[mapguide-commits] r1235 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Thu Mar 15 12:03:22 EDT 2007
Author: traianstanev
Date: 2007-03-15 12:03:22 -0400 (Thu, 15 Mar 2007)
New Revision: 1235
trunk/MgDev/Common/Stylization/LabelRenderer.cpp
trunk/MgDev/Common/Stylization/SE_Include.h
trunk/MgDev/Common/Stylization/SE_LineBuffer.cpp
trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp
trunk/MgDev/Common/Stylization/SE_Renderer.cpp
trunk/MgDev/Common/Stylization/SE_Renderer.h
trunk/MgDev/Common/Stylization/SE_StyleVisitor.h
trunk/MgDev/Common/Stylization/SE_SymbolManager.h
trunk/MgDev/Common/Stylization/StylizationEngine.cpp
This submission adds some initial memory management code -- meaning that I added calls to free all the memory that the new style engine allocates. Previously, all memory was leaked. I had to add support for cloning of render proxy graphics objects so that I can ensure they are not shared (and therefore not deleted twice).
Also, I am still seeing some sort of heap corruption in STL when I delete the MDF proxy objects, so those are leaked for now, until I track than down.
Modified: trunk/MgDev/Common/Stylization/LabelRenderer.cpp
--- trunk/MgDev/Common/Stylization/LabelRenderer.cpp 2007-03-15 11:43:58 UTC (rev 1234)
+++ trunk/MgDev/Common/Stylization/LabelRenderer.cpp 2007-03-15 16:03:22 UTC (rev 1235)
@@ -511,8 +511,8 @@
//here are done with the style and we free it.
//it was cloned when it was passed to the LabelRenderer.
- //delete info.m_sestyle;
- //info.m_sestyle = NULL;
+ delete info.m_sestyle;
+ info.m_sestyle = NULL;
return true;
Modified: trunk/MgDev/Common/Stylization/SE_Include.h
--- trunk/MgDev/Common/Stylization/SE_Include.h 2007-03-15 11:43:58 UTC (rev 1234)
+++ trunk/MgDev/Common/Stylization/SE_Include.h 2007-03-15 16:03:22 UTC (rev 1235)
@@ -287,6 +287,7 @@
SE_Boolean weightScalable;
SE_INLINE SE_Polyline() : weight(0.0) { type = SE_PolylinePrimitive; }
+ ~SE_Polyline() { geometry->Free(); }
struct SE_Polygon : public SE_Polyline
@@ -294,6 +295,7 @@
SE_Color fill;
SE_INLINE SE_Polygon() { type = SE_PolygonPrimitive; weight = 0.0; }
+ ~SE_Polygon() { geometry->Free(); }
/* Font/properties caching is left to the implementor of SE_Renderer */
@@ -320,7 +322,7 @@
struct SE_Raster : public SE_Primitive
SE_String pngPath;
- unsigned char* pngPtr;
+ const unsigned char* pngPtr;
int pngSize;
SE_Double position[2];
SE_Double extent[2];
@@ -350,6 +352,7 @@
unsigned int color;
SE_INLINE SE_RenderPolyline() { type = SE_PolylinePrimitive; }
+ ~SE_RenderPolyline() { if (geometry) geometry->Free(); }
struct SE_RenderPolygon : public SE_RenderPolyline
@@ -357,6 +360,7 @@
unsigned int fill;
SE_INLINE SE_RenderPolygon() { type = SE_PolygonPrimitive; }
+ ~SE_RenderPolygon() { }
struct SE_RenderText : public SE_RenderPrimitive
@@ -372,7 +376,7 @@
/* Caching, if any, is left to the implementor of SE_Renderer */
struct SE_RenderRaster : public SE_RenderPrimitive
int pngSize;
double position[2];
double extent[2];
@@ -381,8 +385,8 @@
SE_INLINE SE_RenderRaster() : pngPtr(0), pngSize(0) { type = SE_RasterPrimitive; }
-typedef std::vector<SE_Primitive*> SE_Symbol;
-typedef std::vector<SE_RenderPrimitive*> SE_RenderSymbol;
