CHECK(whether std::string::compare takes a string in argument 1,
-ac_cv_cxx_string_compare_string_first,
-[AC_REQUIRE([AC_CXX_NAMESPACES])
- AC_LANG_SAVE
- AC_LANG_CPLUSPLUS
- AC_TRY_COMPILE([#include <string>
-#ifdef HAVE_NAMESPACES
-using namespace std;
-#endif],[string x("hi"); string y("h");
-return x.compare(y,0,1) == 0;],
- ac_cv_cxx_string_compare_string_first=yes,
- ac_cv_cxx_string_compare_string_first=no)
- AC_LANG_RESTORE
-if test "$ac_cv_cxx_string_compare_string_first" = yes; then
- AC_DEFINE(FUNC_STRING_COMPARE_STRING_FIRST,1,
- [define if library uses std::string::compare(string,pos,n)])
-fi
-dnl @synopsis AC_CXX_NAMESPACES
-dnl
-dnl If the compiler can prevent names clashes using namespaces, define
-dnl HAVE_NAMESPACES.
-dnl
-dnl @version $Id: ac_cxx_namespaces.m4,v 1.1 2001/06/02 23:26:36 smr99 Exp $
-dnl
-AC_DEFUN([AC_CXX_NAMESPACES],
-[AC_CACHE_CHECK(whether the compiler implements namespaces,
-ac_cv_cxx_namespaces,
-[AC_LANG_SAVE
- AC_LANG_CPLUSPLUS
- AC_TRY_COMPILE([namespace Outer { namespace Inner { int i = 0; }}],
- [using namespace Outer::Inner; return i;],
- ac_cv_cxx_namespaces=yes, ac_cv_cxx_namespaces=no)
- AC_LANG_RESTORE
-if test "$ac_cv_cxx_namespaces" = yes; then
- AC_DEFINE(HAVE_NAMESPACES,1,[define to 1 if the compiler implements namespaces])
-fi
-dnl @synopsis AC_CXX_HAVE_SSTREAM
-dnl
-dnl If the C++ library has a working stringstream, define HAVE_SSTREAM.
-dnl
-dnl @author Ben Stanley
-dnl @version $Id: ac_cxx_have_sstream.m4,v 1.1 2001/07/07 16:05:47 smr99 Exp $
-dnl
-AC_DEFUN([AC_CXX_HAVE_SSTREAM],
-[AC_CACHE_CHECK(whether the compiler has stringstream,
-ac_cv_cxx_have_sstream,
- AC_LANG_SAVE
- AC_LANG_CPLUSPLUS
- AC_TRY_COMPILE([#include <sstream>
-#endif],[stringstream message; message << "Hello"; return 0;],
- ac_cv_cxx_have_sstream=yes, ac_cv_cxx_have_sstream=no)
- AC_LANG_RESTORE
-if test "$ac_cv_cxx_have_sstream" = yes; then
- AC_DEFINE(HAVE_SSTREAM,1,[define if the compiler has stringstream])
-fi
-dnl @synopsis AC_CXX_HAVE_STRSTREAM
-dnl
-dnl If the C++ library has a working strstream, define HAVE_CLASS_STRSTREAM.
-dnl
-dnl Adapted from ac_cxx_have_sstream.m4 by Steve Robbins
-dnl
-AC_DEFUN([AC_CXX_HAVE_STRSTREAM],
-[AC_CACHE_CHECK(whether the library defines class strstream,
-ac_cv_cxx_have_class_strstream,
- AC_LANG_SAVE
- AC_LANG_CPLUSPLUS
- AC_CHECK_HEADERS(strstream)
- AC_TRY_COMPILE([
-#if HAVE_STRSTREAM
-# include <strstream>
-#else
-# include <strstream.h>
-#endif
-#endif],[ostrstream message; message << "Hello"; return 0;],
- ac_cv_cxx_have_class_strstream=yes, ac_cv_cxx_have_class_strstream=no)
- AC_LANG_RESTORE
-if test "$ac_cv_cxx_have_class_strstream" = yes; then
- AC_DEFINE(HAVE_CLASS_STRSTREAM,1,[define if the library defines strstream])
-fi
-dnl @synopsis AC_CREATE_PREFIX_CONFIG_H [(OUTPUT-HEADER [,PREFIX [,ORIG-HEADER]])]
-dnl
-dnl this is a new variant from ac_prefix_config_
-dnl this one will use a lowercase-prefix if
-dnl the config-define was starting with a lowercase-char, e.g.
-dnl #define const or #define restrict or #define off_t
-dnl (and this one can live in another directory, e.g. testpkg/config.h
-dnl therefore I decided to move the output-header to be the first arg)
-dnl
-dnl takes the usual config.h generated header file; looks for each of
-dnl the generated "#define SOMEDEF" lines, and prefixes the defined name
-dnl (ie. makes it "#define PREFIX_SOMEDEF". The result is written to
-dnl the output config.header file. The PREFIX is converted to uppercase
-dnl for the conversions.
-dnl
-dnl default OUTPUT-HEADER = $PACKAGE-config.h
-dnl default PREFIX = $PACKAGE
-dnl default ORIG-HEADER, derived from OUTPUT-HEADER
-dnl if OUTPUT-HEADER has a "/", use the basename
-dnl if OUTPUT-HEADER has a "-", use the section after it.
-dnl otherwise, just config.h
-dnl
-dnl In most cases, the configure.in will contain a line saying
-dnl AC_CONFIG_HEADER(config.h)
-dnl somewhere *before* AC_OUTPUT and a simple line saying
-dnl AC_PREFIX_CONFIG_HEADER
-dnl somewhere *after* AC_OUTPUT.