+typedef std::vector<SE_Primitive*> SE_PrimitiveList;
+typedef std::vector<SE_RenderPrimitive*> SE_RenderPrimitiveList;
@@ -393,7 +397,7 @@
struct SE_Style
SE_StyleType type;
- SE_Symbol symbol;
+ SE_PrimitiveList symbol;
SE_Integer renderPass;
bool useBox;
@@ -405,7 +409,7 @@
~SE_Style()
- for (SE_Symbol::iterator iter = symbol.begin(); iter != symbol.end(); iter++)
+ for (SE_PrimitiveList::iterator iter = symbol.begin(); iter != symbol.end(); iter++)
delete *iter;
@@ -467,14 +471,25 @@
~SE_RenderStyle()
- for (SE_RenderSymbol::iterator iter = symbol.begin(); iter != symbol.end(); iter++)
- delete *iter;
+ for (SE_RenderPrimitiveList::iterator iter = symbol.begin(); iter != symbol.end(); iter++)
+ //necessary since destructor of SE_RenderPrimitive is not virtual
+ //we may want to figure out a better scheme to manage render primitives
+ switch ((*iter)->type)
+ case SE_PolylinePrimitive: delete (SE_RenderPolyline*)(*iter);break;
+ case SE_PolygonPrimitive: delete (SE_RenderPolygon*)(*iter);break;
+ case SE_RasterPrimitive: delete (SE_RenderRaster*)(*iter);break;
+ case SE_TextPrimitive: delete (SE_RenderText*)(*iter);break;
+ default: throw; //means there is a bug
if (bounds) bounds->Free();
SE_StyleType type;
- SE_RenderSymbol symbol;
+ SE_RenderPrimitiveList symbol;
SE_Bounds* bounds;
int renderPass;
@@ -561,6 +576,8 @@
~SE_Symbolization()
for (std::vector<SE_Style*>::iterator iter = styles.begin(); iter != styles.end(); iter++)
+ //TODO: SE_Styles have no virtual destructor but they don't seem to need
+ //to free stuff specific to the derived classes
delete *iter;
styles.clear();
Modified: trunk/MgDev/Common/Stylization/SE_LineBuffer.cpp
--- trunk/MgDev/Common/Stylization/SE_LineBuffer.cpp 2007-03-15 11:43:58 UTC (rev 1234)
+++ trunk/MgDev/Common/Stylization/SE_LineBuffer.cpp 2007-03-15 16:03:22 UTC (rev 1235)
@@ -15,11 +15,14 @@
// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
-#include "stdafx.h"
#include "SE_LineBuffer.h"
#include "SE_ConvexHull.h"
#include "SE_Bounds.h"
+#define _USE_MATH_DEFINES
+#include <math.h>
+#include <float.h>
#define GROWTH_FACTOR 1.5
#define ENSURE_POINT_BUFFER(points) \
Modified: trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp
--- trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp 2007-03-15 11:43:58 UTC (rev 1234)
+++ trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp 2007-03-15 16:03:22 UTC (rev 1235)
@@ -12,10 +12,10 @@
SE_RenderPointStyle* DeepClonePointStyle(SE_RenderPointStyle* st)
- SE_RenderPointStyle* ret = new SE_RenderPointStyle(); //LEAK
+ SE_RenderPointStyle* ret = new SE_RenderPointStyle();
*ret = *st;
- ret->bounds = st->bounds->Clone(); //LEAK
- SE_RenderText* txt = new SE_RenderText(); //LEAK
+ ret->bounds = st->bounds->Clone();
+ SE_RenderText* txt = new SE_RenderText();
*txt = *((SE_RenderText*)st->symbol[0]);
ret->symbol[0] = txt;
@@ -97,7 +97,7 @@
//assume there is a single text label in the render symbol
//and extract it from in there
- SE_RenderPointStyle* rstyle2 = new SE_RenderPointStyle(); //LEAK
+ SE_RenderPointStyle* rstyle2 = new SE_RenderPointStyle();
rstyle2->addToExclusionRegions = rstyle->addToExclusionRegions;
rstyle2->checkExclusionRegions = rstyle->checkExclusionRegions;
rstyle2->drawLast = rstyle->drawLast;
@@ -105,7 +105,7 @@
rstyle2->bounds = rstyle->bounds->Clone();
SE_RenderText* txt = NULL;
- for (SE_RenderSymbol::iterator iter = rstyle->symbol.begin(); iter != rstyle->symbol.end(); iter++)
+ for (SE_RenderPrimitiveList::iterator iter = rstyle->symbol.begin(); iter != rstyle->symbol.end(); iter++)
if ((*iter)->type == SE_TextPrimitive)
Modified: trunk/MgDev/Common/Stylization/SE_Renderer.cpp
--- trunk/MgDev/Common/Stylization/SE_Renderer.cpp 2007-03-15 11:43:58 UTC (rev 1234)
+++ trunk/MgDev/Common/Stylization/SE_Renderer.cpp 2007-03-15 16:03:22 UTC (rev 1235)
@@ -23,6 +23,127 @@
using namespace MDFMODEL_NAMESPACE;
+//cloning of RenderSymbols. Unfortunate but nexessary for delay-drawing labels
+static SE_RenderStyle* CloneRenderStyle(SE_RenderStyle* symbol)
+ SE_RenderStyle* ret = NULL;
+ //first determine what kind of style it is and copy all the
+ //style specific properties
+ switch (symbol->type)
+ case SE_PointStyleType:
+ SE_RenderPointStyle* dps = new SE_RenderPointStyle();
+ ret = dps;
+ break;
+ case SE_LineStyleType:
+ SE_RenderLineStyle* dls = new SE_RenderLineStyle();
+ SE_RenderLineStyle* sls = (SE_RenderLineStyle*)symbol;
+ ret = dls;
+ dls->angle = sls->angle;
+ dls->angleControl = sls->angleControl;
+ dls->endOffset = sls->endOffset;
+ dls->repeat = sls->repeat;
+ dls->startOffset = sls->startOffset;
+ dls->unitsControl = sls->unitsControl;
+ dls->vertexAngleLimit = sls->vertexAngleLimit;
+ dls->vertexControl = sls->vertexControl;
+ break;
+ case SE_AreaStyleType:
+ SE_RenderAreaStyle* das = new SE_RenderAreaStyle();
+ SE_RenderAreaStyle* sas = (SE_RenderAreaStyle*)symbol;
+ ret = das;
+ das->angle = sas->angle;
+ das->angleControl = sas->angleControl;
+ das->bufferWidth = sas->bufferWidth;
+ das->clippingControl = sas->clippingControl;
+ das->origin[0] = sas->origin[0];
+ das->origin[1] = sas->origin[1];
+ das->originControl = sas->originControl;
+ das->repeat[0] = sas->repeat[0];
+ das->repeat[1] = sas->repeat[1];
+ default:
+ break;
+ //copy all the common properties
+ ret->addToExclusionRegions = symbol->addToExclusionRegions;
+ ret->bounds = symbol->bounds->Clone();
+ ret->checkExclusionRegions = symbol->checkExclusionRegions;
+ ret->drawLast = symbol->drawLast;
+ ret->renderPass = symbol->renderPass;
+ //copy the graphics for the symbol
+ for (size_t i=0; i<symbol->symbol.size(); i++)
+ SE_RenderPrimitive* rp = symbol->symbol[i];
+ SE_RenderPrimitive* rpc = NULL;
+ switch (rp->type)
+ rpc = new SE_RenderPolygon();
+ ((SE_RenderPolygon*)rpc)->fill = ((SE_RenderPolygon*)rp)->fill;
+ if (!rpc) rpc = new SE_RenderPolyline();
+ SE_RenderPolyline* drp = (SE_RenderPolyline*)rpc;
+ SE_RenderPolyline* srp = (SE_RenderPolyline*)rp;
+ drp->bounds = srp->bounds->Clone();
+ drp->color = srp->color;
+ drp->resize = srp->resize;
+ drp->weight = srp->weight;
+ drp->geometry = srp->geometry->Clone();
+ break;
+ rpc = new SE_RenderText();
+ SE_RenderText* st = (SE_RenderText*)rp;
+ SE_RenderText* dt = (SE_RenderText*)rpc;
+ dt->bounds = st->bounds->Clone();
+ dt->position[0] = st->position[0];
+ dt->position[1] = st->position[1];
+ dt->resize = st->resize;
+ dt->tdef = st->tdef;
+ dt->text = st->text;
+ break;