-dnl
-dnl example:
-dnl AC_INIT(config.h.in) # config.h.in as created by "autoheader"
-dnl AM_INIT_AUTOMAKE(testpkg, 0.1.1) # "#undef VERSION" and "PACKAGE"
-dnl AM_CONFIG_HEADER(config.h) # in config.h.in
-dnl AC_MEMORY_H # "#undef NEED_MEMORY_H"
-dnl AC_C_CONST_H # "#undef const"
-dnl AC_OUTPUT(Makefile) # creates the "config.h" now
-dnl AC_CREATE_PREFIX_CONFIG_H # creates "testpkg-config.h"
-dnl and the resulting "testpkg-config.h" contains lines like
-dnl #ifndef TESTPKG_VERSION
-dnl #define TESTPKG_VERSION "0.1.1"
-dnl #endif
-dnl #ifndef TESTPKG_NEED_MEMORY_H
-dnl #define TESTPKG_NEED_MEMORY_H 1
-dnl #endif
-dnl #ifndef _testpkg_const
-dnl #define _testpkg_const const
-dnl #endif
-dnl
-dnl and this "testpkg-config.h" can be installed along with other
-dnl header-files, which is most convenient when creating a shared
-dnl library (that has some headers) where some functionality is
-dnl dependent on the OS-features detected at compile-time. No
-dnl need to invent some "testpkg-confdefs.h.in" manually. :-)
-dnl
-dnl @version $Id: ac_create_prefix_config_h.m4,v 1.1 2001/06/17 15:47:32 bastiaan Exp $
-dnl @author Guido Draheim <guidod at gmx.de>
-AC_DEFUN([AC_CREATE_PREFIX_CONFIG_H],
-[changequote({, })dnl
-ac_prefix_conf_OUT=`echo ifelse($1, , $PACKAGE-config.h, $1)`
-ac_prefix_conf_DEF=`echo _$ac_prefix_conf_OUT | sed -e 'y:abcdefghijklmnopqrstuvwxyz./,-:ABCDEFGHIJKLMNOPQRSTUVWXYZ____:'`
-ac_prefix_conf_PKG=`echo ifelse($2, , $PACKAGE, $2)`
-ac_prefix_conf_LOW=`echo _$ac_prefix_conf_PKG | sed -e 'y:ABCDEFGHIJKLMNOPQRSTUVWXYZ-:abcdefghijklmnopqrstuvwxyz_:'`
-ac_prefix_conf_UPP=`echo $ac_prefix_conf_PKG | sed -e 'y:abcdefghijklmnopqrstuvwxyz-:ABCDEFGHIJKLMNOPQRSTUVWXYZ_:' -e '/^[0-9]/s/^/_/'`
-ac_prefix_conf_INP=`echo ifelse($3, , _, $3)`
-if test "$ac_prefix_conf_INP" = "_"; then
- case $ac_prefix_conf_OUT in
- */*) ac_prefix_conf_INP=`basename $ac_prefix_conf_OUT`
- *-*) ac_prefix_conf_INP=`echo $ac_prefix_conf_OUT | sed -e 's/[a-zA-Z0-9_]*-//'`
- *) ac_prefix_conf_INP=config.h
- esac
-fi
-changequote([, ])dnl
-if test -z "$ac_prefix_conf_PKG" ; then
- AC_MSG_ERROR([no prefix for _PREFIX_PKG_CONFIG_H])
-else
- AC_MSG_RESULT(creating $ac_prefix_conf_OUT - prefix $ac_prefix_conf_UPP for $ac_prefix_conf_INP defines)
- if test -f $ac_prefix_conf_INP ; then
- AS_DIRNAME([/* automatically generated */], $ac_prefix_conf_OUT)
-changequote({, })dnl
- echo '#ifndef '$ac_prefix_conf_DEF >$ac_prefix_conf_OUT
- echo '#define '$ac_prefix_conf_DEF' 1' >>$ac_prefix_conf_OUT
- echo ' ' >>$ac_prefix_conf_OUT
- echo /'*' $ac_prefix_conf_OUT. Generated automatically at end of configure. '*'/ >>$ac_prefix_conf_OUT
- echo 's/#undef *\([A-Z_]\)/#undef '$ac_prefix_conf_UPP'_\1/' >conftest.sed
- echo 's/#undef *\([a-z]\)/#undef '$ac_prefix_conf_LOW'_\1/' >>conftest.sed
- echo 's/#define *\([A-Z_][A-Za-z0-9_]*\)\(.*\)/#ifndef '$ac_prefix_conf_UPP"_\\1 \\" >>conftest.sed
- echo '#define '$ac_prefix_conf_UPP"_\\1 \\2 \\" >>conftest.sed
- echo '#endif/' >>conftest.sed
- echo 's/#define *\([a-z][A-Za-z0-9_]*\)\(.*\)/#ifndef '$ac_prefix_conf_LOW"_\\1 \\" >>conftest.sed
- echo '#define '$ac_prefix_conf_LOW"_\\1 \\2 \\" >>conftest.sed
- sed -f conftest.sed $ac_prefix_conf_INP >>$ac_prefix_conf_OUT
- echo '/*' $ac_prefix_conf_DEF '*/' >>$ac_prefix_conf_OUT
- echo '#endif' >>$ac_prefix_conf_OUT
- else
- AC_MSG_ERROR([input file $ac_prefix_conf_IN does not exist, dnl
- skip generating $ac_prefix_conf_OUT])
- fi
- rm -f conftest.*
-fi])
More information about the mapguide-commits