+ rpc = new SE_RenderRaster();
+ SE_RenderRaster* sr = (SE_RenderRaster*)rp;
+ SE_RenderRaster* dr = (SE_RenderRaster*)rpc;
+ dr->angle = sr->angle;
+ dr->bounds = sr->bounds->Clone();
+ dr->extent[0] = sr->extent[0];
+ dr->extent[1] = sr->extent[1];
+ dr->pngSize = sr->pngSize;
+ dr->pngPtr = sr->pngPtr; //this pointer is managed/cached by the SE_SymbolManager
+ dr->position[0] = sr->position[0];
+ dr->position[1] = sr->position[1];
+ dr->resize = sr->resize;
+ if (rpc)
+ ret->symbol.push_back(rpc);
+ return ret;
SE_Renderer::SE_Renderer()
: m_bSelectionMode(false)
, m_selWeight(0.0)
@@ -83,7 +204,7 @@
void SE_Renderer::ProcessLine(LineBuffer* geometry, SE_RenderLineStyle* style)
//determine if the style is a simple straight solid line
- SE_RenderSymbol& rs = style->symbol;
+ SE_RenderPrimitiveList& rs = style->symbol;
//check if it is a single symbol that is not a label participant
if (rs.size() == 1
@@ -199,7 +320,7 @@
-void SE_Renderer::DrawSymbol(SE_RenderSymbol& symbol, const SE_Matrix& posxform, double anglerad)
+void SE_Renderer::DrawSymbol(SE_RenderPrimitiveList& symbol, const SE_Matrix& posxform, double anglerad)
for (unsigned i = 0; i < symbol.size(); i++)
@@ -262,7 +383,7 @@
double x, y;
posxform.transform(rp->position[0], rp->position[1], x, y);
- DrawScreenRaster(rp->pngPtr, rp->pngSize, RS_ImageFormat_PNG, -1, -1, x, y, rp->extent[0], rp->extent[1], anglerad / M_PI180);
+ DrawScreenRaster((unsigned char*)rp->pngPtr, rp->pngSize, RS_ImageFormat_PNG, -1, -1, x, y, rp->extent[0], rp->extent[1], anglerad / M_PI180);
@@ -270,7 +391,12 @@
void SE_Renderer::AddLabel(LineBuffer* geom, SE_RenderStyle* style, SE_Matrix& xform, double angle)
- SE_LabelInfo info(xform.x2, xform.y2, 0.0, 0.0, RS_Units_Device, angle, style);
+ //clone the SE_RenderStyle so that the label renderer can keep track of it until
+ //the end of rendering when it draws all the labels
+ //TODO: cloning is bad.
+ SE_RenderStyle* copied_style = CloneRenderStyle(style);
+ SE_LabelInfo info(xform.x2, xform.y2, 0.0, 0.0, RS_Units_Device, angle, copied_style);
RS_OverpostType type = RS_OverpostType_AllFit;
Modified: trunk/MgDev/Common/Stylization/SE_Renderer.h
--- trunk/MgDev/Common/Stylization/SE_Renderer.h 2007-03-15 11:43:58 UTC (rev 1234)
+++ trunk/MgDev/Common/Stylization/SE_Renderer.h 2007-03-15 16:03:22 UTC (rev 1235)
@@ -34,7 +34,7 @@
STYLIZATION_API virtual void ProcessLine(LineBuffer* geometry, SE_RenderLineStyle* style);
STYLIZATION_API virtual void ProcessArea(LineBuffer* geometry, SE_RenderAreaStyle* style);
- STYLIZATION_API virtual void DrawSymbol(SE_RenderSymbol& symbol, const SE_Matrix& xform, double anglerad);
+ STYLIZATION_API virtual void DrawSymbol(SE_RenderPrimitiveList& symbol, const SE_Matrix& xform, double anglerad);
virtual void DrawScreenPolyline(LineBuffer* polyline, unsigned int color, double weight) = 0; // px
virtual void DrawScreenPolygon(LineBuffer* polygon, unsigned int fill) = 0;
@@ -74,6 +74,7 @@
RS_F_Point m_lastExclusionRegion[4];
protected:
SE_LineBufferPool* m_lbp;
bool m_bSelectionMode;
Modified: trunk/MgDev/Common/Stylization/SE_StyleVisitor.h
--- trunk/MgDev/Common/Stylization/SE_StyleVisitor.h 2007-03-15 11:43:58 UTC (rev 1234)
+++ trunk/MgDev/Common/Stylization/SE_StyleVisitor.h 2007-03-15 16:03:22 UTC (rev 1235)
@@ -60,7 +60,7 @@
void Convert(std::vector<SE_Symbolization*>& styles, MdfModel::CompositeSymbolization* symbolization);
private:
SE_Style* ParseSymbol(MdfModel::CompoundSymbolDefinition* symbol);
- void ParseSymbol(SimpleSymbolDefinition* symbol, SE_Matrix& xform, SE_Symbol* primitives, SE_RenderSymbol* renderPrimitives);
+ void ParseSymbol(SimpleSymbolDefinition* symbol, SE_Matrix& xform, SE_PrimitiveList* primitives, SE_RenderPrimitiveList* renderPrimitives);
bool ParseDouble(const wchar_t*& str, double& val);
bool ParseDoublePair(const wchar_t*& str, double& x, double& y);
bool ParseGeometry(const MdfModel::MdfString& geometry, SE_LineBuffer& buffer);
Modified: trunk/MgDev/Common/Stylization/SE_SymbolManager.h
--- trunk/MgDev/Common/Stylization/SE_SymbolManager.h 2007-03-15 11:43:58 UTC (rev 1234)
+++ trunk/MgDev/Common/Stylization/SE_SymbolManager.h 2007-03-15 16:03:22 UTC (rev 1235)
@@ -27,7 +27,7 @@
public:
virtual SymbolDefinition* GetSymbolDefinition(const wchar_t* resource) = 0;
- virtual unsigned char* GetImageData(const wchar_t* resource, int& length) = 0;
+ virtual const unsigned char* GetImageData(const wchar_t* resource, int& length) = 0;
#endif
Modified: trunk/MgDev/Common/Stylization/StylizationEngine.cpp
--- trunk/MgDev/Common/Stylization/StylizationEngine.cpp 2007-03-15 11:43:58 UTC (rev 1234)
+++ trunk/MgDev/Common/Stylization/StylizationEngine.cpp 2007-03-15 16:03:22 UTC (rev 1235)
@@ -215,9 +215,9 @@
- //TODO: LEAK: the RenderStyles used for labeling are leaked because of this -- we need to free them somehow
- if (!sym->drawLast.evaluate(m_exec))
- delete rstyle;
+ //Free the render style. If the style was needed for drawing as a label,
+ //the renderer would have cloned it and created its own pointer
+ delete rstyle;
m_pool->FreeLineBuffer(xformGeom);
@@ -330,7 +330,7 @@
growy = 0.0;
- for (SE_Symbol::const_iterator src = style->symbol.begin(); src != style->symbol.end(); src++)
+ for (SE_PrimitiveList::const_iterator src = style->symbol.begin(); src != style->symbol.end(); src++)
SE_Primitive* sym = *src;
SE_RenderPrimitive* rsym = NULL;
@@ -350,13 +350,13 @@
m_renderer->GetPixelsPerMillimeterWorld() :
m_renderer->GetPixelsPerMillimeterScreen();
rp->weight = p->weight.evaluate(m_exec)*wx;
- rp->geometry = p->geometry;
+ rp->geometry = p->geometry->Clone();
rp->color = p->color.evaluate(m_exec);
/* Defer transformation */
if (sym->resize != GraphicElement::AdjustToResizeBox)
rp->geometry->Transform(xform, rp->weight);
- rp->bounds = p->geometry->xf_bounds();
+ rp->bounds = rp->geometry->xf_bounds()->Clone();
else
rp->bounds = NULL;
@@ -537,7 +537,7 @@
growxf.translate(dx, dy);
totalxf.premultiply(growxf);
- for (SE_RenderSymbol::iterator rs = renderStyle->symbol.begin(); rs != renderStyle->symbol.end(); rs++)
+ for (SE_RenderPrimitiveList::iterator rs = renderStyle->symbol.begin(); rs != renderStyle->symbol.end(); rs++)
SE_RenderPrimitive* rsym = *rs;
if (rsym->resize)
@@ -549,7 +549,7 @@
SE_RenderPolyline* rp = (SE_RenderPolyline*)rsym;
rp->geometry->Transform(totalxf, rp->weight);
- rp->bounds = rp->geometry->xf_bounds();
break;
More information about the mapguide-commits
